Portable Indoor Cordless Vacuum for Bare Floors and Low Pile Carpets
When it comes to keeping your bare floors and low pile carpets spotless, a lightweight, powerful, and cordless vacuum is a must-have. The
Wyze Cordless Vacuum S stands out as an exceptional choice, combining strong suction, portability, and smart features to make your cleaning effortless and efficient.
Wyze Cordless Vacuum S: Lightweight Powerhouse for Your Floors
Powerful Suction for Every Cleaning Need
The Wyze Cordless Vacuum S delivers an impressive suction power of up to
20,000 Pa in Turbo Mode, ensuring deep cleaning on bare floors and low pile carpets alike. It offers three suction modes to suit your cleaning preferences:
- Turbo Mode: 20,000 Pa (10 minutes runtime)
- Medium Mode: 9,000 Pa (23 minutes runtime)
- ECO Mode: 6,000 Pa (40 minutes runtime)
This versatility means you can quickly switch between modes for a thorough clean or extended vacuuming sessions without worrying about battery life.
Ultra-Lightweight and Ergonomic Design
Weighing only
2.8 lbs for the main unit and
4.9 lbs when fully assembled, this vacuum is as light as feathers, making it easy to maneuver around furniture and carry between rooms. Its compact size (12.4 x 4.5 x 8.7 inches main unit) and cordless design free you from the hassle of cords and bulky machines.
Long-Lasting Battery and Quick Charging
Equipped with a
6-cell lithium-ion battery (2,000mAh*6), the vacuum charges fully in
4-6 hours and offers up to
40 minutes of runtime in ECO mode. The interchangeable battery design means you can swap batteries for uninterrupted cleaning sessions.
Smart Features for Enhanced Cleaning
- Dual Motors: Two motors provide powerful suction and efficient brush roll operation.
- 3-Stage Filtration System: Captures fine dust and allergens, ideal for maintaining indoor air quality.
- LED Screen: Displays battery life and suction mode for easy monitoring.
- 6 Daylight-Bright LED Lights: Illuminate dark corners and under furniture for thorough cleaning.
Included Attachments
The vacuum comes with a
Crevice Tool, Floor Brush, Dust Cap, HEPA Filter, Filter Housing, and Standard Tube, making it versatile for different surfaces and hard-to-reach areas.
Experience the freedom of cordless cleaning with the Wyze Cordless Vacuum S — perfect for bare floors and low pile carpets, especially in pet-friendly homes.
Lightweight cordless vacuum perfect for pet owners and bare floors
Why Choose a Cordless Vacuum for Bare Floors and Low Pile Carpets?
Cordless vacuums like the Wyze Cordless Vacuum S offer unmatched convenience for quick cleanups and regular maintenance. Their lightweight design prevents fatigue during use, and the absence of cords means you can easily reach every corner without unplugging or tripping hazards. The powerful suction modes ensure that even fine dust and debris on smooth surfaces and low pile carpets are effectively removed.
Enhance Your Cleaning Experience with Wyze Accessories
Foldable Vacuum Tube for Added Flexibility
The
Wyze Cordless Vacuum - Foldable Vacuum Tube accessory bends so you don’t have to, allowing you to clean awkward spaces with ease. This accessory is designed exclusively for the Wyze Cordless Vacuum, enhancing its versatility for indoor cleaning tasks.
Effortless cleaning on hardwood and low pile carpets
Summary
For those seeking a
portable, indoor cordless vacuum tailored for
bare floors and low pile carpets, the
Wyze Cordless Vacuum S is a top-tier option. Its combination of powerful suction, lightweight design, long battery life, and smart features makes it ideal for everyday cleaning. Paired with the foldable vacuum tube accessory, it offers flexibility and ease for all your cleaning needs.
What makes the Wyze Cordless Vacuum S ideal for bare floors and low pile carpets?
The Wyze Cordless Vacuum S is specifically designed for bare floors and low pile carpets, offering powerful suction up to 20,000 Pa in Turbo Mode, lightweight portability, and a cordless design. Its three suction modes allow you to adjust cleaning power for different surfaces, ensuring effective removal of dust and debris from both hard floors and low pile carpets.How long does the Wyze Cordless Vacuum S battery last on a single charge?
The Wyze Cordless Vacuum S provides up to 40 minutes of runtime in ECO mode, 23 minutes in Medium mode, and 10 minutes in Turbo mode. The vacuum fully charges in 4-6 hours and features an interchangeable battery design for extended cleaning sessions.How much does the Wyze Cordless Vacuum S weigh?
The main unit of the Wyze Cordless Vacuum S weighs only 2.8 lbs, and the fully assembled vacuum weighs 4.9 lbs. Its ultra-lightweight design makes it easy to maneuver and carry between rooms.What attachments are included with the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S comes with a Crevice Tool, Floor Brush, Dust Cap, HEPA Filter, Filter Housing, and Standard Tube. These attachments make it versatile for cleaning different surfaces and hard-to-reach areas.Does the Wyze Cordless Vacuum S have a HEPA filter?
Yes, the Wyze Cordless Vacuum S features a 3-stage filtration system that includes a HEPA filter. This system captures fine dust and allergens, helping to maintain indoor air quality.What smart features does the Wyze Cordless Vacuum S offer?
The Wyze Cordless Vacuum S includes dual motors for powerful suction and efficient brush roll operation, a 3-stage filtration system, an LED screen that displays battery life and suction mode, and 6 daylight-bright LED lights to illuminate dark corners and under furniture.Is there an accessory to help clean under furniture with the Wyze Cordless Vacuum S?
Yes, the Wyze Cordless Vacuum - Foldable Vacuum Tube accessory is available. It bends to help you clean awkward spaces and under furniture with ease, enhancing the vacuum's flexibility for indoor cleaning tasks.Why should I choose a cordless vacuum for bare floors and low pile carpets?
Cordless vacuums like the Wyze Cordless Vacuum S offer unmatched convenience, allowing you to clean without the hassle of cords. Their lightweight design prevents fatigue, and powerful suction ensures effective cleaning of dust and debris from bare floors and low pile carpets.How long does it take to fully charge the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S takes approximately 4-6 hours to fully charge its 6-cell lithium-ion battery.Is the Wyze Cordless Vacuum S suitable for pet owners?
Yes, the Wyze Cordless Vacuum S is perfect for pet owners. Its strong suction and HEPA filtration system effectively capture pet hair and allergens, making it ideal for homes with pets.
