High Suction Handheld Vacuum for Deep Dirt Removal at Home
When it comes to deep dirt removal at home, having a handheld vacuum with powerful suction and versatile features is essential. The Wyze Cordless Vacuum S stands out as a top choice for homeowners seeking a lightweight yet highly effective cleaning tool. Paired with essential accessories like the Wyze Handheld Vacuum Filter and the Foldable Vacuum Tube, this vacuum system offers a comprehensive solution for tackling dirt, dust, and pet hair in every corner of your home.
Wyze Cordless Vacuum S: Unmatched Suction Power and Portability
Exceptional Suction for Deep Cleaning
The Wyze Cordless Vacuum S delivers an impressive 20,000 Pa suction power in Turbo Mode, ensuring deep dirt and debris removal from carpets, hardwood floors, and upholstery. With multiple suction settings—Turbo (20,000 Pa), Medium (9,000 Pa), and ECO (6,000 Pa)—you can customize the cleaning intensity based on your needs, balancing power and battery life.
Lightweight and Ergonomic Design
Weighing only 2.8 pounds for the main unit and 4.9 pounds when fully assembled, this vacuum is as light as 2.8 pounds of feathers, making it easy to maneuver around furniture and reach tight spaces without fatigue.
Long-Lasting Battery Life
Equipped with a 6-cell lithium-ion battery, the vacuum offers up to 40 minutes of runtime in ECO mode, 23 minutes in Medium mode, and 10 minutes in Turbo mode. The battery is interchangeable, allowing for extended cleaning sessions without interruption.
Advanced Features for Enhanced Cleaning
  • Dual Motors: Two powerful motors work together to maximize suction and efficiency.
  • 3-Stage Filtration System: Captures fine dust and allergens, improving indoor air quality.
  • LED Screen: Displays battery life and suction mode for easy monitoring.
  • 6 Daylight-Bright LED Lights: Illuminate dark corners and under furniture for thorough cleaning.
Versatile Attachments Included
The vacuum comes with a crevice tool, floor brush, dust cap, HEPA filter, filter housing, and a standard tube, enabling you to clean various surfaces and hard-to-reach areas effectively. Wyze Cordless Vacuum S in Use Lightweight and powerful vacuum for home cleaning
Essential Accessories for Optimal Performance
To maintain peak suction and filtration efficiency, regularly replacing the Wyze Handheld Vacuum Filter is crucial. Available in 1-pack or 3-pack options, these filters are designed exclusively for the Wyze Handheld Vacuum, ensuring a perfect fit and optimal performance.
Foldable Vacuum Tube for Easy Cleaning
The Wyze Cordless Vacuum Foldable Vacuum Tube bends effortlessly, allowing you to clean awkward spaces without straining. This accessory is compatible only with the Wyze Cordless Vacuum and enhances your ability to reach under furniture, corners, and other difficult spots.
Why Choose Wyze for Your Home Cleaning Needs?
Wyze combines powerful technology with user-friendly design to deliver a handheld vacuum that is both effective and convenient. Whether you have pets, kids, or just want a spotless home, the Wyze Cordless Vacuum S and its accessories provide a reliable solution for deep dirt removal.
"Experience the freedom of cordless cleaning with unmatched suction power and smart features designed for your home."
Cozy Home Cleaning Scene Pet-friendly vacuuming for a cleaner home environment
Summary of Product Highlights
ProductKey FeaturesPrice (USD)
Wyze Cordless Vacuum S20,000 Pa Turbo suction, 2 motors, 40 min battery, LED lights, 3-stage filtration139.99
Wyze Handheld Vacuum FilterReplacement filter, 1 or 3 pack options, exclusive compatibility9.99 - 13.99
Foldable Vacuum TubeFlexible tube for hard-to-reach areas, compatible with Wyze Cordless Vacuum15.99
Conclusion
For deep dirt removal at home, the Wyze Cordless Vacuum S offers powerful suction, lightweight design, and versatile attachments that make cleaning effortless and efficient. Complemented by essential accessories like replacement filters and a foldable vacuum tube, this handheld vacuum system is your go-to solution for maintaining a clean and healthy living space.
FeatureWyze Cordless Vacuum SWyze Cordless Vacuum - Foldable Vacuum Tube
TypeCordless VacuumAccessory (Foldable Vacuum Tube)
Price$139.99$15.99
CompatibilityN/A (Main Unit)Only for Wyze Cordless Vacuum
Weight2.8 lbs (main unit), 4.9 lbs (assembled)Not specified
Dimensions12.4 x 4.5 x 8.7 inches (main unit)Not specified
Suction Power100 AW; 20,000 Pa (Turbo); 9,000 Pa (Medium); 6,000 Pa (ECO)N/A
Battery6 cell lithium ion, 2,000mAh*6, 40 min runtime (ECO)N/A
Charging Time4-6 hoursN/A
Dust Cup Volume0.7 LN/A
Noise Level65 dBA (Turbo Mode)N/A
FeaturesLED screen, 2 motors, 3-stage filtration, 6 LED lights on brush headBends so you do not have to
Attachments IncludedCrevice Tool, Floor Brush, Dust cap, HEPA Filter, Filter Housing, Standard Tube, Quick Start GuideN/A
PurposeVacuum cleaningExtension tube accessory for vacuum
What makes the Wyze Cordless Vacuum S effective for deep dirt removal at home?The Wyze Cordless Vacuum S features a powerful 20,000 Pa suction in Turbo Mode, dual motors, and a 3-stage filtration system, making it highly effective for deep dirt removal from carpets, hardwood floors, and upholstery.
How long does the Wyze Cordless Vacuum S battery last?The Wyze Cordless Vacuum S offers up to 40 minutes of runtime in ECO mode, 23 minutes in Medium mode, and 10 minutes in Turbo mode. The battery is also interchangeable for extended cleaning sessions.
Is the Wyze Cordless Vacuum S lightweight and easy to use?Yes, the Wyze Cordless Vacuum S weighs only 2.8 pounds for the main unit and 4.9 pounds when fully assembled, making it lightweight and easy to maneuver around furniture and tight spaces.
What attachments come with the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S includes a crevice tool, floor brush, dust cap, HEPA filter, filter housing, and a standard tube, allowing for versatile cleaning on various surfaces and hard-to-reach areas.
How does the 3-stage filtration system in the Wyze Cordless Vacuum S work?The 3-stage filtration system captures fine dust and allergens, improving indoor air quality and ensuring that dirt and debris are effectively trapped inside the vacuum.
Why should I replace the Wyze Handheld Vacuum Filter regularly?Regularly replacing the Wyze Handheld Vacuum Filter ensures peak suction and filtration efficiency, maintaining optimal performance and prolonging the life of your vacuum.
Are Wyze Handheld Vacuum Filters compatible with other vacuums?No, Wyze Handheld Vacuum Filters are designed exclusively for the Wyze Handheld Vacuum, ensuring a perfect fit and optimal performance.
What is the purpose of the Foldable Vacuum Tube for the Wyze Cordless Vacuum?The Foldable Vacuum Tube bends easily, allowing you to clean under furniture, in corners, and other hard-to-reach areas without straining, enhancing the vacuum’s versatility.
Is the Foldable Vacuum Tube compatible with all Wyze vacuums?The Foldable Vacuum Tube is compatible only with the Wyze Cordless Vacuum, ensuring a secure fit and optimal cleaning performance.
What are the key features of the Wyze Cordless Vacuum S?Key features include 20,000 Pa Turbo suction, dual motors, up to 40 minutes of battery life, 3-stage filtration, LED screen, 6 LED lights for visibility, and a lightweight, ergonomic design.
Is the Wyze Cordless Vacuum S suitable for pet hair removal?Yes, the Wyze Cordless Vacuum S is highly effective at removing pet hair from floors, carpets, and upholstery, making it ideal for pet owners.
How much does the Wyze Cordless Vacuum S and its accessories cost?The Wyze Cordless Vacuum S is priced at $139.99. The Wyze Handheld Vacuum Filter ranges from $9.99 to $13.99, and the Foldable Vacuum Tube is $15.99.
What are the different suction settings available on the Wyze Cordless Vacuum S?How long does the battery last in each mode for the Wyze Cordless Vacuum S?Do you have any deals, ongoing sales, discounts, or promotions?
