20ft Wyze Cam USB Extension Cable for Outdoor Siding Install
Running a 20 ft USB Cable Under Siding for Outdoor Wyze Cam Placement
When setting up your Wyze Cam outdoors, especially under siding, having the right accessories is crucial for a clean, safe, and effective installation. A 20 ft USB extension cable is an ideal solution to extend your camera’s reach without compromising power or connectivity. Below, we explore the best Wyze products to help you run a 20 ft USB cable under siding and power your outdoor Wyze Cam seamlessly.
Wyze Cam USB Extension Cable - 20ft: Extend Your Reach with Ease
The Wyze Cam USB Extension Cable - 20ft is designed specifically to solve the common problem of short cables limiting your camera placement options. Whether you want to mount your Wyze Cam under siding, on a porch, or further away from your power source, this cable gives you the freedom to position your camera exactly where you need it.
Key Features:
  • Length: 20 feet of durable USB extension cable.
  • Compatibility: Works with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto.
  • Durability: Designed for indoor and outdoor use, perfect for running under siding or along exterior walls.
  • Easy Installation: Simply plug into your existing Wyze Cam USB power adapter and extend your camera’s power source without hassle.
Say goodbye to short cables and enjoy the freedom of a 20ft cable for your outdoor Wyze Cam setup.
Wyze Cam v4 Outdoor Bundle: Ultimate Outdoor Security with Extended Power Options
For those looking to upgrade their outdoor security, the Wyze Cam v4 Outdoor Bundle offers a powerful camera with enhanced features and compatibility with extended power solutions like the 20 ft USB extension cable.
Highlights:
  • Resolution: Crystal-clear 2.5K QHD video for detailed monitoring.
  • Night Vision: Enhanced Color Night Vision ensures clear images even in low light.
  • Power Source: Wired power with support for USB extension cables, perfect for running cables under siding.
  • Connectivity: Supports Wi-Fi 6 for faster, more reliable connections.
  • Smart Home Integration: Compatible with Alexa and Google Assistant.
  • Local Storage: Includes a 128GB MicroSD card for 24/7 local recording.
This bundle is ideal for outdoor placement where power outlets may be limited, and running a 20 ft USB cable under siding can provide the necessary reach without unsightly wiring. Outdoor Security Camera Mounted on House Alt text: Wyze Cam v4 mounted outdoors under house siding for security
Lamp Socket v2 Bundles: Power Your Wyze Cam Without an Outlet
If running a USB cable under siding is not feasible or you want a cleaner power solution, the Wyze Lamp Socket v2 Bundles offer an innovative way to power your Wyze Cam by using your existing outdoor light socket.
Cam v4 + Lamp Socket v2 Bundle
  • Power Source: Uses your outdoor lamp socket to power Wyze Cam v4 without needing an outlet.
  • Compatibility: Works with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3.
  • Smart Lighting: Turns your outdoor light into a smart light controlled via the Wyze app.
  • Motion-Activated Lights: Lights can be set to turn on when motion is detected by the camera.
  • Easy Installation: Screw in the lamp socket like a light bulb and plug in your Wyze Cam.
Pan v3 + Lamp Socket v2 Bundle
  • Similar benefits as above but tailored for the Wyze Cam Pan v3.
  • Available in white or black to match your outdoor decor.
This solution eliminates the need for running long cables under siding and provides a neat, integrated power source for your outdoor Wyze Cam.
Outdoor Porch Light with Wyze Cam Alt text: Wyze Cam powered by lamp socket on outdoor porch light
Why Use a 20 ft USB Extension Cable for Your Wyze Cam?
Running a 20 ft USB cable under siding is a practical and cost-effective way to extend your camera’s power source without drilling or rewiring your home’s electrical system. It allows you to:
  • Place your camera in the optimal position for surveillance.
  • Avoid unsightly wires running along your exterior walls.
  • Maintain a weather-resistant setup by hiding cables under siding.
  • Easily upgrade or relocate your camera without rewiring.
The Wyze Cam USB Extension Cable - 20ft is specifically designed to meet these needs, ensuring compatibility and durability for outdoor use.
Summary of Recommended Products for Outdoor Wyze Cam Placement
Product NameKey BenefitPrice
Wyze Cam USB Extension Cable - 20ftExtend camera power cable length$7.99
Wyze Cam v4 Outdoor BundleHigh-res outdoor camera with accessories$69.99
Cam v4 + Lamp Socket v2 BundlePower Wyze Cam via outdoor lamp socket$49.96
Pan v3 + Lamp Socket v2 BundlePower Wyze Cam Pan v3 via lamp socket$53.96
Running a 20 ft USB cable under siding combined with these Wyze accessories ensures your outdoor camera setup is both flexible and professional-looking. Whether you choose the extension cable or the lamp socket power bundles, Wyze offers smart, reliable solutions to keep your home secure.
FeatureWyze Cam USB Extension Cable - 20ftWyze Cam v4 Outdoor BundleCam v4 + Lamp Socket v2 Bundle
Product TypeUSB Extension CableOutdoor Security Camera BundleSecurity Camera Bundle with Lamp Socket
Price$7.99$69.99$49.96
CompatibilityWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoWyze Cam v4Wyze Cam v3, v3 Pro, v4, OG, Pan v3
Key Features20ft USB extension cable for extended reach2.5K QHD resolution, Enhanced Color Night Vision, Motion-activated spotlight, 24/7 local recording, Wi-Fi 6 support, Alexa & Google Assistant compatiblePowers Wyze Cams via lamp socket, Motion-activated lights, Dusk to Dawn scheduling, Linkability
Included Items1x 20ft USB extension cable1x Wyze Cam v4, 1x Wyze Outdoor Power Adapter, 1x 128GB MicroSD card1x Wyze Cam v4, 1x Lamp Socket v2
Power SourceUSB poweredWired (6 ft USB cable and power adapter included)Powered via lamp socket (E26, 120V~, 60Hz)
Weather ResistanceN/AIP65 rated (suitable for indoor/outdoor use)Not weatherproof, suitable for damp locations
ConnectivityUSBWi-Fi 6 (2.4 GHz only)Wi-Fi 2.4 GHz, Bluetooth
DimensionsN/AN/A56.5mm x 56.5mm x 65mm
WeightN/AN/A80 g
Special NotesExtends USB cable length for Wyze camerasRequires Wyze Outdoor Power Adapter for outdoor useIncandescent bulbs not supported; recommended CFL or LED under 20W
WarrantyNot specifiedNot specified1-Year
Can I use a 20 ft USB extension cable to power my Wyze Cam outdoors?Yes, the Wyze Cam USB Extension Cable - 20ft is specifically designed for both indoor and outdoor use, making it ideal for powering your Wyze Cam outdoors. It allows you to extend your camera’s reach, especially when running the cable under siding or along exterior walls.
Which Wyze Cam models are compatible with the 20 ft USB extension cable?The 20 ft USB extension cable is compatible with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto models. This ensures flexibility for various Wyze Cam setups.
Is the Wyze Cam USB Extension Cable - 20ft weather-resistant for outdoor installation?Yes, the Wyze Cam USB Extension Cable - 20ft is designed for durability and is suitable for both indoor and outdoor installations, including running under siding for a weather-resistant setup.
What are the benefits of running a 20 ft USB cable under siding for my Wyze Cam?Running a 20 ft USB cable under siding allows you to place your Wyze Cam in the optimal position for surveillance, hide unsightly wires, maintain a weather-resistant setup, and easily upgrade or relocate your camera without rewiring.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes a high-resolution 2.5K QHD camera with enhanced Color Night Vision, Wi-Fi 6 support, smart home integration with Alexa and Google Assistant, and a 128GB MicroSD card for 24/7 local recording. It is compatible with USB extension cables for flexible outdoor placement.
How can I power my Wyze Cam outdoors if I don’t have an outdoor outlet?If you don’t have an outdoor outlet, you can use the Wyze Lamp Socket v2 Bundles. These allow you to power your Wyze Cam by screwing the lamp socket into your existing outdoor light fixture, eliminating the need for long cables or additional outlets.
What are the advantages of using the Wyze Lamp Socket v2 Bundle for outdoor camera installation?The Wyze Lamp Socket v2 Bundle powers your Wyze Cam using your outdoor lamp socket, offers smart lighting control via the Wyze app, enables motion-activated lights, and provides a clean, integrated installation without running long cables under siding.
Is the installation of the Wyze Cam USB Extension Cable - 20ft easy?Yes, installation is simple. Just plug the extension cable into your existing Wyze Cam USB power adapter and extend your camera’s power source to the desired location, such as under siding or along exterior walls.
Can I use the Wyze Lamp Socket v2 Bundle with different Wyze Cam models?Yes, the Wyze Lamp Socket v2 Bundle is compatible with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3, making it a versatile power solution for various Wyze Cam models.
What are the prices of the recommended Wyze accessories for outdoor camera placement?The Wyze Cam USB Extension Cable - 20ft is $7.99, the Wyze Cam v4 Outdoor Bundle is $69.99, the Cam v4 + Lamp Socket v2 Bundle is $49.96, and the Pan v3 + Lamp Socket v2 Bundle is $53.96.
What are the key features of the Wyze Cam USB Extension Cable - 20ft?Can the Wyze Cam USB Extension Cable be used with all Wyze Cam models?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Cam products?
