Wyze Wi-Fi 6 Mesh Router: 1500 Sq Ft Fast Home Coverage
Wyze Wi-Fi 6 Mesh Router for 1500 Square Feet Coverage
When it comes to reliable, fast, and seamless Wi-Fi coverage for your home, the Wyze Wi-Fi 6 Mesh Router stands out as an excellent choice, especially for spaces up to 1500 square feet. Designed with the latest Wi-Fi 6 technology, this router ensures every corner of your home enjoys blazing internet speeds and stable connections for all your smart devices.
Powerful Coverage and Speed
The Wyze Wi-Fi 6 Mesh Router covers up to 1500 square feet per router, making it ideal for apartments, small homes, or specific zones within larger houses. It supports 50+ devices simultaneously, so you can connect your smartphones, laptops, smart TVs, and IoT devices without worrying about slowdowns.
  • Internet speeds up to 1 Gbps with AX3000 Wi-Fi bandwidth
  • Dual-band radio configuration: 2.4 GHz (ax 2x2) + 5 GHz (ax 2x2)
  • Wi-Fi data rates of 576 Mbps (2.4 GHz) and 2400 Mbps (5 GHz)
  • Four high-performance antennas for strong, consistent signals
  • Supports Wi-Fi 6 (802.11ax) and backward compatible with Wi-Fi 5, 4, and legacy standards
Modern Features for Smart Homes
This router is built for today’s connected lifestyle with features that enhance your home network experience:
  • Simple setup via Bluetooth Low Energy 5.1 provisioning technology
  • Wired backhaul support for stable mesh connections
  • Parental controls to manage internet access for family members
  • Robust wireless security with WPA3-PSK and WPA2-PSK encryption
  • Compact, matte white design that blends seamlessly into any home decor
What’s Included?
Each package contains:
  • 1-Pack Wyze Mesh Router
  • 3’ Category 6 Ethernet Cable
  • Power Adapter
  • Quick Start Guide
Wyze Wi-Fi 6 Mesh Router in Home Office Setup Experience fast, reliable Wi-Fi coverage with the Wyze Wi-Fi 6 Mesh Router in your home office.
Wyze Wi-Fi 6E Mesh Router Pro for Larger Coverage and Ultra-Fast Speeds
If your home exceeds 1500 square feet or you want the absolute latest in Wi-Fi technology, the Wyze Wi-Fi 6E Mesh Router Pro is the premium upgrade. It extends coverage up to 2000 square feet per router and supports over 75 devices, perfect for larger homes or tech-heavy environments.
Next-Level Speed and Bandwidth
The Mesh Router Pro leverages Wi-Fi 6E technology, unlocking the new 6 GHz band for less interference and faster speeds:
  • Maximum internet speeds up to 2.5 Gbps
  • Tri-band radio configuration: 2.4 GHz + 5 GHz + 6 GHz (ax 2x2 each)
  • Wi-Fi data rates: 576 Mbps (2.4 GHz), 2400 Mbps (5 GHz), and 2400 Mbps (6 GHz)
  • Six antennas per node for superior signal strength and range
  • AXE5400 Wi-Fi bandwidth for cutting-edge performance
Advanced Features for Seamless Connectivity
  • Wired backhaul for stable mesh networking
  • Parental controls and advanced security protocols (WPA3-PSK)
  • Bluetooth Low Energy 5.1 for easy provisioning
  • Multiple operation modes including Router and Bridge Mode
  • Sleek matte black finish that complements modern home aesthetics
Package Options
Available in 1-Pack or 2-Pack styles to customize your home coverage needs. Wyze Wi-Fi 6E Mesh Router Pro on Bookshelf The Wyze Wi-Fi 6E Mesh Router Pro blends into your home decor while delivering powerful Wi-Fi coverage.
Why Choose Wyze Mesh Routers for Your Home?
"Put dead spots in their graves" with Wyze Mesh Routers — designed to deliver fast, reliable Wi-Fi coverage tailored to your home size and device needs.
Both Wyze Mesh Router models offer:
  • Easy setup and management through the Wyze app
  • Support for a large number of devices without compromising speed
  • Parental controls to keep your family’s internet safe and manageable
  • Wired backhaul options for enhanced mesh stability
  • Compact, stylish designs that fit any home environment
Whether you need coverage for a cozy 1500 sq. ft. space or a larger 2000 sq. ft. area with the latest Wi-Fi 6E technology, Wyze has you covered with affordable, high-performance mesh routers.
Summary of Wyze Mesh Router Specs
FeatureWyze Wi-Fi 6 Mesh RouterWyze Wi-Fi 6E Mesh Router Pro
Coverage per RouterUp to 1500 sq. ft.Up to 2000 sq. ft.
Maximum SpeedUp to 1 GbpsUp to 2.5 Gbps
Devices Supported50+75+
Wi-Fi Bands2.4 GHz + 5 GHz2.4 GHz + 5 GHz + 6 GHz
Antennas46
CPUARM Cortex A53 Dual-Core 1 GHzARM Cortex A53 Dual-Core 1 GHz
SecurityWPA3-PSK, WPA2-PSKWPA3-PSK, WPA2-PSK
SetupBluetooth Low Energy 5.1Bluetooth Low Energy 5.1
ColorWhiteBlack
Optimize your home Wi-Fi experience with Wyze Mesh Routers — the perfect blend of speed, coverage, and smart home compatibility.
Wi-Fi TechnologyWi-Fi 6Wi-Fi 6E
Maximum Internet SpeedUp to 1 GbpsUp to 2.5 Gbps
Device CapacitySupports 50+ devicesSupports 75+ devices
Coverage per Router1500 square feet2000 square feet
Frequency Bands2.4 GHz and 5 GHz2.4 GHz, 5 GHz, and 6 GHz (uncongested)
Wired Backhaul SupportYesYes
Ethernet Ports22
Parental ControlsYesYes
SetupSimple setup with Wyze appSimple setup with Wyze app
Price (2 Pack)$99.99$167.99
Additional FeaturesOptimized antenna, stronger power amplifier, bigger processor with more memoryAccess to new 6 GHz band, premium components for future-proof performance
Network Control via AppYesYes
What is the coverage area of the Wyze Wi-Fi 6 Mesh Router?The Wyze Wi-Fi 6 Mesh Router covers up to 1500 square feet per router, making it ideal for apartments, small homes, or specific zones within larger houses.
How many devices can the Wyze Wi-Fi 6 Mesh Router support simultaneously?The Wyze Wi-Fi 6 Mesh Router supports over 50 devices at the same time, ensuring stable connections for all your smartphones, laptops, smart TVs, and IoT devices.
What are the maximum internet speeds supported by the Wyze Wi-Fi 6 Mesh Router?The Wyze Wi-Fi 6 Mesh Router supports internet speeds up to 1 Gbps with AX3000 Wi-Fi bandwidth, providing fast and reliable connectivity throughout your home.
Is the Wyze Wi-Fi 6 Mesh Router compatible with older Wi-Fi standards?Yes, the Wyze Wi-Fi 6 Mesh Router supports Wi-Fi 6 (802.11ax) and is backward compatible with Wi-Fi 5, Wi-Fi 4, and legacy Wi-Fi standards.
What security features does the Wyze Wi-Fi 6 Mesh Router offer?The Wyze Wi-Fi 6 Mesh Router provides robust wireless security with WPA3-PSK and WPA2-PSK encryption to keep your network safe.
How easy is it to set up the Wyze Wi-Fi 6 Mesh Router?The Wyze Wi-Fi 6 Mesh Router features a simple setup process using Bluetooth Low Energy 5.1 provisioning technology, making it easy to get your network up and running quickly.
Does the Wyze Wi-Fi 6 Mesh Router have parental controls?Yes, the Wyze Wi-Fi 6 Mesh Router includes parental controls, allowing you to manage internet access for family members and keep your home network safe.
What is included in the Wyze Wi-Fi 6 Mesh Router package?Each Wyze Wi-Fi 6 Mesh Router package includes one mesh router, a 3’ Category 6 Ethernet cable, a power adapter, and a quick start guide.
What is the difference between the Wyze Wi-Fi 6 Mesh Router and the Wyze Wi-Fi 6E Mesh Router Pro?The Wyze Wi-Fi 6 Mesh Router covers up to 1500 sq. ft. per router and supports 50+ devices with speeds up to 1 Gbps, while the Wyze Wi-Fi 6E Mesh Router Pro covers up to 2000 sq. ft. per router, supports 75+ devices, and offers speeds up to 2.5 Gbps with tri-band (2.4 GHz, 5 GHz, and 6 GHz) Wi-Fi 6E technology.
What are the key features of the Wyze Wi-Fi 6E Mesh Router Pro?The Wyze Wi-Fi 6E Mesh Router Pro features coverage up to 2000 sq. ft. per router, support for 75+ devices, maximum speeds up to 2.5 Gbps, tri-band Wi-Fi (2.4 GHz, 5 GHz, 6 GHz), six antennas per node, advanced security with WPA3-PSK, wired backhaul, and easy setup via Bluetooth Low Energy 5.1.
Can I use wired backhaul with Wyze Mesh Routers?Yes, both the Wyze Wi-Fi 6 Mesh Router and the Wyze Wi-Fi 6E Mesh Router Pro support wired backhaul for stable and reliable mesh networking.
Are Wyze Mesh Routers easy to manage?Yes, Wyze Mesh Routers are easy to set up and manage through the Wyze app, allowing you to control your network, set parental controls, and monitor connected devices.
What color options are available for Wyze Mesh Routers?The Wyze Wi-Fi 6 Mesh Router comes in a compact matte white design, while the Wyze Wi-Fi 6E Mesh Router Pro features a sleek matte black finish.
Which Wyze Mesh Router should I choose for my home?Choose the Wyze Wi-Fi 6 Mesh Router for coverage up to 1500 sq. ft. and 50+ devices, or the Wyze Wi-Fi 6E Mesh Router Pro for larger homes up to 2000 sq. ft., 75+ devices, and the latest Wi-Fi 6E technology for ultra-fast speeds.
What are the main features of the Wyze Wi-Fi 6 Mesh Router?How many devices can the Wyze Wi-Fi 6 Mesh Router support at the same time?Do you have any ongoing sales or discounts for the Wyze Wi-Fi 6 Mesh Router?
