Wyze Cam Pan v3: Compact Rotating Camera for Discreet Corners
Discover the Wyze Cam Pan v3: Compact, Rotating, and Discreet
If you're searching for a compact rotating camera that fits discreetly in corners or on shelves, the Wyze Cam Pan v3 is your ideal choice. Designed for both indoor and outdoor use, this camera offers 360° horizontal pan and 180° vertical tilt, ensuring no blind spots in your surveillance. Its sleek, matte polycarbonate body with a small footprint (124mm x 60mm x 63mm) allows it to blend seamlessly into any room corner or shelf without drawing attention.
The Wyze Cam Pan v3 is engineered to be both powerful and subtle, making it perfect for discreet home or office monitoring.
Wyze Cam Pan v3 in snowy outdoor setting Weather-resistant Wyze Cam Pan v3 capturing outdoor moments
Key Features of Wyze Cam Pan v3
360° Pan and 180° Tilt for Full Coverage
The Wyze Cam Pan v3 boasts a 360° horizontal rotation and 180° vertical tilt, allowing you to monitor an entire room or outdoor area without blind spots. With a rotation speed of up to 110° per second, it can quickly track movement and keep your property secure.
Compact and Lightweight Design
Weighing just 11.29 oz (320 g) and featuring a circular base diameter of 1.69" (43mm), this camera fits discreetly on shelves, corners, or mounted on walls using a standard 1/4"-20 screw mount. Its compact size makes it easy to position in tight spaces.
High-Definition Video and Color Night Vision
Capture crystal-clear 1080p HD video with a 120° field of view. The camera uses a 1/2.9" CMOS image sensor and supports H.264 video encoding at 20 fps during the day and 15 fps at night. Four IR LEDs provide color night vision, ensuring you see vivid details even in low light.
Two-Way Audio with Noise Cancellation
Stay connected with built-in microphone and speaker featuring noise and echo cancellation. The 2-way audio lets you listen and speak through the camera remotely, perfect for interacting with family, pets, or deterring intruders.
Weather Resistant for Indoor and Outdoor Use
Rated IP65, the Wyze Cam Pan v3 is fully weather resistant, making it suitable for outdoor installation in covered areas. For outdoor use, pairing with the Wyze Outdoor Power Adapter (sold separately) is recommended to ensure safe and reliable power.
Smart Home Integration and Alerts
Compatible with Alexa, Google Assistant, and IFTTT, this camera fits effortlessly into your smart home ecosystem. Receive push notifications on your phone for motion alerts and customize your monitoring preferences via the Wyze app (supports Android 9.0+ and iOS 15.0+).
Enhance Your Setup with Wyze Cam Pan v3 Accessories
Wyze Cam Pan v3 Skins by dBrand
Personalize and protect your camera with stylish vinyl skins available in Green Camo or Triple Black. These precision-cut skins prevent scratches and add a unique look to your device, helping it blend even better into your environment.
Wyze Cam Pan v3 USB Cable
Keep your camera powered with a replacement USB cable designed specifically for the Pan v3. This affordable accessory ensures you never lose connectivity due to a damaged or misplaced cable.
Pan v3 + Lamp Socket v2 Bundle
Power your Wyze Cam Pan v3 without needing a traditional outlet by using the Lamp Socket v2. This innovative accessory fits into standard E26 lamp sockets, allowing you to install your camera in places where outlets are scarce, such as on shelves or corners near lamps.
Complete Home Security with the Essential Security Bundle
For those looking for a comprehensive security solution, the Essential Security Bundle includes the Wyze Cam Pan v3 alongside other advanced devices:
  • Wyze Video Doorbell v2: Crisp 1080p HD video and two-way audio for front door monitoring.
  • Wyze Lock Bolt: Smart lock with fingerprint sensor and backlit keypad for secure keyless entry.
  • Two Wyze Cam OG Cameras: Plug-in cameras with motion-activated spotlights and color night vision.
This bundle offers all-around protection with cloud and local recording, real-time alerts, and weather resistance, making it perfect for safeguarding your home from every angle.
Wyze Cam Pan v3 two-way audio lifestyle Stay connected with two-way audio, perfect for monitoring pets or communicating remotely
Why Choose Wyze Cam Pan v3 for Discreet Surveillance?
  • Compact size fits easily in corners or on shelves without being obtrusive.
  • 360° pan and 180° tilt cover large areas with a single camera.
  • Color night vision ensures clear images even in darkness.
  • Weather resistance allows flexible indoor/outdoor placement.
  • Smart integrations with Alexa, Google Assistant, and IFTTT.
  • Two-way audio for real-time communication.
  • Affordable price with optional bundles and accessories.
The Wyze Cam Pan v3 is the perfect blend of functionality, style, and discretion for anyone needing a reliable rotating camera that fits neatly into any space.
Product Specifications at a Glance
FeatureSpecification
Dimensions124mm (H) x 60mm (W) x 63mm (D)
Weight11.29 oz (320 g)
Video Resolution1920 x 1080 (1080p)
Frame Rate20 fps (day), 15 fps (night)
Field of View120° FOV
Pan/Tilt Range360° horizontal, 180° vertical
Night Vision4 IR LEDs, color night vision
AudioBuilt-in speaker & mic, 2-way audio
Connectivity802.11 b/g/n, 2.4 GHz Wi-Fi
StorageSupports up to 256 GB microSD
Weather ResistanceIP65
Operating Temperature-20°C to 50°C (-4°F to 122°F)
Warranty1 Year
Experience the perfect combination of discreet design, advanced pan-tilt technology, and smart home compatibility with the Wyze Cam Pan v3 — your go-to compact rotating camera for secure, unobtrusive monitoring.
FeatureWyze Cam Pan v3 + 30-Day Cam Plus BundleEssential Security Bundle
Included ProductsWyze Cam Pan v3 + 30-Day Cam Plus subscriptionWyze Video Doorbell v2, Wyze Lock Bolt, Wyze Cam Pan v3, 2× Wyze Cam OG
Camera Coverage360° pan, 180° tiltWyze Cam Pan v3: 360° pan, 180° tilt; Wyze Cam OG: fixed
Weather ResistanceIP65 (camera), requires Outdoor Power Adapter for outdoor useIP65 (Wyze Cam Pan v3 and Wyze Cam OG)
Motion TrackingAutomatic motion trackingWyze Cam Pan v3 automatic motion tracking
Night VisionColor Night Vision with Starlight SensorColor Night Vision (Wyze Cam Pan v3 and Wyze Cam OG)
Two-Way AudioYesYes (Wyze Cam Pan v3 and Wyze Video Doorbell v2)
Cloud Storage30-Day Cam Plus free trial, then $2.99/month/cam auto-renewNot specified (likely standard cloud/local storage)
NotificationsPerson, package, vehicle notifications with Cam PlusReal-time alerts, motion-activated voice deterrence
Additional Security FeaturesPrivacy Mode, Custom detection zones, Smoke & CO alertsSmart lock with fingerprint sensor and keypad, video doorbell with 2-way audio
Price$39.98$199.99 (compare at $224.90)
Return Policy30-day hassle-free returnsNot specified
Bundled Cameras Count1 camera3 cameras (1 Pan v3 + 2 Wyze Cam OG)
What is the Wyze Cam Pan v3 and what makes it unique?The Wyze Cam Pan v3 is a compact, rotating security camera designed for discreet indoor and outdoor surveillance. Its unique features include 360° horizontal pan, 180° vertical tilt, color night vision, weather resistance (IP65), and seamless smart home integration with Alexa, Google Assistant, and IFTTT.
Does the Wyze Cam Pan v3 support both indoor and outdoor use?Yes, the Wyze Cam Pan v3 is weather resistant with an IP65 rating, making it suitable for both indoor and outdoor installation. For outdoor use, it is recommended to pair the camera with the Wyze Outdoor Power Adapter (sold separately) for safe and reliable power.
What are the video quality and night vision capabilities of the Wyze Cam Pan v3?The Wyze Cam Pan v3 captures high-definition 1080p video with a 120° field of view. It features color night vision using four IR LEDs, allowing you to see vivid details even in low-light conditions.
How does the pan and tilt function work on the Wyze Cam Pan v3?The Wyze Cam Pan v3 offers 360° horizontal rotation and 180° vertical tilt, enabling full coverage of any room or outdoor area. It can rotate at speeds up to 110° per second, quickly tracking movement and eliminating blind spots.
Is the Wyze Cam Pan v3 easy to install and where can it be placed?Yes, the Wyze Cam Pan v3 is compact and lightweight, making it easy to install on shelves, in corners, or mounted on walls using a standard 1/4"-20 screw mount. Its discreet design allows it to blend seamlessly into any environment.
Does the Wyze Cam Pan v3 have two-way audio?Yes, the Wyze Cam Pan v3 features built-in two-way audio with noise and echo cancellation, allowing you to listen and speak through the camera remotely. This is ideal for communicating with family, pets, or deterring intruders.
What smart home platforms is the Wyze Cam Pan v3 compatible with?The Wyze Cam Pan v3 is compatible with Alexa, Google Assistant, and IFTTT, making it easy to integrate into your existing smart home ecosystem.
How do I receive alerts from the Wyze Cam Pan v3?You can receive push notifications for motion alerts directly to your smartphone via the Wyze app, which supports Android 9.0+ and iOS 15.0+ devices. You can also customize your monitoring preferences within the app.
What accessories are available for the Wyze Cam Pan v3?Accessories for the Wyze Cam Pan v3 include dBrand vinyl skins for personalization and protection, a replacement USB cable, and the Lamp Socket v2, which allows you to power the camera using a standard E26 lamp socket.
What is included in the Essential Security Bundle with the Wyze Cam Pan v3?The Essential Security Bundle includes the Wyze Cam Pan v3, Wyze Video Doorbell v2, Wyze Lock Bolt, and two Wyze Cam OG Cameras. This bundle provides comprehensive home security with features like HD video, two-way audio, smart lock access, and motion-activated spotlights.
What are the technical specifications of the Wyze Cam Pan v3?The Wyze Cam Pan v3 measures 124mm x 60mm x 63mm, weighs 11.29 oz (320 g), records 1080p video at 20 fps (day) and 15 fps (night), has a 120° field of view, supports up to 256 GB microSD storage, and operates in temperatures from -20°C to 50°C (-4°F to 122°F).
How can I power the Wyze Cam Pan v3 if there is no nearby outlet?You can use the Pan v3 + Lamp Socket v2 Bundle, which allows you to power the camera using a standard E26 lamp socket, making it easy to install the camera in locations without traditional power outlets.
Is the Wyze Cam Pan v3 suitable for discreet surveillance?Yes, the Wyze Cam Pan v3 is designed with a compact, matte polycarbonate body and a small footprint, making it ideal for discreet placement in corners or on shelves without drawing attention.
What warranty does the Wyze Cam Pan v3 come with?The Wyze Cam Pan v3 comes with a 1-year warranty, ensuring peace of mind with your purchase.
What are the dimensions of the Wyze Cam Pan v3?Can the Wyze Cam Pan v3 be used outdoors?Do you have any ongoing sales or discounts for the Wyze Cam Pan v3?
