Top Wyze Wireless Security Cameras for Home & Outdoor Use
Best Wireless Security Cameras for Home and Outdoor Use
When it comes to securing your home or business, wireless security cameras offer the perfect blend of convenience, flexibility, and advanced technology. Whether you want to monitor your front porch, backyard, or indoor spaces, Wyze provides a range of wireless security cameras designed to meet diverse needs with crystal-clear video quality, smart features, and weather-resistant durability. Explore the top wireless security cameras from Wyze that combine high-resolution video, smart detection, and easy installation without the hassle of wiring or hubs.
Wyze Battery Cam Pro: Premium Wire-Free Security with 2.5K HDR Video
Experience the freedom of true wire-free security with the Wyze Battery Cam Pro. This camera delivers stunning 2.5K HDR video resolution, ensuring every detail is captured with vibrant clarity day or night.
Key Features:
  • 2.5K HDR Video Resolution for crystal-clear footage
  • Wire-Free Design with removable, rechargeable 6200mAh battery packs
  • Integrated Spotlight & Siren to deter intruders instantly
  • Radar + PIR Motion Detection for precise alerts and fewer false alarms
  • IP65 Weatherproof Rating to withstand rain, snow, and dust
  • Supports both 2.4 & 5GHz WiFi for flexible connectivity
  • No hub required — easy setup anywhere
Available in black or white, and sold in single or multi-packs, the Wyze Battery Cam Pro is perfect for outdoor areas where running power cables is impractical.
Ideal for homeowners seeking a reliable, high-resolution wireless camera with advanced motion sensing and weather resistance.
Wyze Battery Cam Pro in outdoor setting Capture vibrant outdoor security footage with Wyze Battery Cam Pro
Wyze Cam v4: Wired Camera with Wireless Convenience and 2.5K QHD Clarity
The Wyze Cam v4 blends wired power reliability with wireless smart features, delivering unmatched home security with crystal-clear 2.5K QHD resolution.
Highlights:
  • 2.5K QHD (2560x1440) Video for sharp, detailed images
  • Enhanced Color Night Vision to see vivid colors even in low light
  • Motion-Activated Spotlight to illuminate and alert simultaneously
  • Wi-Fi 6 Support for faster, more stable connections
  • 24/7 Local Recording capability for continuous monitoring
  • Compatible with Alexa and Google Assistant for voice control
  • Available in multiple colors: Black, Clear, Grey, White
This camera is ideal for both indoor and outdoor use, providing smart home integration and reliable wired power with the convenience of wireless connectivity.
Perfect for users wanting high-resolution video with smart home compatibility and enhanced night vision.
Wyze Cam Pan v3: 360° Pan and 180° Tilt with Weather Resistance
For comprehensive coverage, the Wyze Cam Pan v3 offers a dynamic 360° horizontal pan and 180° vertical tilt, allowing you to monitor large areas with a single camera.
Features:
  • 360° Pan & 180° Tilt for full room or yard coverage
  • IP65 Weatherproof for outdoor durability (requires outdoor power adapter)
  • Redesigned for improved performance and reliability
  • Available in Black or White
  • Ideal for indoor or outdoor use with optional power adapter
This camera is perfect for users who want to track movement across wide spaces without blind spots.
Best for those needing flexible, wide-angle surveillance with weatherproof design.
Wyze Cam Pan v3 in snowy outdoor environment Wyze Cam Pan v3 offers versatile 360° coverage in all weather
Wyze Cam OG and OG Telephoto: Affordable 1080p Security with Fast Alerts
If you’re looking for budget-friendly wireless security cameras, the Wyze Cam OG and Wyze Cam OG Telephoto provide reliable 1080p video with quick notifications and two-way audio.
Wyze Cam OG:
  • 1080p Full HD Video with 120° field of view
  • 3X Faster Notifications for prompt alerts
  • Built-in spotlight and improved two-way audio
  • Suitable for indoor and outdoor use
Wyze Cam OG Telephoto:
  • All OG features plus a 3x Telephoto Lens for zoomed-in views
  • Ideal for focusing on specific areas or objects
These cameras are great for users who want dependable security without breaking the bank.
Affordable, fast-alert cameras with clear video and audio.
Wyze Cam v4 Home Security Bundle: Complete Wired Security Solution
For those seeking a comprehensive package, the Wyze Cam v4 Home Security Bundle offers multiple cameras with all the benefits of the Wyze Cam v4, including: 2.5K QHD Resolution Enhanced Color Night Vision Motion-Activated Spotlight 24/7 Local Recording IP65 Weather Resistance
  • Compatibility with Alexa and Google Assistant
This bundle is perfect for securing multiple areas of your home with wired cameras that offer wireless smart features.
Complete home security with multiple cameras and smart integration.
Why Choose Wyze Wireless Security Cameras?
Wyze wireless security cameras combine high-resolution video, smart detection technologies, and weatherproof designs to provide reliable, easy-to-install security solutions for any home or business. Whether you prefer fully wire-free setups like the Battery Cam Pro or wired cameras with wireless smart features like the Cam v4, Wyze offers options tailored to your security needs.
Summary of Wyze Wireless Security Cameras
ProductVideo ResolutionWirelessWeatherproofSpecial Features
Wyze Battery Cam Pro2.5K HDRYesIP65Spotlight, Siren, Radar + PIR Motion
Wyze Cam v42.5K QHDWiredIP65Color Night Vision, Wi-Fi 6, Voice
Wyze Cam Pan v31080pWiredIP65360° Pan, 180° Tilt
Wyze Cam OG1080pWirelessIndoor/OutdoorFast Alerts, Two-Way Audio
Wyze Cam OG Telephoto1080p + 3x ZoomWirelessIndoor/OutdoorTelephoto Lens
Wyze Cam v4 Bundle2.5K QHDWiredIP65Multiple Cameras, Night Vision
Secure your home with Wyze’s trusted wireless security cameras that deliver peace of mind through advanced technology and user-friendly features.
FeatureWyze Battery Cam ProWyze Cam v4Wyze Cam Pan v3Wyze Cam OGWyze Cam OG TelephotoWyze Cam v4 Home Security Bundle
TypeBattery CameraWired CameraWired Camera (Pan/Tilt)Wired CameraWired CameraWired Camera Bundle
Video Resolution2.5K HDR2.5K QHD (2560x1440)1080p (1920x1080)1080p (1920x1080)1080p (1920x1080)2.5K QHD (2560x1440)
Field of View (FOV)Not specified exact degrees115.9° (D) x 98.5° (H) x 53.1° (V)360° horizontal, 180° vertical, 120° FOV120°Telephoto: 27° (D), 23.6° (H), 13.6° (V)115.8° (D), 98.5° (H), 53.1° (V)
Night VisionColor Night VisionEnhanced Color Night Vision4 IR LEDs (850 nm)4 IR LEDs (850 nm)4 IR LEDs (850 nm)4 IR LEDs (850 nm) + 2 white spotlight LEDs (72 lumens)
SpotlightIntegrated Spotlight (150 lumens)Motion-activated spotlightNoBuilt-in spotlight (40 lumens)NoMotion-activated spotlight
SirenIntegrated SirenIntegrated SirenNo90 dB user-activated sirenNoIntegrated siren
AudioEnhanced Two-Way Audio (mic + speaker)Enhanced Two-Way Talk (AAC, improved mic)Built-in speaker & mic; 2-way audioBuilt-in speaker & mic; noise & echo cancelBuilt-in speaker & mic; noise & echo cancelImproved 2-way audio
PowerBattery-powered, removable rechargeable packsWired (continuous power)Wired (continuous power)Wired (continuous power)Wired (continuous power)Wired (continuous power)
Weather ResistanceIP65IP65IP65IP65IP65IP65
Wi-Fi Support2.4 & 5 GHz dual-bandWi-Fi 62.4 GHz only2.4 GHz only2.4 GHz onlyWi-Fi 6
Local StorageMicroSD card support (up to 256GB)MicroSD card support (up to 256GB)MicroSD card support (up to 256GB)MicroSD card support (up to 256GB)MicroSD card support (up to 256GB)MicroSD card support (128GB included)
Motion DetectionRadar + PIR motion detection, custom zonesMotion & sound detection, custom zonesMotion detection, push notificationsMotion detection, custom zonesMotion detection, custom zonesPerson detection, custom zones
SetupBluetoothⓇ setup, no hub requiredBluetoothⓇ setup, no QR code scanningStandard setupStandard setupStandard setupBluetoothⓇ setup
DimensionsNot specifiedNot specified124mm (H) x 60mm (W) x 63mm (D)48mm x 48mm x 48mm48mm x 48mm x 48mm2in x 2in x 2 3/8in
WeightNot specifiedNot specified11.29 oz (320 g)4.1 oz (116 g)4.1 oz (116 g)0.49 lb (222 g)
Mounting OptionsFlexible, includes universal mount for ceilingMagnetic base, stand, wall, ceiling mountsScrew mount (1/4"-20), ceiling mountStand, wall, ceiling mountStand, wall, ceiling mountStand, wall, ceiling, magnetic wall mount
Additional FeaturesSolar panel compatible, local recording, bird detectionSmoke & CO alerts, AI auto-zoom, Wi-Fi 6 support360° pan & 180° tilt, noise & echo cancellationFaster live streaming, 3X faster notifications3X telephoto lensBundle includes multiple cameras, enhanced bundle features
Price (1 Pack)$89.98$35.98$39.98$29.98$25.98$169.99
What are the best Wyze wireless security cameras for home and outdoor use?Wyze offers a range of wireless security cameras ideal for both home and outdoor use, including the Wyze Battery Cam Pro, Wyze Cam v4, Wyze Cam Pan v3, Wyze Cam OG, and Wyze Cam OG Telephoto. Each model provides features like high-resolution video, weather resistance, smart detection, and easy installation.
What features does the Wyze Battery Cam Pro offer?The Wyze Battery Cam Pro features 2.5K HDR video resolution, a wire-free design with removable rechargeable batteries, integrated spotlight and siren, radar plus PIR motion detection, IP65 weatherproof rating, and support for both 2.4GHz and 5GHz WiFi. It requires no hub and is easy to set up anywhere.
Is the Wyze Battery Cam Pro suitable for outdoor use?Yes, the Wyze Battery Cam Pro is designed for outdoor use with an IP65 weatherproof rating, making it resistant to rain, snow, and dust. Its wire-free design is perfect for areas where running power cables is impractical.
What makes the Wyze Cam v4 a good choice for home security?The Wyze Cam v4 offers 2.5K QHD video resolution, enhanced color night vision, motion-activated spotlight, Wi-Fi 6 support, 24/7 local recording, and compatibility with Alexa and Google Assistant. It is suitable for both indoor and outdoor use and provides reliable wired power with wireless smart features.
Can the Wyze Cam Pan v3 cover large areas?Yes, the Wyze Cam Pan v3 provides 360° horizontal pan and 180° vertical tilt, allowing it to monitor large rooms or outdoor spaces without blind spots. It is also IP65 weatherproof (with an outdoor power adapter) for reliable outdoor use.
What is the difference between Wyze Cam OG and Wyze Cam OG Telephoto?The Wyze Cam OG offers 1080p full HD video, a 120° field of view, fast notifications, built-in spotlight, and two-way audio. The Wyze Cam OG Telephoto includes all OG features plus a 3x telephoto lens for zoomed-in views, making it ideal for monitoring specific areas or objects.
Are Wyze security cameras weatherproof?Many Wyze security cameras, such as the Wyze Battery Cam Pro, Wyze Cam v4, and Wyze Cam Pan v3, are IP65 weatherproof, making them suitable for outdoor use in various weather conditions. Always check the specific model’s weather resistance rating before installation.
Do Wyze wireless security cameras require a hub for installation?No, Wyze wireless security cameras like the Wyze Battery Cam Pro and Wyze Cam OG do not require a hub. They are designed for easy installation and can connect directly to your WiFi network.
Can Wyze security cameras be integrated with smart home systems?Yes, many Wyze security cameras, including the Wyze Cam v4 and Wyze Cam v4 Home Security Bundle, are compatible with Alexa and Google Assistant, allowing for convenient voice control and smart home integration.
What is included in the Wyze Cam v4 Home Security Bundle?The Wyze Cam v4 Home Security Bundle includes multiple Wyze Cam v4 cameras, each offering 2.5K QHD resolution, enhanced color night vision, motion-activated spotlight, 24/7 local recording, IP65 weather resistance, and compatibility with Alexa and Google Assistant.
Are there affordable Wyze wireless security camera options?Yes, the Wyze Cam OG and Wyze Cam OG Telephoto are budget-friendly wireless security cameras that provide reliable 1080p video, fast alerts, and two-way audio, making them great options for affordable home security.
What are the benefits of choosing Wyze wireless security cameras?Wyze wireless security cameras offer high-resolution video, smart detection technologies, weatherproof designs, and easy installation. They provide reliable security solutions for homes and businesses, with options for both wire-free and wired setups with wireless smart features.
What are the key features of the Wyze Battery Cam Pro?How does the Wyze Cam v4 compare to the Wyze Battery Cam Pro in terms of video quality?Are there any ongoing promotions or discounts for Wyze security cameras?
