Wyze Outdoor Smart Cameras with Google Assistant Voice Control
Best Outdoor Smart Cameras Compatible with Google Assistant
If you're searching for an outdoor smart camera that pairs seamlessly with Google Assistant voice commands, Wyze offers some of the most advanced and versatile options on the market. Whether you want a wire-free battery-powered camera or a wired solution with enhanced night vision, Wyze has you covered with their latest models including the Wyze Battery Cam Pro, Wyze Cam v4, and the Wyze Battery Cam Pro + Solar Panel.
Wyze Battery Cam Pro: Wire-Free Outdoor Security with Smart Voice Control
Key Features
  • 2.5K HDR Video Resolution for crystal-clear footage day and night.
  • Wire-Free Design with removable, rechargeable 6200mAh battery packs offering up to 6 months of battery life on a single charge.
  • Integrated Spotlight & Siren to deter intruders and alert you instantly.
  • Radar + PIR Motion Detection for precise and reliable motion alerts.
  • IP65 Weatherproof Rating ensures durability in rain, snow, or shine.
  • Dual-Band WiFi Support (2.4 & 5 GHz) for stable connectivity.
  • Google Assistant Integration allows you to control the camera hands-free with voice commands.
  • Local Storage Support up to 256GB microSD card and optional cloud recording with Cam Plus.
  • Two-Way Audio with built-in microphone and speaker for real-time communication.
Why Choose Wyze Battery Cam Pro?
This camera is perfect for those who want a wireless, flexible outdoor security solution without the hassle of running power cables. Its long battery life and smart features make it ideal for remote locations or areas without easy access to power. Outdoor security camera mounted on house exterior at dusk Wyze Battery Cam Pro providing clear night vision and spotlight security
Wyze Cam v4: Wired Outdoor Camera with Enhanced Night Vision and Google Assistant
Key Features
  • 2.5K QHD (2560x1440) Resolution delivers sharp, detailed video.
  • Enhanced Color Night Vision with 4 IR LEDs and 2 white spotlight LEDs (72 lumens) for vibrant nighttime footage.
  • Motion-Activated Spotlight to illuminate and alert when movement is detected.
  • Person Detection reduces false alarms by distinguishing people from other motion.
  • IP65 Weather Resistance for reliable outdoor use.
  • Wi-Fi 6 Support for faster and more stable wireless connections.
  • Google Assistant Compatibility for voice-activated control.
  • Multiple Mounting Options including stand, wall, ceiling, and magnetic mounts.
  • 24/7 Local Recording with support for up to 128GB microSD cards.
Ideal Use Cases
The Wyze Cam v4 is a great choice if you prefer a wired camera with continuous power and advanced night vision capabilities. It’s perfect for homeowners who want a reliable, always-on security camera with smart home integration. Wyze Cam v4 mounted outdoors on a home wall Wyze Cam v4 installed outdoors, blending into modern smart homes
Wyze Battery Cam Pro + Solar Panel: Extended Power for Continuous Outdoor Monitoring
Key Features
  • All the features of the Wyze Battery Cam Pro including 2.5K HDR video, integrated spotlight, siren, and radar + PIR motion detection.
  • Solar Panel Accessory (sold separately) to keep your camera charged continuously without manual recharging.
  • Up to 6 Months Battery Life on a single charge, extended further with solar power.
  • IP65 Weatherproof for all-season outdoor use.
  • Google Assistant and Alexa Integration for voice control.
  • Supports local microSD storage and cloud recording options.
Benefits of Solar Power
Pairing the Wyze Battery Cam Pro with a solar panel is ideal for users who want maintenance-free, long-term outdoor security without worrying about battery replacement or recharging.
Why Choose Wyze for Your Outdoor Smart Camera Needs?
Wyze cameras stand out for their combination of high-resolution video, smart home compatibility, and affordable pricing. With native support for Google Assistant, you can easily control your cameras with simple voice commands like “Hey Google, show me the front door camera,” making home security effortless and hands-free.
“Wyze’s outdoor cameras offer a perfect blend of advanced technology and user-friendly smart home integration, ensuring your property stays safe and monitored 24/7.”
Summary of Wyze Outdoor Smart Cameras Compatible with Google Assistant
ProductPower SourceVideo ResolutionNight Vision TypeWeatherproofVoice Assistant SupportBattery Life
Wyze Battery Cam ProRechargeable Battery2.5K HDRColor Night Vision + IRIP65Google Assistant, AlexaUp to 6 months
Wyze Cam v4Wired (AC Power)2.5K QHDEnhanced Color Night VisionIP65Google Assistant, AlexaContinuous power
Wyze Battery Cam Pro + SolarRechargeable Battery + Solar2.5K HDRColor Night Vision + IRIP65Google Assistant, AlexaExtended with solar
Conclusion
For an outdoor smart camera that pairs perfectly with Google Assistant voice commands, the Wyze Battery Cam Pro and Wyze Cam v4 are top contenders. Choose the Battery Cam Pro for wireless convenience and long battery life, or the Cam v4 for wired reliability and enhanced night vision. For ultimate freedom, add the solar panel to the Battery Cam Pro and enjoy continuous, maintenance-free security. Secure your home with Wyze’s smart, high-quality outdoor cameras and experience peace of mind with hands-free voice control.
FeatureWyze Battery Cam ProWyze Cam v4 Home Security BundleWyze Cam v4 + FREE 32GB MicroSD CardWyze Battery Cam Pro + Solar Panel
Video Resolution2.5K HDR (2560 x 1440)2.5K QHD2.5K QHD2.5K HDR (2560 x 1440)
Power SourceRemovable, Rechargeable Battery PacksWired (continuous power)Wired (continuous power)Removable, Rechargeable Battery Packs + Solar Panel
Battery LifeUp to 6 monthsN/AN/AExtended with Solar Panel
Charging TimeApprox. 9 hoursN/AN/AApprox. 9 hours (battery)
WirelessYes (2.4 & 5 GHz WiFi)No (Wired)No (Wired)Yes (2.4 & 5 GHz WiFi)
Weather ResistanceIP65IP65IP65IP65
Motion DetectionRadar + PIR Motion DetectionMotion & Sound DetectionMotion & Sound DetectionRadar + PIR Motion Detection
Night VisionColor Night Vision (2 IR LEDs + 2 White LEDs)Enhanced Color Night VisionEnhanced Color Night VisionColor Night Vision (2 IR LEDs + 2 White LEDs)
SpotlightIntegrated Spotlight (150 lumens)Motion-activated SpotlightMotion-activated SpotlightIntegrated Spotlight (150 lumens)
Local StorageSupports microSD up to 256GB24/7 Local Recording (microSD required)24/7 Local Recording (microSD included 32GB)Supports microSD up to 256GB
Cloud StorageCam Plus subscription availableCam Plus subscription availableCam Plus subscription availableCam Plus subscription available
Two-Way AudioYesYesYesYes
Smart Home IntegrationAlexa, Google Assistant, IFTTTAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant, IFTTT
SetupBluetoothⓇ Setup, No Hub RequiredRequires Hub (wired)Requires Hub (wired)BluetoothⓇ Setup, No Hub Required
Dimensions2.5 x 1.8 x 3.5 inchesNot specified (4 cameras in bundle)Not specified2.5 x 1.8 x 3.5 inches
Weight0.94 lbsNot specifiedNot specified0.94 lbs
Included ItemsCamera only4x Wyze Cam v4 + 4x 128GB microSD CardsWyze Cam v4 + 32GB microSD CardWyze Battery Cam Pro + Solar Panel
Price (approximate)$89.98 (1 pack)$169.99 (bundle)$35.98$109.98
What are the best outdoor smart cameras compatible with Google Assistant?The best outdoor smart cameras compatible with Google Assistant include the Wyze Battery Cam Pro, Wyze Cam v4, and the Wyze Battery Cam Pro + Solar Panel. These cameras offer advanced features such as high-resolution video, weatherproof design, and seamless integration with Google Assistant for hands-free voice control.
Does the Wyze Battery Cam Pro work with Google Assistant?Yes, the Wyze Battery Cam Pro is fully compatible with Google Assistant. You can control the camera and view live feeds using simple voice commands, making it easy to monitor your property hands-free.
What are the key features of the Wyze Battery Cam Pro?The Wyze Battery Cam Pro features 2.5K HDR video resolution, a wire-free design with up to 6 months of battery life, integrated spotlight and siren, radar + PIR motion detection, IP65 weatherproof rating, dual-band WiFi support, Google Assistant integration, local microSD storage, and two-way audio.
Is the Wyze Cam v4 compatible with Google Assistant?Yes, the Wyze Cam v4 is compatible with Google Assistant. This allows you to control the camera and access live video streams using voice commands for convenient smart home integration.
What are the benefits of using the Wyze Battery Cam Pro with a solar panel?Pairing the Wyze Battery Cam Pro with a solar panel accessory provides continuous, maintenance-free power, eliminating the need for manual recharging. This setup is ideal for long-term outdoor security in remote locations and ensures your camera stays powered year-round.
How long does the battery last on the Wyze Battery Cam Pro?The Wyze Battery Cam Pro offers up to 6 months of battery life on a single charge. When paired with the optional solar panel, the battery life is extended even further, providing continuous outdoor monitoring.
What is the video resolution of Wyze outdoor cameras compatible with Google Assistant?Both the Wyze Battery Cam Pro and Wyze Cam v4 offer high-resolution video. The Wyze Battery Cam Pro provides 2.5K HDR video, while the Wyze Cam v4 delivers 2.5K QHD (2560x1440) resolution for sharp and detailed footage.
Are Wyze outdoor cameras weatherproof?Yes, Wyze outdoor cameras such as the Wyze Battery Cam Pro, Wyze Cam v4, and Wyze Battery Cam Pro + Solar Panel are all rated IP65 weatherproof, making them suitable for use in rain, snow, or shine.
Can Wyze outdoor cameras record locally and to the cloud?Yes, Wyze outdoor cameras support local storage via microSD cards (up to 256GB for Battery Cam Pro and up to 128GB for Cam v4) and offer optional cloud recording with the Cam Plus subscription.
What are the main differences between Wyze Battery Cam Pro and Wyze Cam v4?The Wyze Battery Cam Pro is a wire-free, battery-powered camera with up to 6 months of battery life and optional solar charging, making it ideal for flexible placement. The Wyze Cam v4 is a wired camera with continuous power and enhanced color night vision, suitable for users who prefer a reliable, always-on security solution.
What are the key features of the Wyze Cam v4?Can you tell me more about the night vision capabilities of the Wyze Battery Cam Pro?Do you have any ongoing sales or discounts for Wyze cameras?
