Safely Power Wyze Cam Outdoors with Weatherproof Adapter
Keep Your Wyze Cam Outdoor Powered Safely During Long Vacations
When leaving your home for an extended period, ensuring your Wyze outdoor cameras stay powered and protected is essential for continuous security monitoring. The Wyze Outdoor Power Adapter is the safest and most reliable solution to keep your Wyze Cam outdoor devices powered through rain, snow, or shine. This page highlights the best accessories and cameras designed for outdoor use, focusing on long-term power solutions and weather resistance.
Wyze Outdoor Power Adapter: Reliable Power for Outdoor Cameras
Weather-Resistant and Durable Design
The Wyze Outdoor Power Adapter is built to withstand harsh outdoor conditions with an IP67 weather-resistant rating, making it perfect for powering your Wyze cameras during long vacations or any extended outdoor use. Whether it's rain, snow, or extreme temperatures from -30°C to 50°C (-22°F to 122°F), this adapter keeps your camera running without interruption.
Compatibility and Convenience
  • Compatible with Wyze Cam v3, v4, Pan v3, and Battery Cam Pro (note: some models require additional adapters).
  • Comes with a 12.5 ft (3.8 m) cable for flexible installation.
  • Includes L-shaped Micro USB Adapter and USB-C adapter options for different camera models.
  • Certified by FCC and UL for safety and reliability.
  • Comes with mounting accessories like wire clips and screws for secure outdoor installation.
Ready for rain, snow, or shine, the Wyze Outdoor Power Adapter ensures your camera stays powered safely and continuously.
Wyze Cam Pan v3: 360° Outdoor Surveillance with Power Adapter Support
Full Outdoor Protection with IP65 Rating
The Wyze Cam Pan v3 is a versatile indoor/outdoor camera featuring a 360° horizontal pan and 180° vertical tilt, allowing you to monitor wide areas with ease. Its IP65 weather resistance makes it suitable for outdoor use when paired with the Wyze Outdoor Power Adapter.
Key Features
  • 1080p Full HD video with 4 IR LEDs for night vision.
  • Built-in two-way audio with noise and echo cancellation.
  • Supports up to 256 GB microSD for local storage.
  • Compatible with Alexa, Google Assistant, and IFTTT.
  • Requires the Wyze Outdoor Power Adapter for safe outdoor power.
Perfect for Vacation Security
With the Pan v3 and Outdoor Power Adapter combo, you can leave your home knowing your property is monitored with a weatherproof, powered camera that won’t lose connection or power during your absence. Wyze Cam Pan v3 Outdoor Use Wyze Cam Pan v3 powered outdoors in snowy conditions
Wyze L-Shaped Micro USB Adapter: Essential for Proper Power Connection
Designed for Seamless Outdoor Setup
The Wyze L-Shaped Micro USB Adapter is a small but crucial accessory that works with the Wyze Outdoor Power Adapter to ensure a secure and weatherproof connection to your Wyze Cam Pan v3 or Cam v3 Pro. Its L-shaped design helps reduce cable strain and fits neatly against walls or mounting surfaces.
Why You Need It
  • Enables compatibility between the Outdoor Power Adapter and specific Wyze camera models.
  • Helps maintain a weatherproof seal at the connection point.
  • Affordable and easy to install.
Why Choose Wyze Outdoor Power Solutions for Long Vacations?
Leaving your Wyze Cam outdoors powered safely during long vacations requires a combination of weatherproof hardware and reliable power delivery. The Wyze Outdoor Power Adapter paired with compatible cameras like the Pan v3 ensures continuous surveillance without worrying about battery life or weather damage.
  • IP67-rated adapter and IP65-rated cameras provide robust protection.
  • Long cable lengths allow flexible camera placement.
  • Certified safety standards give peace of mind.
  • Accessories like the L-shaped adapter optimize installation and durability.
Summary of Products for Outdoor Power and Security
ProductKey FeaturesIdeal For
Wyze Outdoor Power AdapterIP67 weather resistance, 12.5 ft cable, multiple adapters includedKeeping Wyze outdoor cams powered safely
Wyze Cam Pan v3360° pan, 1080p HD, IP65 rating, two-way audioWide-area outdoor surveillance
Wyze L-Shaped Micro USB AdapterWeatherproof connection, compatible with Pan v3 and Cam v3 ProSecure power connection outdoors
By choosing the Wyze Outdoor Power Adapter and compatible Wyze cameras, you ensure your home security system remains active and reliable throughout your long vacations, no matter the weather.
FeatureWyze Outdoor Power AdapterWyze Cam Pan v3Wyze L-Shaped Micro USB Adapter
TypeAccessoryCameraReplacement Part
Weather ResistanceIP67IP65Not specified
CompatibilityWyze Cam v4, OG series, Cam Pan v3, Cam v3 Pro (with L-shaped adapter), Battery Cam Pro (with USB-C adapter)Indoor/outdoor use with Wyze Outdoor Power AdapterWorks with Wyze Cam Pan v3, Cam v3 Pro, Outdoor Adapter v1
Required for Outdoor UseYesYes (requires Outdoor Power Adapter)Used with Outdoor Power Adapter for Pan v3 or v3 Pro
Power Adapter Output5V/2000mA5V/2000mA (via included power adapter)N/A
Cable LengthNot specified6" (1.8 m) micro USB cable includedN/A
Price$14.99 - $19.99 (varies by variant)$39.98 - $114.94 (varies by pack and color)$5.99
VariantsOutdoor Adapter + L-shaped Adapter + USB-C Adapter, Outdoor Adapter + L-shaped Adapter, L-shaped Micro USB Adapter onlyBlack or White, 1/2/3 packDefault Title
Use CaseProvides weather-resistant power supply for outdoor Wyze cameras360° pan, 180° tilt security camera with motion tracking and two-way audioAdapter to connect Outdoor Power Adapter to Pan v3 or v3 Pro
DimensionsNot specified124mm (H) x 60mm (W) x 63mm (D)Not specified
WeightNot specified11.29 oz (320 g)Not specified
IP RatingIP67IP65Not specified
WarrantyNot specified1-YearNot specified
How can I keep my Wyze Cam outdoor powered safely during long vacations?To keep your Wyze Cam outdoor powered safely during long vacations, use the Wyze Outdoor Power Adapter. It provides continuous, weather-resistant power to your Wyze cameras, ensuring uninterrupted security monitoring even in harsh weather conditions.
What is the Wyze Outdoor Power Adapter and why is it recommended for outdoor cameras?The Wyze Outdoor Power Adapter is a weather-resistant power solution designed specifically for Wyze outdoor cameras. With an IP67 rating, it protects against rain, snow, and extreme temperatures, making it ideal for long-term outdoor use and extended vacations.
Which Wyze cameras are compatible with the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter is compatible with Wyze Cam v3, v4, Pan v3, and Battery Cam Pro. Some models may require additional adapters, such as the L-shaped Micro USB Adapter or USB-C adapter, which are included.
Is the Wyze Outdoor Power Adapter weatherproof?Yes, the Wyze Outdoor Power Adapter is IP67 weather-resistant, meaning it is protected against dust and can withstand immersion in water up to 1 meter. It operates reliably in temperatures ranging from -30°C to 50°C (-22°F to 122°F).
What accessories are included with the Wyze Outdoor Power Adapter?The Wyze Outdoor Power Adapter comes with a 12.5 ft (3.8 m) cable, L-shaped Micro USB Adapter, USB-C adapter, wire clips, and screws for secure and flexible outdoor installation.
Why do I need the Wyze L-Shaped Micro USB Adapter?The Wyze L-Shaped Micro USB Adapter is essential for creating a secure and weatherproof connection between the Wyze Outdoor Power Adapter and certain camera models, such as the Wyze Cam Pan v3 and Cam v3 Pro. Its design reduces cable strain and helps maintain a tight seal against the elements.
What are the key features of the Wyze Cam Pan v3 for outdoor surveillance?The Wyze Cam Pan v3 offers 360° horizontal pan, 180° vertical tilt, 1080p Full HD video, night vision with 4 IR LEDs, two-way audio with noise and echo cancellation, and an IP65 weather resistance rating. It supports up to 256 GB microSD cards for local storage and is compatible with Alexa, Google Assistant, and IFTTT.
Do I need the Wyze Outdoor Power Adapter to use the Wyze Cam Pan v3 outdoors?Yes, for safe and reliable outdoor use, the Wyze Cam Pan v3 requires the Wyze Outdoor Power Adapter. This ensures the camera remains powered and protected from weather conditions during extended periods.
Are Wyze outdoor power solutions certified for safety?Yes, the Wyze Outdoor Power Adapter is certified by FCC and UL, ensuring it meets high safety and reliability standards for outdoor use.
What makes Wyze outdoor power solutions ideal for long vacations?Wyze outdoor power solutions, such as the Outdoor Power Adapter and compatible cameras, offer weatherproof protection, long cable lengths for flexible placement, certified safety, and essential accessories for secure installation. This combination ensures your security cameras remain active and reliable throughout your long vacations.
What are the key features of the Wyze Outdoor Power Adapter?Can the Wyze Outdoor Power Adapter be used with other Wyze camera models?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Outdoor Power Adapter?
