Wyze Cam Pan v3: Silent, Smooth Rotating Security Camera
Wyze Cam Pan v3: The Ultimate Rotating Camera with Smooth Mechanical Operation
If you're searching for a rotating camera that offers smooth mechanical operation combined with a near-silent motor, the Wyze Cam Pan v3 stands out as a top choice. Designed for both indoor and outdoor use, this camera delivers 360° horizontal and 180° vertical coverage with whisper-quiet panning, making it perfect for home security, pet monitoring, and more.
Seamless 360° Pan and 180° Tilt with Near-Silent Motor
The Wyze Cam Pan v3 features a highly responsive motor capable of rotating up to 110° per second. This ensures smooth, fluid movement without the distracting noise common in many pan-tilt cameras. Whether you're monitoring your living room or keeping an eye on your outdoor space, the camera’s near-silent operation allows discreet surveillance without disturbing your environment.
Robust Weather Resistance for Outdoor Use
Built with a durable polycarbonate body and a matte finish, the Wyze Cam Pan v3 is fully IP65 rated, making it resistant to dust and water. This weatherproof design allows you to confidently install it outdoors, even in challenging weather conditions. For outdoor setups, pairing it with the Wyze Outdoor Power Adapter (sold separately) ensures safe and reliable power. Wyze Cam Pan v3 in snowy outdoor setting Experience reliable outdoor security with Wyze Cam Pan v3’s weather-resistant design.
Crystal Clear 1080p HD Video with Night Vision
Equipped with a 1/2.9" CMOS image sensor and glass + plastic lens, the Wyze Cam Pan v3 captures sharp 1080p Full HD video at 20 fps during the day and 15 fps at night. Four 850 nm IR LEDs provide clear black-and-white night vision, ensuring you never miss a detail in low-light conditions. The camera also supports color night vision in the bundled version, enhancing visibility after dark.
Advanced Features for Smart Home Integration
  • Two-Way Audio: Built-in speaker and microphone with noise and echo cancellation allow seamless communication through the camera.
  • Digital Zoom: Up to 8x zoom to focus on important details.
  • Wide Field of View: 120° field of view combined with pan and tilt capabilities for comprehensive coverage.
  • Connectivity: Supports 2.4 GHz Wi-Fi (802.11 b/g/n) and integrates with Alexa, Google Assistant, and IFTTT.
  • Storage: Supports microSD cards up to 256 GB for local recording and offers cloud storage options.
  • Push Notifications: Instant alerts keep you informed of motion or sound events.
Dimensions and Design
  • Size: 124mm (H) x 60mm (W) x 63mm (D)
  • Weight: 11.29 oz (320 g)
  • Finish: Matte black or white options
  • Mount: Standard 1/4" - 20 screw mount for versatile installation
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle: Enhanced Security Experience
For those looking to maximize their security setup, the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle offers the same impressive hardware with the added benefit of a 30-day trial to Cam Plus. This subscription service unlocks advanced AI features such as person detection, package detection, and more, providing smarter alerts and enhanced monitoring capabilities.
Key Bundle Benefits
  • Includes Wyze Cam Pan v3 with all core features.
  • Comes with a power adapter, micro USB cable, mounting kit, and quick start guide.
  • Enables color night vision for clearer nighttime footage.
  • Access to Cam Plus AI-powered event detection for 30 days.
Two-way audio feature with pet monitoring Communicate effortlessly with two-way audio, perfect for pet monitoring or home interaction.
Why Choose Wyze Cam Pan v3 Over Previous Models?
The Wyze Cam Pan v3 improves upon its predecessor, the Wyze Cam Pan v2, by offering:
  • Weatherproof IP65 rating for outdoor use (v2 is indoor only).
  • Color night vision in the bundle version.
  • Improved mechanical design for quieter and smoother pan/tilt operation.
  • Updated firmware and integrations for better smart home compatibility.
  • Same fast rotation speed of up to 110° per second but with enhanced durability.
Additional Accessories for Wyze Cam Pan v3
To complement your Wyze Cam Pan v3, consider these accessories:
  • Wyze Cam Pan v3 Skins by dBrand: Stylish vinyl skins in Green Camo or Triple Black to protect and personalize your camera.
  • Wyze Cam Pan v3 USB Cable: Replacement USB cable to ensure continuous power supply.
  • Pan v3 + Lamp Socket v2 Bundle: Power your Pan v3 camera through a lamp socket without needing an outlet, ideal for flexible installation.
The Wyze Cam Pan v3 is a versatile, reliable, and smart rotating camera solution that combines smooth mechanical operation with near-silent motor technology. Whether for indoor or outdoor use, it offers comprehensive coverage, crystal-clear video, and smart features to keep your home and loved ones safe.
Summary of Featured Products
Wyze Cam Pan v3 Wyze Cam Pan v3 + 30-Day Cam Plus Bundle Wyze Cam Pan v2
FeatureWyze Cam Pan v3Wyze Cam Pan v3 + 30-Day Cam Plus BundleWyze Cam Pan v2
TypeIndoor/Outdoor Pan & Tilt Security CameraIndoor/Outdoor Pan & Tilt Security Camera + 30-Day Cam PlusIndoor Pan & Tilt Security Camera
Pan Range360° horizontal360° horizontal360° horizontal
Tilt Range180° vertical180° vertical93° vertical
Weather ResistanceIP65 (requires Outdoor Power Adapter for outdoor use)IP65 (requires Outdoor Power Adapter for outdoor use)Indoor use only
Motion TrackingYes, automatic motion trackingYes, automatic motion trackingYes, automatic motion tracking
Night VisionColor Night Vision with Starlight SensorColor Night Vision with Starlight SensorStarlight Color Night Vision
Two-Way AudioYesYesYes
Privacy ModeYesYesNo
Cloud StorageOptional Cam Plus subscriptionIncludes 30-Day free Cam Plus trialFree rolling 14 days of alert videos
Cam Plus SubscriptionAvailable, $2.99/month/cam after trialIncluded free for 30 days, then $2.99/month/camNot included
Video Resolution1080p HD1080p HD1080p HD
Video Frame RateNot specifiedNot specified20 FPS day / 15 FPS night
Local Storage SupportmicroSD card support (sold separately)microSD card support (sold separately)Supports 8GB, 16GB, 32GB microSD cards
Motion & Sound DetectionYesYesMotion detection only
Custom Detection ZonesYesYesNot specified
Smoke & CO Alarm AlertsYesYesNot specified
Price (Single Unit)$39.98$39.98Not specified
Color VariantsBlack, WhiteBlack, WhiteWhite
WarrantyNot specifiedNot specified1 Year
Additional FeaturesQuieter tracking motor, Pan Scan™ patrol, Privacy ModeSame as Pan v3 plus 30-day Cam Plus trial8x digital zoom, 1.5GHz CPU, 128MB memory
What is the Wyze Cam Pan v3 and what makes it unique?The Wyze Cam Pan v3 is a rotating security camera designed for both indoor and outdoor use. It features smooth mechanical operation with a near-silent motor, offering 360° horizontal and 180° vertical coverage. Its weatherproof IP65 rating, advanced night vision, and smart home integration set it apart from other cameras.
Is the Wyze Cam Pan v3 suitable for outdoor use?Yes, the Wyze Cam Pan v3 is fully IP65 rated, making it resistant to dust and water. Its durable polycarbonate body and weatherproof design allow for reliable outdoor installation, even in challenging weather conditions.
What video quality does the Wyze Cam Pan v3 offer?The Wyze Cam Pan v3 captures crystal-clear 1080p Full HD video at 20 fps during the day and 15 fps at night. It also features four 850 nm IR LEDs for black-and-white night vision and supports color night vision in the bundled version.
Does the Wyze Cam Pan v3 support two-way audio?Yes, the Wyze Cam Pan v3 includes a built-in speaker and microphone with noise and echo cancellation, allowing for seamless two-way communication through the camera.
What smart home platforms is the Wyze Cam Pan v3 compatible with?The Wyze Cam Pan v3 supports 2.4 GHz Wi-Fi and integrates with Alexa, Google Assistant, and IFTTT for easy smart home automation and voice control.
How does the Wyze Cam Pan v3 store video recordings?The Wyze Cam Pan v3 supports microSD cards up to 256 GB for local recording and also offers cloud storage options for added convenience and security.
What is included in the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle?The Wyze Cam Pan v3 + 30-Day Cam Plus Bundle includes the camera, a power adapter, micro USB cable, mounting kit, quick start guide, and a 30-day trial of Cam Plus, which unlocks advanced AI features like person and package detection, as well as color night vision.
What are the main differences between Wyze Cam Pan v3 and v2?The Wyze Cam Pan v3 offers a weatherproof IP65 rating for outdoor use, color night vision in the bundle version, improved mechanical design for quieter and smoother operation, updated firmware for better smart home compatibility, and enhanced durability compared to the v2, which is for indoor use only.
What accessories are available for the Wyze Cam Pan v3?Available accessories for the Wyze Cam Pan v3 include stylish vinyl skins by dBrand, replacement USB cables, and a Pan v3 + Lamp Socket v2 Bundle that allows you to power the camera through a lamp socket for flexible installation.
How fast can the Wyze Cam Pan v3 rotate?The Wyze Cam Pan v3 features a highly responsive motor capable of rotating up to 110° per second, ensuring smooth and fluid movement for comprehensive coverage.
What are the dimensions and mounting options for the Wyze Cam Pan v3?The Wyze Cam Pan v3 measures 124mm (H) x 60mm (W) x 63mm (D), weighs 11.29 oz (320 g), and features a matte black or white finish. It uses a standard 1/4" - 20 screw mount for versatile installation options.
What are the key features of the Wyze Cam Pan v3 that make it suitable for outdoor use?Can you explain how the two-way audio feature works on the Wyze Cam Pan v3?Do you have any ongoing sales or discounts for the Wyze Cam Pan v3?
