Smart Assistant Security Camera Kits with Pan Tracking
Smart Assistant Compatible Security Cameras Kit with Pan Tracking
Enhance your home security with a comprehensive range of smart assistant compatible security cameras that offer advanced features including pan tracking, crystal-clear video, and seamless integration with Alexa and Google Assistant. Whether you want full home coverage, outdoor monitoring, or a versatile pan-and-tilt camera, these kits and individual cameras provide reliable, weather-resistant solutions tailored to your needs.
Whole Home Security Starter Kit: All-in-One Smart Security Solution
The Whole Home Security Starter Kit is perfect for those seeking a complete security setup with smart assistant compatibility. This bundle includes:
  • Wyze Cam v4: The clearest Wyze Cam ever with 2.5K QHD resolution and enhanced color night vision.
  • Wyze Video Doorbell v2: Crisp 2K video doorbell with two-way audio and motion-activated voice deterrence.
  • Wyze Home Monitoring Starter Kit: Provides additional security sensors and monitoring.
Key Features:
  • Smart Assistant Integration: Works flawlessly with Alexa and Google Assistant for voice control and automation.
  • Comprehensive Coverage: Indoor and outdoor security with video doorbell and cameras.
  • Local and Cloud Storage: Supports microSD cards for continuous recording and optional cloud plans.
  • Weather Resistant: Cameras rated IP65 for reliable outdoor use.
This kit is ideal for users who want a ready-to-go, smart home security system with pan tracking capabilities through included cameras.
Wyze Cam Pan v3: 360° Pan and 180° Tilt with Smart Tracking
Wyze Cam Pan v3 in snowy outdoor setting Weather-resistant Wyze Cam Pan v3 providing full panoramic coverage The Wyze Cam Pan v3 is the ultimate pan tracking camera designed for both indoor and outdoor use. It offers:
  • 360° horizontal and 180° vertical rotation for complete room or yard coverage.
  • 1080p Full HD video resolution with 4 IR LEDs for night vision.
  • Auto-zoom with AI Smart Focus to track moving objects smoothly.
  • IP65 weather resistance, making it durable in rain, snow, or sun.
  • Two-way audio with noise and echo cancellation for clear communication.
  • Smart assistant compatibility with Alexa, Google Assistant, and IFTTT.
Technical Highlights:
  • Rotation speed up to 110° per second for quick tracking.
  • Supports up to 256GB microSD card for local storage.
  • Easy screw mount with a compact, matte polycarbonate body.
This camera is perfect for users who want dynamic pan tracking to monitor large areas with smart assistant voice control.
Wyze Cam v4: Crystal Clear 2.5K QHD with Enhanced Color Night Vision
Wyze Cam v4 two-way talk with pet Wyze Cam v4 with enhanced two-way audio for clear communication The Wyze Cam v4 is a versatile wired camera offering:
  • 2.5K Quad HD resolution for sharp, detailed video.
  • Enhanced Color Night Vision that reveals vibrant colors even in low light.
  • Motion-activated spotlight and 99 dB siren for deterrence.
  • Wi-Fi 6 support for stronger, more reliable connections.
  • 24/7 local recording with microSD card support (up to 256GB).
  • Smart assistant compatibility with Alexa and Google Assistant.
Ideal for indoor or outdoor use (with optional outdoor power adapter), this camera provides excellent image quality and smart features for everyday security.
Wyze Battery Cam Pro: Wire-Free, Long-Lasting Outdoor Security
The Wyze Battery Cam Pro is a wire-free security camera designed for flexible placement without sacrificing power or performance:
  • 2.5K HDR video resolution with CMOS-Starlight sensor.
  • Radar + PIR motion detection for precise alerts.
  • Integrated spotlight and 100 dB siren for active deterrence.
  • Removable rechargeable battery packs lasting up to 6 months.
  • Dual-band Wi-Fi (2.4 & 5 GHz) for stable connectivity.
  • IP65 weatherproof rating for all-season outdoor use.
  • Smart assistant support with Alexa, Google Assistant, and IFTTT.
This camera is perfect for users who want a wireless, battery-powered option with pan tracking capabilities via app control and smart assistant integration.
Wyze Bulb Cam: 2-in-1 Security Camera and Smart LED Light
Wyze Bulb Cam installed in outdoor light fixture Wyze Bulb Cam combines security and lighting in one smart device The Wyze Bulb Cam is a unique outdoor security camera integrated into a smart LED bulb:
  • 2K HD video with color night vision for clear monitoring day and night.
  • 160° field of view for wide coverage.
  • Motion-activated light and push notifications for instant alerts.
  • Fits standard E26 light sockets for easy installation.
  • Supports local microSD storage up to 256GB.
  • IP65 weather resistance for outdoor durability.
  • Works with Alexa and Google Assistant for voice control.
This camera is ideal for users wanting discreet outdoor security combined with smart lighting.
Wyze Video Doorbell v2: Clear 2K Video and Smart Alerts
The Wyze Video Doorbell v2 offers a smart way to monitor your front door with:
  • 2K resolution video for detailed images.
  • Wide 135° horizontal and 103° vertical field of view.
  • Two-way audio and motion-activated voice deterrence.
  • Local microSD storage and optional cloud plans.
  • IP65 weather resistance for all-weather reliability.
Perfect for answering your door remotely and enhancing your home’s entryway security.
Why Choose These Smart Assistant Compatible Security Cameras?
"Experience seamless home security with smart assistant integration, pan tracking, and crystal-clear video quality."
  • Smart Assistant Compatibility: Control your cameras with voice commands via Alexa or Google Assistant.
  • Pan Tracking: Keep moving subjects in focus with Wyze Cam Pan v3’s 360° coverage and AI tracking.
  • Weather Resistant: All outdoor cameras are IP65 rated, built to withstand harsh weather.
  • High-Resolution Video: From 1080p to 2.5K QHD, capture every detail day and night.
  • Flexible Storage Options: Local microSD support and cloud plans for continuous recording.
  • Two-Way Audio & Sirens: Communicate and deter intruders instantly.
Secure your home with the best smart assistant compatible security cameras featuring pan tracking and advanced smart features. Whether you want a full starter kit or individual cameras tailored to your needs, these Wyze products deliver reliable, high-quality security solutions.
FeatureWhole Home Security Starter KitWyze Cam v4Wyze Cam Pan v3Wyze Battery Cam ProWyze Bulb CamWyze Video Doorbell v2
Price$155.95$35.98 (1 Pack)$114.94 (1 Pack)$159.98 (1 Pack)$49.98$44.98
Video ResolutionIncludes Wyze Cam v4 (2.5K QHD) and Doorbell (2K)2.5K QHD (2560x1440)1080p (1920x1080)2.5K HDR (2560x1440)2K HD (2304x1296)2K (2048x1536)
Field of View (Horizontal)Wyze Cam v4: 98.5°; Doorbell: 135°98.5°360° horizontal108°144°135°
Night VisionColor Night Vision (Wyze Cam v4 & Bulb Cam)Enhanced Color Night VisionIR Night Vision (4 IR LEDs)IR + White LEDs (Color Night Vision)Color Night Vision + IR Night VisionIR Night Vision (6 IR LEDs)
AudioTwo-way audio (Wyze Cam v4 & Doorbell)Enhanced Two-Way TalkTwo-way audio with noise & echo cancellationTwo-way audio with built-in speaker & micTwo-way audioTwo-way audio
Spotlight & SirenIncluded (Wyze Cam v4 & Doorbell)Motion-activated spotlight + 99 dB sirenNo spotlight; siren not specifiedIntegrated spotlight & 100 dB sirenSiren 95 dBMotion-activated voice deterrence
Power SourceWired (Wyze Cam v4 & Doorbell)WiredWiredWire-free, rechargeable battery packsWired (standard bulb socket)Wired (16V-24V AC)
Weather ResistanceIP65 (Wyze Cam v4 & Doorbell)IP65IP65IP65IP65IP65
Local Storage SupportmicroSD (Wyze Cam v4 & Doorbell)microSD up to 512 GBmicroSD up to 256 GBmicroSD up to 256 GBmicroSD up to 256 GBmicroSD up to 256 GB
Cloud StorageAvailable with subscriptionAvailable with subscriptionNot specifiedNot specifiedStored in AWS cloudAvailable with subscription
ConnectivityWi-Fi 2.4 GHz, Wi-Fi 6 (Wyze Cam v4)Wi-Fi 2.4 GHz, Wi-Fi 6Wi-Fi 2.4 GHz onlyWi-Fi 2.4 & 5 GHzWi-Fi 2.4 GHzWi-Fi 2.4 GHz
Smart Assistant IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
DimensionsN/A (Kit includes multiple devices)2in x 2in x 2 3/8in124mm x 60mm x 63mm2.5 x 1.8 x 3.5 inchesStandard E26 bulb size4.3in x 1.7in x 0.9in
WeightN/A0.49 lb (222 g)11.29 oz (320 g)0.94 lbsN/AN/A
Warranty1 Year1 Year1 Year1 Year1 Year1 Year
Additional FeaturesIncludes Wyze Video Doorbell v2 and Home Monitoring KitMotion-activated spotlight, AI auto-zoom, Smoke & CO alerts360° pan, 180° tilt, 8x digital zoomRadar + PIR motion detection, up to 6 months battery life2-in-1 camera and smart LED bulb, up to 800 lm brightnessMotion-activated voice deterrence, chime controller included
What is a smart assistant compatible security camera kit with pan tracking?A smart assistant compatible security camera kit with pan tracking is a home security solution that integrates with voice assistants like Alexa and Google Assistant. It features cameras with advanced pan and tilt capabilities, allowing you to track moving objects and monitor large areas. These kits offer seamless voice control, high-resolution video, and weather-resistant designs for both indoor and outdoor use.
Which smart security cameras work with Alexa and Google Assistant?All Wyze security cameras mentioned, including Wyze Cam Pan v3, Wyze Cam v4, Wyze Battery Cam Pro, Wyze Bulb Cam, and Wyze Video Doorbell v2, are compatible with Alexa and Google Assistant. This allows you to control your cameras and view live feeds using simple voice commands.
What are the benefits of pan tracking in security cameras?Pan tracking in security cameras, such as the Wyze Cam Pan v3, enables the camera to automatically follow moving objects across a 360° horizontal and 180° vertical range. This ensures comprehensive coverage of large areas, reduces blind spots, and provides dynamic monitoring for enhanced home security.
What is included in the Whole Home Security Starter Kit?The Whole Home Security Starter Kit includes the Wyze Cam v4 (2.5K QHD resolution, color night vision), Wyze Video Doorbell v2 (2K video, two-way audio), and the Wyze Home Monitoring Starter Kit (security sensors and monitoring). This bundle offers complete indoor and outdoor coverage with smart assistant integration.
Are Wyze security cameras weather resistant?Yes, Wyze security cameras such as the Wyze Cam Pan v3, Wyze Cam v4 (with outdoor adapter), Wyze Battery Cam Pro, Wyze Bulb Cam, and Wyze Video Doorbell v2 are rated IP65 for weather resistance. This makes them suitable for reliable outdoor use in rain, snow, or sun.
Do Wyze security cameras support local and cloud storage?Yes, Wyze cameras support both local storage via microSD cards (up to 256GB) for continuous recording and optional cloud storage plans for added convenience and backup.
What video resolution do Wyze security cameras offer?Wyze security cameras offer high-resolution video, ranging from 1080p Full HD (Wyze Cam Pan v3) to 2.5K QHD (Wyze Cam v4 and Wyze Battery Cam Pro) and 2K HD (Wyze Bulb Cam and Wyze Video Doorbell v2). This ensures sharp, detailed footage for effective monitoring.
Can I use Wyze security cameras for two-way communication?Yes, Wyze cameras such as the Wyze Cam Pan v3, Wyze Cam v4, and Wyze Video Doorbell v2 feature two-way audio with noise and echo cancellation. This allows you to communicate clearly with visitors or deter intruders remotely.
Are there wireless, battery-powered security camera options available?Yes, the Wyze Battery Cam Pro is a wire-free, battery-powered security camera designed for flexible placement. It features up to 6 months of battery life, 2.5K HDR video, radar and PIR motion detection, and smart assistant compatibility.
What is the Wyze Bulb Cam and how does it work?The Wyze Bulb Cam is a 2-in-1 device that combines a security camera with a smart LED light. It offers 2K HD video, color night vision, a 160° field of view, motion-activated lighting, and fits standard E26 light sockets for easy installation. It is weather resistant and works with Alexa and Google Assistant.
How does the Wyze Video Doorbell v2 enhance front door security?The Wyze Video Doorbell v2 provides 2K resolution video, a wide field of view, two-way audio, and motion-activated voice deterrence. It supports local and cloud storage, is weather resistant, and integrates with Alexa and Google Assistant for smart alerts and remote answering.
Why should I choose Wyze smart assistant compatible security cameras?Wyze smart assistant compatible security cameras offer seamless integration with Alexa and Google Assistant, advanced pan tracking, high-resolution video, weather resistance, flexible storage options, and features like two-way audio and sirens. They provide reliable, high-quality security solutions for both indoor and outdoor use.
Can you tell me more about the features of the Wyze Cam v4?What is the difference between the Wyze Cam v4 and the Wyze Cam Pan v3?Do you have any ongoing sales or discounts for the security camera kits?
