Secure 20ft Wyze Cam USB Extension for Front Gate & Fence
Secure Wiring Solutions for Wyze Cam Near Front Gate or Fence Line
When installing your Wyze Cam near a front gate or along a fence line, having a reliable and secure wiring setup is essential to ensure continuous power and optimal performance. Whether you want to extend your camera’s reach or power it conveniently outdoors, Wyze offers accessories and cameras designed to meet these needs with ease and durability.
Wyze Cam USB Extension Cable - 20ft: Extend Your Camera’s Reach
Key Features
  • Length: 20 feet of USB extension cable to overcome short cable limitations.
  • Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Telephoto models.
  • Flexibility: Allows you to position your Wyze Cam farther from power sources, perfect for mounting near gates or along fences where outlets may be distant.
  • Durability: Designed for easy installation and reliable connection outdoors when paired with weatherproof setups.
Say goodbye to short cables and enjoy the freedom to place your Wyze Cam exactly where you need it without worrying about power constraints.
This 20ft USB extension cable is an affordable and practical solution to secure wiring challenges, enabling you to maintain a clean, organized, and safe installation near your property’s entry points.
Wyze Cam OG: Advanced Outdoor Security Camera with Built-In Spotlight
Why Wyze Cam OG is Ideal for Front Gate or Fence Line Installation
  • Weatherproof: Rated IP65, it withstands harsh weather conditions, making it perfect for outdoor use.
  • Wide Field of View: 120° coverage to capture a broad area around your gate or fence.
  • Built-In Spotlight & Mini-Siren: Deter unwanted visitors with a 40-lumen spotlight and a 90-decibel siren.
  • Fast Notifications: Sends motion alerts 3X faster than previous Wyze models, ensuring you’re instantly aware of activity.
  • Enhanced Two-Way Audio: Communicate clearly with visitors or delivery personnel at your gate.
  • Color Night Vision: See vivid details even in low light, improving security during nighttime hours.
  • Local Storage Support: Compatible with Wyze microSD cards up to 256GB for continuous recording.
The Wyze Cam OG combines robust outdoor durability with smart features to keep your front gate or fence line secure and well-monitored.
Installation Tip
Pair the Wyze Cam OG with the 20ft USB extension cable to position the camera exactly where you need it without worrying about power outlet proximity. Wyze Cam OG installed outdoors near a gate
Wyze Cam Floodlight Plug-In Mount: Easy Outdoor Power Solution
Simplify Your Outdoor Camera Setup
  • Plug-n-Play: Avoid complex junction box installations with this easy plug-in mount.
  • 20ft Power Cord: Provides ample length to reach outdoor outlets near gates or fences.
  • Outdoor Safe: Designed to withstand outdoor conditions, rated for temperatures from -22°F to 122°F.
  • Compatible With: Wyze Cam Floodlight v1, v2, and Floodlight Pro models.
  • Certified Safety: UL and RoHS certifications ensure safe and reliable use.
This mount is perfect for powering Wyze floodlight cameras securely near your front gate or fence line without costly electrical work.
Using the Floodlight Plug-In Mount with your Wyze Cam Floodlight models ensures your security lighting and camera system stays powered and functional, enhancing your home’s perimeter security. Wyze Cam Floodlight in evening outdoor setting
Additional Tips for Secure Wiring Near Front Gates or Fence Lines
  • Weatherproofing: Use weather-resistant cable conduits or protective tubing to shield USB extension cables from rain, sun, and physical damage.
  • Cable Management: Secure cables along fence posts or gate frames with clips or ties to prevent tripping hazards and tampering.
  • Power Source: Consider outdoor-rated power outlets or use Wyze’s lamp socket bundles (compatible with various Wyze Cam models) to power cameras via existing light fixtures.
  • Camera Placement: Position cameras to cover entry points clearly while avoiding obstructions for optimal motion detection and video quality.
Summary
For secure wiring and reliable power supply of your Wyze Cam near front gates or fence lines, the Wyze Cam USB Extension Cable - 20ft is an essential accessory that extends your camera’s reach effortlessly. Pair it with the Wyze Cam OG for a weatherproof, feature-rich outdoor camera experience, or use the Wyze Cam Floodlight Plug-In Mount for a simple, plug-and-play power solution for floodlight cameras. These products combined provide a flexible, secure, and smart home security setup tailored to your outdoor needs.
FeatureWyze Cam USB Extension Cable - 20ftWyze Cam OGWyze Cam Floodlight Plug-In Mount
TypeAccessoryCameraAccessory
Price$7.99$29.98 (1 Pack)$19.98
Description20ft USB extension cable for Wyze Cam modelsNext-gen Wyze Cam with spotlight, 3X faster notifications, 2-way audio, indoor/outdoorPlug-n-play floodlight mount, no junction box needed
Compatible DevicesWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoStandalone cameraWyze Cam Floodlight v1, v2, Floodlight Pro
Cable Length20 ftN/A20 ft (6m) power cord
Weather ResistanceN/AIP65 (Indoor/Outdoor)Yes (Outdoor safe)
PowerUSB powered110-240V AC/DC adapter (5V/1A output)110-120V AC input
MountingN/AVarious mounting optionsPlug-in mount with mounting kit
FeaturesExtends USB cable length120° FOV, built-in spotlight (40 lumens), 2-way audio, 3X faster notifications, color night visionEasy installation, floodlight mount, outdoor safe
Operating TemperatureN/A-4°F to 131°F (-20°C to 55°C)-22°F to 122°F
DimensionsN/A1.89 in x 1.89 in x 1.89 in (48 mm x 48 mm x 48 mm)Package: 153mm x 155mm x 79mm
WeightN/A4.1 oz (116 g)1.39 lbs
Included Items1x 20ft USB extension cableCamera onlyFloodlight Plug-in Mount, mounting kit, screws, foam tape, quick start guide
WarrantyNot specified1 YearNot specified
What is the best way to power a Wyze Cam near my front gate or fence line?The best way to power a Wyze Cam near your front gate or fence line is by using the Wyze Cam USB Extension Cable - 20ft. This cable allows you to extend your camera’s reach to distant power outlets, ensuring a secure and reliable power supply for outdoor installations.
Which Wyze Cam models are compatible with the 20ft USB extension cable?The 20ft USB extension cable is compatible with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Telephoto models.
Is the Wyze Cam OG suitable for outdoor use near gates or fences?Yes, the Wyze Cam OG is ideal for outdoor use near gates or fences. It is IP65 weatherproof rated, has a wide 120° field of view, built-in spotlight and mini-siren, fast motion notifications, enhanced two-way audio, color night vision, and supports local storage up to 256GB.
How can I install a Wyze Cam Floodlight near my front gate without complex wiring?You can use the Wyze Cam Floodlight Plug-In Mount, which features a 20ft power cord and plug-n-play design. This allows you to power your Wyze Cam Floodlight v1, v2, or Floodlight Pro models easily from an outdoor outlet, avoiding the need for complex junction box installations.
What are some tips for securing and protecting camera wiring outdoors?To secure and protect camera wiring outdoors, use weather-resistant cable conduits or protective tubing to shield cables from the elements. Secure cables along fence posts or gate frames with clips or ties to prevent tripping hazards and tampering. Always use outdoor-rated power outlets or compatible lamp socket bundles for safe power supply.
Can I use Wyze Cam accessories to improve security at my property’s entry points?Yes, Wyze Cam accessories like the 20ft USB extension cable and Floodlight Plug-In Mount help you position and power your cameras securely at entry points such as front gates or fence lines, ensuring optimal coverage and reliable operation.
How do I ensure my Wyze Cam installation is weatherproof?To ensure your Wyze Cam installation is weatherproof, use weather-resistant cable conduits or protective tubing for all exposed wiring, and choose cameras like the Wyze Cam OG, which are rated for outdoor use. Proper cable management and secure mounting also help protect your setup from weather and physical damage.
What are the benefits of using a 20ft USB extension cable with my Wyze Cam?Using a 20ft USB extension cable with your Wyze Cam allows you to overcome short cable limitations, position your camera farther from power sources, and maintain a clean, organized, and safe installation near your property’s entry points.
What are the key features of the Wyze Cam USB Extension Cable - 20ft?How does the Wyze Cam OG perform in different weather conditions?Do you have any deals, ongoing sales, discounts, or promotions available?
