Refurbished Battery-Powered HD Video Doorbells: Quick Install
Refurbished Battery Powered HD Video Doorbell with Quick Installation
Looking for a reliable, refurbished battery-powered HD video doorbell that offers quick installation and advanced security features? Discover Wyze’s lineup of smart home security devices designed to keep your front porch safe and connected with ease. This guide highlights the best Wyze products tailored to your needs, focusing on battery-powered options with high-definition video and simple setup.
Wyze Video Doorbell v2: Wired with Crisp 2K Video Quality
While not battery-powered, the Wyze Video Doorbell v2 is a top-tier wired video doorbell offering exceptional 2K (2048 x 1536) resolution for crystal-clear video footage. It features:
  • 2K HD Video & Local Storage: Capture every detail with 2K resolution and save footage locally on microSD cards up to 256GB.
  • Two-Way Audio & Voice Deterrence: Communicate with visitors or deter unwanted guests with motion-activated voice alerts.
  • Wide Field of View: A broad 166.8° diagonal view ensures you don’t miss any activity.
  • Weather Resistant: IP65 rating means it withstands rain, snow, and dust.
  • Quick Installation Kit Included: Comes with a wedge kit for angled door frames and all necessary mounting hardware for a fast setup.
Though wired, this doorbell is a great option if you want high-definition video and reliable power without worrying about battery life.
Installation Made Easy with the Wyze Video Doorbell v2 Wedge Kit
For homes with angled door frames or porches with stairs, the Wyze Video Doorbell v2 Wedge Kit is the perfect accessory. It allows you to adjust the doorbell’s viewing angle horizontally and vertically, eliminating blind spots and enhancing security coverage.
  • Includes a 15° horizontal bracket and two 7.5° vertical brackets.
  • Quick installation with included screws and a simple guide.
  • Weather-resistant and designed specifically for the Doorbell v2.
Wyze Battery Cam Pro: True Battery-Powered Wireless Security
If you want a battery-powered HD video doorbell alternative, the Wyze Battery Cam Pro is an excellent choice. Though technically a battery-powered security camera, it offers features that make it ideal for doorbell use:
  • 2.5K HDR Video Resolution: Higher than standard HD, providing sharp, detailed images.
  • Wire-Free & Battery Powered: Removable rechargeable 6200mAh battery packs last up to 6 months on a single charge.
  • Integrated Spotlight & Siren: Built-in spotlight and 100 dB siren enhance security and deter intruders.
  • Radar + PIR Motion Detection: Advanced motion sensing reduces false alerts.
  • IP65 Weatherproof: Durable for all weather conditions.
  • Dual-Band WiFi Support: Connects to both 2.4 GHz and 5 GHz networks for stable streaming.
  • Two-Way Audio: Talk to visitors or delivery personnel remotely.
This camera’s wireless design and long battery life make it a flexible and powerful option for those seeking a battery-powered video doorbell experience without wiring.
Wyze Bulb Cam: 2-in-1 Battery Alternative with Lighting and Security
For a unique approach to battery-powered security, the Wyze Bulb Cam combines a smart LED light bulb with a 2K HD security camera:
  • 2K HD Video with Color Night Vision: See visitors clearly day and night with vibrant color video.
  • Easy Installation: Screws into any standard E26 light socket—no wiring needed.
  • Motion-Activated Light & Alerts: Lights up your porch automatically and sends instant motion notifications.
  • Local and Cloud Storage: Supports microSD cards up to 256GB and optional cloud storage.
  • Weather Resistant: IP65 rating for outdoor use.
  • Two-Way Audio & Siren: Communicate and deter intruders with built-in speaker and microphone.
This product is perfect if you want a discreet, battery-alternative video doorbell that also brightens your porch. Wyze Bulb Cam Outdoor Installation Wyze Bulb Cam installed in outdoor light fixture for security and illumination
Why Choose Refurbished Wyze Battery-Powered Doorbells?
Refurbished Wyze products offer a cost-effective way to secure your home with trusted technology, backed by warranties and quality checks. Battery-powered models provide flexibility in installation, eliminating the need for complex wiring and allowing placement anywhere with WiFi coverage.
Wyze’s battery-powered cameras and doorbells are designed for quick setup, long battery life, and seamless integration with smart home assistants like Alexa and Google Assistant.
Summary of Key Features for Quick Installation and HD Video
ProductPower SourceVideo ResolutionInstallation TypeWeather ResistanceSpecial Features
Wyze Video Doorbell v2Wired (16V-24V AC)2K (2048x1536)Wired, with wedge kitIP65Two-way audio, voice deterrence, local storage
Wyze Battery Cam ProRechargeable Battery (6200mAh)2.5K (2560x1440)Wireless, battery poweredIP65Spotlight, siren, radar motion detection
Wyze Bulb CamStandard E26 Socket (120V AC)2K (2304x1296)Screw-in bulb socketIP65Color night vision, motion-activated light
Enhance Your Home Security Today
Choose the Wyze product that fits your lifestyle and installation preferences. Whether you want a wired doorbell with crystal-clear 2K video or a flexible battery-powered camera with quick installation, Wyze offers smart, affordable solutions to keep your home safe and connected. Wyze Bulb Cam Night Security Wyze Bulb Cam providing security and lighting during nighttime with motion detection
FeatureWyze Video Doorbell v2Wyze Battery Cam ProWyze Video Doorbell v2 Wedge Kit
TypeWired Video DoorbellWireless Battery CameraAccessory (Mounting Wedge Kit)
Video Resolution2K (2048 x 1536)2.5K HDR (2560 x 1440)N/A
Field of View135° horizontal, 103° vertical, 166.8° diagonal134° diagonal, 108° horizontal, 56° verticalN/A
Local StoragemicroSD card slot (up to 256GB)microSD card support (up to 256GB)N/A
Cloud StorageOptional with Cam Plus subscriptionOptional with Cam Plus subscriptionN/A
Two-Way AudioYesYesN/A
Motion DetectionYes, with motion-activated voice deterrence*Radar + PIR motion detectionN/A
Night VisionColor Night Vision with Starlight SensorColor Night Vision with 2 IR LEDs + 2 White LEDsN/A
Weather ResistanceIP65IP65Weather resistant
Power SourceWired (16V-24V AC)Removable, rechargeable battery packs (6200mAh)N/A
Battery LifeN/A (wired)Up to 6 months per chargeN/A
MountingIncludes chime controller, works with existing chimeFlexible mounting options, includes wall mountIncludes 15° horizontal bracket, 2x 7.5° vertical brackets
Special FeaturesPre-roll motion recording (3-6 seconds), works with Alexa & Google HomeIntegrated spotlight & siren, dual-band WiFi, bird detection (with Cam Plus)Adjusts viewing angle for Doorbell v2 only
Dimensions4.3in x 1.7in x 0.9in (110mm x 44mm x 24mm)2.5 x 1.8 x 3.5 inchesN/A
WeightNot specified0.94 lbsN/A
Color OptionsBlackBlack, WhiteBlack
Price (approximate)$44.98 (Doorbell + Chime Controller)$89.98 (1 Pack)$8.99 (Wedge Kit Only), $51.97 (Doorbell + Wedge Kit)
Warranty1 YearNot specified1 Year
InstallationWired installation, quick setupWire-free, Bluetooth setupQuick installation
Compatible WithWired doorbell systemWireless, no hub requiredWyze Video Doorbell v2 only
*Motion-activated voice deterrence requires Cam Plus or Cam Protect subscription.
What are the benefits of choosing a refurbished battery-powered HD video doorbell from Wyze?Refurbished Wyze battery-powered HD video doorbells offer a cost-effective way to secure your home with advanced technology. These products undergo quality checks and are backed by warranties, ensuring reliability. Battery-powered models provide flexible installation without the need for wiring, allowing you to place them anywhere with WiFi coverage.
Which Wyze product is best for a true battery-powered video doorbell experience?The Wyze Battery Cam Pro is the best option for a true battery-powered video doorbell experience. It features 2.5K HDR video resolution, a removable rechargeable battery lasting up to 6 months, wire-free installation, integrated spotlight and siren, advanced motion detection, and weatherproof design.
Can I use the Wyze Video Doorbell v2 as a battery-powered doorbell?No, the Wyze Video Doorbell v2 is a wired device and requires a 16V-24V AC power source. However, it offers exceptional 2K video quality, two-way audio, voice deterrence, and comes with a quick installation kit, making it a great choice if you have existing doorbell wiring.
How easy is it to install Wyze battery-powered security cameras and doorbells?Wyze battery-powered security cameras and doorbells are designed for quick and simple installation. The Wyze Battery Cam Pro is completely wire-free and can be mounted anywhere with WiFi access. The Wyze Bulb Cam screws into any standard E26 light socket, requiring no wiring at all.
What is the Wyze Bulb Cam and how does it work as a video doorbell alternative?The Wyze Bulb Cam is a 2-in-1 smart LED light bulb and 2K HD security camera. It screws into a standard E26 light socket, providing both illumination and security. With color night vision, motion-activated lighting, two-way audio, and weather resistance, it serves as a discreet alternative to traditional video doorbells.
Are Wyze battery-powered security devices weather resistant?Yes, Wyze battery-powered security devices like the Battery Cam Pro and Bulb Cam are IP65 weather resistant, making them suitable for outdoor use in rain, snow, and dust.
What storage options are available for Wyze video doorbells and cameras?Wyze video doorbells and cameras support local storage via microSD cards up to 256GB, allowing you to save footage directly on the device. Additionally, optional cloud storage is available for added convenience and backup.
Do Wyze battery-powered cameras and doorbells support smart home integration?Yes, Wyze battery-powered cameras and doorbells seamlessly integrate with smart home assistants like Amazon Alexa and Google Assistant, enabling voice control and smart automation.
What special features do Wyze battery-powered security devices offer?Wyze battery-powered security devices offer features such as high-definition video (up to 2.5K), two-way audio, integrated spotlights and sirens, radar and PIR motion detection, color night vision, and motion-activated lighting for enhanced security and convenience.
What is included with the Wyze Video Doorbell v2 for installation?The Wyze Video Doorbell v2 comes with a quick installation kit, including a wedge kit for angled door frames, all necessary mounting hardware, and a simple installation guide to ensure a fast and easy setup.
What are the key features of the Wyze Battery Cam Pro?Can you tell me more about the Wyze Bulb Cam and its installation process?Do you have any ongoing sales or discounts for the Wyze products?
