Replace Air Purifier Filters for Pet Odors & Allergens | Wyze
Replace Air Purifier Filters That Trap Pet Odors and Allergens
If you're looking to replace your air purifier filter specifically to tackle pet odors and allergens, Wyze offers smart, effective solutions designed to keep your home’s air fresh and clean. Whether you have pets that bring in dander or you want to reduce allergens and unpleasant smells, the right filter can make a significant difference in your indoor air quality. Wyze provides both the air purifiers and replacement filters tailored to your needs, ensuring you breathe cleaner, healthier air every day.
Wyze Air Filter: Custom Filters for Pet Odors and Allergens
Tailored Filtration for Your Home Environment
The Wyze Air Filter is designed to customize your air purification experience. Unlike generic filters, Wyze lets you choose from specialized filter types to address specific air quality concerns, including pet odors and allergens. Filter Variants:
  • Allergen Filter (Standard)
  • Formaldehyde Filter (Premium)
  • Wildfire Filter (Special Use)
Key Features:
  • HEPA 12 and HEPA 13 options for superior particulate removal
  • Activated carbon layer to trap pet odors and volatile organic compounds (VOCs)
  • High TVOC removal efficiency (up to 98.9%)
  • Service life ranging from 4 to 12 months depending on filter type
  • Pre-filter included to capture larger particles and extend filter life
Dimensions & Weight
  • Size: 8.1" x 8.1" x 11.3" (205 mm x 205 mm x 286 mm)
  • Weight: 1.5 to 1.9 lbs depending on filter variant
This filter is perfect for those who want to specifically target pet-related allergens and odors while maintaining flexibility for other air quality needs.
Wyze Air Purifier: Powerful and Quiet Air Cleaning
Advanced Air Purification with Smart Features
The Wyze Air Purifier comes pre-installed with filters that effectively trap pet dander, odors, and allergens, making it an excellent choice for pet owners. Filter Options Included:
Performance Specs:
  • CADR (Clean Air Delivery Rate) up to 350 m³/h (206 CFM) for allergen filter
  • Whisper-quiet operation at just 21 decibels on the lowest setting
  • Effective coverage area of 450-550 ft², ideal for medium to large rooms
  • Laser particle sensor with 0.3-micron accuracy for real-time air quality monitoring
  • Smart controls with AQ alerts and compatibility with Google Home and Alexa
Physical Specs:
  • Dimensions: 9.5" x 9.4" x 18.5" (243 mm x 240 mm x 472 mm)
  • Weight: Approximately 8.75 to 9.32 lbs depending on filter type
Why Choose Wyze Air Purifier?
This purifier combines powerful filtration with smart home integration, making it easy to maintain fresh air free from pet odors and allergens. Its quiet operation ensures it won’t disturb your daily life or sleep. Man replacing air purifier filter in home Replacing your air purifier filter regularly keeps pet odors and allergens at bay.
Why Replace Your Air Purifier Filter Regularly?
Regular filter replacement is essential to maintain optimal air quality, especially in homes with pets. Filters that trap pet dander, hair, and odors can become clogged over time, reducing their effectiveness and potentially releasing trapped particles back into the air.
Wyze filters are designed with a service life of 4 to 12 months depending on usage and filter type, ensuring you always have fresh, clean air. The activated carbon layer in these filters is particularly effective at neutralizing pet odors, while the HEPA layers capture allergens and fine particles.
Summary: Best Filters for Pet Odors and Allergens
ProductFilter TypeKey BenefitsService LifeCADR (m³/h)
Wyze Air FilterAllergen, Formaldehyde, WildfireCustomizable, activated carbon, HEPA 12/134-12 months317-362
Wyze Air PurifierPre-installed Allergen FilterPowerful, quiet, smart controls6 monthsUp to 350
Both products are excellent choices for pet owners seeking to reduce odors and allergens effectively. The Wyze Air Filter offers flexibility for filter replacement, while the Wyze Air Purifier provides an all-in-one solution with smart features.
Enhance Your Home Air Quality Today
Investing in the right air purifier filter replacement is key to maintaining a healthy, odor-free home environment, especially if you have pets. Wyze’s filters and purifiers combine advanced HEPA filtration with activated carbon technology to trap pet odors and allergens efficiently. Make sure to replace your filters on schedule to enjoy the best air quality and a fresher living space. Lifestyle image of clean home environment Breathe easier with Wyze air purifier filters designed for pet owners.
FeatureWyze Air FilterWyze Air Purifier
Product TypeAir Filter AccessoriesConnected Home Air Purifier
Price Range$37.99 - $63.99$169.99 - $194.99
VariantsAllergen Filter (Standard), Formaldehyde Filter (Premium), Wildfire Filter (Special Use)Allergen Filter (Standard), Formaldehyde Filter (Premium), Wildfire Filter (Special Use) (Pre-installed)
Filter ComponentsAllergen: Pre-Filter + HEPA 13 + Granulated Carbon
Formaldehyde: Pre-Filter + True HEPA 12 + Granulated Carbon with Activated Manganese
Wildfire: Pre-Filter + True HEPA 12 + Chemically Modified Granulated Carbon
Same as Wyze Air Filter variants (filters pre-installed)
PurposeCustomize air filtration for specific needs (pet odors, allergens, germs, gases)Clears air with premium filters, smart controls, AQ alerts, laser particle detection
Air Cleaning CapacityN/A (filters only)350 CADR (cubic feet per minute), cycles 12,000 cubic feet/hour
Noise LevelN/A21 to 54 decibels (whisper-quiet, quieter than a purring kitten)
Smart FeaturesN/AAuto Mode, fan speed control, dimmable display, child lock, Alexa & Google Home compatible, app control with air quality monitoring
Sensor TechnologyN/ALaser particle sensor detecting particles down to 0.3 microns, 100 times per second
Filter ReplacementEasy 3-step replacementEasy filter replacement with handle
WarrantyNot specifiedNot specified
Return Policy30-day hassle-free returns30-day hassle-free returns
AvailabilityCurrently sold out or unavailableLow stock (43 left)
What makes Wyze air purifier filters effective for pet odors and allergens?Wyze air purifier filters are specifically designed with HEPA 12 or HEPA 13 filtration and an activated carbon layer. This combination efficiently traps pet dander, allergens, and neutralizes pet odors, ensuring cleaner and fresher air in your home.
Which Wyze air filter should I choose for pet odors and allergens?For pet odors and allergens, the Wyze Allergen Filter is recommended. It features HEPA filtration and an activated carbon layer to capture pet dander, hair, and neutralize unpleasant smells. Wyze also offers Formaldehyde and Wildfire filters for other specific air quality concerns.
How often should I replace my Wyze air purifier filter?Wyze air purifier filters should be replaced every 4 to 12 months, depending on the filter type and your usage. Regular replacement is essential to maintain optimal air quality, especially in homes with pets.
What are the benefits of using a Wyze air purifier in homes with pets?Wyze air purifiers are ideal for pet owners because they effectively trap pet dander, hair, and odors. They offer powerful filtration, quiet operation, real-time air quality monitoring, and smart home integration with Google Home and Alexa.
What is the coverage area of the Wyze Air Purifier?The Wyze Air Purifier covers an area of 450-550 square feet, making it suitable for medium to large rooms in your home.
How does the activated carbon layer in Wyze filters help with pet odors?The activated carbon layer in Wyze filters absorbs and neutralizes pet odors and volatile organic compounds (VOCs), ensuring your home smells fresh and clean.
What is the Clean Air Delivery Rate (CADR) of Wyze air purifiers?The Wyze Air Purifier offers a CADR of up to 350 m³/h (206 CFM) with the allergen filter, ensuring rapid and efficient air cleaning for pet owners.
Are Wyze air purifiers quiet enough for bedrooms or living rooms?Yes, Wyze air purifiers operate as quietly as 21 decibels on the lowest setting, making them ideal for use in bedrooms, living rooms, or any space where quiet operation is important.
Can I monitor air quality in real time with Wyze air purifiers?Yes, Wyze air purifiers feature a laser particle sensor with 0.3-micron accuracy, providing real-time air quality monitoring and alerts through smart controls.
Why is it important to replace air purifier filters regularly in homes with pets?Regular filter replacement prevents clogging from pet dander, hair, and odors, ensuring your air purifier continues to operate efficiently and maintains optimal indoor air quality.
What are the different filter variants available for the Wyze Air Filter?How often should I replace the air purifier filter for optimal performance?Are there any ongoing sales or discounts available for Wyze products?
