Wyze Security Cameras: Top Models & Features for Home Protection
Comprehensive Guide to Wyze Security Cameras
When it comes to securing your home or business, Wyze offers a versatile lineup of security cameras designed to meet various needs—from wired indoor setups to wireless outdoor solutions. Whether you want crystal-clear video, smart home integration, or weather-resistant durability, Wyze has you covered.
Wyze Cam v4: Cutting-Edge Wired Security Camera
Experience unmatched security with the Wyze Cam v4, a top-tier wired camera perfect for both indoor and outdoor use.
  • Resolution: Stunning 2.5K QHD for crystal-clear video quality.
  • Night Vision: Enhanced Color Night Vision lets you see vivid details even in low light.
  • Spotlight & Motion Detection: Motion-activated spotlight alerts and deters intruders.
  • Connectivity: Supports Wi-Fi 6 for faster, more reliable streaming.
  • Smart Home Compatible: Works seamlessly with Alexa and Google Assistant.
  • Field of View: Wide-angle lens with DFOV 115.8°, HFOV 98.5°, VFOV 53.1°.
  • Build: Durable polycarbonate body with glass + plastic lens.
  • Recording: 24/7 local recording ensures you never miss a moment.
Available in multiple colors (Black, Clear, Grey, White) and pack sizes (1, 2, or 3 packs), the Wyze Cam v4 is a versatile choice for comprehensive home security.
Wyze Cam Pan v3: 360° Pan & Tilt Outdoor/Indoor Camera
For those who want full coverage with flexible viewing angles, the Wyze Cam Pan v3 is an excellent option.
  • 360° Pan & 180° Tilt: Covers every corner of your property with smooth motorized movement.
  • Weather Resistant: IP65 rating makes it suitable for outdoor use (requires separate outdoor power adapter).
  • Dual Use: Perfect for indoor or outdoor monitoring.
  • Colors: Available in Black and White.
  • Smart Features: Compatible with Wyze app for remote control and alerts.
<img src="https://www.wyze.com/cdn/shop/files/IMG_4216-5_1.jpg?v=1670422469&width=1500" alt="Wyze Cam Pan v3 in snowy outdoor setting">
Stay protected in all weather with Wyze Cam Pan v3’s rugged design.
Wyze Battery Cam Pro: Wire-Free, High-Resolution Security
If you prefer a wireless, battery-powered camera, the Wyze Battery Cam Pro offers premium features without the hassle of wiring.
  • Video Quality: 2.5K HDR resolution for sharp, detailed footage.
  • Wireless: Completely wire-free with removable, rechargeable 6200mAh battery packs.
  • Motion Detection: Radar + PIR sensors for precise motion alerts.
  • Integrated Spotlight & Siren: Deter unwanted visitors instantly.
  • Weatherproof: IP65 rating ensures reliable outdoor performance.
  • Wi-Fi Support: Compatible with both 2.4GHz and 5GHz networks.
  • Colors: Black and White options available.
This camera is ideal for flexible placement anywhere around your property without worrying about power outlets.
Wyze Bulb Cam: 2-in-1 Outdoor Security & Smart Lighting
Combine security and lighting with the innovative Wyze Bulb Cam, a smart LED bulb with a built-in camera.
  • Video Resolution: Clear 2K HD video with color night vision.
  • Dual Function: Acts as both a security camera and a smart LED light bulb.
  • Easy Installation: Fits most standard light fixtures.
  • Local Storage: Supports local video storage with no subscription required.
  • Motion Alerts: Instant notifications on your phone.
  • Weatherproof: IP65 certified for outdoor use.
  • Material: Durable plastic body with metal bulb base.
<img src="https://www.wyze.com/cdn/shop/files/Wyze_Bulb_Cam_Shopify-07.jpg?v=1746478547&width=1500" alt="Wyze Bulb Cam installed in outdoor light fixture">
Secure your porch with Wyze Bulb Cam’s smart lighting and surveillance.
Wyze Video Doorbell v2: Clear, Wired Door Security
Keep an eye on your front door with the Wyze Video Doorbell v2, offering high-quality video and smart features.
  • Resolution: Crisp 2K video for detailed visitor monitoring.
  • Two-Way Audio: Communicate with visitors remotely.
  • Motion-Activated Voice Deterrence: Scare off unwanted guests with pre-recorded messages.
  • Local Storage: Save footage on microSD card without monthly fees.
  • Real-Time Alerts: Instant notifications when someone approaches your door.
  • Color: Sleek Black finish.
This wired doorbell is perfect for anyone wanting reliable, high-definition video door monitoring.
Wyze Cam OG: Affordable, Reliable Wired Camera
For budget-conscious buyers, the Wyze Cam OG offers solid performance at an unbeatable price.
  • Resolution: 1080p Full HD video.
  • Field of View: Wide 120° angle.
  • Improved Features: Faster live streaming, 3X quicker notifications, and enhanced two-way audio.
  • Built-in Spotlight: Adds extra security during nighttime.
  • Indoor/Outdoor Use: Versatile placement options.
  • Colors: Black and White.
  • Frame Rate: 20 FPS during day, 15 FPS at night.
<img src="https://www.wyze.com/cdn/shop/files/2_way_talk-03.png?v=1670674480&width=1500" alt="Wyze Cam OG with two-way audio feature">
Communicate clearly with visitors or pets using Wyze Cam OG’s two-way audio.
Why Choose Wyze Security Cameras?
Wyze cameras combine affordability, advanced technology, and smart home compatibility to provide comprehensive security solutions for every home and budget. From wired to wireless, indoor to outdoor, and even smart lighting integration, Wyze offers a camera tailored to your unique security needs.
Summary of Wyze Security Cameras
ModelResolutionPower SourceKey FeaturesUse Case
Wyze Cam v42.5K QHDWiredColor Night Vision, Wi-Fi 6, SpotlightIndoor/Outdoor
Wyze Cam Pan v31080pWired (Outdoor adapter needed)360° Pan/Tilt, Weather ResistantIndoor/Outdoor
Wyze Battery Cam Pro2.5K HDRBattery (Rechargeable)Wire-Free, Spotlight, Siren, RadarWireless Outdoor
Wyze Bulb Cam2K HDWired (Light Fixture)Smart LED Bulb, Color Night VisionOutdoor Lighting
Wyze Video Doorbell v22K HDWiredTwo-Way Audio, Voice DeterrenceDoor Security
Wyze Cam OG1080pWiredAffordable, Spotlight, Two-Way AudioIndoor/Outdoor
Choose the Wyze security camera that fits your lifestyle and enjoy peace of mind with smart, reliable surveillance.
FeatureWyze Cam v4Wyze Cam Pan v3Wyze Battery Cam ProWyze Bulb CamWyze Video Doorbell v2Wyze Cam OG
TypeWired CameraWired Pan & Tilt CameraBattery CameraLighting Camera (Bulb)Wired Video DoorbellWired Camera
Video Resolution2.5K QHD (2560 x 1440)2.5K (2560 x 1440)2.5K HDR (2560 x 1440)2K HD (2304 x 1296)2K (2048 x 1536)1080p (1920 x 1080)
Field of View (Diagonal)115.9°360° Pan / 180° Tilt134°166°166.8°120°
Night VisionEnhanced Color Night VisionColor Night Vision (Starlight Sensor)2 IR LEDs + 2 White LEDs (Color)Color Night Vision + IR6 x 940nm IR lights4 IR LEDs (850nm)
AudioEnhanced Two-Way TalkTwo-Way AudioTwo-Way Audio (Speaker & Mic)Two-Way AudioTwo-Way AudioBuilt-in Speaker & Mic (Upgraded)
SirenYes (Integrated)NoYes (100 dB)Yes (95 dB)Yes (Digital Voice Deterrence)Yes (90 dB user-activated)
SpotlightMotion-activated SpotlightNoIntegrated SpotlightSmart LED Light BulbNoBuilt-in Spotlight (40 Lumens)
Power SourceWiredWiredRemovable Rechargeable Battery120V AC (Bulb)Wired (16V-24V AC)Wired (5V/1A adapter)
Weather ResistanceIP65IP65IP65IP65IP65IP65
Local StoragemicroSD up to 256GBmicroSD up to 256GBmicroSD up to 256GBmicroSD up to 256GBmicroSD up to 256GBmicroSD up to 256GB
Wireless ConnectivityWi-Fi 6Wi-Fi 2.4 GHzWi-Fi 2.4 & 5 GHzWi-Fi 2.4 GHzWi-Fi 2.4 GHzWi-Fi 2.4 GHz
BluetoothYes (Bluetooth for setup)Not specifiedBLE 5.1BLE 4.2 / BLE Low EnergyNot specifiedNot specified
Smart Assistant IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google AssistantAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
DimensionsNot specifiedNot specified2.5 x 1.8 x 3.5 inNot specified4.3 x 1.7 x 0.9 in1.89 x 1.89 x 1.89 in
WeightNot specifiedNot specified0.94 lbsNot specifiedNot specified4.1 oz (116 g)
Additional FeaturesAI Auto-Zoom, Motion-activated spotlight, Smoke & CO alerts360° Pan & 180° Tilt, Motion Tracking, Privacy ModeRadar + PIR Motion Detection, Up to 6 months battery life2-in-1 camera & smart bulb, Motion-activated light, Up to 800 lm brightnessMotion-activated voice deterrence, Digital zoomFaster live streaming, 3X faster notifications, Custom detection zones
Price (1 Pack)$35.98$39.98$159.98$49.98$44.98$29.98
What are the main types of Wyze security cameras available?Wyze offers a variety of security cameras including the Wyze Cam v4 (wired, indoor/outdoor), Wyze Cam Pan v3 (360° pan and tilt, indoor/outdoor), Wyze Battery Cam Pro (wire-free, outdoor), Wyze Bulb Cam (2-in-1 smart bulb and camera), Wyze Video Doorbell v2 (wired door security), and Wyze Cam OG (affordable, wired, indoor/outdoor).
What features does the Wyze Cam v4 offer?The Wyze Cam v4 features 2.5K QHD resolution, enhanced color night vision, motion-activated spotlight, Wi-Fi 6 connectivity, smart home compatibility with Alexa and Google Assistant, a wide-angle lens, durable build, and 24/7 local recording. It is suitable for both indoor and outdoor use.
Is the Wyze Cam Pan v3 suitable for outdoor use?Yes, the Wyze Cam Pan v3 is weather resistant with an IP65 rating, making it suitable for outdoor use when paired with a separate outdoor power adapter. It offers 360° pan and 180° tilt for comprehensive coverage.
What makes the Wyze Battery Cam Pro a good choice for wireless security?The Wyze Battery Cam Pro is completely wire-free, powered by removable and rechargeable 6200mAh battery packs. It offers 2.5K HDR video, radar and PIR motion detection, an integrated spotlight and siren, weatherproof IP65 rating, and supports both 2.4GHz and 5GHz Wi-Fi networks.
How does the Wyze Bulb Cam combine security and lighting?The Wyze Bulb Cam is a 2-in-1 device that functions as both a smart LED light bulb and a security camera. It provides 2K HD video with color night vision, supports local video storage, offers instant motion alerts, and is IP65 certified for outdoor use.
What are the key features of the Wyze Video Doorbell v2?The Wyze Video Doorbell v2 offers crisp 2K video resolution, two-way audio for communication, motion-activated voice deterrence, local storage via microSD card, real-time alerts, and a sleek black finish. It is a wired doorbell designed for reliable front door security.
Is the Wyze Cam OG a good budget security camera?Yes, the Wyze Cam OG is an affordable wired camera that delivers 1080p Full HD video, a wide 120° field of view, faster live streaming, improved two-way audio, a built-in spotlight, and versatile indoor/outdoor placement.
Do Wyze security cameras support smart home integration?Many Wyze security cameras, such as the Wyze Cam v4, are compatible with popular smart home platforms like Alexa and Google Assistant, allowing for seamless integration and voice control.
Can Wyze cameras record video locally without a subscription?Yes, several Wyze cameras, including the Wyze Cam v4, Wyze Bulb Cam, and Wyze Video Doorbell v2, support local video storage via microSD card, so you can record and access footage without a monthly subscription.
Are Wyze security cameras weatherproof for outdoor use?Many Wyze cameras are designed for outdoor use with weatherproof ratings. The Wyze Cam v4, Wyze Cam Pan v3 (with outdoor adapter), Wyze Battery Cam Pro, and Wyze Bulb Cam all feature IP65 weather resistance for reliable performance in various conditions.
What resolution do Wyze security cameras offer?Wyze security cameras offer a range of video resolutions, including 1080p Full HD (Wyze Cam Pan v3, Wyze Cam OG), 2K HD (Wyze Bulb Cam, Wyze Video Doorbell v2), and 2.5K QHD/HDR (Wyze Cam v4, Wyze Battery Cam Pro) for clear and detailed footage.
Why should I choose Wyze security cameras for my home or business?Wyze security cameras combine affordability, advanced technology, smart home compatibility, and a variety of models to suit different needs. Whether you need wired or wireless, indoor or outdoor, or even integrated lighting, Wyze offers reliable and comprehensive security solutions.
What are the key features of the Wyze Cam v4?Can you tell me more about the Wyze Cam Pan v3 and its capabilities?Are there any ongoing promotions or discounts for Wyze security cameras?
