Wyze Cam v4 Trio Bundle: Affordable Indoor & Outdoor Security
Buy Affordable Wyze Cam v4 Trio Bundle for Advanced Indoor and Outdoor Security
Looking for a reliable, affordable, and advanced security solution for your home? The Wyze Cam v4 trio bundle offers the perfect combination of indoor and outdoor surveillance with cutting-edge features, crystal-clear video quality, and smart home compatibility. Whether you want to monitor your living room, backyard, or front porch, this bundle covers all your security needs with ease and style.
Wyze Cam v4: The Core of Your Security Setup
Premium Features at an Affordable Price
The Wyze Cam v4 is designed with a polycarbonate body and a combination of glass and plastic lenses, delivering a robust and sleek camera that fits seamlessly into any home environment. Priced at just $100, this camera is a great value, especially considering it supports American manufacturing initiatives.
Crystal-Clear 2.5K QHD Video Resolution
Enjoy ultra-high-definition video with 2560x1440 resolution, ensuring every detail is captured with clarity. The camera’s CMOS Starlight Sensor enhances low-light performance, while the wide dynamic range (WDR) balances bright and dark areas for perfect image quality day or night.
Advanced Night Vision & Spotlight
Wyze Cam v4 features 4 IR LEDs and 2 white spotlight LEDs (72 lumens) for enhanced color night vision, allowing you to see vibrant colors even in the dark. The motion-activated spotlight adds an extra layer of security by illuminating suspicious activity instantly.
Flexible Mounting & Weather Resistance
Mount your camera anywhere with multiple options including stand, wall mount, ceiling mount, or magnetic adhesive mount. Rated IP65 for weather resistance, it’s suitable for both indoor and outdoor use, operating reliably in temperatures from -4ºF to 122ºF (-20ºC to 50ºC).
Smart Home Integration & Connectivity
Compatible with Alexa, Google Assistant, and IFTTT, the Wyze Cam v4 integrates smoothly into your smart home ecosystem. It supports Wi-Fi 6 and Bluetooth 5.2 for fast, stable connections and offers simultaneous two-way talk with noise and echo cancellation.
Wyze Cam v4 Outdoor Bundle: Enhanced Outdoor Security
Outdoor Security with Wyze Cam v4 Experience vibrant, clear outdoor security day and night.
What’s Included?
  • Wyze Cam v4 camera
  • Wyze Outdoor Power Adapter for reliable wired power
  • 128GB Wyze MicroSD Card for 24/7 local recording
Key Outdoor Features
  • Enhanced Color Night Vision: See true-to-life colors even in low light.
  • Motion-Activated Spotlight: Automatically lights up when motion is detected.
  • Wide Dynamic Range (WDR): Captures balanced images in challenging lighting.
  • Motion & Sound Detection: Customize detection zones and receive alerts.
  • Smoke & CO Alerts: Integrated safety notifications for your home.
Durable & Weatherproof
Designed specifically for outdoor use, this bundle’s camera is IP65 rated and built to withstand harsh weather conditions, ensuring continuous protection for your property.
Wyze Cam v4 Home Security Bundle: Complete Indoor & Outdoor Protection
All-in-One Security Solution
Priced at $169.99, this bundle combines multiple Wyze Cam v4 units with accessories to provide comprehensive coverage for your entire home.
Features Overview
  • 2.5K QHD video with enhanced color night vision
  • Motion-activated spotlight and person detection for precise alerts
  • Improved 2-way audio for clear communication
  • Supports indoor and outdoor use with IP65 weather resistance
  • Includes a 128GB Class 10 UHS-3 microSD card for extensive local storage (~192 hours of HD video)
  • Multiple mounting options for versatile installation
Ideal for Smart Home Enthusiasts
This bundle supports Alexa and Google Assistant, making it easy to control and monitor your cameras via voice commands or mobile app.
Why Choose the Wyze Cam v4 Trio Bundle?
"Affordable, reliable, and packed with advanced features, the Wyze Cam v4 trio bundle is the ultimate choice for homeowners seeking seamless indoor and outdoor security."
  • Affordable Pricing: Get premium 2.5K QHD cameras without breaking the bank.
  • Versatile Use: Perfect for indoor rooms, outdoor yards, and entryways.
  • Smart Features: Motion detection, color night vision, two-way talk, and smart assistant compatibility.
  • Robust Build: Weather-resistant and durable for all environments.
  • Local & Cloud Storage: Flexible options to keep your footage safe and accessible.
Summary of Wyze Cam v4 Trio Bundle Specs
FeatureWyze Cam v4 (Indoor/Outdoor)Outdoor Bundle Add-onsHome Security Bundle Extras
Video Resolution2.5K QHD (2560x1440)SameSame
Night Vision4 IR LEDs + 2 white spotlight LEDs (color)Enhanced Color Night VisionEnhanced Color Night Vision
Field of ViewDFOV 115.8°, HFOV 98.5°, VFOV 53.1°SameSame
Audio99dB waterproof speaker, 2-way talkSameImproved 2-way audio
StoragemicroSD up to 512GB, cloud subscription option128GB microSD included128GB Class 10 UHS-3 microSD included
PowerIndoor USB power adapter (outdoor adapter sold separately)Outdoor power adapter includedIncluded
Weather ResistanceIP65IP65IP65
Smart Home IntegrationAlexa, Google Assistant, IFTTTAlexa, Google AssistantAlexa, Google Assistant
Price$100 (single), $35.98 (with 32GB microSD)$69.99$169.99
Enhance Your Home Security Today
Invest in the Wyze Cam v4 trio bundle to secure your home with advanced technology, vibrant video quality, and smart home convenience—all at an affordable price. Whether you want to monitor your indoor spaces or keep an eye on your outdoor surroundings, Wyze Cam v4 offers unmatched value and performance. Indoor Family Security Protect your loved ones with clear indoor monitoring.
Final Thoughts
The Wyze Cam v4 trio bundle is the perfect choice for anyone seeking a comprehensive, affordable, and technologically advanced security system. With its American-made promise, superior video quality, and versatile mounting options, it’s designed to keep your home safe and secure 24/7.
FeatureWyze Cam v4Wyze Cam v4 Outdoor BundleWyze Cam v4 Home Security Bundle
Price$100.00$69.99$169.99
Resolution2.5K QHD (2560x1440)2.5K QHD (2560x1440)2.5K QHD (2560x1440)
Color Night VisionYesYesYes
Night Vision LEDs4 IR LEDs (850 nm) + 2 white spotlight LEDs (72 lumens)Same as Wyze Cam v4Same as Wyze Cam v4
Motion-Activated SpotlightYesYesYes
Siren99 dBIncluded (via camera)Included (via camera)
AudioEnhanced Two-Way Talk, 99 dB speakerSame as Wyze Cam v4Improved 2-way audio
Wi-Fi Support2.4 GHz Wi-Fi, Wi-Fi 6Wi-Fi 6Wi-Fi 6
Continuous Local RecordingmicroSD card up to 512 GB (sold separately)128GB microSD Card included128GB microSD Card included
Outdoor Power AdapterSold separatelyIncludedIncluded
Mounting OptionsStand, Wall mount, Ceiling mount, Magnetic wall mount (adhesive)Same as Wyze Cam v4Same as Wyze Cam v4
Field of View (FOV)DFOV 115.8°, HFOV 98.5°, VFOV 53.1°Same as Wyze Cam v4Same as Wyze Cam v4
Motion & Sound DetectionYesYesYes
Motion Detection ZonesYesYesYes
Smoke & CO AlertsYesYesYes
AI Auto-Zoom & Smart FocusYesYesYes
Bluetooth Version5.2Not specifiedNot specified
Video FPSDaytime 20 FPS / Nighttime 15 FPSSame as Wyze Cam v4Daytime 20 FPS / Nighttime 15 FPS
Video EncodingH.264H.264H.264
Dimensions2in x 2in x 2 3/8inSame as Wyze Cam v4Same as Wyze Cam v4
Weight0.49 lb (222 g)Same as Wyze Cam v4Same as Wyze Cam v4
Warranty1 Year1 Year1 Year
Included ItemsCamera onlyCamera, Outdoor Power Adapter, 128GB microSD CardCamera, 128GB microSD Card, Outdoor Power Adapter
Compatibility with Smart AssistantsAlexa, Google Assistant, IFTTTAlexa, Google AssistantAlexa, Google Assistant
What is included in the Wyze Cam v4 Trio Bundle?The Wyze Cam v4 Trio Bundle includes multiple Wyze Cam v4 cameras, a Wyze Outdoor Power Adapter for reliable wired power, and a 128GB Wyze MicroSD Card for 24/7 local recording. This bundle is designed to provide comprehensive indoor and outdoor security coverage for your home.
What video quality does the Wyze Cam v4 offer?The Wyze Cam v4 features 2.5K QHD video resolution (2560x1440), delivering ultra-high-definition footage with crystal-clear detail. It also includes a CMOS Starlight Sensor and Wide Dynamic Range (WDR) for enhanced image quality in both bright and low-light conditions.
Is the Wyze Cam v4 suitable for both indoor and outdoor use?Yes, the Wyze Cam v4 is IP65 weather-resistant, making it suitable for both indoor and outdoor environments. It operates reliably in temperatures ranging from -4ºF to 122ºF (-20ºC to 50ºC), ensuring year-round protection.
Does the Wyze Cam v4 have night vision capabilities?Absolutely. The Wyze Cam v4 is equipped with 4 IR LEDs and 2 white spotlight LEDs (72 lumens) for enhanced color night vision. This allows you to see vibrant, true-to-life colors even in complete darkness.
What smart home systems are compatible with Wyze Cam v4?The Wyze Cam v4 integrates seamlessly with Alexa, Google Assistant, and IFTTT, allowing you to control and monitor your cameras using voice commands or through your smart home ecosystem.
How is the Wyze Cam v4 mounted?The Wyze Cam v4 offers flexible mounting options, including stand, wall mount, ceiling mount, or magnetic adhesive mount. This versatility allows you to install the camera wherever you need it most.
What storage options are available for Wyze Cam v4 recordings?The Wyze Cam v4 supports microSD cards up to 512GB for local storage and also offers cloud subscription options. The bundle includes a 128GB Class 10 UHS-3 microSD card, capable of storing approximately 192 hours of HD video.
Does the Wyze Cam v4 support two-way audio?Yes, the Wyze Cam v4 features improved two-way audio with noise and echo cancellation, allowing you to communicate clearly with anyone near the camera.
What advanced security features does the Wyze Cam v4 offer?The Wyze Cam v4 includes motion and sound detection with customizable detection zones, motion-activated spotlight, person detection for precise alerts, and integrated smoke and CO alert notifications for enhanced safety.
How much does the Wyze Cam v4 Trio Bundle cost?The Wyze Cam v4 Trio Bundle is priced at $169.99, offering a cost-effective solution for advanced indoor and outdoor home security.
Is the Wyze Cam v4 made in the USA?The Wyze Cam v4 is designed to support American manufacturing initiatives, ensuring a robust and reliable product.
What makes the Wyze Cam v4 Trio Bundle a good value?The Wyze Cam v4 Trio Bundle offers premium 2.5K QHD video, advanced night vision, smart home integration, weather resistance, and flexible storage options—all at an affordable price, making it an excellent value for comprehensive home security.
What are the key features of the Wyze Cam v4?How does the night vision feature work on the Wyze Cam v4?Can the Wyze Cam v4 be used in extreme weather conditions?
