Practical Solar Charging Station for Wyze Cams Off-Grid
Practical Solar Charging Station for Wyze Security Devices in Off-Grid Locations
For those seeking a reliable, off-grid power solution for Wyze security devices, the Wyze Battery Cam Solar Panel combined with the Wyze Battery Cam Pro offers an ideal setup. This practical solar charging station ensures your Wyze cameras stay powered longer without frequent battery swaps or wired power sources, perfect for remote cabins, RVs, campsites, or any off-grid location.
Wyze Battery Cam Solar Panel: Extend Your Camera’s Battery Life with Sun Power
Key Features and Benefits
  • Weather Resistant Design: Rated IP65, the solar panel withstands rain, dust, and harsh outdoor conditions, making it perfect for off-grid and outdoor use.
  • Universal Compatibility: Works seamlessly with Wyze Cam Outdoor v1/v2 and Wyze Battery Cam Pro.
  • Compact and Mountable Anywhere: Measuring 173 mm x 120 mm x 17 mm, it features a white frame with black solar cells and includes a 13-foot (4m) micro USB cable for flexible installation.
  • Easy 360° Mount: Adjust the panel to capture optimal sunlight throughout the day.
  • Complete Installation Kit: Comes with the solar panel, wall mount, micro USB and USB-C adapter cables, screws, wall anchors, and a quick start guide.
Technical Specs
  • Solar Power Rating: 2.5W, 5VDC
  • Waterproof Level: IP65
  • Cable Length: 13 feet (4 meters)
  • Color: White frame with black solar cells
Attach this solar panel to your Wyze Battery Cam Pro to record for longer periods without worrying about battery depletion.
Wyze Battery Cam Pro: High-Resolution, Wire-Free Security Camera
Why Choose Wyze Battery Cam Pro?
  • 2.5K HDR Video Resolution: Crystal-clear 2560 x 1440 video quality captures every detail.
  • Wire-Free & No Hub Required: Easy to install anywhere without complicated wiring.
  • Integrated Spotlight & Siren: Enhances security with a built-in spotlight and a 100 dB siren.
  • Advanced Motion Detection: Combines Radar and PIR sensors for accurate alerts.
  • Long Battery Life: Removable, rechargeable 6200mAh battery packs last up to 6 months on a single charge.
  • Dual-Band WiFi Support: Connects to both 2.4 GHz and 5 GHz networks for stable streaming.
  • Weatherproof: IP65 rating ensures reliable operation in temperatures from -20°C to 50°C (-4°F to 122°F).
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
  • Local and Cloud Storage: Supports up to 256 GB microSD cards and cloud recording with Cam Plus subscription.
Dimensions & Weight
  • Size: 2.5 x 1.8 x 3.5 inches
  • Weight: 0.94 lbs
  • Available Colors: Black and White
The Wyze Battery Cam Pro is the perfect companion for the solar panel, providing wire-free, long-lasting security in any off-grid environment.
Outdoor Security Camera in Snowy Landscape Wyze Cam Pan v3 shown in rugged outdoor conditions, illustrating weather resistance and durability.
Wyze Battery Charging Dock: Convenient Dual Battery Charging
Features
  • Charge Two Batteries Simultaneously: Keep multiple battery packs ready for uninterrupted camera operation.
  • Compact and Portable: Small footprint (2.6in x 2in x 1in) and lightweight (2.75 oz) for easy placement.
  • Fast Charging: Fully charges batteries in approximately 8.5 hours at room temperature.
  • Included Accessories: Comes with the charging dock, adapter cable, and power adapter.
  • Compatibility: Designed specifically for Wyze Battery Cam Pro’s removable battery packs.
Ideal for off-grid users who want to keep spare batteries charged and ready, ensuring continuous security coverage.
Why Choose a Solar Charging Station for Wyze Security Devices?
Off-grid locations often lack reliable power sources, making battery life a critical factor for security cameras. The Wyze Battery Cam Solar Panel harnesses renewable energy to keep your cameras running longer without manual recharging. Combined with the Wyze Battery Cam Pro’s efficient battery system and the convenience of the Wyze Battery Charging Dock, you get a complete, practical solar charging station that ensures your security devices stay powered and vigilant.
Summary of the Ideal Off-Grid Security Setup
ProductHighlightsBenefits for Off-Grid Use
Wyze Battery Cam Solar PanelIP65 weatherproof, 2.5W solar power, 13 ft cableContinuous solar charging, easy installation anywhere
Wyze Battery Cam Pro2.5K HDR, wire-free, long battery life, spotlight & sirenHigh-quality security, no wiring needed, long-lasting battery
Wyze Battery Charging DockDual battery charging, compact designKeeps spare batteries charged for uninterrupted use
Enhance Your Off-Grid Security with Wyze
Investing in the Wyze Battery Cam Solar Panel and Wyze Battery Cam Pro creates a reliable, practical solar charging station tailored for off-grid security needs. Whether you’re monitoring a remote cabin, RV, or outdoor property, this combination ensures your Wyze security devices stay powered, connected, and ready to protect.
FeatureWyze Battery Cam Solar PanelWyze Battery Cam ProWyze Battery Charging Dock
TypeAccessoryCameraAccessory
Price$24.99 (Solar Panel), $5.99 (USB-C Adapter Cable)$89.98 (1 Pack), $159.98 (2 Pack), $219.98 (3 Pack)$17.99
CompatibilityWyze Cam Outdoor v1/v2, Wyze Battery Cam ProN/A (Camera itself)Wyze Battery Cam Pro's battery packs
BatteryN/ARemovable, Rechargeable 6200mAh battery packsCharges up to two battery packs simultaneously
Power SourceSolar panel converts sunlight to powerRechargeable battery packs, solar panel optionalUSB-A to USB-C power adapter
Weather ResistanceIP65 (Weatherproof and dustproof)IP65 WeatherproofOperating temp +10°C to +40°C, humidity <90%
Mounting360° freestyle mount, mountable anywhereMultiple mounting options including ceiling mountN/A
Cable Length13-foot weatherproof power cableN/A6 ft (1.8 m) power cable
Video ResolutionN/A2.5K HDR (2560 x 1440)N/A
WirelessN/AYes, dual-band Wi-Fi (2.4 & 5 GHz), Bluetooth 5.1N/A
Additional FeaturesExtends battery life by solar chargingIntegrated spotlight & siren, Radar + PIR motion detection, color night vision, local recording supportCharges two batteries simultaneously
Dimensions173 mm x 120 mm x 17 mm2.5 x 1.8 x 3.5 inchesCharging Dock: 2.6in x 2in x 1in (58mm x 52mm x 26mm)
WeightNot specified0.94 lbs (camera)2.75 oz (78 g)
Return Policy30-day hassle-free returns30-day hassle-free returnsNot specified
What is the best solar charging solution for Wyze security cameras in off-grid locations?The Wyze Battery Cam Solar Panel combined with the Wyze Battery Cam Pro offers a practical and reliable solar charging station for off-grid locations. This setup ensures your Wyze cameras stay powered longer without frequent battery swaps or the need for wired power sources, making it ideal for remote cabins, RVs, campsites, and other off-grid environments.
Which Wyze cameras are compatible with the Wyze Battery Cam Solar Panel?The Wyze Battery Cam Solar Panel is universally compatible with Wyze Cam Outdoor v1/v2 and Wyze Battery Cam Pro, allowing you to extend the battery life of these security cameras using solar power.
How weather-resistant is the Wyze Battery Cam Solar Panel?The Wyze Battery Cam Solar Panel is rated IP65, making it highly weather-resistant. It can withstand rain, dust, and harsh outdoor conditions, ensuring reliable performance in off-grid and outdoor settings.
What are the key features of the Wyze Battery Cam Solar Panel?Key features of the Wyze Battery Cam Solar Panel include an IP65 weather-resistant design, universal compatibility with select Wyze cameras, a compact and mountable form factor, a 13-foot (4m) micro USB cable for flexible installation, a 360° adjustable mount, and a complete installation kit with all necessary accessories.
What are the technical specifications of the Wyze Battery Cam Solar Panel?The Wyze Battery Cam Solar Panel has a solar power rating of 2.5W, 5VDC, an IP65 waterproof level, a 13-foot (4 meters) cable, and features a white frame with black solar cells. Its dimensions are 173 mm x 120 mm x 17 mm.
What makes the Wyze Battery Cam Pro suitable for off-grid security?The Wyze Battery Cam Pro is ideal for off-grid security due to its wire-free installation, long-lasting removable and rechargeable 6200mAh battery (up to 6 months per charge), IP65 weatherproof rating, 2.5K HDR video resolution, integrated spotlight and siren, advanced motion detection, dual-band WiFi support, and compatibility with smart home platforms like Alexa, Google Assistant, and IFTTT.
How long does the Wyze Battery Cam Pro battery last on a single charge?The Wyze Battery Cam Pro features a removable, rechargeable 6200mAh battery pack that can last up to 6 months on a single charge, depending on usage and environmental conditions.
Does the Wyze Battery Cam Pro require a hub or wired connection?No, the Wyze Battery Cam Pro is completely wire-free and does not require a hub or complicated wiring, making it easy to install anywhere, especially in off-grid locations.
What storage options are available for the Wyze Battery Cam Pro?The Wyze Battery Cam Pro supports both local and cloud storage. It can use microSD cards up to 256 GB for local recording and also offers cloud recording with a Cam Plus subscription.
What is the Wyze Battery Charging Dock and how does it benefit off-grid users?The Wyze Battery Charging Dock is a compact, portable device that allows you to charge two Wyze Battery Cam Pro battery packs simultaneously. It ensures you always have spare batteries ready for uninterrupted camera operation, which is especially useful for off-grid users.
How long does it take to fully charge batteries with the Wyze Battery Charging Dock?The Wyze Battery Charging Dock can fully charge two batteries in approximately 8.5 hours at room temperature, ensuring your spare batteries are always ready for use.
Why should I choose a solar charging station for Wyze security devices in remote areas?A solar charging station, like the Wyze Battery Cam Solar Panel paired with the Wyze Battery Cam Pro, harnesses renewable energy to keep your security cameras running longer without manual recharging. This is especially important in off-grid locations where reliable power sources are unavailable.
What is included in the Wyze Battery Cam Solar Panel installation kit?The Wyze Battery Cam Solar Panel installation kit includes the solar panel, wall mount, 13-foot micro USB and USB-C adapter cables, screws, wall anchors, and a quick start guide for easy setup.
Can the Wyze Battery Cam Solar Panel be adjusted for optimal sunlight?Yes, the Wyze Battery Cam Solar Panel features an easy 360° mount, allowing you to adjust the panel to capture optimal sunlight throughout the day for maximum charging efficiency.
What are the dimensions and weight of the Wyze Battery Cam Pro?The Wyze Battery Cam Pro measures 2.5 x 1.8 x 3.5 inches and weighs 0.94 lbs. It is available in both black and white colors.
What are the key features of the Wyze Battery Cam Solar Panel?How does the Wyze Battery Charging Dock work with the Wyze Battery Cam Pro?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Battery Cam products?
