Outdoor Ready Backup Adapter for Wyze Cam V3: Secure Your Camera Power
When it comes to protecting your home with Wyze Cam V3 or upgrading to the latest Wyze Cam V4, having a reliable outdoor power solution is essential. Cable damage or power interruptions can leave your security vulnerable. The
Wyze Outdoor Power Adapter is designed specifically to keep your Wyze cameras running smoothly outdoors, even in harsh weather conditions.
This page highlights the best Wyze cameras and bundles equipped with outdoor-ready power adapters, ensuring continuous security coverage without interruption.
Wyze Cam V4: The Ultimate Outdoor Security Camera
Superior Video Quality and Night Vision
Wyze Cam V4 delivers crystal-clear 2.5K Quad High Definition (QHD) video resolution, providing sharp and detailed footage day or night. Its enhanced
Color Night Vision uses advanced hardware to reveal vibrant colors in low-light conditions, far beyond traditional black-and-white night vision.
Weather-Resistant and Durable
Rated
IP65 weather resistance, Wyze Cam V4 is built to withstand rain, snow, and extreme temperatures from -4ºF to 122ºF (-20ºC to 50ºC). This makes it perfect for outdoor installation where cable damage risks are higher.
Smart Features and Connectivity
- Wi-Fi 6 support ensures a stronger, more reliable connection.
- Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home integration.
- Motion and sound detection with customizable detection zones.
- Built-in siren (99 dB) and motion-activated spotlight for enhanced security.
- Continuous 24/7 local recording with microSD card support up to 512GB (sold separately).
Easy Installation and Power Backup
Wyze Cam V4 uses a 6-foot flat micro USB to USB-A cable and requires a
Wyze Outdoor Power Adapter for outdoor use, protecting the power connection from weather and damage.
"Wyze Cam V4 is the clearest and most feature-packed Wyze camera yet, designed to keep your home safe in any environment."
Wyze Cam V4 in action outdoors with night vision and spotlight
Wyze Cam V4 Outdoor Bundle: Complete Outdoor Security Solution
What’s Included?
- Wyze Cam V4 (available in White, Grey, or Black)
- Wyze Outdoor Power Adapter designed for weather resistance and durability
- 128GB Wyze MicroSD Card for continuous local recording
Why Choose the Outdoor Bundle?
This bundle is perfect for those who want a hassle-free, all-in-one outdoor security setup. The included outdoor power adapter ensures your camera stays powered even if cables are damaged or exposed to the elements.
Key Features
- 2.5K QHD video with Wide Dynamic Range (WDR) for vibrant colors
- Enhanced Color Night Vision and motion-activated spotlight
- Wi-Fi 6 for improved connectivity
- Compatibility with Alexa and Google Assistant
- 24/7 local recording with included 128GB microSD card
"The Wyze Cam V4 Outdoor Bundle offers unmatched security and convenience, making it the ideal choice for outdoor surveillance."
Wyze Cam V4 Home Security Bundle: Multi-Camera Protection
Expand Your Security Network
The Home Security Bundle includes multiple Wyze Cam V4 cameras with outdoor-ready features, perfect for comprehensive home coverage. Each camera supports the outdoor power adapter, ensuring reliable power supply and protection against cable damage.
Features at a Glance
- 2.5K QHD resolution with color night vision
- Motion-activated spotlight and built-in siren
- IP65 weather resistance for outdoor durability
- 128GB microSD card included for local storage
- Multiple mounting options: stand, wall, ceiling, or magnetic mounts
"Ideal for users who want to secure multiple areas with the same trusted Wyze technology."
Why Use the Wyze Outdoor Power Adapter?
Protect Your Investment
Outdoor environments expose power cables to weather, animals, and accidental damage. The Wyze Outdoor Power Adapter is specifically designed to:
- Provide a weatherproof connection for your Wyze Cam V3 or V4
- Prevent power interruptions caused by cable wear or damage
- Ensure continuous 24/7 recording and monitoring without downtime
Compatibility
- Works seamlessly with Wyze Cam V3 and Wyze Cam V4 models
- Supports the camera’s power requirements (5V/1A output)
- Designed for easy installation with a 6-foot flat micro USB cable
Summary: Best Outdoor Backup Power for Wyze Cameras
Product | Key Features | Outdoor Power Adapter Included | Price Range |
Wyze Cam V4 | 2.5K QHD, Color Night Vision, IP65, Wi-Fi 6 | No | $35.98+ |
Wyze Cam V4 Outdoor Bundle | Includes Outdoor Power Adapter + 128GB microSD | Yes | $69.99 |
Wyze Cam V4 Home Security Bundle | Multi-camera pack with outdoor-ready features | Yes | $169.99 |
For reliable outdoor security and peace of mind, pairing your Wyze Cam V3 or V4 with the
Wyze Outdoor Power Adapter is essential. Protect your camera’s power source from damage and enjoy uninterrupted surveillance.
Secure your home with Wyze Cam and outdoor power adapter
Frequently Asked Questions
Q: Can I use the Wyze Outdoor Power Adapter with Wyze Cam V3?
A: Yes, the adapter is designed to work with both Wyze Cam V3 and V4 for outdoor use.
Q: Does the outdoor power adapter protect against weather damage?
A: Yes, it is built to withstand outdoor conditions and protect the power connection from rain, snow, and other elements.
Q: Is a microSD card required for continuous recording?
A: Yes, continuous local recording requires a microSD card, which is included in some bundles or sold separately.
Secure your Wyze Cam with the right outdoor power solution today and never worry about cable damage disrupting your home security.
Is the Wyze Outdoor Power Adapter compatible with both Wyze Cam V3 and V4?
Yes, the Wyze Outdoor Power Adapter is specifically designed to work seamlessly with both Wyze Cam V3 and Wyze Cam V4 models, providing reliable outdoor power and weather protection.Does the Wyze Outdoor Power Adapter protect against weather and cable damage?
Absolutely. The Wyze Outdoor Power Adapter is built for weather resistance, protecting your camera’s power connection from rain, snow, extreme temperatures, and accidental cable damage.What is included in the Wyze Cam V4 Outdoor Bundle?
The Wyze Cam V4 Outdoor Bundle includes a Wyze Cam V4 (available in White, Grey, or Black), a Wyze Outdoor Power Adapter for weather-resistant power, and a 128GB Wyze MicroSD Card for continuous local recording.Is a microSD card required for continuous 24/7 recording on Wyze Cam V4?
Yes, a microSD card is required for continuous 24/7 local recording on Wyze Cam V4. Some bundles include a 128GB microSD card, or you can purchase one separately (supports up to 512GB).What weather conditions can Wyze Cam V4 withstand?
Wyze Cam V4 is rated IP65 for weather resistance and can operate in temperatures ranging from -4ºF to 122ºF (-20ºC to 50ºC), making it suitable for outdoor use in rain, snow, and extreme temperatures.What are the key features of Wyze Cam V4 for outdoor security?
Wyze Cam V4 offers 2.5K QHD video resolution, enhanced Color Night Vision, motion-activated spotlight, built-in 99 dB siren, Wi-Fi 6 connectivity, IP65 weather resistance, and compatibility with Alexa, Google Assistant, and IFTTT.Why should I use the Wyze Outdoor Power Adapter for my security camera?
Using the Wyze Outdoor Power Adapter ensures a weatherproof and durable power connection for your Wyze Cam V3 or V4, preventing power interruptions and protecting against cable wear or damage for uninterrupted security monitoring.Does the Wyze Cam V4 Home Security Bundle include outdoor-ready features?
Yes, the Wyze Cam V4 Home Security Bundle includes multiple cameras with outdoor-ready features, such as IP65 weather resistance and support for the Wyze Outdoor Power Adapter, ensuring reliable power and protection for comprehensive home security.How long is the cable included with the Wyze Outdoor Power Adapter?
The Wyze Outdoor Power Adapter comes with a 6-foot flat micro USB to USB-A cable, designed for easy installation and optimal outdoor use.Is the Wyze Outdoor Power Adapter easy to install?
Yes, the Wyze Outdoor Power Adapter is designed for simple installation, allowing you to quickly set up your Wyze Cam V3 or V4 for reliable outdoor power and protection.
