Organized Cable Solution for Wyze Cam: Eliminate Tripping Hazards with the 20ft USB Extension Cable
When it comes to securing your home with Wyze Cam, cable management is essential to maintain a clean, safe, and hazard-free environment. The
Wyze Cam USB Extension Cable - 20ft is the perfect accessory to extend your camera’s reach while eliminating tripping hazards caused by short or tangled cables. Whether you have indoor or outdoor Wyze cameras, this extension cable offers the flexibility and length you need for a neat and organized setup.
Wyze Cam USB Extension Cable - 20ft: Freedom and Safety in One Cable
Key Features:
- Length: 20 feet of durable USB extension cable, providing ample length to position your Wyze Cam exactly where you want it.
- Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
- Safety: By extending the cable length, you can route cables along walls, ceilings, or behind furniture to prevent tripping hazards and maintain a tidy space.
- Affordable: Priced at just $7.99, it’s an economical solution to improve your home security setup.
Say goodbye to short cables and tangled wires. This extension cable lets you enjoy the freedom to place your Wyze Cam in the optimal location without worrying about power outlet proximity or messy cables.
Enhance Your Wyze Cam Setup with Compatible Cameras
To maximize the benefits of the 20ft USB extension cable, consider pairing it with these popular Wyze Cam models that are fully compatible and ideal for various home security needs.
Wyze Cam v4
- Video Quality: Stunning 2.5K QHD resolution with wide dynamic range and color night vision.
- Field of View: 115.8° diagonal, 98.5° horizontal, and 53.1° vertical.
- Connectivity: Supports Wi-Fi 6 and Bluetooth 5.2 for reliable streaming.
- Weather Resistance: Rated IP65 for outdoor use.
- Mounting Options: Versatile mounting including magnetic wall mount, ceiling, and stand.
- Included Cable: Comes with a 6-foot flat micro USB to USB-A cable, which can be extended with the 20ft USB extension cable for flexible placement.
Wyze Cam OG
- Video Quality: Full HD 1080p with 120° field of view.
- Features: Built-in spotlight, 3X faster notifications, improved two-way audio.
- Durability: IP65 weather resistance for indoor/outdoor use.
- Cable Length: Standard 6 ft cable, extendable with the 20ft USB extension cable.
- Ideal For: Versatile indoor/outdoor monitoring with motion-activated spotlights.
Wyze Cam Pan v3 (Included in Bundles)
- Coverage: 360° horizontal and 180° vertical pan and tilt.
- Smart Tracking: AI-powered motion tracking to follow activity.
- Night Vision: Color night vision with two-way audio.
- Power Options: Can be powered via lamp socket or USB cable, extendable with the 20ft USB extension cable for flexible installation.
Why Use the Wyze Cam USB Extension Cable?
Longer cables allow you to route wires along walls, ceilings, or behind furniture, keeping floors clear and safe from accidental trips or damage.
Flexible Camera Placement
Place your Wyze Cam exactly where you need it — high corners, outdoor eaves, or hard-to-reach spots — without being limited by the original cable length.
Easy Installation
No need for complicated wiring or additional power sources. Simply plug the extension cable between your camera and power adapter for instant extended reach.
Lifestyle Image: Secure and Organized Home Setup
Keep your home security neat and hazard-free with extended cable solutions.
Additional Accessories to Complement Your Wyze Cam Setup
While the USB extension cable solves cable length issues, consider these accessories for a complete, organized, and smart home security system:
- Wyze Cam Floodlight Plug-In Mount: A plug-and-play floodlight mount with a 20 ft power cord, perfect for outdoor lighting and security without complex wiring.
- Pan v3 + Lamp Socket v2 Bundle: Power your Pan v3 camera directly from a lamp socket, eliminating the need for an outlet and additional cables.
Summary
The
Wyze Cam USB Extension Cable - 20ft is an essential accessory for anyone looking to organize their Wyze Cam setup and eliminate tripping hazards caused by short cables. Compatible with a wide range of Wyze cameras, it offers flexibility, safety, and convenience at an affordable price. Pair it with your Wyze Cam v4, Wyze Cam OG, or Wyze Cam Pan v3 for a seamless, tidy, and effective home security solution.
What is the Wyze Cam USB Extension Cable - 20ft used for?
The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze Cam, allowing you to position your camera exactly where you need it while eliminating tripping hazards caused by short or tangled cables. It helps maintain a clean, safe, and organized home security setup.Which Wyze Cam models are compatible with the 20ft USB extension cable?
The 20ft USB extension cable is compatible with Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.How does the Wyze Cam USB Extension Cable improve safety?
By providing a longer cable, the Wyze Cam USB Extension Cable allows you to route wires along walls, ceilings, or behind furniture, keeping floors clear and reducing the risk of tripping hazards in your home.Can the Wyze Cam USB Extension Cable be used outdoors?
Yes, the Wyze Cam USB Extension Cable can be used with outdoor Wyze cameras, such as the Wyze Cam v4 and Wyze Cam OG, which are rated for outdoor use. The cable’s length and durability make it suitable for both indoor and outdoor installations.How long is the Wyze Cam USB Extension Cable?
The Wyze Cam USB Extension Cable is 20 feet long, providing ample length to position your camera in hard-to-reach or optimal locations.Is the Wyze Cam USB Extension Cable easy to install?
Yes, installation is simple. Just plug the extension cable between your Wyze Cam and the power adapter to instantly extend your camera’s reach without the need for complicated wiring or additional power sources.What is the price of the Wyze Cam USB Extension Cable - 20ft?
The Wyze Cam USB Extension Cable - 20ft is affordably priced at $7.99, making it an economical solution for improving your home security setup.Can I use the 20ft USB extension cable with the Wyze Cam Pan v3?
Yes, the 20ft USB extension cable is fully compatible with the Wyze Cam Pan v3, allowing for flexible installation and extended reach, whether you power it via a lamp socket or USB cable.What are the benefits of using a USB extension cable with my Wyze Cam?
Using a USB extension cable with your Wyze Cam allows for flexible camera placement, eliminates tripping hazards, and helps maintain a tidy and organized home security setup.Are there additional accessories to complement the Wyze Cam USB Extension Cable?
Yes, you can further enhance your Wyze Cam setup with accessories like the Wyze Cam Floodlight Plug-In Mount, which includes a 20 ft power cord for outdoor lighting and security, and the Pan v3 + Lamp Socket v2 Bundle, which allows you to power your Pan v3 camera directly from a lamp socket.
