Wyze Battery Cam Pro: Alexa & Google Assistant Compatible
Wyze Battery Cam Pro and Alexa & Google Assistant Compatibility
When it comes to smart home security, seamless integration with voice assistants like Alexa and Google Assistant is a must-have feature. The Wyze Battery Cam Pro stands out as a top choice for those seeking a wire-free, high-quality security camera that works effortlessly with both Alexa and Google Assistant. This compatibility allows you to control your camera hands-free, view live feeds on smart displays, and receive alerts through your preferred smart home ecosystem.
Key Features of Wyze Battery Cam Pro
  • 2.5K HDR Video Resolution: Capture crystal-clear video with 2560 x 1440 resolution, ensuring every detail is visible.
  • Wire-Free Design: No hub required, powered by removable, rechargeable 6200mAh battery packs that last up to 6 months on a single charge.
  • Integrated Spotlight & Siren: Enhance security with a built-in spotlight and a 100 dB siren to deter intruders.
  • Radar + PIR Motion Detection: Advanced motion sensing technology reduces false alerts by combining radar and passive infrared sensors.
  • Weatherproof (IP65 Rated): Durable for outdoor use in rain, snow, or shine.
  • Dual-Band WiFi Support: Connects to both 2.4 GHz and 5 GHz networks for reliable streaming.
  • Two-Way Audio: Communicate through the camera with a built-in speaker and microphone.
  • Local Storage & Cloud Options: Supports up to 256GB microSD cards for local recording and offers cloud storage via Cam Plus subscription.
  • Alexa & Google Assistant Integration: Easily view camera feeds on Echo Show, Google Nest Hub, and control camera functions with voice commands.
Technical Specs at a Glance
FeatureSpecification
Video Resolution2560 x 1440 (2.5K HDR)
Battery Capacity6200mAh, up to 6 months battery life
Charging TimeApprox. 9 hours
Weather ResistanceIP65
Field of View134° diagonal, 108° horizontal
Night Vision2 IR LEDs + 2 White LEDs (187 lumens)
AudioTwo-way with MEMS digital mic
WiFi2.4 GHz & 5 GHz (802.11a/n/g/b)
Voice Assistant SupportAlexa, Google Assistant, IFTTT
The Wyze Battery Cam Pro’s wire-free design combined with Alexa and Google Assistant compatibility makes it an ideal choice for flexible, smart home security without the hassle of wiring.
Wyze Battery Cam Pro + Solar Panel: Extended Power with Smart Integration
For users looking to maximize convenience and reduce manual charging, the Wyze Battery Cam Pro + Solar Panel bundle offers the same powerful features as the Battery Cam Pro with the added benefit of solar charging. This bundle ensures your camera stays powered longer with minimal intervention, perfect for remote or hard-to-reach locations.
Highlights of the Solar Panel Bundle
  • Continuous Power Supply: Solar panel keeps the rechargeable battery charged, extending camera uptime.
  • Same 2.5K HDR Video Quality: Enjoy the same high-resolution video and night vision capabilities.
  • Alexa & Google Assistant Compatible: Control and monitor your camera hands-free.
  • Weatherproof Design: Both camera and solar panel are rated IP65 for outdoor durability.
  • Integrated Spotlight & Siren: Maintain security with built-in deterrents.
  • Radar + PIR Motion Detection: Accurate motion alerts with reduced false alarms.
This bundle is perfect for those who want a truly wireless, low-maintenance security solution that integrates smoothly with smart home voice assistants.
Wyze Cam v4 Series: Wired Security with Alexa & Google Assistant Support
If you prefer wired cameras with continuous power and advanced features, the Wyze Cam v4 lineup offers excellent options with full Alexa and Google Assistant compatibility.
Wyze Cam v4 Outdoor Bundle
  • 2.5K QHD Resolution: Crystal-clear video with enhanced color night vision.
  • Motion-Activated Spotlight: Automatically lights up when motion is detected.
  • Wi-Fi 6 Support: Improved connection stability and range.
  • 24/7 Local Recording: Continuous recording with microSD card support.
  • Alexa & Google Assistant Integration: View live feeds and control camera functions via voice.
  • Smoke & CO Alerts: Receive alerts when smoke or carbon monoxide alarms are triggered.
  • Includes 4 Wyze Cam v4 cameras with 128GB microSD cards for comprehensive home coverage.
  • All features of the Outdoor Bundle plus improved 2-way audio quality.
  • Ideal for users wanting multiple wired cameras with smart assistant compatibility.
Both wired bundles provide robust security with the convenience of voice control, perfect for users who want reliable, always-on monitoring.
Why Choose Wyze Cameras for Alexa and Google Assistant?
Wyze cameras, including the Battery Cam Pro and Cam v4 series, are designed to integrate seamlessly with popular smart home ecosystems. This means:
  • Hands-Free Control: Use voice commands to view camera feeds on smart displays or control camera settings.
  • Smart Notifications: Receive alerts and interact with your cameras through Alexa or Google Assistant routines.
  • Flexible Installation: Choose between wire-free battery-powered cameras or wired cameras with continuous power.
  • Advanced Features: Enjoy high-resolution video, color night vision, motion detection, and more.
Lifestyle Image
Outdoor home security with Wyze camera Enhance your home security day and night with Wyze cameras featuring Alexa and Google Assistant compatibility.
Summary
Whether you want a wire-free camera with long battery life like the Wyze Battery Cam Pro, a solar-powered option for extended use, or a wired solution like the Wyze Cam v4 bundles, all these products offer:
  • High-quality 2.5K video resolution
  • Enhanced color night vision
  • Motion-activated spotlight and siren
  • Reliable Wi-Fi connectivity (including Wi-Fi 6 for wired cams)
  • Full compatibility with Alexa and Google Assistant for smart home integration
Choose the Wyze camera that fits your lifestyle and enjoy the convenience of voice-controlled home security.
FeatureWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelWyze Cam v4 Outdoor BundleWyze Cam v4 Home Security Bundle
Video Resolution2.5K HDR2.5K HDR2.5K QHD2.5K QHD (2560x1440)
Power SourceBattery (Removable, Rechargeable)Battery + Solar PanelWired (Outdoor Power Adapter included)Wired
WirelessYes (2.4 & 5 GHz WiFi)Yes (2.4 & 5 GHz WiFi)Yes (Wi-Fi 6)No (Wired)
Weatherproof RatingIP65IP65Yes (Outdoor compatible)IP65
Motion DetectionRadar + PIRRadar + PIRYesYes
SpotlightIntegrated Spotlight (150 lumens)Integrated Spotlight (150 lumens)Motion-activated spotlightMotion-activated spotlight
SirenIntegratedIntegratedNot specifiedNot specified
Local RecordingYes (MicroSD card, optional)Yes (MicroSD card, optional)24/7 local recording (MicroSD included)24/7 local recording (MicroSD included)
Night VisionColor Night VisionColor Night VisionEnhanced Color Night VisionColor Night Vision
AudioTwo-way audioTwo-way audioYesImproved two-way audio
SetupBluetoothⓇ Setup, no hub requiredBluetoothⓇ Setup, no hub requiredNot specifiedNot specified
Mounting OptionsFlexible, includes universal mount optionFlexible, includes universal mount optionStand, Wall mountStand, Wall mount, Ceiling mount, Magnetic
Included AccessoriesBattery packs (removable)Battery Cam Pro + Solar PanelWyze Cam v4, Outdoor Power Adapter, 128GB MicroSDWyze Cam v4 Home Security Bundle (multiple devices)
Price (approximate)$89.98 (1 pack) to $219.98 (3 pack)$109.98 (bundle)$69.99$169.99
Additional FeaturesHot-swap batteries, dual-band Wi-FiContinuous power with solar panelWi-Fi 6 support, Alexa & Google AssistantPerson detection, Wide Dynamic Range (WDR)
Smart Home CompatibilityYes (via Wyze app)Yes (via Wyze app)Alexa, Google AssistantAlexa, Google Assistant
Is the Wyze Battery Cam Pro compatible with Alexa and Google Assistant?Yes, the Wyze Battery Cam Pro is fully compatible with both Alexa and Google Assistant. You can control your camera hands-free, view live feeds on smart displays like Echo Show and Google Nest Hub, and receive alerts through your preferred smart home ecosystem.
What are the key features of the Wyze Battery Cam Pro?The Wyze Battery Cam Pro offers 2.5K HDR video resolution, a wire-free design with up to 6 months of battery life, integrated spotlight and 100 dB siren, radar plus PIR motion detection, weatherproof IP65 rating, dual-band WiFi support (2.4 GHz & 5 GHz), two-way audio, local and cloud storage options, and seamless integration with Alexa and Google Assistant.
How long does the Wyze Battery Cam Pro battery last and how is it charged?The Wyze Battery Cam Pro uses removable, rechargeable 6200mAh battery packs that can last up to 6 months on a single charge. Charging the battery takes approximately 9 hours.
Does the Wyze Battery Cam Pro require a hub for installation?No, the Wyze Battery Cam Pro features a wire-free design and does not require a hub for installation. It connects directly to your WiFi network.
Can I use a solar panel with the Wyze Battery Cam Pro?Yes, the Wyze Battery Cam Pro + Solar Panel bundle is available. The solar panel provides continuous power, reducing the need for manual charging and making it ideal for remote or hard-to-reach locations.
Is the Wyze Battery Cam Pro weatherproof?Yes, the Wyze Battery Cam Pro is IP65 rated, making it weatherproof and suitable for outdoor use in rain, snow, or shine.
What storage options are available for Wyze Battery Cam Pro?The Wyze Battery Cam Pro supports local storage with microSD cards up to 256GB and offers cloud storage through a Cam Plus subscription.
What is the video resolution of the Wyze Battery Cam Pro?The Wyze Battery Cam Pro records in 2.5K HDR with a resolution of 2560 x 1440, ensuring crystal-clear video quality.
Does the Wyze Battery Cam Pro have night vision?Yes, the Wyze Battery Cam Pro features night vision with 2 IR LEDs and 2 white LEDs (187 lumens) for clear footage even in low-light conditions.
What is included in the Wyze Cam v4 Outdoor and Home Security Bundles?The Wyze Cam v4 Outdoor Bundle includes a wired camera with 2.5K QHD resolution, color night vision, motion-activated spotlight, Wi-Fi 6 support, 24/7 local recording, and Alexa & Google Assistant integration. The Home Security Bundle includes four Wyze Cam v4 cameras with 128GB microSD cards and improved two-way audio, offering comprehensive home coverage.
Do Wyze Cam v4 cameras support Alexa and Google Assistant?Yes, all Wyze Cam v4 series cameras are compatible with Alexa and Google Assistant, allowing you to view live feeds and control camera functions using voice commands.
What are the benefits of using Wyze cameras with Alexa and Google Assistant?Wyze cameras offer hands-free control, smart notifications, flexible installation options (wire-free or wired), and advanced features like high-resolution video, color night vision, and motion detection, all integrated seamlessly with Alexa and Google Assistant for a smarter home security experience.
Can I receive alerts from Wyze cameras through Alexa or Google Assistant?Yes, you can receive smart notifications and interact with your Wyze cameras through Alexa or Google Assistant routines, keeping you informed of any activity detected by your cameras.
What WiFi networks are supported by Wyze Battery Cam Pro and Cam v4?The Wyze Battery Cam Pro supports both 2.4 GHz and 5 GHz WiFi networks (802.11a/n/g/b), while the Wyze Cam v4 series supports Wi-Fi 6 for improved connection stability and range.
Can you tell me more about the features of the Wyze Cam v4 Outdoor Bundle?What is the difference between the Wyze Battery Cam Pro and the Wyze Cam v4?Are there any ongoing sales or discounts for Wyze products?
