Easy Solar Panel Installation for Wyze Battery Cam in Backyard
Simple Installation of a Solar Panel for Wyze Battery Cam in Your Backyard
If you're looking to keep your Wyze Battery Cam powered continuously without the hassle of frequent recharging, the Wyze Battery Cam Solar Panel is the perfect accessory. Designed specifically for Wyze's outdoor battery cameras, this solar panel offers a simple, weather-resistant solution to extend your camera's battery life using clean, renewable energy from the sun.
Wyze Battery Cam Solar Panel: Effortless Power from the Sun
Key Features and Benefits
  • Weather Resistant (IP65 Rated): Built to withstand rain, dust, and outdoor elements, ensuring reliable performance year-round.
  • Easy 360° Mounting: The included wall mount allows you to position the solar panel optimally for maximum sun exposure anywhere in your backyard.
  • Long 13-Foot Power Cable: Provides flexible placement options, so you can mount the panel in the sunniest spot while keeping your camera securely installed.
  • Compact and Sleek Design: Measuring 173 mm x 120 mm x 17 mm, it blends seamlessly with your outdoor setup.
  • Compatibility: Works perfectly with Wyze Cam Outdoor v1/v2 and Wyze Battery Cam Pro models.
What’s Included?
  • Solar panel unit
  • Wall mount bracket
  • Micro USB and USB-C adapter cables
  • Screws and wall anchors for easy installation
  • Quick start guide for hassle-free setup
With this solar panel, you can say goodbye to frequent battery swaps or manual recharging. Simply mount it in a sunny spot in your backyard, connect it to your Wyze Battery Cam, and enjoy extended recording time powered by the sun.
Wyze Battery Cam Pro: The Ideal Camera for Solar Power
Advanced Camera Specs
  • 2.5K HDR Video Resolution: Capture crisp, detailed footage with vibrant colors and clarity.
  • Wire-Free Design: No hub required, making installation quick and flexible.
  • Integrated Spotlight & Siren: Enhance security with built-in lighting and a loud siren.
  • Radar + PIR Motion Detection: Detects movement accurately to reduce false alerts.
  • Battery Life Up to 6 Months: Rechargeable 6200mAh battery keeps your camera running long.
  • Weatherproof (IP65): Durable for outdoor use in various climates.
  • Dual-Band WiFi Support: Connects to both 2.4 GHz and 5 GHz networks for stable streaming.
  • Two-Way Audio: Communicate through the camera with built-in mic and speaker.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
Dimensions and Design
  • Compact size (2.5 x 1.8 x 3.5 inches) with a matte finish.
  • Lightweight at 0.94 lbs, easy to mount anywhere in your backyard.
Wyze Battery Cam Pro + Solar Panel Bundle: Convenience and Value
For those who want a ready-to-go solution, the Wyze Battery Cam Pro + Solar Panel bundle offers both the camera and solar panel together at a great price. This combo ensures you have everything needed for a simple, efficient backyard security setup with extended battery life powered by solar energy.
Bundle Highlights
  • All the advanced features of the Wyze Battery Cam Pro.
  • Solar panel included for continuous power supply.
  • Easy installation with included mounting hardware and cables.
  • Compatible with both black and white color options to match your outdoor decor.
How to Install Your Wyze Battery Cam Solar Panel in the Backyard
1. Choose the Location: Find a sunny spot in your backyard where the solar panel can receive direct sunlight for most of the day. 2. Mount the Solar Panel: Use the included wall mount, screws, and anchors to securely attach the panel to a wall, fence, or post. 3. Connect to Your Camera: Plug the solar panel’s USB-C or micro USB cable into your Wyze Battery Cam Pro or Outdoor Cam. 4. Position Your Camera: Mount the camera nearby using the included wall mount, ensuring it has a clear view of the area you want to monitor. 5. Configure in the App: Use the Wyze app to connect your camera to WiFi and customize settings like motion detection and notifications.
Installation is straightforward and requires no special tools or electrical work, making it ideal for DIY backyard security upgrades.
Why Choose Wyze Battery Cam with Solar Panel?
  • Eco-Friendly Power: Harness solar energy to reduce electricity use and lower maintenance.
  • Extended Battery Life: Keep your camera running longer without manual recharging.
  • Reliable Outdoor Performance: IP65 rating ensures durability in rain, dust, and heat.
  • Smart Security Features: High-resolution video, motion detection, and two-way audio keep your home safe.
  • Flexible Setup: Wireless design and long cable length allow versatile placement.
Backyard Security with Solar Power Alt text: Backyard with Wyze Battery Cam and solar panel installed on fence in sunny weather
Summary
For a simple, effective way to keep your Wyze Battery Cam powered in your backyard, the Wyze Battery Cam Solar Panel is an excellent choice. Whether purchased separately or as part of the Wyze Battery Cam Pro + Solar Panel bundle, this setup offers easy installation, weatherproof durability, and extended battery life powered by the sun. Protect your home effortlessly with Wyze’s smart, solar-powered security solution.
FeatureWyze Battery Cam Solar PanelWyze Battery Cam ProWyze Battery Cam Pro + Solar Panel
TypeAccessoryCameraCamera Bundle
Video ResolutionN/A2.5K HDR (2560 x 1440)2.5K HDR (2560 x 1440)
Power SourceSolar Panel (weather resistant)Removable, Rechargeable Battery Packs (6200mAh)Removable, Rechargeable Battery Packs + Solar Panel
Battery LifeExtends battery life of compatible camerasUp to 6 MonthsUp to 6 Months (extended with solar panel)
Weather ResistanceIP65 (weatherproof and dustproof)IP65IP65
CompatibilityWyze Cam Outdoor v1/v2, Wyze Battery Cam ProN/AN/A
WirelessN/AYes (2.4 & 5 GHz WiFi)Yes (2.4 & 5 GHz WiFi)
Motion DetectionN/ARadar + PIR Motion DetectionRadar + PIR Motion Detection
Spotlight & SirenN/AIntegrated Spotlight & SirenIntegrated Spotlight & Siren
Mounting360° Freestyle Mount, 13 ft weatherproof cableFlexible mounting optionsFlexible mounting options
Local Storage SupportN/ASupports microSD cards up to 256 GBSupports microSD cards up to 256 GB
Dimensions173 mm x 120 mm x 17 mm2.5 x 1.8 x 3.5 inches2.5 x 1.8 x 3.5 inches
WeightN/A0.94 lbs (camera)0.94 lbs (camera)
Price$24.99 (Solar Panel), $5.99 (USB-C Cable)From $89.98 (varies by pack and color)$109.98
Included AccessoriesSolar Panel or USB-C Adapter CableRemovable battery packs (sold separately)Wyze Battery Cam Pro + Solar Panel
Additional FeaturesWeather resistant, extends recording time2.5K HDR, dual-band WiFi, two-way audio, local recording, IP65 weatherproofSame as Wyze Battery Cam Pro plus solar power extension
What is the Wyze Battery Cam Solar Panel and how does it work?The Wyze Battery Cam Solar Panel is an accessory designed to keep your Wyze Battery Cam powered continuously using solar energy. It connects directly to your Wyze Cam Outdoor v1/v2 or Wyze Battery Cam Pro, providing a renewable power source and reducing the need for frequent battery recharging.
Which Wyze cameras are compatible with the Wyze Battery Cam Solar Panel?The Wyze Battery Cam Solar Panel is compatible with Wyze Cam Outdoor v1, Wyze Cam Outdoor v2, and Wyze Battery Cam Pro models.
Is the Wyze Battery Cam Solar Panel weatherproof?Yes, the Wyze Battery Cam Solar Panel is IP65 rated, making it weather resistant and suitable for outdoor use in rain, dust, and various climates.
What is included with the Wyze Battery Cam Solar Panel?The package includes the solar panel unit, a wall mount bracket, micro USB and USB-C adapter cables, screws and wall anchors for installation, and a quick start guide.
How long is the power cable on the Wyze Battery Cam Solar Panel?The Wyze Battery Cam Solar Panel comes with a 13-foot power cable, allowing flexible placement for optimal sun exposure while keeping your camera securely installed.
How do I install the Wyze Battery Cam Solar Panel in my backyard?To install, choose a sunny location, use the included wall mount and hardware to secure the panel, connect the USB-C or micro USB cable to your Wyze camera, and configure your camera in the Wyze app. No special tools or electrical work are required.
What are the benefits of using a solar panel with my Wyze Battery Cam?Using a solar panel provides eco-friendly, renewable power, extends your camera's battery life, reduces maintenance, and ensures reliable outdoor performance with weatherproof durability.
What features does the Wyze Battery Cam Pro offer?The Wyze Battery Cam Pro features 2.5K HDR video resolution, wire-free installation, integrated spotlight and siren, radar plus PIR motion detection, up to 6 months of battery life, IP65 weatherproof rating, dual-band WiFi support, two-way audio, and smart home integration with Alexa, Google Assistant, and IFTTT.
Is there a bundle available for the Wyze Battery Cam Pro and Solar Panel?Yes, the Wyze Battery Cam Pro + Solar Panel bundle includes both the camera and solar panel, offering a convenient and cost-effective solution for backyard security with extended battery life.
Can I install the Wyze Battery Cam Solar Panel myself?Yes, the Wyze Battery Cam Solar Panel is designed for easy DIY installation. All necessary mounting hardware and cables are included, and no special tools or electrical expertise are required.
What are the key features of the Wyze Battery Cam Solar Panel?Can you explain how to mount the solar panel for optimal sun exposure?Are there any ongoing promotions or discounts for the Wyze Battery Cam or solar panel?
