Wyze Cam Pan v3: 360° Rotating Security Camera with Local Storage
Wyze Cam Pan v3: The Ultimate Rotating Security Camera with Local Storage
When it comes to securing your home with continuous recording and versatile coverage, the Wyze Cam Pan v3 stands out as a top choice. This advanced rotating security camera offers 360° horizontal pan and 180° vertical tilt, ensuring no blind spots in your surveillance. Whether you want to monitor indoors or outdoors, the Pan v3 delivers reliable performance with local storage options for uninterrupted recording.
Experience peace of mind with a camera designed for all-around protection and smart home integration.
Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3 weather-resistant outdoor use
Key Features of Wyze Cam Pan v3
360° Pan and 180° Tilt for Full Coverage
The Wyze Cam Pan v3 offers a complete 360-degree horizontal rotation and 180-degree vertical tilt, allowing you to monitor every corner of your space without needing multiple cameras. With a rotation speed of up to 110° per second, it quickly tracks movement to keep you informed.
Crisp 1080p HD Video with Night Vision
Capture clear, detailed footage day and night with a 1/2.9" CMOS image sensor and 4 IR LEDs for night vision. The camera supports 1920 x 1080 resolution at 20 fps during the day and 15 fps at night, ensuring smooth video quality. Color night vision enhances visibility in low-light conditions.
Local Storage for Continuous Recording
Wyze Cam Pan v3 supports microSD cards up to 256 GB (ExFAT format), enabling continuous local recording without relying solely on cloud storage. This feature is perfect for users who want to keep their footage private and accessible anytime.
Durable and Weather Resistant
With an IP65 rating, the Pan v3 is built to withstand outdoor elements like rain and dust. For outdoor use, pairing it with the Wyze Outdoor Power Adapter (sold separately) ensures safe and reliable power supply.
Smart Home Integration and Connectivity
Compatible with Alexa, Google Assistant, and IFTTT, the camera fits seamlessly into your smart home ecosystem. It connects via 2.4 GHz Wi-Fi (802.11 b/g/n) and supports Android 9.0+ and iOS 15.0+ devices for easy remote access and control.
Two-Way Audio with Noise Cancellation
Communicate clearly through the built-in speaker and microphone featuring noise and echo cancellation. Whether you want to greet visitors or deter intruders, the two-way audio functionality adds an interactive layer to your security. Two-way audio feature with pet Two-way audio for real-time communication
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle: Enhanced Security Experience
For those looking to maximize their security setup, the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle offers the same powerful camera with added benefits. This bundle includes a 30-day trial of Cam Plus, Wyze’s subscription service that provides advanced AI detection, person detection, package detection, and more.
What’s Included in the Bundle?
  • Wyze Cam Pan v3 (available in Black or White)
  • 6-foot micro USB cable and power adapter
  • Mounting kit and quick start guide
  • 30-day Cam Plus trial for enhanced smart alerts and cloud storage options
This bundle is ideal for users who want both local storage and cloud-based smart features for comprehensive home monitoring.
Optional Accessories for Wyze Cam Pan v3
Wyze Cam Pan v3 Skins by dBrand
Customize and protect your camera with stylish vinyl skins available in Green Camo and Triple Black. These skins provide scratch protection and a flawless fit, allowing your camera to blend seamlessly with your home décor.
Wyze Cam Pan v3 USB Cable
Keep your camera powered with a replacement USB cable designed specifically for the Pan v3, ensuring uninterrupted operation.
Pan v3 + Lamp Socket v2 Bundle
Power your Pan v3 camera through a lamp socket without needing an outlet. This accessory is perfect for exterior lighting setups, making your security system even smarter and more convenient.
Why Choose Wyze Cam Pan v3 for Your Home Security?
  • Comprehensive 360° coverage with fast rotation and tilt
  • Continuous local recording with support for up to 256 GB microSD cards
  • Weather-resistant design suitable for indoor and outdoor use
  • Smart home compatibility with Alexa, Google Assistant, and IFTTT
  • Clear two-way audio for real-time communication
  • Affordable pricing with options for bundles and accessories
The Wyze Cam Pan v3 is a versatile, reliable, and feature-rich security camera that meets the needs of modern homeowners seeking continuous, local storage-based surveillance with smart capabilities.
Feature / ProductWyze Cam Pan v3Wyze Cam Pan v3 + 30-Day Cam Plus BundleWyze Cam Pan v3 Skins by dBrand (Skin Only)Wyze Cam Pan v3 USB CablePan v3 + Lamp Socket v2 Bundle
TypeCameraCamera BundleAccessory (Skin)Replacement PartBundle (Camera + Lamp Socket)
Price$39.98 (1 Pack)$39.98$11.98$1.99$53.96
Color VariantsBlack, WhiteBlack, WhiteGreen Camo, Triple BlackN/ABlack, White
Pack Options1, 2, 3 PacksSingle camera onlySingle skinSingle cableSingle bundle
Weather ResistanceIP65 rated (outdoor ready with adapter)IP65 rated (outdoor ready with adapter)Not applicableNot applicableCamera: IP65 with adapter; Lamp Socket: Not weatherproof, suitable for damp locations
Outdoor UseRequires Wyze Outdoor Power Adapter (sold separately)Requires Wyze Outdoor Power Adapter (sold separately)N/AN/AYes, with included lamp socket power option
Pan & Tilt Coverage360° pan, 180° tilt360° pan, 180° tiltN/AN/A360° pan, 180° tilt (camera included)
Motion TrackingYesYesN/AN/AYes (camera included)
Two-Way AudioYesYesN/AN/AYes (camera included)
Color Night VisionYes (Starlight Sensor)Yes (Starlight Sensor)N/AN/AYes (camera included)
Cam Plus SubscriptionOptional, not includedIncluded free 30 days, then $2.99/month/cam auto-renewN/AN/AOptional, not included
Custom Detection ZonesYesYesN/AN/AYes (camera included)
Smoke & CO AlertsYesYesN/AN/AYes (camera included)
Included ItemsCamera, USB cableCamera, USB cable, 30-day Cam Plus trial1x Skin, Installation instructionsUSB cableCamera, Lamp Socket v2
Material / BuildPolycarbonate bodyPolycarbonate bodyStylish vinyl skinUSB cablePolycarbonate & Plastic (lamp socket)
Dimensions (Lamp Socket)N/AN/AN/AN/A56.5mm x 56.5mm x 65mm
Weight (Lamp Socket)N/AN/AN/AN/A80 g
Power Input (Lamp Socket)N/AN/AN/AN/A120V~, 60Hz
Connectivity (Lamp Socket)Wi-Fi 2.4 GHzWi-Fi 2.4 GHzN/AN/AWi-Fi 2.4 GHz, Bluetooth
Warranty1 Year1 YearN/AN/A1 Year
Special NotesOutdoor use requires separate power adapterOutdoor use requires separate power adapterProtects device, prevents scratchesReplacement USB cable for Pan v3Incandescent bulbs not supported; use CFL or LED under 20W
What is the Wyze Cam Pan v3 and what makes it unique?The Wyze Cam Pan v3 is a rotating security camera designed for both indoor and outdoor use. It features 360° horizontal pan and 180° vertical tilt, providing full coverage without blind spots. Its unique features include local storage support, weather resistance, smart home integration, and two-way audio.
Does the Wyze Cam Pan v3 support local storage for continuous recording?Yes, the Wyze Cam Pan v3 supports local storage with microSD cards up to 256 GB (ExFAT format), allowing for continuous recording without relying solely on cloud storage. This ensures your footage is private and always accessible.
Is the Wyze Cam Pan v3 weather-resistant for outdoor use?Yes, the Wyze Cam Pan v3 has an IP65 weather-resistant rating, making it suitable for outdoor use. For safe and reliable outdoor power, it is recommended to use the Wyze Outdoor Power Adapter (sold separately).
What video quality does the Wyze Cam Pan v3 offer?The Wyze Cam Pan v3 delivers crisp 1080p HD video with a 1/2.9" CMOS image sensor. It records at 1920 x 1080 resolution at 20 fps during the day and 15 fps at night, and features color night vision for enhanced low-light visibility.
How does the Wyze Cam Pan v3 integrate with smart home systems?The Wyze Cam Pan v3 is compatible with Alexa, Google Assistant, and IFTTT, allowing seamless integration into your smart home ecosystem. It connects via 2.4 GHz Wi-Fi and supports Android 9.0+ and iOS 15.0+ devices for easy remote access and control.
What is included in the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle?The Wyze Cam Pan v3 + 30-Day Cam Plus Bundle includes the camera (available in Black or White), a 6-foot micro USB cable and power adapter, a mounting kit, a quick start guide, and a 30-day trial of Cam Plus for advanced AI detection and cloud storage.
What accessories are available for the Wyze Cam Pan v3?Available accessories for the Wyze Cam Pan v3 include dBrand vinyl skins for customization and protection, a replacement USB cable, and the Pan v3 + Lamp Socket v2 Bundle, which allows you to power the camera through a lamp socket for added convenience.
Does the Wyze Cam Pan v3 have two-way audio?Yes, the Wyze Cam Pan v3 features two-way audio with noise and echo cancellation, allowing you to communicate clearly with visitors or deter intruders in real time.
What are the main benefits of choosing the Wyze Cam Pan v3 for home security?The Wyze Cam Pan v3 offers comprehensive 360° coverage, continuous local recording, weather-resistant design, smart home compatibility, clear two-way audio, and affordable pricing with bundle and accessory options, making it an excellent choice for modern home security.
What are the key features of the Wyze Cam Pan v3 that make it suitable for outdoor use?Can the Wyze Cam Pan v3 be integrated with other smart home devices?Is there a warranty available for the Wyze Cam Pan v3?
