Refurbished Wyze Smart Thermostat for Forced Air HVAC Systems
Refurbished Wyze Smart Thermostat Compatible with Forced Air HVAC Systems
Looking for an affordable, reliable, and smart thermostat solution compatible with your forced air HVAC system? The (Refurbished) Wyze Thermostat offers a like-new smart heating and cooling experience at a fraction of the price. Fully tested and guaranteed to work, this refurbished model brings you all the benefits of Wyze’s smart climate control with energy-saving features and seamless integration.
Why Choose the Refurbished Wyze Thermostat?
Smart Heating & Cooling Simplified
The Wyze Thermostat is designed to make your home environment comfortable and energy-efficient. Whether you want to warm up your home before you arrive or keep your pets cozy while you're away, this thermostat has you covered.
  • Remote Control: Adjust your thermostat from anywhere in the world using the Wyze app.
  • Voice Assistant Compatibility: Works effortlessly with Alexa and Google Assistant for hands-free temperature control.
  • Energy Savings: Receive personalized energy-saving tips based on your usage history.
  • Motion-Sensing Comfort Mode: When paired with Wyze Room Sensors, it prioritizes rooms you’re using, eliminating hot and cold spots.
Easy Installation & Setup
Installing the Wyze Thermostat is a breeze with a guided 20-minute DIY process. The app walks you through every step, and the included C-wire adapter ensures compatibility with most forced air HVAC systems.
Features at a Glance
  • Wireless setup and control via 2.4GHz WiFi and Bluetooth
  • Always-on IPS display with a wide 180º viewing angle
  • Compatible with Android 9.0+ and iOS 15.0+
  • Eco-friendly materials and recyclable packaging
  • One-year warranty included
“Smart heating & cooling - simplified.”
Enhance Comfort with Wyze Room Sensors
Pair your Wyze Thermostat with Wyze Room Sensors to monitor and balance the temperature in multiple rooms. These sensors detect motion and temperature, allowing the thermostat to adjust heating or cooling only where needed, saving energy and improving comfort.
  • Place up to 6 sensors throughout your home
  • Monitor climate remotely via the Wyze app
  • Use motion detection to prioritize occupied rooms
Product Details
SpecificationDetails
Dimensions120mm (L) x 65mm (W) x 33mm (D)
WeightLess than 1 lb
Power Source24VAC through C terminal
Operating Temperature32°F - 130°F (0°C - 55°C)
ConnectivityBluetooth, 2.4GHz WiFi
Voice Assistant SupportAlexa, Google Assistant
Included in BoxThermostat, C-Wire Adapter, Mounting hardware, Quick Start Guide
Why Buy Refurbished?
Choosing the refurbished Wyze Thermostat means you get a fully tested, like-new product at a significantly reduced price. It’s a final sale item but backed by Wyze’s quality assurance, making it a smart choice for budget-conscious homeowners who want smart home convenience without compromise.
Visualize Smart Comfort in Your Home
Cozy living room with smart thermostat control Experience seamless smart home comfort with Wyze technology.
Summary
The (Refurbished) Wyze Thermostat is an excellent choice for anyone with a forced air HVAC system looking to upgrade to smart climate control without breaking the bank. With easy installation, remote control, voice assistant compatibility, and energy-saving features, it’s a smart investment for a comfortable, efficient home.
What is the (Refurbished) Wyze Smart Thermostat?The (Refurbished) Wyze Smart Thermostat is a like-new, fully tested smart thermostat compatible with most forced air HVAC systems. It offers smart heating and cooling features, remote control, voice assistant compatibility, and energy-saving benefits at a fraction of the price of a new unit.
Is the refurbished Wyze Thermostat compatible with my forced air HVAC system?Yes, the refurbished Wyze Thermostat is designed to work with most forced air HVAC systems. It includes a C-wire adapter to ensure broad compatibility and easy installation.
What are the main features of the Wyze Smart Thermostat?Key features include remote control via the Wyze app, voice assistant compatibility with Alexa and Google Assistant, personalized energy-saving tips, motion-sensing comfort mode (with Wyze Room Sensors), wireless setup, and an always-on IPS display.
How easy is it to install the Wyze Thermostat?The Wyze Thermostat is designed for easy DIY installation, with a guided 20-minute setup process through the Wyze app. All necessary hardware, including a C-wire adapter, is included in the box.
Can I control the Wyze Thermostat remotely?Yes, you can control the Wyze Thermostat from anywhere using the Wyze app on your smartphone, allowing you to adjust your home's temperature even when you're away.
Does the Wyze Thermostat work with Alexa or Google Assistant?Yes, the Wyze Thermostat is compatible with both Alexa and Google Assistant, enabling hands-free voice control of your home's temperature.
What are Wyze Room Sensors and how do they work with the thermostat?Wyze Room Sensors are optional accessories that monitor temperature and motion in up to six rooms. When paired with the thermostat, they help balance the temperature throughout your home by prioritizing occupied rooms, improving comfort and energy efficiency.
What is included in the box with the refurbished Wyze Thermostat?The box includes the Wyze Thermostat, a C-wire adapter, mounting hardware, and a quick start guide for easy installation.
What warranty is provided with the refurbished Wyze Thermostat?The refurbished Wyze Thermostat comes with a one-year warranty, ensuring peace of mind and reliable performance.
Why should I choose a refurbished Wyze Thermostat?Choosing a refurbished Wyze Thermostat allows you to enjoy all the benefits of smart climate control at a significantly reduced price. Each unit is fully tested, guaranteed to work, and backed by Wyze’s quality assurance, making it a cost-effective and eco-friendly choice.
What are the technical specifications of the Wyze Thermostat?The Wyze Thermostat measures 120mm x 65mm x 33mm, weighs less than 1 lb, operates on 24VAC through the C terminal, supports Bluetooth and 2.4GHz WiFi connectivity, and is compatible with Android 9.0+ and iOS 15.0+ devices.
Is the refurbished Wyze Thermostat eco-friendly?Yes, the Wyze Thermostat is made from eco-friendly materials and comes in recyclable packaging, making it a sustainable choice for your smart home.
What are the energy-saving features of the refurbished Wyze Thermostat?How does the Wyze Thermostat integrate with voice assistants like Alexa and Google Assistant?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Thermostat?
