Wyze Cam Pan v3: Pan & Tilt Camera with Advanced Motion Tagging
Wyze Cam Pan v3: Advanced Pan and Tilt Camera with Motion Tagging
The Wyze Cam Pan v3 is a cutting-edge indoor/outdoor security camera designed to provide comprehensive 360° horizontal pan and 180° vertical tilt coverage. This camera is perfect for users seeking advanced motion tagging for easy playback, ensuring you never miss a moment. With its IP65 weather resistance, the Pan v3 is built to withstand outdoor conditions when paired with the Wyze Outdoor Power Adapter (sold separately).
Experience seamless security monitoring with smooth pan and tilt capabilities, enhanced by intelligent motion tagging that highlights activity for quick review.
Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3 weather resistant outdoor use
Key Features and Specifications
  • 360° Horizontal Pan & 180° Vertical Tilt: Full room or outdoor area coverage with rotation speeds up to 110° per second.
  • 1080p Full HD Video: Crisp 1920 x 1080 resolution with H.264 encoding for smooth streaming and recording.
  • Advanced Motion Tagging: Automatically tags detected motion events for easy playback and review.
  • Night Vision: Equipped with 4 IR LEDs (850 nm) for clear black-and-white night vision.
  • Color Night Vision: Available in the Cam Plus bundle for enhanced nighttime color footage.
  • Two-Way Audio: Built-in speaker and microphone with noise and echo cancellation for real-time communication.
  • Connectivity: Supports 2.4 GHz Wi-Fi (802.11 b/g/n), compatible with Android 9.0+ and iOS 15.0+.
  • Storage: Supports up to 256 GB microSD card (ExFAT format) for local storage.
  • Durability: Polycarbonate body with IP65 rating for dust and water resistance.
  • Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT for voice control and automation.
  • Dimensions & Weight: 124mm (H) x 60mm (W) x 63mm (D), weighing 11.29 oz (320 g).
  • Warranty: 1-Year manufacturer warranty.
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle
For users wanting the full experience, the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle includes the camera along with a 30-day trial of Cam Plus, Wyze’s subscription service that unlocks advanced features like person detection, package detection, and enhanced motion tagging with color night vision. This bundle comes with everything needed to get started: the camera, power adapter, micro USB cable, mounting kit, and quick start guide.
Why Choose Wyze Cam Pan v3?
  • Versatile Indoor/Outdoor Use: Weatherproof design lets you monitor your home’s interior or exterior.
  • Smart Motion Tagging: Quickly find important events without scrolling through hours of footage.
  • Clear Two-Way Communication: Perfect for checking in on pets, kids, or talking to visitors remotely.
  • Affordable and Reliable: High-end features at a budget-friendly price point.
Two-way audio feature with pet Communicate easily with two-way audio
Accessories to Enhance Your Wyze Cam Pan v3 Experience
Wyze Cam Pan v3 Skins by dBrand
Customize and protect your camera with stylish vinyl skins available in Green Camo and Triple Black. These precision-cut skins prevent scratches and give your camera a unique look.
  • Easy to apply with included instructions.
  • Durable and protective material.
  • Perfect for personalizing your Wyze Cam Pan v3.
Wyze Cam Pan v3 USB Cable
Keep your camera powered with an official replacement USB cable designed specifically for the Pan v3. Affordable and reliable, this cable ensures uninterrupted connectivity.
Pan v3 + Lamp Socket v2 Bundle
Make your outdoor lighting smarter by powering your Wyze Cam Pan v3 through a lamp socket without needing an outlet. This bundle is ideal for flexible installation in outdoor or damp locations.
  • Compatible with Wyze Cam Pan v3 and other Wyze cameras.
  • Supports CFL or LED bulbs under 20W.
  • Easy Bluetooth and Wi-Fi connectivity.
Conclusion
The Wyze Cam Pan v3 stands out as a top-tier pan and tilt camera with advanced motion tagging, making playback and event review effortless. Its robust weather resistance, high-definition video, and smart home compatibility make it an excellent choice for anyone looking to enhance their home security system with intelligent, flexible monitoring. Whether you choose the standalone camera or the Cam Plus bundle, the Wyze Cam Pan v3 delivers exceptional value and performance for indoor and outdoor surveillance needs.
Feature / ProductWyze Cam Pan v3Wyze Cam Pan v3 + 30-Day Cam Plus BundleWyze Cam Pan v3 Skins by dBrand (Skin Only)Wyze Cam Pan v3 USB CablePan v3 + Lamp Socket v2 Bundle
TypeCameraCamera BundleAccessory (Skin)Replacement PartBundle (Camera + Lamp Socket)
Price$39.98 (1 Pack)$39.98$11.98$1.99$53.96
Color VariantsBlack, WhiteBlack, WhiteGreen Camo, Triple BlackN/ABlack, White
Pack Options1, 2, 3 PacksSingle camera onlySingle skinSingle cableSingle bundle
Weather ResistanceIP65 rated (outdoor ready with adapter)IP65 rated (outdoor ready with adapter)Not applicableNot applicableCamera: IP65 with adapter; Lamp Socket: Not weatherproof, suitable for damp locations
Outdoor UseRequires Wyze Outdoor Power Adapter (sold separately)Requires Wyze Outdoor Power Adapter (sold separately)N/AN/AYes, with included lamp socket power option
Pan & Tilt Coverage360° pan, 180° tilt360° pan, 180° tiltN/AN/A360° pan, 180° tilt (camera included)
Motion TrackingYesYesN/AN/AYes (camera included)
Two-Way AudioYesYesN/AN/AYes (camera included)
Color Night VisionYes (Starlight Sensor)Yes (Starlight Sensor)N/AN/AYes (camera included)
Cam Plus SubscriptionOptional, not includedIncluded free 30 days, then $2.99/month/cam auto-renewN/AN/AOptional, not included
Custom Detection ZonesYesYesN/AN/AYes (camera included)
Smoke & CO AlertsYesYesN/AN/AYes (camera included)
Included ItemsCamera, USB cableCamera, USB cable, 30-day Cam Plus trial1x Skin, Installation instructionsUSB cableCamera, Lamp Socket v2
Material / BuildPolycarbonate bodyPolycarbonate bodyStylish vinyl skinUSB cablePolycarbonate & Plastic (lamp socket)
Dimensions (Lamp Socket)N/AN/AN/AN/A56.5mm x 56.5mm x 65mm
Weight (Lamp Socket)N/AN/AN/AN/A80 g
Power Input (Lamp Socket)N/AN/AN/AN/A120V~, 60Hz
Connectivity (Lamp Socket)Wi-Fi 2.4 GHzWi-Fi 2.4 GHzN/AN/AWi-Fi 2.4 GHz, Bluetooth
Warranty1 Year1 YearN/AN/A1 Year
Special NotesOutdoor use requires separate power adapterOutdoor use requires separate power adapterProtects device, prevents scratchesReplacement USB cable for Pan v3Incandescent bulbs not supported; use CFL or LED under 20W
What is the Wyze Cam Pan v3?The Wyze Cam Pan v3 is an advanced indoor/outdoor security camera featuring 360° horizontal pan and 180° vertical tilt, motion tagging, 1080p HD video, night vision, two-way audio, and smart home integration. It is designed for comprehensive home monitoring and is weather resistant with an IP65 rating.
Is the Wyze Cam Pan v3 weatherproof for outdoor use?Yes, the Wyze Cam Pan v3 has an IP65 weather resistance rating, making it suitable for outdoor use when paired with the Wyze Outdoor Power Adapter (sold separately). Its durable polycarbonate body is built to withstand dust and water.
What are the key features of the Wyze Cam Pan v3?Key features of the Wyze Cam Pan v3 include 360° horizontal pan, 180° vertical tilt, 1080p Full HD video, advanced motion tagging, night vision, two-way audio, support for up to 256 GB microSD card, IP65 weather resistance, and compatibility with Alexa, Google Assistant, and IFTTT.
Does the Wyze Cam Pan v3 support night vision?Yes, the Wyze Cam Pan v3 is equipped with 4 IR LEDs for clear black-and-white night vision. Color night vision is also available when you subscribe to the Cam Plus service.
What is motion tagging on the Wyze Cam Pan v3?Motion tagging is an advanced feature that automatically highlights and tags detected motion events in your video footage, making it easy to review and find important moments quickly.
What is included in the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle?The Wyze Cam Pan v3 + 30-Day Cam Plus Bundle includes the camera, power adapter, micro USB cable, mounting kit, quick start guide, and a 30-day trial of Cam Plus, which unlocks features like person detection, package detection, and color night vision.
What smart home systems is the Wyze Cam Pan v3 compatible with?The Wyze Cam Pan v3 works with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.
How much local storage does the Wyze Cam Pan v3 support?The Wyze Cam Pan v3 supports up to a 256 GB microSD card (ExFAT format) for local video storage.
Can I use the Wyze Cam Pan v3 to communicate with people or pets?Yes, the Wyze Cam Pan v3 features two-way audio with a built-in speaker and microphone, allowing you to communicate in real time with people or pets through the camera.
Are there accessories available for the Wyze Cam Pan v3?Yes, accessories for the Wyze Cam Pan v3 include dBrand vinyl skins for customization and protection, an official replacement USB cable, and the Pan v3 + Lamp Socket v2 Bundle for flexible outdoor installation.
What is the warranty on the Wyze Cam Pan v3?The Wyze Cam Pan v3 comes with a 1-year manufacturer warranty.
What are the dimensions and weight of the Wyze Cam Pan v3?The Wyze Cam Pan v3 measures 124mm (H) x 60mm (W) x 63mm (D) and weighs 11.29 oz (320 g).
What type of Wi-Fi does the Wyze Cam Pan v3 support?The Wyze Cam Pan v3 supports 2.4 GHz Wi-Fi (802.11 b/g/n) and is compatible with Android 9.0+ and iOS 15.0+ devices.
How can I power the Wyze Cam Pan v3 outdoors?For outdoor use, the Wyze Cam Pan v3 can be powered using the Wyze Outdoor Power Adapter (sold separately) or through the Pan v3 + Lamp Socket v2 Bundle, which allows you to power the camera via a lamp socket.
What are the dimensions and weight of the Wyze Cam Pan v3?Can the Wyze Cam Pan v3 be used for both indoor and outdoor monitoring?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Cam Pan v3?
