Affordable Refurbished Wyze Thermostat for Low Voltage Systems
Looking for an affordable, smart, and reliable thermostat compatible with low voltage systems? The Wyze Thermostat offers a simplified, smart heating and cooling solution designed to fit seamlessly into your home environment. Whether you're upgrading your current system or replacing an older thermostat, Wyze provides an eco-friendly, user-friendly option that integrates well with modern smart home setups.
Wyze Thermostat: Smart Heating & Cooling Simplified
Key Features and Specifications
  • Compatibility: Designed for low voltage systems, powered by 24VAC through the included C-wire adapter.
  • Smart Connectivity: Connects via Bluetooth and 2.4GHz WiFi, compatible with Android 9.0+ and iOS 15.0+ devices.
  • Voice Assistant Integration: Works with Alexa and Google Assistant for hands-free control.
  • Display: Features a crisp IPS display with a wide 180º viewing angle for easy readability.
  • Compact Design: Measures 120mm (L) x 65mm (W) x 33mm (D), weighing less than 1 lb, with a sleek black or white finish.
  • Energy Efficient: Consumes less than 3.5VA power, helping reduce your energy bills.
  • Eco-Friendly Packaging: Mercury-free, arsenic-free, PVC-free, and recyclable packaging.
  • Operating Range: Suitable for indoor use with operating temperatures from 32ºF to 130ºF (0ºC to 55ºC) and humidity tolerance of 5% to 95% RH (non-condensing).
  • Warranty: Comes with a 1-year warranty for peace of mind.
What’s Included
  • Wyze Thermostat unit
  • C-Wire Adapter for easy installation
  • Back Panel, Mounting Plate, Wall Cover, Screws, Anchors, Wire Labels, Screwdriver, and Quick Start Guide
The Wyze Thermostat is designed to simplify your home's heating and cooling control while saving energy and money.
Why Choose Wyze Thermostat for Low Voltage Systems?
Low voltage HVAC systems require thermostats that can handle 24VAC power sources efficiently. The Wyze Thermostat is specifically built for these systems, ensuring compatibility and easy installation with the included C-wire adapter. Its smart features allow you to control your home's temperature remotely, set schedules, and integrate with your existing smart home ecosystem without breaking the bank.
Enhance Your Smart Home with Wyze Connected Devices
While the Wyze Thermostat is a standout for affordable smart climate control, Wyze also offers a range of connected home products that complement your smart home setup:
Wyze Wi-Fi 6E Mesh Router Pro
  • Ultra-fast internet speeds up to 2.5 Gbps with the latest Wi-Fi 6E technology.
  • Supports 75+ devices and covers up to 2000 sq. ft. per router, eliminating dead zones.
  • Features simple setup, wired backhaul, and parental controls.
  • Perfect for smart homes with multiple connected devices, ensuring your thermostat and other smart devices stay online seamlessly.
Wyze Wi-Fi 6E Mesh Router Pro in a modern home setting Alt text: Lifestyle image of Wyze Wi-Fi 6E Mesh Router Pro providing seamless home internet coverage
Wyze Wi-Fi 6 Mesh Router
  • Provides internet speeds up to 1 Gbps with Wi-Fi 6 technology.
  • Supports 50+ devices and covers 1500 sq. ft. per router.
  • Includes wired backhaul and parental controls.
  • Ideal for smaller homes or apartments looking for reliable, fast Wi-Fi to support smart devices like the Wyze Thermostat.
Wyze Wi-Fi 6 Mesh Router on a home office desk Alt text: Lifestyle image of Wyze Wi-Fi 6 Mesh Router in a home office setup
Summary
If you want an affordable, refurbished smart thermostat that works perfectly with low voltage HVAC systems, the Wyze Thermostat is your best choice. It combines smart home integration, energy efficiency, and easy installation at a budget-friendly price. Pair it with Wyze’s advanced mesh routers to ensure your smart home devices stay connected and responsive.
Smart heating and cooling made simple, affordable, and efficient with Wyze.
FeatureWyze ThermostatWyze Wi-Fi 6E Mesh Router ProWyze Wi-Fi 6 Mesh Router
TypeConnected HomeConnected HomeHealth & Lifestyle / Connected Home
Price$79.98 (Sold out)$98.99 (1 Pack), $167.99 (2 Pack)$99.99 (2 Pack)
Internet SpeedN/AUp to 2.5 GbpsUp to 1 Gbps
Wi-Fi TechnologyWi-Fi enabledWi-Fi 6E (6 GHz band)Wi-Fi 6 (802.11ax)
Device SupportN/A75+ devices per router50+ devices per router
CoverageN/A2000 sq. ft. per router1500 sq. ft. per router
Key FeaturesSmart heating & cooling, voice control, remote app control, scheduling, energy saving tips, motion-sensing comfort mode with Wyze Room SensorLatest Wi-Fi 6E tech, 6 GHz band, wired backhaul, parental controls, network management via appWi-Fi 6 tech, wired backhaul, parental controls, network management via app
Setup20-minute DIY installation guided by appSimple plug-and-play setup with app guidanceSimple setup with app guidance
Voice Assistant IntegrationAlexa, Google AssistantN/AN/A
App ControlYesYesYes
Dimensions120mm x 65mm x 33mmNot specifiedNot specified
Power Source24VAC through C terminalDC power (12V 1A)DC power (12V 1A)
Warranty1 YearNot specifiedNot specified
Additional FeaturesAlways-on display, wireless setup, scheduling, energy-saving tipsNetwork health monitoring, device management, guest networkDedicated Wi-Fi and routing accelerators, multiple operation modes
CertificationsFCC, IC, California Proposition 65FCC, ICFCC, IC
What is the Wyze Thermostat and what systems is it compatible with?The Wyze Thermostat is a smart, affordable thermostat designed specifically for low voltage HVAC systems powered by 24VAC. It comes with a C-wire adapter for easy installation and is ideal for upgrading or replacing older thermostats in homes with low voltage setups.
Is the Wyze Thermostat compatible with smart home devices and voice assistants?Yes, the Wyze Thermostat integrates seamlessly with smart home ecosystems. It supports Bluetooth and 2.4GHz WiFi connectivity and works with both Alexa and Google Assistant for convenient hands-free control.
What are the key features of the Wyze Thermostat?Key features of the Wyze Thermostat include compatibility with low voltage systems, a crisp IPS display with a 180º viewing angle, energy efficiency (less than 3.5VA power consumption), eco-friendly packaging, compact design, and a 1-year warranty. It also supports remote control and scheduling via the Wyze app.
What is included with the purchase of a refurbished Wyze Thermostat?Each refurbished Wyze Thermostat package includes the thermostat unit, a C-wire adapter, back panel, mounting plate, wall cover, screws, anchors, wire labels, screwdriver, and a quick start guide for easy installation.
How does the Wyze Thermostat help save energy and reduce bills?The Wyze Thermostat is designed to be energy efficient, consuming less than 3.5VA of power. Its smart scheduling and remote control features allow you to optimize your heating and cooling, helping to reduce energy usage and lower your utility bills.
What is the operating temperature and humidity range for the Wyze Thermostat?The Wyze Thermostat is suitable for indoor use with an operating temperature range of 32ºF to 130ºF (0ºC to 55ºC) and can tolerate humidity levels from 5% to 95% RH (non-condensing).
Does the Wyze Thermostat come with a warranty?Yes, the Wyze Thermostat comes with a 1-year warranty, providing peace of mind for your smart home investment.
What are the benefits of pairing the Wyze Thermostat with Wyze Mesh Routers?Pairing the Wyze Thermostat with Wyze Wi-Fi 6E Mesh Router Pro or Wyze Wi-Fi 6 Mesh Router ensures fast, reliable internet connectivity for all your smart home devices. These routers support multiple devices, eliminate dead zones, and provide seamless coverage, keeping your thermostat and other smart devices online and responsive.
Is the Wyze Thermostat eco-friendly?Yes, the Wyze Thermostat features eco-friendly packaging that is mercury-free, arsenic-free, PVC-free, and fully recyclable, making it a sustainable choice for environmentally conscious homeowners.
What are the dimensions and design options for the Wyze Thermostat?The Wyze Thermostat has a compact design, measuring 120mm (L) x 65mm (W) x 33mm (D) and weighing less than 1 lb. It is available in a sleek black or white finish to complement any home décor.
What are the key features of the Wyze Thermostat for low voltage systems?How does the Wyze Thermostat integrate with smart home devices?Do you have any ongoing sales or discounts for the Wyze Thermostat?
