Refurbished Secure Entry Video Doorbell Pro Kit with Extended Battery Life
Enhance your home security with the latest refurbished secure entry video doorbell kits that combine advanced features, extended battery life, and seamless smart home integration. Whether you want wired or wireless options, crystal-clear video, or smart detection alerts, these Wyze video doorbells and bundles offer reliable, easy-to-install solutions for your front porch security needs.
Wyze Video Doorbell Pro: Wireless Power with Wide View
Experience effortless installation and smart security with Wyze Video Doorbell Pro.
The Wyze Video Doorbell Pro stands out as a versatile, battery-powered smart doorbell that can also be hardwired if preferred. It offers a wider ultra-wide viewing angle, ensuring you never miss a visitor or package. Installation is a breeze—mount it in just 30 seconds using screws or a screw-free adhesive plate.
Key Features:
- Battery or Hardwired Power: Flexibility to choose wired or wireless setup.
- Crystal-clear HD Video: High-definition video quality for sharp, detailed footage.
- Smart Detection Alerts: Person, package, vehicle, and pet detection powered by Cam Plus.
- Motion-Activated Security Light: Adds an extra layer of deterrence.
- Two-Way Audio & Quick Responses: Communicate instantly with visitors.
- Customizable Chime: 20 unique tunes and 8 sound levels included.
- Smart Home Integration: Works seamlessly with Alexa and Google Assistant.
- Dual-Band Wi-Fi Extender Chime: Faster notifications and reliable connectivity.
This doorbell is perfect for those seeking a secure, smart, and flexible video doorbell solution with extended battery life and advanced detection capabilities.
Wyze Duo Cam Battery Doorbell: Dual Cameras and Extended Battery Life
Dual camera views for comprehensive porch coverage.
For users who want the most advanced battery-powered video doorbell, the Wyze Duo Cam Battery Doorbell offers dual camera views—one for people and one for packages—capturing every angle of your front porch. It delivers 2K video resolution and supports local microSD storage for continuous recording.
Highlights:
- Dual Cameras: Front camera with 132° horizontal and 100° vertical field of view; bottom camera covers 121° horizontal and 60° vertical.
- Extended Battery Life: Equipped with a 6200 mAh removable lithium-ion battery pack.
- 2K Video & Local Storage: Capture detailed footage with optional 24/7 local recording.
- Two-Way Audio & Voice Deterrence: Communicate and warn visitors with motion-activated voice prompts.
- Weather Resistant: IP65 rating ensures durability in all weather conditions.
- Includes Wyze Wi-Fi Chime: Enhances alert system with audible notifications.
- Smart Integrations: Compatible with Alexa, Google Assistant, and IFTTT.
This doorbell is ideal for those who want comprehensive porch monitoring with extended battery life and dual-camera coverage.
The Front Porch Security Bundle: Complete Secure Entry Solution
Combine your video doorbell with smart lock technology for ultimate front porch security. The Front Porch Security Bundle pairs the Wyze Video Doorbell (including the Pro or v2 models) with the Wyze Lock Bolt Matte Black, allowing you to remotely lock and unlock your door and monitor lock history—all from the Wyze app.
Bundle Benefits:
- 1080p HD Video Doorbell: Crisp video with two-way audio to greet visitors.
- Remote Lock Control: Lock or unlock your door remotely for secure access.
- Lock History Monitoring: Keep track of who enters and exits your home.
- Seamless Integration: Control both doorbell and lock from a single app.
- Smart Notifications: Receive alerts for motion, packages, and lock activity.
This bundle is perfect for homeowners looking for a comprehensive, smart, and secure entry system with extended battery life and remote access capabilities.
Wyze Video Doorbell v2: Wired with 2K Video and Local Storage
The Wyze Video Doorbell v2 is a wired video doorbell that offers crystal-clear 2K video resolution and local microSD card storage for continuous recording. It includes a chime controller to work with your existing mechanical chime, preserving the traditional doorbell sound.
Features:
- 2K HD Video: Capture detailed head-to-toe views of your porch.
- Local 24/7 Recording: Onboard microSD slot for continuous video storage.
- Two-Way Talk: Communicate with visitors via the Wyze app.
- Motion-Activated Voice Deterrence: Warn visitors with automated voice prompts.
- Pre-Roll Motion Recording: Capture 3-6 seconds before motion events.
- Weatherproof: IP65 rating for all-weather durability.
- Smart Home Compatible: Works with Alexa and Google Home.
- Included 30° Corner Kit: Adjust the viewing angle for optimal coverage.
This wired doorbell is a great choice for those who prefer a stable wired connection with extended recording options and smart features.
Wyze Video Doorbell v2 Wedge Kit: Perfect Angle Adjustment
To complement the Wyze Video Doorbell v2, the Wedge Kit accessory allows you to adjust the doorbell’s viewing angle for maximum coverage, especially useful for angled door frames or porches with stairs.
Wedge Kit Includes:
- 1x 15° Horizontal Bracket
- 2x 7.5° Vertical Brackets
- Installation screws and quick start guide
- Weather-resistant plastic construction
This accessory ensures you never miss a moment by eliminating blind spots.
Secure your home with a refurbished video doorbell kit that offers extended battery life, smart detection, and seamless integration. Whether you choose the wireless Wyze Video Doorbell Pro, the dual-camera Wyze Duo Cam, or the wired Wyze Video Doorbell v2, you get reliable, high-quality security tailored to your needs.
Summary of Featured Products
Product Name | Power Type | Video Quality | Key Feature | Price Range |
Wyze Video Doorbell Pro | Battery/Wired | HD | Ultra-wide view, fast install | ~$99.98 |
Wyze Duo Cam Battery Doorbell | Battery | 2K Dual Cam | Dual cameras, removable battery | ~$89.98 |
The Front Porch Security Bundle | Wired/Battery | 1080p HD | Doorbell + smart lock integration | ~$124.96+ |
Wyze Video Doorbell v2 | Wired | 2K | Local microSD storage, voice deterrence | ~$44.98 |
Wyze Video Doorbell v2 Wedge Kit | Accessory | N/A | Adjustable mounting angle | ~$8.99 |
What is included in the Refurbished Secure Entry Video Doorbell Pro Kit?
The Refurbished Secure Entry Video Doorbell Pro Kit includes a Wyze Video Doorbell Pro with extended battery life, a customizable chime, mounting hardware, and a dual-band Wi-Fi extender chime for faster notifications and reliable connectivity.What are the main features of the Wyze Video Doorbell Pro?
The Wyze Video Doorbell Pro offers battery or hardwired power options, crystal-clear HD video, smart detection alerts for people, packages, vehicles, and pets, a motion-activated security light, two-way audio, customizable chime, smart home integration with Alexa and Google Assistant, and an ultra-wide viewing angle.How easy is it to install the Wyze Video Doorbell Pro?
The Wyze Video Doorbell Pro is designed for effortless installation and can be mounted in just 30 seconds using either screws or a screw-free adhesive plate.What is the Wyze Duo Cam Battery Doorbell and how does it differ from other models?
The Wyze Duo Cam Battery Doorbell features dual cameras—one for people and one for packages—offering comprehensive porch coverage. It provides 2K video resolution, extended battery life with a 6200 mAh removable battery, local microSD storage for continuous recording, and is weather resistant with an IP65 rating.Does the Wyze Duo Cam Battery Doorbell support local video storage?
Yes, the Wyze Duo Cam Battery Doorbell supports local microSD card storage for optional 24/7 continuous video recording.What smart home systems are compatible with Wyze video doorbells?
Wyze video doorbells are compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless smart home integration and voice control.What is included in the Front Porch Security Bundle?
The Front Porch Security Bundle includes a Wyze Video Doorbell (Pro or v2 model) and the Wyze Lock Bolt Matte Black, enabling remote lock and unlock capabilities, lock history monitoring, and control of both devices from the Wyze app.What are the benefits of the Wyze Video Doorbell v2?
The Wyze Video Doorbell v2 offers wired installation, 2K HD video resolution, local 24/7 recording via microSD card, two-way talk, motion-activated voice deterrence, pre-roll motion recording, weatherproof IP65 rating, and compatibility with Alexa and Google Home.How does the Wyze Video Doorbell v2 Wedge Kit improve doorbell coverage?
The Wyze Video Doorbell v2 Wedge Kit allows you to adjust the doorbell’s viewing angle with included horizontal and vertical brackets, ensuring optimal coverage and eliminating blind spots, especially for angled door frames or porches with stairs.Are refurbished Wyze video doorbells reliable for home security?
Yes, refurbished Wyze video doorbells offer reliable, high-quality security with advanced features such as extended battery life, smart detection alerts, and seamless smart home integration, making them a cost-effective choice for enhancing your home security.Can I use Wyze video doorbells in all weather conditions?
Yes, both the Wyze Duo Cam Battery Doorbell and Wyze Video Doorbell v2 are IP65 weather resistant, ensuring durability and reliable performance in various weather conditions.What is the price range for Wyze refurbished video doorbells and accessories?
The price range for Wyze refurbished video doorbells and accessories is approximately $8.99 for the Wedge Kit, $44.98 for the Video Doorbell v2, $89.98 for the Duo Cam Battery Doorbell, $99.98 for the Video Doorbell Pro, and $124.96 and up for the Front Porch Security Bundle.
