Affordable Cordless Vacuum with Crevice Tool & Washable Filter
Affordable Cordless Vacuum with Crevice Tool and Easy Filter Wash
Looking for an affordable cordless vacuum that combines powerful suction, handy crevice tools, and easy-to-clean filters? The Wyze Cordless Vacuum S is your perfect cleaning companion. Designed to deliver industrial-level suction in a lightweight, user-friendly package, this vacuum makes home cleaning effortless and efficient.
Wyze Cordless Vacuum S: Powerful, Lightweight, and Easy to Maintain
Exceptional Suction Power for Every Surface
The Wyze Cordless Vacuum S boasts 20,000 Pa suction power, powered by not one but two high-performance motors—one in the main body and another in the brush head. This dual-motor design ensures deep cleaning on carpets, hardwood floors, and tight corners alike. Choose from three cleaning speeds to match your needs:
  • Eco: 6,000 Pa
  • Medium: 9,000 Pa
  • Turbo: 20,000 Pa
Lightweight and Ergonomic Design
Weighing just 2.8 pounds, this vacuum is as light as a fluffy corgi puppy, making it easy to maneuver around furniture and up stairs without fatigue. Its cordless design frees you from outlet constraints, allowing you to clean anywhere with ease.
Long-Lasting, Interchangeable Battery
With up to 40 minutes of fade-free runtime, the removable lithium-ion battery lets you finish your cleaning without interruptions. When needed, swap batteries quickly to extend cleaning sessions.
Crevice Tool and LED Illumination
The vacuum includes a crevice tool perfect for reaching narrow spaces, corners, and edges where dust loves to hide. Plus, the brush head features 6 daylight-bright LED lights that illuminate dark areas under furniture, ensuring no dust bunnies escape your notice.
Easy Filter Maintenance
The 3-stage filtration system captures 95% of particles as small as 0.3 microns, including allergens and pet hair. The dust cup and filters are washable and reusable, making maintenance simple and cost-effective. A built-in filter brush helps knock dust off the filter into the dust cup, maintaining peak efficiency.
"Finally! A vacuum that is free and independent and no longer reliant on its parents for financial and emotional support." – Wyze
Wyze Cordless Vacuum S in use with pet on sofa Lightweight cordless vacuum perfect for pet owners and sofa cleaning
Why Choose Wyze Cordless Vacuum S?
  • Affordable Price: At $139.99, it offers premium features without breaking the bank.
  • Powerful Dual Motors: Industrial-level suction for thorough cleaning.
  • Lightweight & Cordless: Easy to carry and use anywhere.
  • Long Battery Life: 40 minutes of continuous cleaning.
  • Easy-to-Clean Filters: Washable dust cup and HEPA filters.
  • Crevice Tool Included: Reach tight spaces effortlessly.
  • LED Brush Head: Illuminates hidden dust and debris.
Additional Cleaning Options: Wyze Robot Vacuum
If you want to complement your cordless vacuum with automated cleaning, consider the Wyze Robot Vacuum. It features:
  • Room Mapping & Path Planning: Efficiently cleans your home with smart navigation.
  • 2100 Pa Suction Power: Strong enough for hardwood floors and carpets.
  • 7 Sensor Groups Including LIDAR: Detects obstacles and stairs for safe operation.
  • 110 Minutes Runtime: Long-lasting battery for thorough cleaning.
  • Automatic Recharge: Returns to its charging station when battery is low.
While the robot vacuum is not cordless handheld, it offers a hands-free cleaning solution that works well alongside the Wyze Cordless Vacuum S for a complete home cleaning system. Wyze Robot Vacuum lifestyle image Wyze Robot Vacuum efficiently cleans hardwood and carpeted floors
Summary
For an affordable cordless vacuum with crevice tool and easy filter wash, the Wyze Cordless Vacuum S stands out as a top choice. Its powerful suction, lightweight design, and washable filters make it ideal for everyday cleaning tasks. Pair it with the Wyze Robot Vacuum for a smart, comprehensive cleaning experience.
FeatureWyze Cordless Vacuum SWyze Robot Vacuum
TypeCordless Stick VacuumRobot Vacuum
Price$139.99 (compare at $193.99)$99.98 (compare at $314.99)
Suction PowerUp to 20,000 Pa2,100 Pa
Motors2 motors (one digital motor + one in brush head)Single motor with edge brush and center brush
Weight2.8 lbs (light as feathers)Not specified
Battery LifeUp to 40 minutes (interchangeable lithium-ion)Up to 110 minutes (standard mode)
Cleaning Speeds3 speeds: Eco (6,000 Pa), Med (9,000 Pa), Turbo (20,000 Pa)Not specified
Filtration System3-stage filtration with HEPA filter (removes 95% of particles <0.3 µm)HEPA filter (replacement available)
LED Lights6 daylight-bright LEDs on brush headNot specified
Surface CompatibilityMultiple surfaces, adjustable suctionHard floors and carpets, crosses up to 0.8 in height
NavigationManual operationLIDAR room mapping and path planning
SensorsNot specified7 sensor groups for obstacle and stair detection
Smart FeaturesNo smart home integration mentionedWorks with Alexa, app control, auto recharge and resume
Weight ComparisonLighter than a fluffy corgi puppyNot specified
Dust CupEasy one-finger release, washableDustbin replacement available
Accessories & Replacement PartsBattery pack, HEPA filter, charger, floor brush, mini motorized brush head, foldable vacuum tubeCharging station, HEPA filter, edge brush, main rolling brush, dustbin, power adapter, replacement parts kit
Return Policy30-day hassle-free returnsNo returns (final sale) for vacuum; 30-day returns for parts
Special FeaturesBrushless digital motor, interchangeable batteryEdge brush sweeps debris inward, all-wheel drive for uneven surfaces
What makes the Wyze Cordless Vacuum S an affordable choice for home cleaning?The Wyze Cordless Vacuum S is priced at just $139.99, offering premium features such as powerful dual motors, a crevice tool, LED illumination, and washable filters without breaking the bank.
How powerful is the suction on the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S delivers up to 20,000 Pa of suction power, thanks to its dual-motor design—one in the main body and another in the brush head. It offers three cleaning speeds: Eco (6,000 Pa), Medium (9,000 Pa), and Turbo (20,000 Pa) for versatile cleaning on carpets, hardwood floors, and tight corners.
Is the Wyze Cordless Vacuum S lightweight and easy to use?Yes, the Wyze Cordless Vacuum S weighs only 2.8 pounds, making it extremely lightweight and easy to maneuver around furniture, up stairs, and throughout your home. Its cordless design allows for hassle-free cleaning anywhere.
How long does the battery last on the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S features a removable lithium-ion battery that provides up to 40 minutes of fade-free runtime. The battery is also interchangeable, so you can swap it out for extended cleaning sessions.
Does the Wyze Cordless Vacuum S come with a crevice tool?Yes, the Wyze Cordless Vacuum S includes a crevice tool designed to reach narrow spaces, corners, and edges, making it easy to clean hard-to-reach areas.
What type of filtration system does the Wyze Cordless Vacuum S use?The Wyze Cordless Vacuum S uses a 3-stage filtration system that captures 95% of particles as small as 0.3 microns, including allergens and pet hair. The dust cup and filters are washable and reusable for easy maintenance.
How do I clean the filters on the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S features washable dust cup and HEPA filters. Simply remove the filters, wash them with water, and let them dry before reinserting. A built-in filter brush helps knock dust off the filter into the dust cup for efficient cleaning.
Does the Wyze Cordless Vacuum S have LED lights for cleaning?Yes, the brush head of the Wyze Cordless Vacuum S is equipped with 6 daylight-bright LED lights that illuminate dark areas under furniture, ensuring you don’t miss any hidden dust or debris.
Is the Wyze Cordless Vacuum S suitable for pet owners?Absolutely! The Wyze Cordless Vacuum S is lightweight, powerful, and features a 3-stage filtration system that effectively captures pet hair and allergens, making it an excellent choice for pet owners.
What are the benefits of pairing the Wyze Cordless Vacuum S with the Wyze Robot Vacuum?Pairing the Wyze Cordless Vacuum S with the Wyze Robot Vacuum provides a comprehensive cleaning solution. The cordless vacuum is ideal for spot cleaning and hard-to-reach areas, while the robot vacuum offers automated, hands-free cleaning with smart navigation, strong suction, and long battery life.
What are the key features of the Wyze Cordless Vacuum S?How does the suction power of the Wyze Cordless Vacuum S compare to other vacuums?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Cordless Vacuum S?
