Portable Security Cameras with Live Video Streaming: Wyze Battery Cam Pro Series
When it comes to portable security cameras that offer live video streaming directly to your smartphone app, the
Wyze Battery Cam Pro lineup stands out as a top choice. Designed for wire-free convenience, high-resolution video, and smart home integration, these cameras provide reliable security wherever you need it most.
Wyze Battery Cam Pro: Advanced Wire-Free Security
Stunning 2.5K HDR Video Quality
The Wyze Battery Cam Pro delivers crystal-clear 2560 x 1440 (2.5K) HDR video resolution, ensuring you never miss a detail. Its CMOS-Starlight sensor combined with an F1.6 lens offers vibrant, sharp images both day and night.
Wireless and Wire-Free Convenience
No hub is required to operate this camera. It supports dual-band WiFi (2.4 GHz & 5 GHz) for stable connectivity and streams live video directly to your smartphone via the Wyze app, compatible with Android 9.0+ and iOS 15.0+.
Long-Lasting Rechargeable Battery
Powered by a removable 6200mAh rechargeable battery pack, the camera can last up to 6 months on a single charge. Charging takes approximately 9 hours, making it easy to maintain.
Smart Motion Detection and Alerts
Equipped with Radar + PIR motion detection, the camera accurately senses movement and sends instant alerts to your phone. The integrated spotlight and 100 dB siren enhance security by deterring intruders.
Weatherproof and Durable
With an IP65 rating, the Wyze Battery Cam Pro is built to withstand harsh weather conditions, operating reliably between -20°C to 50°C (-4°F to 122°F).
Two-Way Audio and Smart Home Integration
Communicate through the built-in speaker and MEMS digital microphone. The camera integrates seamlessly with Alexa, Google Assistant, and IFTTT for voice control and automation.
Wyze Battery Cam Pro + Solar Panel: Extended Power for Continuous Monitoring
Solar-Powered Convenience
The Wyze Battery Cam Pro + Solar Panel bundle offers all the features of the standard Battery Cam Pro with the added benefit of solar charging. The included solar panel is weather-resistant (IP65) and mounts easily to keep your camera powered longer without manual recharging.
Continuous Live Streaming and Recording
Enjoy uninterrupted live video streaming and local recording with support for up to 256 GB microSD cards. The camera also supports cloud recording via Cam Plus for added peace of mind.
Enhanced Night Vision and Color Imaging
The camera features 2 IR LEDs and 2 white LEDs (187 lumens) for clear night vision, including color night vision enabled by the integrated spotlight.
Essential Accessories for Wyze Battery Cam Pro
Wyze Removable Battery Pack
Keep your camera running longer with an extra 6200mAh rechargeable battery pack. Lightweight and compact, it charges via USB-C and lasts up to 6 months per charge, making battery swaps quick and hassle-free.
Wyze Battery Cam Solar Panel
Designed to extend your camera’s battery life, this solar panel accessory is IP65 weather-resistant and includes a 13-foot power cable for flexible installation. It’s compatible with Wyze Battery Cam Pro and Wyze Cam Outdoor models.
Why Choose Wyze Battery Cam Pro for Portable Security?
The Wyze Battery Cam Pro series combines portability, high-definition video, and smart features in a weatherproof design that fits any security need. Whether you want to monitor your home, RV, or outdoor spaces, these cameras provide reliable live streaming and easy smartphone access without the clutter of wires or hubs.
Experience seamless outdoor security with Wyze Battery Cam Pro.
Extend your camera’s battery life with the Wyze Solar Panel.
Stay connected and secure with live video streaming on your phone.
Product Summary
Product | Key Features | Price Range (USD) |
Wyze Battery Cam Pro | 2.5K HDR, Radar + PIR, Spotlight, Siren, IP65 | $89.98 - $219.98 |
Wyze Battery Cam Pro + Solar Panel | Solar charging, 2.5K HDR, Color Night Vision | $109.98 |
Wyze Removable Battery Pack | 6200mAh, USB-C charging, up to 6 months life | $22.99 |
Wyze Battery Cam Solar Panel | Weatherproof solar panel, 13 ft cable | $24.99 |
Experience the freedom of wire-free, high-quality security with the Wyze Battery Cam Pro series — your perfect solution for portable, live-streaming security cameras.
What is the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro is a portable, wire-free security camera that streams live 2.5K HDR video directly to your smartphone. It features smart motion detection, two-way audio, weatherproof design, and integrates with Alexa, Google Assistant, and IFTTT for smart home automation.Does the Wyze Battery Cam Pro require a hub to operate?
No, the Wyze Battery Cam Pro does not require a hub. It connects directly to your WiFi network (2.4 GHz or 5 GHz) and streams live video to your smartphone via the Wyze app.How long does the Wyze Battery Cam Pro battery last?
The Wyze Battery Cam Pro uses a removable 6200mAh rechargeable battery pack that can last up to 6 months on a single charge, depending on usage and settings.How do I recharge the Wyze Battery Cam Pro?
You can recharge the Wyze Battery Cam Pro by removing the battery pack and charging it via USB-C. Charging takes approximately 9 hours.Is the Wyze Battery Cam Pro weatherproof?
Yes, the Wyze Battery Cam Pro is IP65 weatherproof, making it suitable for outdoor use in temperatures ranging from -20°C to 50°C (-4°F to 122°F).Does the Wyze Battery Cam Pro support night vision?
Yes, the Wyze Battery Cam Pro features enhanced night vision with 2 IR LEDs and 2 white LEDs (187 lumens), providing clear images even in low-light conditions. The integrated spotlight enables color night vision.Can I use the Wyze Battery Cam Pro with a solar panel?
Yes, the Wyze Battery Cam Pro can be paired with the Wyze Solar Panel for continuous power. The solar panel is IP65 weather-resistant and includes a 13-foot cable for flexible installation.What smart home systems are compatible with the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro integrates with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.How does motion detection work on the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro uses Radar and PIR (Passive Infrared) motion detection to accurately sense movement and send instant alerts to your smartphone. It also features an integrated spotlight and 100 dB siren to deter intruders.Can I record video locally on the Wyze Battery Cam Pro?
Yes, the Wyze Battery Cam Pro supports local recording with microSD cards up to 256 GB. It also offers cloud recording via the Cam Plus subscription.What is included in the Wyze Battery Cam Pro + Solar Panel bundle?
The Wyze Battery Cam Pro + Solar Panel bundle includes the camera and a weather-resistant solar panel for extended, maintenance-free power. All standard camera features are included, such as 2.5K HDR video, color night vision, and smart motion detection.What accessories are available for the Wyze Battery Cam Pro?
Available accessories include the Wyze Removable Battery Pack (6200mAh, USB-C charging, up to 6 months per charge) and the Wyze Battery Cam Solar Panel (IP65 weatherproof, 13-foot cable).What mobile devices are compatible with the Wyze app for live video streaming?
The Wyze app is compatible with Android devices running version 9.0 or higher and iOS devices running version 15.0 or higher.How much does the Wyze Battery Cam Pro cost?
The Wyze Battery Cam Pro is priced between $89.98 and $219.98, depending on the configuration. The Wyze Battery Cam Pro + Solar Panel bundle is available for $109.98.
