How to Keep Your Wyze Cam Charged with a Solar Panel
Step-by-Step Approach to Keeping Your Wyze Cam Battery Charged with Solar Power
If you own a Wyze Battery Cam Pro or Wyze Cam Outdoor, extending your camera’s battery life with solar power is a smart and eco-friendly solution. The Wyze Battery Cam Solar Panel is designed specifically to keep your Wyze cameras powered longer without the hassle of frequent recharging. This guide will walk you through the best practices and compatible products to maximize your Wyze camera’s uptime using solar energy.
Understanding the Wyze Battery Cam Solar Panel
Key Features of the Wyze Battery Cam Solar Panel
The Wyze Battery Cam Solar Panel is a compact, weather-resistant solar charger designed to keep your Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2 running longer by harnessing the power of the sun.
  • IP65 Weather Resistant: Built to withstand rain, dust, and outdoor elements.
  • Easy 360° Mount: Allows flexible positioning to capture optimal sunlight.
  • 13-foot Power Cable: Provides versatile mounting options, letting you place the solar panel where sunlight is best.
  • Solar Power Rating: 2.5W, 5VDC output to efficiently charge your camera.
  • Compatibility: Works with Wyze Cam Outdoor v1/v2 and Wyze Battery Cam Pro (requires USB-C adapter cable for Battery Cam Pro).
The solar panel automatically stops charging once the camera battery reaches 100% and resumes when the battery drops below 90%, ensuring efficient power management.
Installation Tips for Optimal Charging
1. Choose the Right Location: Mount the solar panel in an area with the most direct sunlight throughout the day. 2. Angle the Panel Correctly: Tilt the panel upward about 30° for maximum sun exposure. 3. Orientation: Point the panel south if you are in the northern hemisphere, or north if in the southern hemisphere. 4. Secure Mounting: Use the included wall mount base, screws, and anchors to firmly attach the panel. 5. Cable Management: Coil any excess cable behind the winding board on the back of the panel to keep the setup tidy.
Compatible Wyze Products to Enhance Your Solar-Powered Security Setup
Wyze Battery Cam Pro with Solar Panel
The Wyze Battery Cam Pro is a versatile wireless security camera designed for outdoor use. When paired with the Wyze Battery Cam Solar Panel and the necessary USB-C adapter cable, it can stay charged continuously without manual intervention.
  • Wireless and Weatherproof: Perfect for outdoor monitoring.
  • Extended Battery Life: Solar panel keeps the camera powered longer.
  • Easy Setup: Simply connect the solar panel cable to the camera’s charging port after removing the silicone cover.
  • Smart Power Management: Automatically stops charging at full battery to prevent overcharging.
Whole Home Security Enhanced Kit Featuring Wyze Cam v4
For those looking to secure their entire home, the Whole Home Security Enhanced Kit includes the Wyze Cam v4 and Wyze Cam Floodlight v2. While the Wyze Cam v4 itself is not compatible with the solar panel, this kit offers a comprehensive security solution with wired power options and smart lighting.
  • Wyze Cam v4: High-definition video with color night vision.
  • Wyze Cam Floodlight v2: Motion-activated floodlight for enhanced security.
  • Multiple Color Options: Black, Grey, White to match your home’s aesthetic.
Cam v4 + Lamp Socket v2 Bundle
If you want to power your Wyze Cam v4 without relying on battery power or outlets, the Cam v4 + Lamp Socket v2 Bundle is an excellent choice. This bundle allows you to power your camera through a lamp socket, providing continuous power without the need for solar or battery charging. Compatible with Wyze Cam v3, v4, and Pan v3
  • Motion-Activated Lights: Adds smart lighting to your setup.
  • Dusk to Dawn Scheduling: Automate lighting based on time of day.
  • Compact and Easy to Install: Fits standard E26 lamp sockets.
How to Keep Your Wyze Battery Cam Charged Using Solar Power: Step-by-Step
1. Purchase the Wyze Battery Cam Solar Panel along with the USB-C adapter cable if you have the Wyze Battery Cam Pro. 2. Mount the Solar Panel in a sunny location using the included wall mount and screws. 3. Connect the Solar Panel Cable securely to the camera’s charging port after removing the silicone cover. 4. Adjust the Solar Panel Angle to maximize sun exposure, ideally around 30° tilt. 5. Monitor Battery Levels via the Wyze app to ensure the camera is charging properly. 6. Maintain the Solar Panel by cleaning the surface occasionally to remove dust or debris that could block sunlight. 7. Enjoy Extended Recording Time without the need to manually recharge your camera battery.
Remember, the solar panel will not charge the camera at night or during extended periods of low sunlight, so placement and angle are crucial for optimal performance.
Why Choose Wyze Solar Power Solutions?
  • Eco-Friendly: Harness renewable energy to power your security cameras.
  • Convenience: Reduce the need to bring cameras indoors for charging.
  • Weatherproof Design: Durable for all seasons and outdoor conditions.
  • Cost-Effective: Save on electricity and battery replacements.
  • Seamless Integration: Designed specifically for Wyze Battery Cam Pro and Outdoor models.
Summary of Recommended Products for Solar Charging Your Wyze Cam
Product NamePrice (USD)Key FeaturesCompatibility
Wyze Battery Cam Solar Panel24.99IP65 weather resistant, 13-ft cable, 360° mountWyze Battery Cam Pro, Outdoor v1/v2
Whole Home Security Enhanced Kit256.91Wyze Cam v4, Floodlight v2, multiple colorsWired cameras, not solar compatible
Cam v4 + Lamp Socket v2 Bundle49.96Powers Wyze Cam v4 via lamp socket, motion lightsWyze Cam v3, v4, Pan v3
Enhance Your Home Security with Solar-Powered Wyze Cameras
Using the Wyze Battery Cam Solar Panel is the easiest way to keep your Wyze Battery Cam Pro or Outdoor camera charged and recording continuously. By following the installation and positioning tips, you can enjoy a reliable, maintenance-free security system powered by the sun. Outdoor Solar-Powered Security Camera
Harness the power of the sun and keep your home safe with Wyze’s innovative solar charging solutions.
# Product Tags Summary
Feature / ProductWyze Battery Cam Solar PanelWhole Home Security Enhanced KitCam v4 + Lamp Socket v2 BundleWhole Home Security Starter Kit
TypeAccessoriesSecurity KitBundleSecurity Kit
Price$24.99 (Solar Panel), $5.99 (USB-C Cable)$256.91$49.96$155.95
CompatibilityWyze Cam Outdoor v1/v2, Wyze Battery Cam ProIncludes Wyze Cam v4 and Wyze Cam Floodlight v2Wyze Cam v3, v3 Pro, v4, OG, Pan v3Wyze Cam v4, Wyze Video Doorbell v2, Home Monitoring Starter Kit
DescriptionExtends battery life of Wyze Battery Cam ProEnhanced whole home security kitPowers Cam v4 without outlet, smart lightingStarter kit with camera, doorbell, and monitoring
Weather ResistanceIP65 (Weatherproof and dustproof)Not specifiedNot weatherproof, suitable for damp locationsNot specified
Key Features- Continuous power via solar panel- Wyze Cam v4 (various colors)- Motion-activated lights- Wyze Cam v4
- 360° freestyle mount- Wyze Cam Floodlight v2 (various colors)- Dusk to dawn scheduling- Wyze Video Doorbell v2
- 13-foot weatherproof power cable- Linkability without limits- Wyze Home Monitoring Starter Kit
Mounting OptionsMountable anywhereNot specifiedE26 lamp socketNot specified
Warranty30-day hassle-free returns30-day hassle-free returns1-Year warranty30-day hassle-free returns
What Wyze cameras are compatible with the Wyze Battery Cam Solar Panel?The Wyze Battery Cam Solar Panel is compatible with the Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2. For the Wyze Battery Cam Pro, a USB-C adapter cable is required for connection.
How does the Wyze Battery Cam Solar Panel help extend camera battery life?The Wyze Battery Cam Solar Panel harnesses solar energy to keep your Wyze Battery Cam Pro or Wyze Cam Outdoor charged, reducing the need for frequent manual recharging and ensuring your camera stays powered for longer periods.
Is the Wyze Battery Cam Solar Panel weatherproof?Yes, the Wyze Battery Cam Solar Panel is IP65 weather resistant, making it suitable for outdoor use in rain, dust, and various weather conditions.
How do I install the Wyze Battery Cam Solar Panel for optimal charging?Mount the solar panel in a location with maximum direct sunlight, tilt it upward at about 30°, and orient it south in the northern hemisphere (or north in the southern hemisphere). Use the included wall mount, screws, and anchors for secure installation, and manage excess cable using the winding board on the back of the panel.
Does the Wyze Battery Cam Solar Panel prevent overcharging?Yes, the solar panel automatically stops charging when the camera battery reaches 100% and resumes charging when the battery drops below 90%, ensuring efficient and safe power management.
Can I use the Wyze Battery Cam Solar Panel with Wyze Cam v4 or Wyze Cam Floodlight v2?No, the Wyze Battery Cam Solar Panel is not compatible with Wyze Cam v4 or Wyze Cam Floodlight v2. These cameras are designed for wired power options.
What should I do if my Wyze camera is not charging with the solar panel?Ensure the solar panel is mounted in a sunny location, the cable is securely connected to the camera’s charging port, and the panel surface is clean and free from dust or debris. Also, check the Wyze app to monitor battery levels and confirm charging status.
Will the Wyze Battery Cam Solar Panel charge my camera at night?No, the solar panel will not charge your camera at night or during extended periods of low sunlight. Proper placement and angling are essential for optimal daytime charging.
What are the benefits of using solar power for Wyze security cameras?Using solar power for Wyze cameras is eco-friendly, reduces the need for manual recharging, offers a weatherproof and durable solution, saves on electricity and battery costs, and provides seamless integration with compatible Wyze camera models.
How do I maintain my Wyze Battery Cam Solar Panel for best performance?Regularly clean the surface of the solar panel to remove dust or debris that could block sunlight, and periodically check the mounting and cable connections to ensure everything remains secure and functional.
What is included with the Wyze Battery Cam Solar Panel?The Wyze Battery Cam Solar Panel comes with a 13-foot power cable, a 360° adjustable mount, wall mount base, screws, and anchors for easy and flexible installation.
Can I use the Cam v4 + Lamp Socket v2 Bundle for solar charging?No, the Cam v4 + Lamp Socket v2 Bundle is designed to power Wyze Cam v3, v4, and Pan v3 through a standard E26 lamp socket, not via solar charging.
What are the best practices for installing the Wyze Battery Cam Solar Panel?Can you explain how the solar panel manages power when the camera battery is full?What other Wyze products can I use to enhance my solar-powered security setup?
