High Performance Camera with Pivoting Lens: Wyze Cam Pan v3
When it comes to securing open spaces with wide coverage, the
Wyze Cam Pan v3 stands out as a top-tier choice. Designed for both indoor and outdoor use, this camera offers a powerful combination of 360° horizontal pan and 180° vertical tilt, ensuring no blind spots in your surveillance area. Whether you want to monitor a large backyard, a parking lot, or an expansive indoor space, the Wyze Cam Pan v3 delivers exceptional performance with its pivoting lens technology.
360° Pan and 180° Tilt for Maximum Coverage
The Wyze Cam Pan v3 features a fully motorized lens that can rotate horizontally a full 360 degrees and tilt vertically up to 180 degrees. This extensive range allows you to cover wide open spaces without needing multiple cameras. The camera’s rotation speed reaches up to 110° per second, enabling quick repositioning to track movement or scan the environment efficiently.
- View Range: 360° horizontal, 180° vertical
- Field of View: 120° FOV
- Digital Zoom: 8x for detailed close-ups
- Mounting: Screw 1/4" - 20 for versatile installation
Robust Video Quality and Night Vision
Equipped with a 1/2.9" CMOS image sensor, the Wyze Cam Pan v3 captures crisp 1080p HD video at 20 frames per second during the day and 15 fps at night. The camera supports H.264 video encoding for smooth streaming and efficient storage.
For low-light conditions, it includes 4 infrared LEDs (850 nm) for clear black-and-white night vision, and the bundle version even offers
color night vision to enhance visibility after dark.
Weather Resistant for Outdoor Use
The Wyze Cam Pan v3 is built with an IP65 rating, making it fully weather resistant and suitable for outdoor environments. It can withstand rain, snow, and dust, ensuring reliable operation year-round. For outdoor installations, pairing it with the Wyze Outdoor Power Adapter (sold separately) is recommended to maintain safe and consistent power.
"Designed to brave the elements, the Wyze Cam Pan v3 keeps your property secure rain or shine."
Wyze Cam Pan v3 weather resistant outdoor camera
Smart Features and Connectivity
The camera integrates seamlessly with popular smart home ecosystems including Alexa, Google Assistant, and IFTTT, allowing voice control and automation. It connects via 2.4 GHz Wi-Fi (802.11 b/g/n) and supports microSD cards up to 256 GB for local storage.
Additional smart features include:
- Push notifications for motion and sound alerts
- Built-in speaker and microphone for two-way audio with noise and echo cancellation
- Compatibility with Android 9.0+ and iOS 15.0+ devices
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle
For users seeking an enhanced experience, the
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle offers the same high-performance camera with added benefits. This bundle includes a 30-day trial of Cam Plus, Wyze’s cloud service that unlocks advanced AI detection, longer event video storage, and person detection alerts.
Included in the bundle:
- Wyze Cam Pan v3 (Black or White)
- 6' micro USB cable
- Power adapter
- Mounting kit
- Quick start guide
This bundle is perfect for those who want to maximize their camera’s capabilities with cloud-based smart monitoring.
Audio and Communication
The Wyze Cam Pan v3 supports two-way audio, allowing you to listen and speak through the camera remotely. This feature is ideal for communicating with family members, pets, or even deterring intruders.
Two-way audio for real-time communication
Optional Accessories for Wyze Cam Pan v3
Wyze Cam Pan v3 Skins by dBrand
Customize and protect your camera with stylish vinyl skins available in Green Camo and Triple Black. These skins provide scratch resistance and a flawless fit, enhancing the camera’s appearance without compromising functionality.
Wyze Cam Pan v3 USB Cable
Keep your camera powered with a replacement USB cable designed specifically for the Pan v3, ensuring reliable connectivity and power supply.
Pan v3 + Lamp Socket v2 Bundle
This innovative bundle allows you to power your Wyze Cam Pan v3 through a lamp socket without needing a traditional outlet. Compatible with E26 sockets, it supports LED or CFL bulbs under 20W and is perfect for smart exterior lighting setups.
Why Choose Wyze Cam Pan v3 for Wide Coverage?
The Wyze Cam Pan v3 is engineered to deliver comprehensive surveillance with its pivoting lens and wide field of view. Its weather-resistant design, high-definition video quality, and smart home integration make it an ideal choice for monitoring open spaces effectively and affordably.
Product Summary
Feature | Wyze Cam Pan v3 |
Pan & Tilt Range | 360° horizontal, 180° vertical |
Video Resolution | 1080p Full HD |
Night Vision | 4 IR LEDs (850 nm), Color Night Vision (bundle) |
Weather Resistance | IP65 rated |
Audio | Two-way with noise & echo cancellation |
Connectivity | 2.4 GHz Wi-Fi (802.11 b/g/n) |
Storage | Up to 256 GB microSD |
Smart Home Integration | Alexa, Google Assistant, IFTTT |
Operating Temperature | -20°C to 50°C (-4°F to 122°F) |
Invest in the Wyze Cam Pan v3 to secure your open spaces with a high-performance camera that offers pivoting lens coverage, smart features, and durable outdoor readiness.
What is the Wyze Cam Pan v3 and what makes it unique?
The Wyze Cam Pan v3 is a high-performance security camera designed for both indoor and outdoor use. Its unique pivoting lens offers 360° horizontal pan and 180° vertical tilt, ensuring comprehensive coverage with no blind spots. This makes it ideal for monitoring large open spaces like backyards, parking lots, or expansive indoor areas.Does the Wyze Cam Pan v3 support outdoor installation?
Yes, the Wyze Cam Pan v3 is IP65 weather resistant, making it suitable for outdoor use. It can withstand rain, snow, and dust, ensuring reliable operation in various weather conditions. For outdoor installations, it is recommended to use the Wyze Outdoor Power Adapter (sold separately) for safe and consistent power.What is the video quality of the Wyze Cam Pan v3?
The Wyze Cam Pan v3 captures crisp 1080p Full HD video using a 1/2.9" CMOS image sensor. It records at 20 frames per second during the day and 15 fps at night, providing clear and detailed footage for effective surveillance.Does the Wyze Cam Pan v3 have night vision?
Yes, the Wyze Cam Pan v3 features 4 infrared LEDs (850 nm) for clear black-and-white night vision. The bundle version also offers color night vision, enhancing visibility in low-light conditions.What is the field of view and pan/tilt range of the Wyze Cam Pan v3?
The Wyze Cam Pan v3 offers a 120° field of view, with a 360° horizontal pan and 180° vertical tilt. This extensive range allows you to monitor wide areas without the need for multiple cameras.How fast can the Wyze Cam Pan v3 rotate?
The Wyze Cam Pan v3 can rotate at speeds up to 110° per second, allowing for quick repositioning to track movement or scan the environment efficiently.What smart home systems is the Wyze Cam Pan v3 compatible with?
The Wyze Cam Pan v3 integrates seamlessly with Alexa, Google Assistant, and IFTTT, enabling voice control and smart home automation.Does the Wyze Cam Pan v3 support local storage?
Yes, the Wyze Cam Pan v3 supports microSD cards up to 256 GB for local video storage, allowing you to record and review footage without a subscription.What are the audio features of the Wyze Cam Pan v3?
The Wyze Cam Pan v3 includes two-way audio with a built-in speaker and microphone, featuring noise and echo cancellation. This allows you to listen and speak through the camera remotely, making it ideal for communicating with family, pets, or deterring intruders.What is included in the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle?
The bundle includes the Wyze Cam Pan v3 (available in Black or White), a 6' micro USB cable, power adapter, mounting kit, and a quick start guide. It also comes with a 30-day trial of Cam Plus, which unlocks advanced AI detection, longer event video storage, and person detection alerts.What optional accessories are available for the Wyze Cam Pan v3?
Optional accessories include Wyze Cam Pan v3 Skins by dBrand (available in Green Camo and Triple Black), a replacement USB cable, and the Pan v3 + Lamp Socket v2 Bundle, which allows you to power the camera through a lamp socket for flexible installation.What are the connectivity requirements for the Wyze Cam Pan v3?
The Wyze Cam Pan v3 connects via 2.4 GHz Wi-Fi (802.11 b/g/n) and is compatible with Android 9.0+ and iOS 15.0+ devices.What is the operating temperature range for the Wyze Cam Pan v3?
The Wyze Cam Pan v3 operates in temperatures ranging from -20°C to 50°C (-4°F to 122°F), making it suitable for a wide variety of climates.Why should I choose the Wyze Cam Pan v3 for wide area surveillance?
The Wyze Cam Pan v3 is engineered for comprehensive surveillance with its pivoting lens, wide field of view, weather-resistant design, high-definition video quality, and smart home integration. It offers an affordable and effective solution for monitoring large open spaces.
