Wyze Cam Pan v3: The Ultimate Pan and Tilt Security Camera
Wyze Cam Pan v3 is a cutting-edge indoor/outdoor security camera designed to provide comprehensive surveillance with advanced pan and tilt capabilities. This camera offers a full 360° horizontal pan and an impressive 180° vertical tilt, allowing you to monitor every corner of your space effortlessly. Whether you want to keep an eye on your home, pets, or outdoor property, the Wyze Cam Pan v3 delivers robust performance with weather-resistant durability and smart app features.
Experience reliable outdoor security with Wyze Cam Pan v3’s IP65 weather resistance.
Key Features and Specifications
- 360° Pan & 180° Tilt: Complete room coverage with smooth, quiet motorized movement that won’t disturb your environment.
- IP65 Weather Resistant: Built to withstand rain, snow, and harsh outdoor conditions (requires Wyze Outdoor Power Adapter for outdoor use).
- Automatic Motion Tracking: Detects and follows moving objects automatically, ensuring nothing escapes your watchful eye.
- Color Night Vision: Equipped with a Starlight sensor for vivid color video even in low-light conditions.
- Two-Way Audio: Communicate directly through the camera using the Wyze app, perfect for talking to family members or pets.
- Privacy Mode: Instantly disable the camera’s view by pointing it downward, giving you peace of mind when privacy is needed.
- Custom Detection Zones: Tailor motion alerts to specific areas to reduce false alarms.
- Smoke and Carbon Monoxide Alerts: Receive instant notifications if your Wyze Cam hears smoke or CO alarms.
- Local and Cloud Storage: Supports microSD cards for local recording and offers optional Cam Plus subscription for cloud storage and advanced notifications.
Robust Mobile App Integration
The Wyze app enhances your security experience with intuitive controls and smart features:
- Pan Scan™ Patrol: Set up to 4 custom waypoints for the camera to patrol automatically.
- Instant Alerts: Receive notifications for motion, sound, and specific events like crying babies or barking pets (with Cam Plus).
- Easy Setup and Control: Manage multiple cameras, view live streams, and review recorded footage from anywhere.
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle: Enhanced Security Out of the Box
For those seeking an all-in-one solution, the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle offers the same powerful camera with an added 30-day free trial of Cam Plus. This subscription unlocks unlimited event video cloud storage and advanced smart notifications, including person, package, and vehicle detection.
Bundle Highlights
- Same IP65 Weatherproof Camera: Perfect for indoor and outdoor use with the optional outdoor power adapter.
- Cam Plus Trial: Experience enhanced security features without additional cost for the first month.
- Advanced Notifications: Get smarter alerts that help you distinguish between different types of motion events.
- Flexible Subscription: Cancel anytime with no commitment after the trial period.
Stay connected with two-way audio, perfect for interacting with pets or family.
Accessories to Customize and Maintain Your Wyze Cam Pan v3
Wyze Cam Pan v3 Skins by dBrand
Personalize your camera with stylish and protective vinyl skins available in Green Camo and Triple Black. These skins provide scratch protection and a flawless fit, making your Wyze Cam Pan v3 stand out while keeping it safe.
- Easy to apply with included instructions.
- Durable, high-quality materials.
- Perfect for blending your camera into any environment.
Wyze Cam Pan v3 USB Cable
Keep your camera powered with a replacement USB cable designed specifically for the Wyze Cam Pan v3. Affordable and reliable, this cable ensures your camera stays connected without interruption.
Pan v3 + Lamp Socket v2 Bundle
Upgrade your outdoor lighting and camera setup with this innovative bundle. The lamp socket powers your Pan v3 camera without needing a separate outlet, simplifying installation and enhancing your smart home ecosystem.
- Compatible with multiple Wyze Cam models.
- Supports CFL or LED bulbs under 20W.
- Suitable for damp locations (not fully weatherproof).
Why Choose Wyze Cam Pan v3?
"Wyze Cam Pan v3 combines comprehensive 360° surveillance with smart app features and weatherproof durability, making it the perfect choice for both indoor and outdoor security needs."
With its advanced motion tracking, color night vision, and seamless mobile app integration, the Wyze Cam Pan v3 stands out as a versatile and affordable security camera. Whether you want to monitor your home, pets, or outdoor spaces, this camera delivers peace of mind with every pan and tilt.
Summary of Wyze Cam Pan v3 Products
Wyze Cam Pan v3
Enhance your security setup today with the Wyze Cam Pan v3 and its versatile accessories, backed by smart app features and reliable performance in any environment.
What is the Wyze Cam Pan v3 and what makes it unique?
The Wyze Cam Pan v3 is an advanced indoor/outdoor security camera featuring 360° horizontal pan and 180° vertical tilt, allowing for complete room or area coverage. Its unique features include automatic motion tracking, color night vision, IP65 weather resistance, two-way audio, privacy mode, and customizable detection zones, making it a versatile and reliable choice for home and property surveillance.Is the Wyze Cam Pan v3 weatherproof for outdoor use?
Yes, the Wyze Cam Pan v3 is IP65 weather resistant, making it suitable for outdoor use in rain, snow, and harsh conditions. For outdoor installation, it requires the Wyze Outdoor Power Adapter to ensure safe and reliable operation.How does motion tracking work on the Wyze Cam Pan v3?
The Wyze Cam Pan v3 features automatic motion tracking, which detects and follows moving objects within its field of view. This ensures that any activity is captured and monitored, providing comprehensive security coverage.Does the Wyze Cam Pan v3 have night vision?
Yes, the Wyze Cam Pan v3 is equipped with a Starlight sensor for color night vision, allowing it to capture vivid, full-color video even in low-light conditions.Can I communicate through the Wyze Cam Pan v3?
Absolutely. The Wyze Cam Pan v3 offers two-way audio, enabling you to speak and listen through the camera using the Wyze app. This feature is perfect for interacting with family members, pets, or visitors.What storage options are available for Wyze Cam Pan v3 recordings?
The Wyze Cam Pan v3 supports local storage via microSD cards for continuous or event-based recording. Additionally, you can opt for the Cam Plus subscription, which provides unlimited cloud storage for event videos and advanced notification features.What is included in the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle?
The Wyze Cam Pan v3 + 30-Day Cam Plus Bundle includes the weather-resistant camera and a 30-day free trial of Cam Plus. This subscription unlocks unlimited event video cloud storage and advanced smart notifications, such as person, package, and vehicle detection.What accessories are available for the Wyze Cam Pan v3?
Accessories for the Wyze Cam Pan v3 include dBrand vinyl skins for personalization and protection, a replacement USB cable for reliable power, and the Pan v3 + Lamp Socket v2 Bundle, which allows you to power the camera through a lamp socket for easy outdoor installation.How does the Pan Scan™ Patrol feature work on the Wyze Cam Pan v3?
The Pan Scan™ Patrol feature allows you to set up to four custom waypoints for the camera to automatically patrol. This ensures regular monitoring of key areas and enhances overall security coverage.Can I customize motion detection zones on the Wyze Cam Pan v3?
Yes, the Wyze Cam Pan v3 allows you to set custom detection zones through the Wyze app. This helps reduce false alarms by focusing motion alerts on specific areas of your choosing.Does the Wyze Cam Pan v3 provide alerts for smoke or carbon monoxide alarms?
Yes, the Wyze Cam Pan v3 can send instant notifications if it hears smoke or carbon monoxide alarms, adding an extra layer of safety to your home monitoring.Is the Wyze Cam Pan v3 easy to set up and control?
Yes, the Wyze Cam Pan v3 is designed for easy setup and control via the Wyze app. You can manage multiple cameras, view live streams, and review recorded footage from anywhere using your mobile device.What types of notifications can I receive with Cam Plus on the Wyze Cam Pan v3?
With Cam Plus, you receive advanced notifications for specific events such as person, package, and vehicle detection, as well as instant alerts for motion, sound, and even crying babies or barking pets.Are there any subscription commitments with the Cam Plus trial included in the bundle?
No, the 30-day Cam Plus trial included in the bundle is commitment-free. You can cancel the subscription at any time after the trial period without any obligation.
