Convenient Power Solutions for Your Wyze Cam Outside the Garage
When it comes to securing your garage exterior with a Wyze Cam, powering the camera conveniently and reliably is key. Whether you want to avoid running long cables or prefer a solar-powered option, Wyze offers smart solutions tailored to outdoor use. This guide highlights the best Wyze products and bundles designed to power your Wyze Cam outside your garage, including the Wyze Cam v4 Outdoor Bundle and the innovative Lamp Socket v2 Bundle.
Wyze Cam v4 Outdoor Bundle: High-Quality Security with Wired Power
Crystal-Clear 2.5K QHD Video and Enhanced Night Vision
The Wyze Cam v4 Outdoor Bundle delivers stunning 2.5K QHD resolution, ensuring you capture every detail outside your garage. Its enhanced color night vision and motion-activated spotlight provide clear visibility day and night, making it ideal for monitoring your garage area.
Wired Power for Continuous Operation
This bundle includes the Wyze Outdoor Power Adapter, which provides a stable wired power source. This eliminates the need to worry about battery life or solar charging conditions, ensuring your camera stays active 24/7.
Smart Features and Compatibility
- Supports Wi-Fi 6 for faster, more reliable connectivity
- Compatible with Alexa and Google Assistant for voice control
- Includes a 128GB microSD card for local continuous recording
- Motion and sound detection with customizable zones
- Weather-resistant design suitable for outdoor use
The Wyze Cam v4 Outdoor Bundle is perfect if you want a dependable wired power solution with advanced security features for your garage exterior.
Alt text: Wyze Cam v4 mounted outside a garage with clear night vision
Lamp Socket v2 Bundle: Power Your Wyze Cam Without an Outlet
Innovative Powering via Existing Light Sockets
The Wyze Cam v4 + Lamp Socket v2 Bundle offers a unique way to power your Wyze Cam without needing a dedicated power outlet. Simply screw the lamp socket into an existing E26 light fixture outside your garage, and plug your Wyze Cam into it.
Features of the Lamp Socket v2
- Compatible with Wyze Cam v3, v4, OG, and Pan v3 models
- Motion-activated lights to enhance security lighting
- Dusk to dawn scheduling for automatic operation
- Supports CFL or LED bulbs up to 20W (incandescent bulbs not recommended)
- Suitable for damp locations (not fully waterproof)
Compact and Easy to Install
With a small form factor (56.5mm x 56.5mm x 65mm) and lightweight design, the lamp socket is easy to install and integrates seamlessly with your existing outdoor lighting setup.
This bundle is an excellent choice if you want to avoid running new wiring and prefer powering your Wyze Cam through your outdoor light fixtures.
Essential Security Bundle: Comprehensive Home Protection Including Outdoor Cameras
Versatile Wyze Cam OG for Outdoor Use
Included in the Essential Security Bundle are two Wyze Cam OG cameras, which are plug-in models featuring motion-activated spotlights and color night vision. These cameras are rated IP65 for weather resistance, making them suitable for outdoor garage monitoring.
Additional Security Devices
- Wyze Video Doorbell v2 with 1080p HD video and two-way audio
- Wyze Lock Bolt with fingerprint sensor and backlit keypad
- Wyze Cam Pan v3 with 360° horizontal and 180° vertical coverage
Why Choose This Bundle?
If you want a full home security setup that includes outdoor cameras with reliable plug-in power, this bundle offers great value and versatility.
Summary: Best Powering Options for Your Wyze Cam Outside the Garage
Product | Power Source | Outdoor Suitability | Key Benefits |
Wyze Cam v4 Outdoor Bundle | Wired (Outdoor Adapter) | Yes | 2.5K QHD, color night vision, 24/7 recording |
Wyze Cam v4 + Lamp Socket v2 Bundle | Lamp Socket (E26) | Damp locations | Powers via light socket, motion-activated lights |
Essential Security Bundle (Wyze Cam OG) | Plug-in (Outlet) | Yes (IP65 rating) | Motion spotlight, color night vision, multi-device security |
For a convenient and reliable approach to powering your Wyze Cam outside your garage, consider the Wyze Cam v4 Outdoor Bundle for wired power or the Lamp Socket v2 Bundle for a no-outlet-needed solution. Both options ensure your camera stays powered and your garage remains secure.
Enhance Your Garage Security Today
Choose the power solution that fits your setup and enjoy peace of mind with Wyze’s advanced outdoor cameras and smart accessories.
What is the best way to power a Wyze Cam outside my garage?
The best way to power a Wyze Cam outside your garage depends on your setup. The Wyze Cam v4 Outdoor Bundle offers a reliable wired power solution with an outdoor power adapter, while the Wyze Cam v4 + Lamp Socket v2 Bundle allows you to power your camera through an existing E26 light socket, eliminating the need for a dedicated outlet.Is the Wyze Cam v4 Outdoor Bundle suitable for outdoor use?
Yes, the Wyze Cam v4 Outdoor Bundle is designed for outdoor use. It features a weather-resistant design, 2.5K QHD video resolution, enhanced color night vision, and comes with an outdoor power adapter for continuous operation.How does the Lamp Socket v2 Bundle power my Wyze Cam?
The Lamp Socket v2 Bundle powers your Wyze Cam by screwing into an existing E26 light fixture outside your garage. You simply plug your Wyze Cam into the lamp socket, which provides power without the need for a separate outlet.Which Wyze Cam models are compatible with the Lamp Socket v2?
The Lamp Socket v2 is compatible with Wyze Cam v3, v4, OG, and Pan v3 models, making it a versatile powering solution for various Wyze cameras.Can I use the Lamp Socket v2 Bundle in fully exposed outdoor locations?
The Lamp Socket v2 is suitable for damp locations but is not fully waterproof. It should be installed in areas that are protected from direct exposure to heavy rain or water.What are the key features of the Wyze Cam v4 Outdoor Bundle?
The Wyze Cam v4 Outdoor Bundle offers 2.5K QHD video, enhanced color night vision, a motion-activated spotlight, Wi-Fi 6 support, compatibility with Alexa and Google Assistant, a 128GB microSD card for local recording, and a weather-resistant design.What is included in the Essential Security Bundle for outdoor garage monitoring?
The Essential Security Bundle includes two Wyze Cam OG cameras (IP65 weather-resistant, plug-in models with motion-activated spotlights and color night vision), a Wyze Video Doorbell v2, a Wyze Lock Bolt, and a Wyze Cam Pan v3 for comprehensive home and garage security.Do Wyze outdoor cameras support continuous recording?
Yes, the Wyze Cam v4 Outdoor Bundle includes a 128GB microSD card for local continuous recording, ensuring you never miss important footage outside your garage.Are Wyze outdoor cameras compatible with smart home assistants?
Yes, Wyze outdoor cameras such as the Wyze Cam v4 are compatible with Alexa and Google Assistant, allowing for convenient voice control and integration with your smart home system.What are the power source options for Wyze outdoor cameras?
Wyze outdoor cameras can be powered via a wired outdoor power adapter (Wyze Cam v4 Outdoor Bundle), an E26 lamp socket (Lamp Socket v2 Bundle), or a standard power outlet (Essential Security Bundle with Wyze Cam OG).
