Refurbished Wyze Thermostat: Affordable Smart Home Installation
Refurbished Wyze Thermostat Installation for Cost-Effective Home Temperature Control
Looking to upgrade your home temperature control without breaking the bank? The Refurbished Wyze Thermostat offers a smart, budget-friendly solution that combines modern technology with easy installation. This page highlights the benefits, specs, and installation tips for the refurbished Wyze Thermostat, helping you achieve efficient heating and cooling while saving money.
Why Choose the Refurbished Wyze Thermostat?
The refurbished Wyze Thermostat is a like-new device that has been fully tested and guaranteed to work perfectly. It offers all the smart features of the original Wyze Thermostat but at a significantly reduced price, making it an excellent choice for cost-conscious homeowners.
Smart heating & cooling - simplified.
Enjoy the convenience of smart temperature control with a device that adapts to your lifestyle and preferences.
Key Benefits:
  • Affordable price: At $29.98, it’s a fraction of the cost of a new thermostat.
  • Fully tested: Certified to work like new with a 1-year warranty.
  • Eco-friendly: Comes with recyclable packaging and is mercury, arsenic, and PVC free.
  • Easy DIY installation: Designed for quick setup, even if you have no electrical experience.
  • Smart integrations: Works seamlessly with Alexa and Google Assistant for voice control.
Refurbished Wyze Thermostat Specifications
FeatureDetails
Dimensions (Thermostat)120mm (L) x 65mm (W) x 33mm (D)
Wall Cover Dimensions165mm (L) x 140mm (W)
WeightLess than 1 lb
DisplayIPS Display with 180º viewing angle
Power Source24VAC through C terminal (C-wire adapter included)
Power ConsumptionLess than 3.5VA
Operating Temperature32°F - 130°F (0°C - 55°C)
Operating Humidity5% - 95% RH (non-condensing)
ConnectivityBluetooth, 2.4GHz WiFi
Phone CompatibilityAndroid 9.0+, iOS 15.0+
IntegrationsAlexa, Google Assistant
Warranty1 Year
Included in the Box:
  • Wyze Thermostat x1
  • C-Wire Adapter x1
  • Back Panel x1
  • Mounting Plate x1
  • Wall Cover x1
  • Wall Screws and Anchors
  • Wire Label Sheets
  • Screw Drivers x2
  • Quick Start Guide
Easy Installation Guide for Refurbished Wyze Thermostat
Installing the refurbished Wyze Thermostat is straightforward and designed for DIY enthusiasts. The included C-wire adapter ensures compatibility with most HVAC systems, even if your home lacks a dedicated C-wire.
Installation Highlights:
  • Step-by-step Quick Start Guide: Included to walk you through the process.
  • No electrical experience needed: The kit comes with all necessary tools and labels.
  • Installation time: Typically under 30 minutes.
  • Safety first: If unsure, professional HVAC assistance is recommended.
“Wyze Thermostat sets the temperature based on where you are, automatically.”
The Auto Switch feature intelligently adjusts your home’s temperature for comfort and energy savings.
Enhance Your Smart Home Environment
Pair your Wyze Thermostat with other Wyze smart home products for a fully integrated experience. While the thermostat controls your heating and cooling, consider upgrading your home network for seamless connectivity.
Recommended Companion Product: Wyze Wi-Fi 6 Mesh Router Pro
Wyze Wi-Fi 6E Mesh Router Pro in a modern home setting Alt text: Modern living room with Wyze Wi-Fi 6E Mesh Router Pro providing seamless internet coverage
  • Blazing fast speeds: Up to 2.5 Gbps with Wi-Fi 6E technology.
  • Wide coverage: 2000 sq. ft. per router, supports 75+ devices.
  • Reliable connection: Eliminates dead spots for uninterrupted smart home control.
  • Easy setup: Bluetooth Low Energy provisioning and parental controls.
Wyze Thermostat Replacement Part Kit
For maintenance or unexpected repairs, the Wyze Thermostat Replacement Part Kit is available to keep your system running smoothly.
Kit Features:
  • Includes screws, cables, and other essential parts.
  • Hassle-free 30-day return policy.
  • Affordable at $19.99 to extend the life of your thermostat.
Final Thoughts: Cost-Effective Smart Temperature Control
The refurbished Wyze Thermostat is an excellent choice for homeowners seeking smart, reliable, and affordable temperature control. With easy installation, smart features like scheduling and Auto Switch, and compatibility with popular voice assistants, it offers great value without compromising on quality.
Save energy, reduce your bills, and enjoy a comfortable home environment with the Wyze Thermostat — now more accessible than ever with the refurbished option.
Feature(Refurbished) Wyze ThermostatWyze ThermostatWyze Thermostat Replacement Part Kit
TypeRefurbishedConnected HomeReplacement Parts
Price$29.98 (Regular $79.98)$79.98$19.99
Return PolicyFinal Sale, no returns30-day hassle-free returns30-day hassle-free returns
ConditionLike new, fully tested and guaranteedNewReplacement parts kit
Key FeaturesSmart heating & cooling, app control, voice assistant compatible, motion-sensing comfort mode, wireless setup, always-on display, DIY installationSmart heating & cooling, app control, voice assistant compatible, motion-sensing comfort mode, wireless setup, always-on display, DIY installationIncludes screws, cables, and more parts
WarrantyWyze decision (implied warranty)30-day returns, standard warranty30-day hassle-free returns
SchedulingYes, simple daily schedulingYes, simple daily schedulingN/A
Voice Assistant CompatibilityAlexa, Google AssistantAlexa, Google AssistantN/A
Room Sensors SupportSupports up to 6 Wyze Room SensorsSupports up to 6 Wyze Room SensorsN/A
Installation20-minute DIY guided by Wyze app20-minute DIY guided by Wyze appN/A
Energy Saving TipsYes, via Wyze appYes, via Wyze appN/A
AvailabilitySold outSold outAvailable
What is a refurbished Wyze Thermostat?A refurbished Wyze Thermostat is a like-new device that has been fully tested, certified to work perfectly, and comes at a significantly reduced price. It offers all the smart features of the original Wyze Thermostat, making it a cost-effective choice for home temperature control.
How much does the refurbished Wyze Thermostat cost?The refurbished Wyze Thermostat is available for $29.98, making it an affordable option for upgrading your home’s heating and cooling system.
Does the refurbished Wyze Thermostat come with a warranty?Yes, the refurbished Wyze Thermostat comes with a 1-year warranty, ensuring peace of mind and reliable performance.
What smart home integrations does the Wyze Thermostat support?The Wyze Thermostat works seamlessly with Alexa and Google Assistant, allowing you to control your home’s temperature using voice commands.
Is the refurbished Wyze Thermostat easy to install?Yes, the refurbished Wyze Thermostat is designed for easy DIY installation. It includes a step-by-step Quick Start Guide, all necessary tools, and a C-wire adapter for compatibility with most HVAC systems. Installation typically takes less than 30 minutes and does not require electrical experience.
What is included in the box with the refurbished Wyze Thermostat?The box includes: Wyze Thermostat, C-Wire Adapter, Back Panel, Mounting Plate, Wall Cover, Wall Screws and Anchors, Wire Label Sheets, two Screw Drivers, and a Quick Start Guide.
What are the key specifications of the refurbished Wyze Thermostat?Key specifications include: 120mm x 65mm x 33mm dimensions, less than 1 lb weight, IPS display with 180º viewing angle, 24VAC power source (C-wire adapter included), Bluetooth and 2.4GHz WiFi connectivity, compatibility with Android 9.0+ and iOS 15.0+, and a 1-year warranty.
Is the refurbished Wyze Thermostat eco-friendly?Yes, the refurbished Wyze Thermostat is eco-friendly. It comes in recyclable packaging and is free from mercury, arsenic, and PVC.
What is the Auto Switch feature on the Wyze Thermostat?The Auto Switch feature automatically adjusts your home’s temperature based on your location, providing comfort and energy savings by adapting to your lifestyle.
What should I do if my Wyze Thermostat needs maintenance or repair?If your Wyze Thermostat requires maintenance or repair, you can purchase the Wyze Thermostat Replacement Part Kit. It includes screws, cables, and other essential parts, and comes with a hassle-free 30-day return policy.
Can I use the Wyze Thermostat if my home doesn’t have a C-wire?Yes, the refurbished Wyze Thermostat includes a C-wire adapter, making it compatible with most HVAC systems even if your home lacks a dedicated C-wire.
How can I enhance my smart home experience with Wyze products?You can pair your Wyze Thermostat with other Wyze smart home products, such as the Wyze Wi-Fi 6 Mesh Router Pro, for seamless connectivity and a fully integrated smart home environment.
What are the key benefits of using the refurbished Wyze Thermostat?Can you explain the installation process for the refurbished Wyze Thermostat?What tools are included in the installation kit for the Wyze Thermostat?
