Top Outdoor Security Cameras with Privacy Mode & Quick Setup
Best Outdoor Security Cameras with Privacy Mode and Quick Setup
When it comes to securing your home or business outdoors, having a reliable security camera that offers privacy mode and quick setup is essential. Wyze offers a range of outdoor security cameras designed to provide crystal-clear video, smart features, and easy installation. Below, we highlight the top Wyze outdoor cameras that perfectly match your needs for privacy and fast setup.
Wyze Cam v4 – The Ultimate Outdoor Security Camera
Crystal-Clear 2.5K QHD Resolution & Enhanced Color Night Vision
Wyze Cam v4 delivers stunning 2.5K Quad HD video quality, ensuring you capture every detail with vibrant colors—even at night. Its enhanced color night vision outperforms traditional black-and-white night vision, revealing more details in low-light conditions.
Quick and Hassle-Free Setup
Thanks to Bluetooth® connectivity, the Wyze Cam v4 eliminates the need for scanning QR codes, making setup a breeze. The screw-free magnetic mount allows you to install the camera anywhere outdoors without power tools.
Privacy and Smart Features
While Wyze Cam v4 does not have a physical privacy shutter, it offers advanced motion and sound detection with customizable detection zones, so you only get alerts that matter. It also supports 24/7 local recording to a microSD card (up to 256GB) without subscription fees.
Weather-Resistant and Durable
Rated IP65, this camera withstands rain, snow, and extreme temperatures, making it perfect for any outdoor environment.
Smart Home Integration
Compatible with Alexa, Google Assistant, and IFTTT, Wyze Cam v4 fits seamlessly into your smart home ecosystem.
Additional Features:
  • Motion-activated spotlight and 99 dB siren for deterrence
  • Wi-Fi 6 support for stronger, more reliable connections
  • Smoke and CO alarm alerts for enhanced safety
Wyze Cam v4 Outdoor Setup Wyze Cam v4 installed outdoors for home security
Wyze Cam Pan v3 – Outdoor Pan, Tilt, and Privacy Mode
360° Pan and 180° Tilt with Motion Tracking
Wyze Cam Pan v3 offers full 360-degree horizontal rotation and 180-degree vertical tilt, allowing you to monitor wide outdoor areas with a single camera. Its automatic motion tracking quietly follows moving objects, ensuring nothing escapes your view.
Unique Privacy Mode
This camera features a dedicated Privacy Mode that physically rotates the lens downward 180° and disables recording, giving you peace of mind when you want to relax without being watched.
Weatherproof and Durable
With an IP65 rating, the Pan v3 is built to endure harsh weather conditions. For outdoor use, pairing it with the Wyze Outdoor Power Adapter (sold separately) ensures safe and reliable power.
Easy Setup and Smart Alerts
Setup is simple with Bluetooth® connectivity, and the camera sends instant alerts for motion and sound detection. Custom detection zones help reduce false alarms.
Two-Way Audio and Night Vision
Communicate through the camera with clear two-way audio, and enjoy color night vision powered by a Starlight sensor for vivid nighttime images. Wyze Cam Pan v3 in Snow Wyze Cam Pan v3 weather-resistant and perfect for snowy outdoor environments
Wyze Cam v4 Outdoor Bundle – Complete Security Solution
All-in-One Outdoor Security Kit
The Wyze Cam v4 Outdoor Bundle includes the Wyze Cam v4 camera with a 128GB microSD card pre-installed, providing ample local storage for continuous recording. This bundle is ideal for those who want a ready-to-go outdoor security system.
Features You Can Count On
  • 2.5K QHD video with enhanced color night vision
  • Motion-activated spotlight and siren for active deterrence
  • IP65 weather resistance for all-season protection
  • Wi-Fi 6 support and smart assistant compatibility
Convenient Mounting Options
The bundle offers multiple mounting options including stand, wall, ceiling, and magnetic mounts, making installation flexible and straightforward.
Why Choose Wyze Outdoor Security Cameras?
"Wyze outdoor cameras combine advanced technology with user-friendly features, making home security accessible and effective for everyone."
  • Privacy Mode: Especially with Wyze Cam Pan v3, you can easily disable the camera’s view when privacy is needed.
  • Quick Setup: Bluetooth-enabled setup and magnetic mounts mean you can have your camera up and running in minutes.
  • Smart Alerts: Customizable motion zones and sound detection reduce false alarms and keep you informed.
  • Weatherproof: IP65 rating ensures your camera performs reliably in rain, snow, or shine.
  • Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT for seamless control.
Summary of Key Specs
FeatureWyze Cam v4Wyze Cam Pan v3Wyze Cam v4 Outdoor Bundle
Video Resolution2.5K QHD (2560x1440)1080p2.5K QHD (2560x1440)
Field of View115.9° diagonal360° pan / 180° tilt115.9° diagonal
Night VisionEnhanced Color Night VisionColor Night Vision (Starlight Sensor)Enhanced Color Night Vision
Privacy ModeNo physical shutterYes (rotates lens down)No physical shutter
Weather ResistanceIP65IP65IP65
SetupBluetooth, Magnetic MountBluetooth, Magnetic MountBluetooth, Magnetic Mount
Two-Way AudioYesYesYes
Spotlight & SirenYesNo spotlight, siren availableYes
Local StorageUp to 256GB microSDUp to 256GB microSD128GB microSD included
Smart Assistant SupportAlexa, Google, IFTTTAlexa, Google, IFTTTAlexa, Google, IFTTT
Secure your outdoor spaces with Wyze’s advanced, easy-to-install security cameras that respect your privacy and keep you connected. Whether you want full panoramic coverage with privacy mode or a high-resolution camera with enhanced night vision, Wyze has the perfect outdoor security solution for you.
FeatureWyze Cam v4Wyze Cam Pan v3Wyze Cam v4 Home Security BundleWyze Cam v4 Outdoor Bundle
TypeWired Security CameraWired Pan & Tilt Security CameraWired Security Camera BundleWired Security Camera Bundle
Video Resolution2.5K QHD (2560x1440)1080p (1920x1080)2.5K QHD (2560x1440)2.5K QHD (2560x1440)
Field of View (FOV)115.8° (D) x 98.5° (H) x 53.1° (V)360° pan, 180° tilt, 120° FOV115.8° (D) x 98.5° (H) x 53.1° (V)115.8° (D) x 98.5° (H) x 53.1° (V)
Night VisionEnhanced Color Night VisionColor Night Vision (Starlight Sensor)Enhanced Color Night VisionEnhanced Color Night Vision
SpotlightMotion-activated spotlightNoMotion-activated spotlightMotion-activated spotlight
SirenYes, 99 dB waterproofBuilt-in siren (not specified dB)Yes, 99 dB waterproofYes, 99 dB waterproof
AudioEnhanced 2-way talk, noise & echo cancellation2-way audio, noise & echo cancellationImproved 2-way audioEnhanced 2-way talk
Motion DetectionYes, with detection zonesYes, with motion tracking & detection zonesYes, with detection zonesYes, with detection zones
Sound DetectionYesYesYesYes
Person DetectionYesNot specifiedYesYes
Smoke & CO AlertsYesYesYesYes
Local StoragemicroSD card up to 512GB (sold separately)microSD up to 256GB (sold separately)microSD card 128GB includedmicroSD card 128GB included
Cloud StorageSubscription requiredSubscription requiredSubscription requiredSubscription required
Wi-Fi Support2.4 GHz & Wi-Fi 62.4 GHz onlyWi-Fi 6Wi-Fi 6
Weather ResistanceIP65IP65IP65IP65
Power SourceWired (USB)Wired (Micro USB)Wired (USB)Wired (USB)
Outdoor UseYes (with outdoor power adapter sold separately)Yes (requires outdoor power adapter sold separately)Indoor/OutdoorYes (includes outdoor power adapter)
Mounting OptionsStand, Wall, Ceiling, MagneticScrew mountStand, Wall, Ceiling, MagneticStand, Wall, Ceiling, Magnetic
Dimensions2in x 2in x 2 3/8in124mm x 60mm x 63mm2in x 2in x 2 3/8inNot specified
Weight0.49 lb (222 g)11.29 oz (320 g)0.49 lb (222 g)Not specified
Digital Zoom8x8x8x8x
Video FPSDay: 20 FPS / Night: 15 FPSDay: 20 FPS / Night: 15 FPSDay: 20 FPS / Night: 15 FPSDay: 20 FPS / Night: 15 FPS
Included ItemsCamera, USB power adapter, mounts, cableCamera, power adapter, mount kit, cableCamera, 128GB microSD card, power adapter, mountsCamera, 128GB microSD card, outdoor power adapter
Price$35.98 (single)$39.98 (single)$169.99$69.99
CompatibilityAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google AssistantAlexa, Google Assistant
Warranty1 Year1 Year1 YearNot specified
What are the best Wyze outdoor security cameras with privacy mode?The Wyze Cam Pan v3 is the best Wyze outdoor security camera with a dedicated privacy mode. It physically rotates the lens downward and disables recording, ensuring your privacy whenever needed.
How easy is it to set up Wyze outdoor security cameras?Wyze outdoor security cameras feature Bluetooth® connectivity and magnetic mounts, allowing for quick and hassle-free setup without the need for power tools or scanning QR codes. Most users can have their cameras up and running in just a few minutes.
Do Wyze outdoor cameras support local video storage?Yes, Wyze outdoor cameras support local video storage via microSD cards. The Wyze Cam v4 and Pan v3 support up to 256GB microSD cards, while the Wyze Cam v4 Outdoor Bundle comes with a 128GB microSD card pre-installed for continuous recording without subscription fees.
Are Wyze outdoor security cameras weatherproof?All featured Wyze outdoor security cameras, including the Cam v4 and Pan v3, are rated IP65. This means they are weather-resistant and can withstand rain, snow, and extreme temperatures, making them suitable for year-round outdoor use.
What smart home systems are Wyze outdoor cameras compatible with?Wyze outdoor security cameras are compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless integration into your existing smart home ecosystem.
What is the video quality of Wyze outdoor security cameras?The Wyze Cam v4 and the v4 Outdoor Bundle offer 2.5K QHD (2560x1440) resolution for crystal-clear video, while the Wyze Cam Pan v3 provides 1080p HD video. All models feature enhanced color night vision for superior low-light performance.
Do Wyze outdoor cameras have two-way audio?Yes, all Wyze outdoor security cameras featured here include two-way audio, allowing you to listen and speak through the camera using the Wyze app.
What privacy features do Wyze outdoor cameras offer?The Wyze Cam Pan v3 offers a unique privacy mode that physically rotates the lens downward and disables recording. Other models provide customizable motion and sound detection zones to minimize unnecessary alerts and protect your privacy.
What mounting options are available for Wyze outdoor cameras?Wyze outdoor cameras offer flexible mounting options, including stand, wall, ceiling, and magnetic mounts. This makes installation easy and adaptable to various outdoor locations.
Do Wyze outdoor cameras have night vision?Yes, Wyze outdoor cameras feature enhanced color night vision. The Wyze Cam v4 uses advanced technology for vibrant nighttime images, while the Pan v3 utilizes a Starlight sensor for vivid color night vision.
What additional security features do Wyze outdoor cameras provide?Wyze Cam v4 and the v4 Outdoor Bundle include a motion-activated spotlight and a 99 dB siren for active deterrence. They also offer smoke and CO alarm alerts for enhanced safety.
Is a subscription required for Wyze outdoor cameras to record video?No subscription is required for local video recording. Wyze outdoor cameras support continuous recording to a microSD card, allowing you to store footage locally without ongoing fees.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes a Wyze Cam v4 camera and a 128GB microSD card pre-installed, providing a complete outdoor security solution with ample local storage.
What are the key features of the Wyze Cam v4?Can you explain how the privacy mode works on the Wyze Cam Pan v3?Are there any ongoing sales or discounts for Wyze outdoor security cameras?
