Easy DIY Installation of Refurbished Wyze Video Doorbell Without Batteries
Installing a refurbished Wyze Video Doorbell without batteries is straightforward and perfect for DIY enthusiasts. Wyze Video Doorbells are designed to work with your existing wired mechanical doorbell system, meaning no batteries are required. This guide will walk you through the simple steps to install your refurbished Wyze Video Doorbell quickly and efficiently.
Why Choose Wyze Video Doorbell?
Wyze Video Doorbell offers a smart, reliable, and weather-resistant solution for home security. Here’s why it stands out:
- Hardwired Power: Unlike battery-powered doorbells, Wyze Video Doorbell connects directly to your existing wired doorbell system, ensuring continuous power without the hassle of recharging or replacing batteries.
- 1080p+ HD Video with Vertical View: Capture visitors from head to toe with crystal-clear video quality and a 3:4 vertical aspect ratio.
- Two-Way Audio & Instant Notifications: Receive alerts on your phone and communicate with visitors remotely.
- Included Wyze Chime: Hear your doorbell ring anywhere in your home with the included chime featuring 19 different tunes.
- IP65 Weather Resistant: Built to withstand rain, snow, and shine.
- Night Vision with White LED: See visitors clearly even in complete darkness.
Wyze Video Doorbell transforms your mechanical doorbell into a smart device without the need for batteries, making it an eco-friendly and maintenance-free choice.
What You Need Before Installation
Before starting your installation, ensure you have:
- An existing wired mechanical doorbell system with a transformer providing at least 16V and 10VA power output.
- Basic tools: Phillips screwdriver.
- Components included in the box:
- Wyze Video Doorbell unit
- Wall plate
- 30º angled wedge (optional for angled mounting)
- Screws and expansion tubes
- Extension wires and wire caps
- Jump wire
Step-by-Step DIY Installation Guide
1. Power Off Your Doorbell Circuit
Turn off the power to your existing doorbell at your electrical panel to ensure safety during installation.
2. Remove Your Old Doorbell
Carefully detach your current doorbell and disconnect the wires.
3. Prepare the Wall Plate
Choose your mounting style:
- Flat Wall Plate: Mounts flush against the wall.
- Angled Wedge: Provides a 30º angle for better viewing if your doorbell is mounted on a corner or angled surface.
Mark and drill holes for the screws, then attach the wall plate securely.
4. Connect the Wires
- Loosen the screws on the back of the Wyze Video Doorbell.
- Attach the forked ends of the extension wires to the screws and tighten.
- Connect the wires from your wall to the extension wires using the wire caps.
- Use the jump wire if your wiring configuration requires bypassing the chime circuit (common with 2-wire setups).
5. Mount the Doorbell
Slide the Wyze Video Doorbell onto the wall plate until it clicks securely in place.
6. Restore Power and Confirm Installation
Turn the power back on at the electrical panel. The doorbell’s status light should flash yellow, indicating it is powered and ready for setup.
Final Setup Using the Wyze App
- Open the Wyze app and tap the plus sign (+) to add a new device.
- Select Cameras > Video Doorbells > Wyze Video Doorbell.
- Follow the in-app instructions to scan the QR code displayed on your phone with the doorbell.
- Confirm the doorbell’s status light turns solid blue.
- Complete the setup by naming your device and configuring notifications.
Tips for a Smooth Installation
- Check Your Wiring: If unsure about your existing doorbell wiring or electrical panel, consult a licensed electrician.
- Use the Included Wire Caps: Properly secure wire connections to avoid loose wiring or shorts.
- Mount at Recommended Height: Install the doorbell approximately 4.3 feet (1.2 meters) from the ground for optimal visitor detection.
- Bypass or Install Chime Correctly: Follow the instructions to bypass your existing chime if necessary, or install the included Wyze Chime for audible alerts inside your home.
Benefits of Installing a Refurbished Wyze Video Doorbell
Choosing a refurbished Wyze Video Doorbell is a cost-effective and environmentally friendly option. You get the same high-quality features and reliable performance as a new unit, with the added benefit of reducing electronic waste.
Easy DIY installation of Wyze Video Doorbell without batteries
Summary
Installing a refurbished Wyze Video Doorbell without batteries is an easy DIY project that enhances your home security with smart features and reliable hardwired power. With clear instructions and the Wyze app’s guided setup, you can have your doorbell up and running in about 30 minutes.
“Wyze Video Doorbell offers a seamless upgrade to your existing doorbell system with no batteries required, making smart home security accessible and hassle-free.”
How do I install a refurbished Wyze Video Doorbell without batteries?
To install a refurbished Wyze Video Doorbell without batteries, first ensure you have an existing wired mechanical doorbell system with at least 16V and 10VA power output. Turn off the power at your electrical panel, remove your old doorbell, and attach the Wyze wall plate. Connect the wires using the included extension wires and wire caps, mount the doorbell, and restore power. Complete the setup using the Wyze app by following the in-app instructions.Does the Wyze Video Doorbell require batteries?
No, the Wyze Video Doorbell does not require batteries. It is designed to connect directly to your existing wired doorbell system, providing continuous power without the need for recharging or replacing batteries.What are the benefits of choosing a refurbished Wyze Video Doorbell?
A refurbished Wyze Video Doorbell offers the same high-quality features and reliable performance as a new unit at a lower cost. It is also an environmentally friendly choice, helping to reduce electronic waste.What tools and components do I need to install the Wyze Video Doorbell?
You will need a Phillips screwdriver and an existing wired mechanical doorbell system. The box includes the Wyze Video Doorbell unit, wall plate, 30º angled wedge, screws, expansion tubes, extension wires, wire caps, and a jump wire.Is the Wyze Video Doorbell weather resistant?
Yes, the Wyze Video Doorbell is IP65 weather resistant, making it suitable for use in rain, snow, and shine.Can I hear the doorbell ring inside my home?
Yes, the Wyze Video Doorbell comes with an included Wyze Chime, which features 19 different tunes so you can hear your doorbell ring anywhere in your home.What features does the Wyze Video Doorbell offer?
The Wyze Video Doorbell offers 1080p+ HD video with a 3:4 vertical aspect ratio, two-way audio, instant notifications, night vision with a white LED, and weather resistance. It also includes a Wyze Chime for in-home alerts.How do I set up the Wyze Video Doorbell using the Wyze app?
After installing the doorbell and restoring power, open the Wyze app, tap the plus sign (+), select Cameras > Video Doorbells > Wyze Video Doorbell, and follow the in-app instructions. Scan the QR code displayed on your phone with the doorbell, wait for the status light to turn solid blue, and complete the setup by naming your device and configuring notifications.What should I do if I am unsure about my doorbell wiring?
If you are unsure about your existing doorbell wiring or electrical panel, it is recommended to consult a licensed electrician to ensure a safe and proper installation.How long does it take to install a refurbished Wyze Video Doorbell?
With clear instructions and the Wyze app’s guided setup, you can install your refurbished Wyze Video Doorbell in about 30 minutes.
