DIY Home Monitoring: Wyze Cam Pan v3 with 360° View & Alerts
DIY Home Monitoring Setup with Wyze Cam Pan v3
Creating a reliable and versatile home monitoring system is easier than ever with the Wyze Cam Pan v3. Whether you want to keep an eye on your indoor spaces or monitor the outdoors, this rotating HD camera offers comprehensive coverage, real-time alerts, and smart integrations to keep your home safe and connected.
Wyze Cam Pan v3: The Ultimate Rotating HD Camera
360° Pan and 180° Tilt for Full Coverage
The Wyze Cam Pan v3 features a redesigned motorized base that allows a full 360° horizontal pan and 180° vertical tilt. This means you can monitor every corner of your room or outdoor area without blind spots. The camera rotates smoothly at speeds up to 110° per second, ensuring quick tracking of any movement.
Crisp 1080p HD Video with Night Vision
Equipped with a 1/2.9" CMOS image sensor and glass + plastic lens, the Pan v3 delivers sharp 1080p Full HD video at 20 fps during the day and 15 fps at night. Four IR LEDs provide clear black-and-white night vision, while the color night vision feature enhances visibility in low-light conditions.
Weather Resistant for Indoor and Outdoor Use
With an IP65 rating, the Wyze Cam Pan v3 is built to withstand rain, snow, and dust, making it perfect for outdoor installations when paired with the Wyze Outdoor Power Adapter (sold separately). Its durable polycarbonate body and matte finish ensure long-lasting performance in various environments.
Smart Alerts and Two-Way Audio
Receive instant push notifications on your smartphone whenever motion or sound is detected. The camera includes a built-in speaker and microphone with noise and echo cancellation, enabling seamless two-way communication. Talk to family members, pets, or even deter intruders remotely.
Easy Integration and Storage
Compatible with Alexa, Google Assistant, and IFTTT, the Pan v3 fits effortlessly into your smart home ecosystem. It supports local storage up to 256 GB microSD cards (ExFAT format) and offers cloud storage options for continuous video recording.
"Wyze Cam Pan v3 combines powerful features with affordability, making it an ideal choice for DIY home monitoring setups."
Wyze Cam Pan v3 Outdoor Lifestyle Wyze Cam Pan v3 installed outdoors, showcasing weather resistance in snowy conditions.
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle: Enhanced Monitoring Experience
All Features of Pan v3 Plus Cam Plus Benefits
This bundle includes the Wyze Cam Pan v3 along with a 30-day trial of Cam Plus, Wyze’s advanced AI-powered subscription service. Cam Plus unlocks person detection, package detection, vehicle detection, and more, reducing false alerts and providing smarter notifications.
Complete Setup Kit Included
The bundle comes with everything you need to get started: the camera, a 6-foot micro USB cable, power adapter, mounting kit, and quick start guide. This makes installation straightforward for any DIY enthusiast.
Color Night Vision for Clearer Images
Unlike the standard Pan v3, this bundle offers color night vision, allowing you to see more details in low-light environments, which is especially useful for outdoor monitoring. Two-way Audio Feature Communicate easily with two-way audio, perfect for indoor monitoring and interacting with pets or family.
Pan v3 + Lamp Socket v2 Bundle: Power Your Camera Smartly
Innovative Power Solution for Outdoor Use
The Pan v3 + Lamp Socket v2 Bundle lets you power your Wyze Cam Pan v3 through a standard E26 lamp socket, eliminating the need for a dedicated power outlet. This is ideal for porch lights or other exterior lighting fixtures.
Smart Lighting and Camera Integration
Control your exterior lighting and camera from the same app, enhancing your home’s security and convenience. The lamp socket supports CFL or LED bulbs up to 20W and is suitable for damp locations.
Easy Installation and Compatibility
Compatible with multiple Wyze cameras including Pan v3, this bundle is a smart upgrade for outdoor monitoring setups, especially where power outlets are limited.
Why Choose Wyze Cam Pan v3 for Your DIY Home Monitoring?
  • Full 360° coverage with smooth pan and tilt
  • 1080p HD video with night vision and color night vision options
  • Weather-resistant design for indoor/outdoor flexibility
  • Real-time push alerts and advanced AI detection with Cam Plus
  • Two-way audio for communication and deterrence
  • Smart home integrations with Alexa, Google Assistant, and IFTTT
  • Flexible power options including lamp socket bundle for outdoor use
With these features, the Wyze Cam Pan v3 and its bundles provide a comprehensive, affordable, and easy-to-install solution for anyone looking to build a DIY home monitoring system with a rotating HD camera and real-time alerts.
Accessories and Replacement Parts
Wyze Cam Pan v3 Skins by dBrand
Customize and protect your camera with stylish vinyl skins available in Green Camo and Triple Black. These precision-cut skins prevent scratches and give your camera a unique look.
Wyze Cam Pan v3 USB Cable
Keep your camera powered with an official replacement USB cable designed specifically for the Pan v3.
Enhance your home security today with the Wyze Cam Pan v3 and its versatile accessories — the perfect DIY solution for real-time, 360° monitoring.
FeatureWyze Cam Pan v3Wyze Cam Pan v3 + 30-Day Cam Plus BundlePan v3 + Lamp Socket v2 Bundle
Product DescriptionRedesigned indoor/outdoor 360° pan, 180° tilt security camera, IP65 weather resistant. Outdoor use requires Wyze Outdoor Power Adapter (sold separately).Same as Wyze Cam Pan v3 plus 30-day free trial of Cam Plus subscription (unlimited event video cloud storage, advanced notifications).Wyze Cam Pan v3 bundled with Lamp Socket v2 to power camera without outlet. Lamp socket suitable for damp locations, not weatherproof.
Pan & Tilt360° pan, 180° tilt360° pan, 180° tilt360° pan, 180° tilt
Weather ResistanceIP65 (weather resistant)IP65 (weather resistant)Camera IP65; Lamp Socket not weatherproof, suitable for damp locations
Outdoor UseRequires Wyze Outdoor Power Adapter (sold separately)Requires Wyze Outdoor Power Adapter (sold separately)Lamp Socket powers camera without outlet; no mention of outdoor power adapter needed
Cam Plus SubscriptionNot includedIncluded 30-day free trial, auto-renews $2.99/month per cameraNot included
Price$39.98 (1 Pack)$39.98 (includes 30-day Cam Plus trial)$53.96 (bundle price)
Color VariantsBlack, WhiteBlack, WhiteBlack, White
Pack Options1 Pack, 2 Pack, 3 PackSingle camera onlySingle camera + lamp socket bundle only
Lamp Socket FeaturesN/AN/AE26 socket, 120V~, 60Hz, max lamp power 20W, suitable for CFL/LED bulbs only, not incandescent
ConnectivityWi-Fi 2.4 GHz b/g/nWi-Fi 2.4 GHz b/g/nWi-Fi 2.4 GHz b/g/n (camera); Bluetooth for lamp socket
Dimensions (Lamp Socket)N/AN/A56.5mm x 56.5mm x 65mm
Weight (Lamp Socket)N/AN/A80 g
Operating TemperatureNot specifiedNot specified-4°F to 120°F (-20°C to 50°C)
Additional FeaturesAutomatic motion tracking, Privacy Mode, Two-way audio, Color Night Vision, Pan Scan™ waypoints, Smoke/CO alertsSame as Wyze Cam Pan v3 plus Cam Plus advanced notifications (crying baby, barking pet, etc.)Same camera features plus lamp socket powers camera without outlet
Warranty1 Year1 Year1 Year
What is the Wyze Cam Pan v3 and how does it enhance home monitoring?The Wyze Cam Pan v3 is a rotating HD camera designed for comprehensive home monitoring. It offers 360° horizontal pan and 180° vertical tilt, providing full coverage of indoor or outdoor spaces. With features like real-time alerts, night vision, two-way audio, and smart home integration, it enhances security and convenience for DIY home monitoring setups.
Does the Wyze Cam Pan v3 support outdoor installation?Yes, the Wyze Cam Pan v3 is weather-resistant with an IP65 rating, making it suitable for both indoor and outdoor use. For outdoor installations, it is recommended to use the Wyze Outdoor Power Adapter (sold separately) to ensure reliable performance in rain, snow, and dust.
What video quality and night vision features does the Wyze Cam Pan v3 offer?The Wyze Cam Pan v3 delivers crisp 1080p Full HD video at 20 fps during the day and 15 fps at night. It features four IR LEDs for clear black-and-white night vision and also offers color night vision for enhanced visibility in low-light conditions, especially with the Cam Plus bundle.
How does the Wyze Cam Pan v3 provide real-time alerts and communication?The camera sends instant push notifications to your smartphone whenever motion or sound is detected. It also includes a built-in speaker and microphone with noise and echo cancellation, allowing for seamless two-way audio communication to talk to family, pets, or deter intruders remotely.
What smart home integrations are available with the Wyze Cam Pan v3?The Wyze Cam Pan v3 is compatible with Alexa, Google Assistant, and IFTTT, making it easy to integrate into your existing smart home ecosystem for voice control and automation.
What storage options are available for the Wyze Cam Pan v3?The Wyze Cam Pan v3 supports local storage with microSD cards up to 256 GB (ExFAT format) for continuous video recording. It also offers cloud storage options for added convenience and security.
What is included in the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle?The bundle includes the Wyze Cam Pan v3 camera, a 6-foot micro USB cable, power adapter, mounting kit, quick start guide, and a 30-day trial of Cam Plus. Cam Plus unlocks advanced AI features like person, package, and vehicle detection, reducing false alerts and providing smarter notifications.
How does the Pan v3 + Lamp Socket v2 Bundle work for outdoor monitoring?The Pan v3 + Lamp Socket v2 Bundle allows you to power your Wyze Cam Pan v3 through a standard E26 lamp socket, eliminating the need for a dedicated power outlet. It also lets you control your exterior lighting and camera from the same app, making it ideal for outdoor setups where power access is limited.
Are there accessories available for the Wyze Cam Pan v3?Yes, there are several accessories available, including Wyze Cam Pan v3 Skins by dBrand for customization and protection, and official replacement USB cables to keep your camera powered.
Why is the Wyze Cam Pan v3 a good choice for DIY home monitoring?The Wyze Cam Pan v3 offers full 360° coverage, 1080p HD video with night vision, weather-resistant design, real-time push alerts, advanced AI detection with Cam Plus, two-way audio, smart home integrations, and flexible power options. These features make it an affordable, comprehensive, and easy-to-install solution for DIY home security.
What are the key features of the Wyze Cam Pan v3 that make it suitable for outdoor use?Can you explain how the two-way audio feature works on the Wyze Cam Pan v3?Do you have any ongoing sales or discounts for the Wyze Cam Pan v3?
