Power Wyze Cam Behind Aquarium: 20ft USB Extension, No Exposed Wires
Powering Your Wyze Cam Behind a Large Aquarium Without Exposed Wires
Setting up a Wyze Cam behind a large aquarium can be challenging due to limited access to power outlets and the need to keep cables hidden for a clean, aesthetic look. Fortunately, Wyze offers smart accessories and solutions that allow you to power your camera discreetly and extend its reach without unsightly exposed wires.
Wyze Cam USB Extension Cable - 20ft: Extend Your Reach Seamlessly
Say Goodbye to Short Cables
The Wyze Cam USB Extension Cable (20ft) is the perfect accessory to power your Wyze Cam behind large objects like aquariums. This long cable gives you the freedom to place your camera exactly where you want it without worrying about proximity to power sources.
- Compatibility: Works with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto.
- Length: 20 feet of flexible USB extension cable.
- Clean Setup: Run the cable discreetly along walls or behind furniture to keep wires out of sight.
- Affordable: Priced at $7.99, it’s a cost-effective way to enhance your camera setup.
Using this extension cable, you can easily position your Wyze Cam behind your aquarium glass, ensuring optimal viewing angles while keeping all wiring hidden and safe from water exposure.
Wyze Cam v4: The Ideal Camera for Aquarium Monitoring
Crystal Clear 2.5K Quad HD Video
The Wyze Cam v4 offers stunning 2.5K Quad High Definition video quality, capturing every detail of your aquarium’s aquatic life with vibrant colors and sharp clarity.
- Enhanced Color Night Vision: See your aquarium in full color even in low light, thanks to advanced hardware that outperforms traditional night vision.
- Wide Dynamic Range (WDR): Enjoy balanced lighting and rich colors, perfect for capturing the subtle movements and colors of fish and plants.
- Weather Resistant (IP65): While ideal for indoor use behind an aquarium, the camera is also durable enough for outdoor use.
- Easy Setup: Bluetooth® connectivity and a magnetic mount make installation behind your aquarium quick and tool-free.
- Continuous Power: Requires wired power, which can be conveniently supplied using the 20ft USB extension cable to keep wires hidden.
Additional Features for Peace of Mind
- Two-Way Talk: Communicate or play sounds near your aquarium.
- Motion & Sound Detection: Receive alerts if unexpected activity occurs.
- MicroSD Card Support: Record 24/7 locally without subscription fees.
The Wyze Cam v4’s advanced imaging and flexible installation options make it the best choice for aquarium enthusiasts who want to monitor their tanks discreetly and effectively.
Lamp Socket v2 Bundle: Power Your Wyze Cam Without Visible Outlets
Innovative Power Solution for Hidden Camera Setups
The Wyze Cam v4 + Lamp Socket v2 Bundle offers a clever way to power your camera without needing a visible power outlet near your aquarium.
- Power Through Existing Lamp Sockets: Simply screw the lamp socket into a standard E26 light fixture and plug your Wyze Cam into it.
- Compatible with Multiple Wyze Cams: Works with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3.
- Motion-Activated Lights: The lamp socket supports dusk-to-dawn scheduling and motion-activated lighting, adding extra security and convenience.
- Compact & Lightweight: Measures 56.5mm x 56.5mm x 65mm and weighs only 80g.
- Safe for Indoor Use: Suitable for damp locations but not waterproof.
Why Choose the Lamp Socket Bundle?
This bundle is perfect if your aquarium is near a lamp or ceiling fixture, allowing you to power your camera without running visible extension cords or installing new outlets. It keeps your setup clean and professional-looking.
Summary: The Perfect Setup for Hidden, Wired Wyze Cam Aquarium Monitoring
- Use the Wyze Cam USB Extension Cable - 20ft to extend your camera’s power cable behind your aquarium without exposed wires.
- Choose the Wyze Cam v4 for superior video quality, color night vision, and easy installation.
- Consider the Lamp Socket v2 Bundle to power your camera through existing lamp sockets, eliminating the need for visible power outlets.
With these Wyze products, you can achieve a neat, wire-free look while keeping your aquarium under constant watch with crystal-clear video.
Product Highlights
Keep your aquarium safe and beautifully monitored with Wyze’s smart camera accessories designed for clean, wire-free installations.
Feature | Wyze Cam USB Extension Cable - 20ft | Wyze Cam v4 | Cam v4 + Lamp Socket v2 Bundle |
Product Type | Accessory (USB Extension Cable) | Camera | Bundle (Camera + Lamp Socket) |
Compatibility | Wyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG Telephoto | Standalone Wyze Cam v4 | Wyze Cam v3, v3 Pro, v4, OG, Pan v3 |
Cable Length | 20 ft USB extension cable | 6-Foot Flat micro USB to USB-A cable included | Included with camera (6-Foot Flat micro USB to USB-A) |
Price | $7.99 | $35.98 (1 Pack) | $49.96 |
Resolution | N/A | 2.5K QHD (2560x1440) | 2.5K QHD (2560x1440) |
Night Vision | N/A | Enhanced Color Night Vision | Enhanced Color Night Vision |
Spotlight | N/A | Motion-activated spotlight | Motion-activated spotlight |
Audio | N/A | Enhanced Two-Way Talk, 99dB speaker, built-in siren | Same as Wyze Cam v4 |
Weather Resistance | N/A | IP65 | Not specified for lamp socket; camera IP65 |
Power Source | USB extension cable only | Wired (5V/1A adapter included) | Wired (5V/1A adapter included) + Lamp Socket (120V input) |
Mounting Options | N/A | Stand, Wall mount, Ceiling mount, Magnetic mount | Same as Wyze Cam v4 camera |
Additional Features | Extends USB cable length for Wyze Cams | Wi-Fi 6 support, Alexa/Google Assistant/IFTTT integration, 24/7 local recording, motion & sound detection, smoke & CO alerts | Lamp Socket features: Motion-activated lights, dusk to dawn scheduling, linkability without limits |
Included in Box | 1 x 20ft USB extension cable | Wyze Cam v4, Quick Start Guide, Wall Mount Plate & Tape, Screw Kit, Indoor USB Power Adapter, 6-Foot USB cable | Wyze Cam v4 + Lamp Socket v2 |
Warranty | 30-day hassle-free returns | 1 Year | 1 Year |
How can I power my Wyze Cam behind a large aquarium without exposed wires?
You can power your Wyze Cam behind a large aquarium without exposed wires by using the Wyze Cam USB Extension Cable (20ft) to discreetly run power along walls or behind furniture. Alternatively, the Wyze Cam v4 + Lamp Socket v2 Bundle allows you to power your camera through an existing lamp socket, eliminating the need for visible outlets or extension cords.What is the Wyze Cam USB Extension Cable and how does it help with aquarium setups?
The Wyze Cam USB Extension Cable is a 20-foot flexible USB cable designed to extend the reach of your Wyze Cam’s power supply. It allows you to position your camera behind large objects like aquariums while keeping cables hidden for a clean, aesthetic look.Which Wyze Cam models are compatible with the 20ft USB Extension Cable?
The 20ft Wyze Cam USB Extension Cable is compatible with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto models.What are the benefits of using the Wyze Cam v4 for aquarium monitoring?
The Wyze Cam v4 offers 2.5K Quad HD video quality, enhanced color night vision, wide dynamic range (WDR), and weather resistance (IP65). It’s easy to install behind an aquarium using Bluetooth® connectivity and a magnetic mount, and it supports continuous power with hidden wiring using the 20ft USB extension cable.Can I record 24/7 video of my aquarium with Wyze Cam v4?
Yes, the Wyze Cam v4 supports microSD card storage, allowing you to record 24/7 locally without any subscription fees.How does the Lamp Socket v2 Bundle work for powering Wyze Cams?
The Lamp Socket v2 Bundle allows you to power your Wyze Cam by screwing the lamp socket into a standard E26 light fixture and plugging your camera into it. This solution is ideal for setups where you want to avoid visible power outlets or extension cords near your aquarium.Which Wyze Cam models are compatible with the Lamp Socket v2 Bundle?
The Lamp Socket v2 Bundle is compatible with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3 models.Is the Lamp Socket v2 safe to use near aquariums?
Yes, the Lamp Socket v2 is safe for indoor use and suitable for damp locations, but it is not waterproof. It is designed to provide a safe and convenient power solution for Wyze Cams near aquariums.What features make the Wyze Cam v4 ideal for monitoring aquariums?
The Wyze Cam v4 features crystal clear 2.5K Quad HD video, enhanced color night vision, wide dynamic range, two-way talk, motion and sound detection, and easy installation with a magnetic mount. These features make it perfect for discreet and effective aquarium monitoring.How can I keep my aquarium monitoring setup clean and professional-looking?
To maintain a clean and professional look, use the Wyze Cam USB Extension Cable to hide wires, or power your camera through a lamp socket with the Lamp Socket v2 Bundle. Both solutions help eliminate visible cords and outlets, ensuring a tidy aquarium monitoring setup.
Can you tell me more about the features of the Wyze Cam v4?How does the color night vision work on the Wyze Cam v4?Do you have any ongoing sales or discounts for the Wyze Cam accessories?
