Top Security Cameras with Person Detection & Sound Alerts
Best Security Cameras with Person Detection and Sound Alert for Smart Homes
Enhance your smart home security with cutting-edge cameras that not only detect people but also alert you with sound notifications. Whether you want indoor or outdoor protection, wired or wireless options, these Wyze cameras offer advanced person detection, sound alerts, and seamless smart home integration to keep your home safe and connected.
Wyze Cam v4: The Ultimate Wired Smart Camera with Person Detection
Wyze Cam v4 is the clearest and most advanced Wyze camera yet, designed to provide unmatched security for your smart home.
Key Features:
  • 2.5K QHD Resolution: Capture crystal-clear video with vibrant colors and wide dynamic range (WDR) for detailed images day and night.
  • Enhanced Color Night Vision: See in full color even in low-light conditions, thanks to upgraded hardware that outperforms traditional night vision.
  • Person Detection & Sound Alerts: Receive instant notifications when a person is detected or when specific sounds occur, such as smoke or CO alarms.
  • Motion-Activated Spotlight & Siren: Deter intruders with a bright spotlight and a loud 99 dB siren.
  • 24/7 Local Recording: Continuous recording to a microSD card (up to 256GB) without subscription fees.
  • Wi-Fi 6 Support: Enjoy a stronger, more reliable connection.
  • Smart Assistant Compatibility: Works seamlessly with Alexa, Google Assistant, and IFTTT.
  • Weather Resistant (IP65): Suitable for both indoor and outdoor use with the optional outdoor power adapter.
Why Choose Wyze Cam v4?
Wyze Cam v4’s AI-powered person detection and sound alert system ensure you only get notified about what truly matters. Its magnetic mount and Bluetooth setup make installation quick and tool-free. Wyze Cam v4 in action Two-way audio and clear communication with Wyze Cam v4
Wyze Cam Pan v3: 360° Pan & Tilt with Smart Tracking and Alerts
For full coverage and dynamic monitoring, Wyze Cam Pan v3 offers a 360° horizontal pan and 180° vertical tilt, making it perfect for both indoor and outdoor smart home security.
Highlights:
  • Automatic Motion Tracking: The camera detects motion and follows it silently, ensuring no movement goes unnoticed.
  • IP65 Weather Resistance: Built to withstand rain, snow, and harsh weather conditions.
  • Color Night Vision: See clear, colorful footage even in the dark.
  • Person Detection & Sound Alerts: Get notified instantly when a person is detected or when sounds like alarms or pets are heard.
  • Privacy Mode: Easily disable the camera’s view by pointing it downward when privacy is needed.
  • Two-Way Audio: Communicate through the camera using your smartphone.
  • Custom Detection Zones: Focus alerts on specific areas to reduce false alarms.
Ideal For:
Those who want a versatile camera that can patrol large areas automatically and provide detailed alerts for person detection and sound events. Wyze Cam Pan v3 outdoor lifestyle Wyze Cam Pan v3 weather-resistant for outdoor use
Wyze Cam Floodlight v2: Brighten and Secure Your Outdoor Spaces
Wyze Cam Floodlight v2 combines powerful lighting with smart security features, perfect for driveways, porches, and backyards.
Features:
  • 2800 Lumens LED Floodlight: Illuminate large outdoor areas with bright, dimmable light.
  • 2K Video with Color Night Vision: Capture sharp, colorful footage day and night.
  • 160° Wide-Angle View: Monitor broad areas with fewer blind spots.
  • Person Detection & Sound Alerts: Receive instant alerts when a person is detected or unusual sounds occur.
  • Built-in 105 dB Siren & Two-Way Audio: Deter intruders with loud sirens and communicate remotely.
  • Dusk-to-Dawn Automation: Automatically turns on/off based on ambient light.
  • IP65 Weatherproof: Designed to withstand all weather conditions.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
Why It Stands Out:
This camera not only secures your home with advanced detection but also lights your outdoor spaces intelligently, enhancing safety and convenience. Wyze Cam Floodlight v2 lifestyle Bright, smart outdoor security with Wyze Cam Floodlight v2
Wyze Battery Cam Pro: Wire-Free Security with Smart Alerts
For flexible placement without wiring constraints, Wyze Battery Cam Pro offers a wireless solution packed with smart features.
Core Specs:
  • 2.5K HDR Video: High-resolution video with vivid colors.
  • Radar + PIR Motion Detection: Advanced sensors for accurate person detection.
  • Integrated Spotlight & 100 dB Siren: Light up and scare off unwanted visitors.
  • Rechargeable Battery Packs: Up to 6 months of battery life per charge.
  • Dual-Band Wi-Fi Support: Connects to both 2.4 GHz and 5 GHz networks.
  • IP65 Weatherproof: Ready for outdoor use in all seasons.
  • Two-Way Audio: Talk and listen through the camera.
  • Local Storage Support: Save footage on microSD cards up to 256GB.
Perfect For:
Users who want a portable, easy-to-install camera with smart person detection and sound alert capabilities without the hassle of wires.
Wyze Bulb Cam: Discreet Security with Smart Lighting
Wyze Bulb Cam is a unique 2-in-1 device combining a smart LED bulb with a security camera, ideal for outdoor fixtures.
Features:
  • 2K HD Video with Color Night Vision: Clear video day and night.
  • 160° Field of View: Wide coverage from a light bulb fixture.
  • Instant Motion Alerts & Sound Detection: Stay informed about people and sounds around your home.
  • Built-in 95 dB Siren & Two-Way Audio: Communicate and deter intruders.
  • Smart LED Light Bulb: Up to 800 lumens brightness with motion-activated and scheduled lighting.
  • Easy Installation: Fits standard E26 sockets, no extra wiring needed.
  • IP65 Weather Resistant: Suitable for outdoor use.
Why Choose Bulb Cam?
It’s perfect for those who want to blend security with smart lighting in a subtle, easy-to-install device. Wyze Bulb Cam lifestyle Wyze Bulb Cam: Security and lighting combined
Conclusion
For smart homes seeking reliable person detection and sound alert security cameras, Wyze offers a comprehensive lineup:
  • Wyze Cam v4 for crystal-clear wired security with spotlight and siren.
  • Wyze Cam Pan v3 for dynamic 360° coverage and motion tracking.
  • Wyze Cam Floodlight v2 for powerful lighting and outdoor protection.
  • Wyze Battery Cam Pro for wire-free, flexible placement.
  • Wyze Bulb Cam for discreet security integrated with smart lighting.
Each camera supports smart assistant integration and advanced AI detection, ensuring your home stays safe and you stay informed.
Product Tags Summary
FeatureWyze Cam v4Wyze Cam Pan v3Wyze Cam Floodlight v2Wyze Battery Cam ProWyze Bulb Cam
Video Resolution2.5K QHD (2560x1440)Not specified (assumed 1080p+)2K (2304x1296)2.5K HDR (2560x1440)2K (2304x1296)
Field of View115.9° (D) x 98.5° (H) x 53.1° (V)360° pan, 180° tilt160° diagonal134° (DFOV), 108° (HFOV), 56° (VFOV)160° diagonal, 166° diagonal
Night VisionEnhanced Color Night VisionColor Night Vision (Starlight Sensor)Color Night VisionIR LEDs + White LEDs (Color Night Vision)Color Night Vision + IR Night Vision
AudioEnhanced Two-Way Talk, 99dB SirenTwo-Way AudioTwo-Way Audio, 105dB SirenTwo-Way Audio, 100dB SirenTwo-Way Audio, 95dB Siren
Power SourceWired (6-ft USB cable)Wired (requires Outdoor Power Adapter for outdoor)Hardwired (110-120V AC)Battery (Removable, Rechargeable)Hardwired (Standard E26 Socket)
Weather ResistanceIP65IP65IP65IP65IP65
ConnectivityWi-Fi 6 (2.4 GHz & Wi-Fi 6)Wi-Fi (2.4 GHz)Wi-Fi 2.4 GHzWi-Fi 2.4 & 5 GHzWi-Fi 2.4 GHz
Local StoragemicroSD up to 512 GB (required)microSD up to 256 GBmicroSD up to 256 GBmicroSD up to 256 GBmicroSD up to 256 GB
Smart Assistant IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Special FeaturesMotion-activated spotlight, AI Auto-Zoom, 24/7 local recording, Bluetooth 5.2360° pan & 180° tilt, motion tracking, Privacy Mode2800 Lumens LED floodlight, Ambient Light Mode, AI-Powered Light Control, Dusk-to-Dawn automationRadar + PIR Motion Detection, Removable battery, Up to 6 months battery life2-in-1 security camera & smart LED bulb, Motion-activated light, Digital zoom
Dimensions2in x 2in x 2 3/8inNot specified9.5in x 7.7in x 7.0in2.5 x 1.8 x 3.5 inchesNot specified
Weight0.49 lb (222 g)Not specified2.76 lbs (1.25 kg)0.94 lbsNot specified
Price (Single Pack)$35.98$39.98$89.98$159.98$49.98
What are the best security cameras with person detection and sound alerts for smart homes?Wyze offers a range of security cameras with advanced person detection and sound alert features, including Wyze Cam v4, Wyze Cam Pan v3, Wyze Cam Floodlight v2, Wyze Battery Cam Pro, and Wyze Bulb Cam. These cameras provide instant notifications, smart home integration, and options for both indoor and outdoor use.
How does Wyze Cam v4 enhance smart home security?Wyze Cam v4 features 2.5K QHD resolution, enhanced color night vision, AI-powered person detection, sound alerts, a motion-activated spotlight, a 99 dB siren, and 24/7 local recording. It supports Wi-Fi 6, works with Alexa, Google Assistant, and IFTTT, and is weather resistant for indoor and outdoor use.
Does Wyze Cam v4 require a subscription for person detection and sound alerts?No, Wyze Cam v4 offers person detection and sound alerts without requiring a subscription, and it supports continuous local recording to a microSD card up to 256GB.
What makes Wyze Cam Pan v3 suitable for full coverage security?Wyze Cam Pan v3 provides 360° horizontal pan and 180° vertical tilt, automatic motion tracking, person detection, sound alerts, color night vision, privacy mode, two-way audio, and custom detection zones. It is IP65 weather resistant, making it ideal for both indoor and outdoor monitoring.
Can Wyze Cam Pan v3 be used outdoors?Yes, Wyze Cam Pan v3 is IP65 weather resistant, allowing it to be used outdoors in various weather conditions.
What are the key features of Wyze Cam Floodlight v2?Wyze Cam Floodlight v2 combines a 2800 lumens LED floodlight with 2K video, color night vision, 160° wide-angle view, person detection, sound alerts, a 105 dB siren, two-way audio, dusk-to-dawn automation, and IP65 weatherproofing. It integrates with Alexa, Google Assistant, and IFTTT.
How does Wyze Battery Cam Pro provide wire-free security?Wyze Battery Cam Pro is a wireless security camera with 2.5K HDR video, radar and PIR motion detection for accurate person alerts, an integrated spotlight, 100 dB siren, rechargeable battery packs (up to 6 months per charge), dual-band Wi-Fi, IP65 weatherproofing, two-way audio, and local storage support.
Is Wyze Battery Cam Pro suitable for outdoor use?Yes, Wyze Battery Cam Pro is IP65 weatherproof, making it suitable for outdoor use in all seasons.
What is Wyze Bulb Cam and how does it work?Wyze Bulb Cam is a 2-in-1 smart LED bulb and security camera that fits standard E26 sockets. It offers 2K HD video with color night vision, a 160° field of view, instant motion and sound alerts, a built-in 95 dB siren, two-way audio, and up to 800 lumens of smart lighting. It is IP65 weather resistant for outdoor use.
Do Wyze security cameras support smart home integration?Yes, all featured Wyze security cameras support integration with popular smart home assistants such as Alexa, Google Assistant, and IFTTT for seamless automation and control.
Can Wyze cameras record video locally without a subscription?Yes, Wyze cameras like Wyze Cam v4 and Wyze Battery Cam Pro support local video recording to microSD cards up to 256GB, allowing continuous or event-based recording without subscription fees.
What is the benefit of person detection and sound alerts in Wyze cameras?Person detection and sound alerts ensure you receive instant notifications only for important events, such as when a person is detected or specific sounds like smoke or CO alarms are heard, reducing false alarms and enhancing home security.
Are Wyze security cameras easy to install?Yes, Wyze cameras are designed for easy installation. For example, Wyze Cam v4 features a magnetic mount and Bluetooth setup, while Wyze Bulb Cam fits standard light sockets with no extra wiring required.
What are the key features of the Wyze Cam v4?Can you tell me more about the Wyze Cam Pan v3 and its capabilities?Are there any ongoing promotions or discounts for Wyze cameras?
