How to Reset Wi-Fi and Optimize Your Network for Wyze Devices: Step-by-Step Guide for Seamless Smart Home Connectivity
Resetting your Wi-Fi connection and ensuring your network is properly configured is essential for seamless performance of Wyze smart home products. Whether you are troubleshooting connectivity issues or setting up a new device, understanding the right Wi-Fi settings and how to reset your network can save you time and frustration.
Understanding the Wi-Fi Requirements for Wyze Devices
Most Wyze devices require a 2.4 GHz Wi-Fi network with WPA/WPA2 security protocol to function correctly. This is because many Wyze cameras and smart devices are optimized for this frequency band, which offers better range and compatibility.
Key Points to Remember:
  • 2.4 GHz Band: Wyze devices primarily connect to 2.4 GHz networks. Dual-band routers broadcast both 2.4 GHz and 5 GHz networks, but Wyze devices (except a few models) do not support 5 GHz.
  • WPA/WPA2 Security: Your router must use WPA or WPA2 encryption. WEP is not supported due to security vulnerabilities.
  • SSID Naming: If you have multiple networks, look for network names with "2.4G," "24G," or "2.4" to identify the 2.4 GHz band. Avoid networks with "5G," "5g," or "5GHz" in the name when setting up Wyze devices.
  • Enterprise Networks: Wyze devices do not work with enterprise Wi-Fi networks that require additional sign-in portals or browser authentication (common in hotels or airports).
Ensuring your Wi-Fi network meets these requirements is the first step to a smooth Wyze device experience.
How to Reset Your Wi-Fi Connection for Wyze Devices
If your Wyze device is having trouble connecting or staying connected to Wi-Fi, performing a Wi-Fi reset can help.
General Wi-Fi Reset Steps:
1. Power Cycle Your Router: Unplug your router from power, wait 30 seconds, then plug it back in. 2. Forget and Reconnect: On your smartphone or tablet, forget the Wi-Fi network and reconnect to the 2.4 GHz network. 3. Reset the Device Wi-Fi:
  • For devices like the Wyze Air Purifier, press and hold specific buttons (e.g., Auto Mode and Fan Speed) until the Wi-Fi icon flashes.
  • For cameras and doorbells, follow device-specific reset instructions (usually involving holding a setup or reset button until a status light changes).
4. Re-setup the Device: Use the Wyze app to add the device again, ensuring you select the correct 2.4 GHz network and enter the password carefully.
Checking Your Wi-Fi Security Type
Knowing your Wi-Fi security type helps confirm compatibility with Wyze devices.
How to Check on Different Devices:
  • Android: Go to Settings > Wi-Fi > Tap your connected network > View security type.
  • Windows 10: Click Wi-Fi icon > Properties > Scroll to Security Type.
  • macOS: Hold Option key and click Wi-Fi icon in the menu bar to see security details.
  • iOS: No direct way; check via router settings or use a computer.
If your router uses WEP, you will need to change it to WPA or WPA2 via your router’s admin panel or contact your ISP for assistance.
Troubleshooting Common Wi-Fi Issues with Wyze Devices
Error Code 90 ("Device is offline")
  • Often caused by incorrect Wi-Fi settings or incompatible security protocols.
  • Try factory resetting the device and ensuring your router is set to 2.4 GHz with WPA/WPA2.
  • Reboot your router and reconnect the device.
QR Code Not Scanning During Setup
  • QR codes expire after 5 minutes; restart setup if needed.
  • Remove any screen glare or protective films.
  • Hold the phone steady and try scanning from different angles.
Device Not Connecting After Firmware Update
  • Power cycle the device and router.
  • Confirm Wi-Fi settings remain compatible.
  • Factory reset the device if problems persist.
Tips to Improve Wi-Fi Connectivity for Wyze Devices
  • Place your router centrally in your home to maximize coverage.
  • Avoid physical obstructions like thick walls or metal objects between your router and devices.
  • Use a mesh Wi-Fi system if you have a large home or multiple floors to ensure consistent 2.4 GHz coverage.
  • Keep your router firmware updated for security and performance improvements.
  • Limit the number of connected devices to reduce network congestion.
Resetting your Wi-Fi and ensuring your network meets Wyze’s requirements will help you enjoy uninterrupted smart home monitoring and control.
Summary
  • Wyze devices mostly require 2.4 GHz Wi-Fi with WPA/WPA2 security.
  • Reset Wi-Fi by power cycling your router and resetting your device’s Wi-Fi settings.
  • Check your Wi-Fi security type on your device or router.
  • Troubleshoot common issues like error code 90 by factory resetting and verifying network settings.
  • Optimize your home Wi-Fi setup for better device performance.
Family using smart home devices connected to Wi-Fi
By following these guidelines, you can reset your Wi-Fi effectively and maintain a reliable connection for all your Wyze smart devices.
What Wi-Fi requirements do Wyze devices need?Most Wyze devices require a 2.4 GHz Wi-Fi network with WPA or WPA2 security protocol. They do not support 5 GHz networks or WEP security. Make sure your router is set to 2.4 GHz and uses WPA/WPA2 encryption for optimal compatibility.
How do I reset my Wi-Fi connection for Wyze devices?To reset your Wi-Fi for Wyze devices, unplug your router for 30 seconds and plug it back in. On your phone or tablet, forget and reconnect to the 2.4 GHz network. Then, reset your Wyze device’s Wi-Fi by following the device-specific instructions, such as holding certain buttons until the Wi-Fi icon flashes. Finally, re-add the device in the Wyze app.
How can I check my Wi-Fi security type for Wyze device compatibility?On Android, go to Settings > Wi-Fi > Tap your connected network to view the security type. On Windows 10, click the Wi-Fi icon, select Properties, and scroll to Security Type. On macOS, hold the Option key and click the Wi-Fi icon in the menu bar. For iOS, check your router settings or use a computer. Wyze devices require WPA or WPA2 security.
Why won’t my Wyze device connect to Wi-Fi after a firmware update?If your Wyze device won’t connect after a firmware update, power cycle both the device and your router. Ensure your Wi-Fi settings are still compatible (2.4 GHz, WPA/WPA2). If issues persist, perform a factory reset on the device and set it up again in the Wyze app.
What should I do if I get Error Code 90 ('Device is offline') on my Wyze device?Error Code 90 usually means your device is offline due to incorrect Wi-Fi settings or incompatible security protocols. Try factory resetting the device, ensure your router is set to 2.4 GHz with WPA/WPA2, and reboot your router before reconnecting the device.
How do I fix Wyze device QR code scanning issues during setup?If the QR code won’t scan, restart the setup process as QR codes expire after 5 minutes. Remove any screen glare or protective films from your phone, and try scanning from different angles while holding your phone steady.
Can Wyze devices connect to enterprise or public Wi-Fi networks?No, Wyze devices do not support enterprise Wi-Fi networks that require additional sign-in portals or browser authentication, such as those found in hotels or airports. Use a standard home Wi-Fi network with WPA/WPA2 security.
How can I optimize my Wi-Fi network for better Wyze device performance?Place your router centrally in your home, avoid physical obstructions, use a mesh Wi-Fi system for large homes, keep your router firmware updated, and limit the number of connected devices to reduce network congestion. These steps help ensure strong and reliable connectivity for Wyze devices.
What should I do if my Wyze device is not connecting to Wi-Fi?First, check that you are connecting to a 2.4 GHz network with WPA/WPA2 security. Power cycle your router and the Wyze device, and try resetting the device’s Wi-Fi settings. If problems persist, factory reset the device and set it up again using the Wyze app.
Why is 2.4 GHz Wi-Fi required for most Wyze devices?Most Wyze devices are optimized for 2.4 GHz Wi-Fi because it offers better range and compatibility compared to 5 GHz. Only a few Wyze models support 5 GHz, so always use the 2.4 GHz band for setup and operation unless your device specifically states otherwise.
What are the specific steps to reset the Wi-Fi connection for my Wyze device?How can I check if my Wi-Fi security type is compatible with Wyze devices?What should I do if I encounter error code 90 with my Wyze device?
