Best Wyze Outdoor Cameras for Home Security & Surveillance
Best Outdoor Cameras for Reliable Home Security
When it comes to securing your home or property, choosing the right outdoor camera is essential. Wyze offers a range of advanced outdoor cameras designed to provide crystal-clear video, weather resistance, and smart features that keep you connected and protected 24/7. Below, we explore the top Wyze outdoor cameras that combine cutting-edge technology with user-friendly design.
Wyze Cam Pan v3 – 360° Pan & Tilt with Weather Resistance
Wyze Cam Pan v3 is a versatile indoor/outdoor security camera that offers a full 360° pan and 180° tilt, allowing you to monitor wide areas without blind spots. This camera is fully IP65 weather resistant, making it perfect for outdoor use in various weather conditions, including rain and snow. For outdoor installation, pairing it with the Wyze Outdoor Power Adapter (sold separately) ensures continuous power supply.
Key Features:
  • 360° Pan and 180° Tilt: Complete coverage with smooth motorized movement.
  • IP65 Weather Resistance: Durable against rain, snow, and dust.
  • Color Options: Available in sleek Black and White.
  • Multiple Pack Options: Choose from 1, 2, or 3 packs for comprehensive coverage.
Experience peace of mind with a camera that watches every angle of your property, rain or shine.
Wyze Cam Pan v3 Outdoor Lifestyle Wyze Cam Pan v3 installed outdoors in snowy weather
Wyze Cam v4 – Crystal-Clear 2.5K QHD Resolution with Enhanced Night Vision
Wyze Cam v4 is a powerful outdoor camera that delivers unmatched video quality with 2.5K QHD resolution. It features an advanced CMOS Starlight Sensor and Enhanced Color Night Vision, allowing you to see vibrant, detailed footage even in low-light conditions. The built-in motion-activated spotlight adds an extra layer of security by illuminating suspicious activity.
Key Features:
  • 2.5K QHD Video: Ultra-clear footage for precise monitoring.
  • Enhanced Color Night Vision: See colors clearly at night.
  • Motion-Activated Spotlight: Automatically lights up when motion is detected.
  • Wi-Fi 6 Support: Faster, more reliable wireless connectivity.
  • Smart Home Compatible: Works seamlessly with Alexa and Google Assistant.
  • Multiple Colors: Black, Clear, Grey, and White options.
  • Pack Options: Available in 1, 2, or 3 packs.
For those looking for an all-in-one solution, the Wyze Cam v4 Home Security Bundle offers the same premium features with added convenience and value. Wyze Cam v4 Outdoor Security Wyze Cam v4 mounted outdoors, providing clear home security
Wyze Cam OG and Wyze Cam OG Telephoto – Affordable and Efficient Outdoor Monitoring
The Wyze Cam OG series offers reliable outdoor security with quick live-streaming and improved 2-way audio for real-time communication. The OG model provides a wide 120° field of view with 1080p resolution, perfect for everyday monitoring. For enhanced zoom capabilities, the Wyze Cam OG Telephoto includes a 3x telephoto lens, allowing you to focus on distant objects without losing clarity.
Key Features of Wyze Cam OG:
  • 1080p Full HD Video: Clear and smooth footage.
  • 120° Field of View: Wide coverage area.
  • Improved 2-Way Audio: Communicate directly through the camera.
  • Quick Live-Streaming: Faster access to live video.
  • Indoor/Outdoor Use: Versatile placement options.
  • Color Options: Black and White.
Additional Features of Wyze Cam OG Telephoto:
  • 3x Telephoto Lens: Zoom in on details from afar.
  • Pack Options: Available in single or 2-pack sets.
Why Choose Wyze Outdoor Cameras?
Wyze outdoor cameras combine affordability with advanced features typically found in high-end security systems. Their weather-resistant designs, high-resolution video, and smart home integration make them ideal for protecting your home, pets, and property. Whether you want panoramic views, crystal-clear night vision, or telephoto zoom, Wyze has an outdoor camera tailored to your needs.
Protect your home with confidence using Wyze’s trusted outdoor cameras — smart, durable, and easy to use.
Summary of Wyze Outdoor Cameras
ModelResolutionField of ViewWeather ResistanceSpecial FeaturesPrice Range (USD)
Wyze Cam Pan v31080p360° pan, 180° tiltIP65360° coverage, weatherproof$39.98 - $114.94
Wyze Cam v42.5K QHD115.8° DFOVIP65Color night vision, spotlight$35.98 - $107.94
Wyze Cam v4 Home Security Bundle2.5K QHD115.8° DFOVIP65Bundle with accessories$169.99
Wyze Cam OG1080p120°Indoor/OutdoorQuick live-stream, 2-way audio$29.98 - $89.94
Wyze Cam OG Telephoto1080p120°Indoor/Outdoor3x telephoto lens$25.98 - $58.98
*Note: Indoor/outdoor use for OG models may require additional considerations for weather protection.
Protect your home with Wyze’s innovative outdoor cameras that deliver exceptional video quality, smart features, and durable designs to keep your property safe around the clock.
FeatureWyze Cam Pan v3Wyze Cam v4Wyze Cam OGWyze Cam OG TelephotoWyze Cam v4 Home Security BundleWyze v3 Bundle
TypeWired Indoor/Outdoor Pan & Tilt CameraWired Indoor/Outdoor CameraWired Indoor/Outdoor CameraWired Indoor/Outdoor CameraWired Indoor/Outdoor Camera BundleWired Indoor/Outdoor Camera Bundle
Price (Starting)$39.98 (1 Pack)$35.98 (1 Pack)$29.98 (1 Pack)$25.98 (1 Pack)$169.99 (Bundle)$92.94 (Bundle)
Resolution1080p (1920 x 1080)2.5K QHD (2560 x 1440)1080p (1920 x 1080)1080p (1920 x 1080)2.5K QHD (2560 x 1440)1080p (1920 x 1080)
Field of View (FOV)360° pan, 180° tilt115.9° (D) x 98.5° (H) x 53.1° (V)120° diagonalTelephoto: 27° (DFOV), 23.6° (HFOV), 13.6° (VFOV)115.8° (D), 98.5° (H), 53.1° (V)121° diagonal
Pan & TiltYes (360° pan, 180° tilt)NoNoNoNoNo
Night VisionColor Night Vision (Starlight Sensor)Enhanced Color Night VisionIR LEDs (4x 850nm)IR LEDs (4x 850nm)IR LEDs (4x 850nm) + 2 white spotlight LEDs (72 lumens)Color Night Vision (4 IR LEDs 850nm)
AudioTwo-Way AudioEnhanced Two-Way TalkUpgraded 2-way audioUpgraded 2-way audioImproved 2-way audioTwo-Way Audio
SpotlightNo (sold separately)Motion-activated spotlightBuilt-in spotlight (40 lumens)No spotlightMotion-activated spotlightNo spotlight
SirenNo99 dB siren90 dB user-activated sirenNo sirenIncluded sirenNo siren
Weather ResistanceIP65IP65IP65IP65IP65IP65
Local Storage SupportmicroSD up to 256GBmicroSD up to 256GBmicroSD up to 256GBmicroSD up to 256GBmicroSD 128GB included32GB microSD included
Motion TrackingYes (automatic pan & tilt tracking)Auto-zoom with AI Smart FocusNoNoNoYes
ConnectivityWiredWired, Wi-Fi 6 support802.11 b/g/n 2.4 GHz Wi-Fi802.11 b/g/n 2.4 GHz Wi-FiWiredWired
Smart Assistant CompatibilityYes (via Wyze app)Alexa, Google Assistant, IFTTTNot specifiedAlexa, Google Assistant, IFTTTAlexa, Google AssistantYes
DimensionsNot specified2in x 2in x 2 3/8in1.89in x 1.89in x 1.89in1.89in x 1.89in x 1.89in2in x 2in x 2 3/8in124mm x 60mm x 63mm
WeightNot specified0.49 lb (222 g)4.1 oz (116 g)4.1 oz (116 g)0.49 lb (222 g)11.29 oz (320 g)
Operating TemperatureNot specifiedNot specified-4°F to 131°F (-20°C to 55°C)-4°F to 131°F (-20°C to 55°C)Not specified-5°F to 113°F (-20°C to 45°C)
WarrantyNot specifiedNot specified1 Year1 Year1 YearNot specified
Additional FeaturesPrivacy Mode, Pan Scan™ patrol, Smoke & CO alerts24/7 local recording, motion-activated spotlight, Wi-Fi 6, Smoke & CO alertsFaster live streaming, 3x faster notifications3x Telephoto lens, improved 2-way audioBundle includes multiple cams and accessoriesBundle includes MicroSD card and accessories
What are the best Wyze outdoor cameras for home security?Wyze offers several top-rated outdoor cameras for home security, including the Wyze Cam Pan v3, Wyze Cam v4, Wyze Cam v4 Home Security Bundle, Wyze Cam OG, and Wyze Cam OG Telephoto. Each model provides advanced features such as weather resistance, high-resolution video, and smart home integration to keep your property protected.
Is the Wyze Cam Pan v3 suitable for outdoor use?Yes, the Wyze Cam Pan v3 is fully IP65 weather resistant, making it ideal for outdoor use in various weather conditions, including rain and snow. For continuous outdoor power, it is recommended to use the Wyze Outdoor Power Adapter (sold separately).
What are the key features of the Wyze Cam Pan v3?The Wyze Cam Pan v3 offers 360° pan and 180° tilt for complete coverage, IP65 weather resistance, multiple color options (Black and White), and is available in 1, 2, or 3 packs for flexible installation.
How does the Wyze Cam v4 enhance outdoor security?The Wyze Cam v4 features 2.5K QHD resolution for ultra-clear video, an advanced CMOS Starlight Sensor for enhanced color night vision, a motion-activated spotlight, Wi-Fi 6 support for faster connectivity, and compatibility with Alexa and Google Assistant.
Does the Wyze Cam v4 work with smart home systems?Yes, the Wyze Cam v4 is compatible with popular smart home systems, including Amazon Alexa and Google Assistant, allowing for seamless integration and voice control.
What is included in the Wyze Cam v4 Home Security Bundle?The Wyze Cam v4 Home Security Bundle includes the Wyze Cam v4 with all its premium features, plus additional accessories for added convenience and value, making it an all-in-one solution for home security.
What makes the Wyze Cam OG series a good choice for outdoor monitoring?The Wyze Cam OG series offers affordable and efficient outdoor monitoring with 1080p full HD video, a wide 120° field of view, improved 2-way audio, quick live-streaming, and versatile indoor/outdoor placement options.
What is the difference between Wyze Cam OG and Wyze Cam OG Telephoto?While both models offer 1080p HD video and a 120° field of view, the Wyze Cam OG Telephoto includes a 3x telephoto lens, allowing you to zoom in on distant objects without losing clarity.
Are Wyze outdoor cameras weather resistant?Yes, most Wyze outdoor cameras, such as the Wyze Cam Pan v3 and Wyze Cam v4, are IP65 weather resistant, making them durable against rain, snow, and dust. The Wyze Cam OG series can be used outdoors but may require additional weather protection.
Can I communicate through Wyze outdoor cameras?Yes, Wyze outdoor cameras like the Wyze Cam OG feature improved 2-way audio, allowing you to communicate directly through the camera for real-time interaction.
What are the available color and pack options for Wyze outdoor cameras?Wyze outdoor cameras come in various color options, including Black, White, Clear, and Grey, depending on the model. They are also available in single, double, or triple packs to suit different coverage needs.
Why should I choose Wyze outdoor cameras for home security?Wyze outdoor cameras combine affordability with advanced features like weather resistance, high-resolution video, smart home integration, and user-friendly design, making them an excellent choice for reliable home security.
What are the key features of the Wyze Cam Pan v3?Can you tell me more about the Wyze Cam v4 and its capabilities?Are there any ongoing sales or discounts for Wyze outdoor cameras?
