20ft Wyze Cam USB Extension Cable for Front Yard Night Security
Extend Your Wyze Cam Reach with the 20ft USB Extension Cable
When monitoring your front yard at night, having the right cable length is crucial for optimal camera placement. The Wyze Cam USB Extension Cable - 20ft is designed to give you the freedom to position your Wyze Cam exactly where you need it without worrying about power outlet proximity.
Key Features of the Wyze Cam USB Extension Cable - 20ft
  • Length: 20 feet of durable USB extension cable, perfect for outdoor setups.
  • Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto models.
  • Ease of Use: Simply plug in to extend your existing USB cable without any complex installation.
  • Affordable: Priced at just $7.99, it’s a cost-effective solution to extend your camera’s reach.
This cable is ideal for extending your Wyze Cam’s power source to cover larger outdoor areas like your front yard, ensuring your camera stays powered throughout the night.
Enhance Nighttime Security with Wyze Cam v4
For front yard activity monitoring at night, the Wyze Cam v4 is a top choice. It offers advanced night vision and smart features that make it perfect for outdoor security.
Wyze Cam v4 Highlights
  • Video Quality: Crisp 2.5K QHD resolution (2560x1440) for clear, detailed footage.
  • Night Vision: Equipped with 4 IR LEDs and 2 white spotlight LEDs (72 lumens) for color night vision.
  • Weather Resistant: Rated IP65, suitable for outdoor use in temperatures from -4ºF to 122ºF.
  • Field of View: Wide 115.8° diagonal field of view to cover more area.
  • Smart Features: Two-way talk, built-in siren, noise and echo cancellation, and Alexa/Google Assistant integration.
  • Connectivity: Supports 2.4 GHz Wi-Fi and Wi-Fi 6 for reliable streaming.
  • Power: Comes with a 6-foot flat micro USB to USB-A cable; extendable with the 20ft USB extension cable for flexible placement.
With the Wyze Cam v4 combined with the 20ft USB extension cable, you can easily position your camera in the perfect spot to monitor your front yard activity at night with vivid color and sharp detail. Outdoor security camera mounted on home exterior at dusk
Brighten and Secure Your Front Yard with Wyze Cam Floodlight Plug-In Mount
For enhanced nighttime visibility and security, pairing your Wyze Cam with the Wyze Cam Floodlight Plug-In Mount is an excellent solution.
Features of Wyze Cam Floodlight Plug-In Mount
  • Plug-n-Play: No need for complicated junction box installation; simply plug in.
  • Power Cord Length: 20 ft power cord to reach outdoor outlets easily.
  • Outdoor Safe: Designed to withstand outdoor conditions with operating temperatures from -22ºF to 122ºF.
  • Compatibility: Works with Wyze Cam Floodlight v1, v2, and Floodlight Pro.
  • Included Items: Mount, mounting kit, foam tape, and quick start guide for easy setup.
  • Certifications: UL, RoHS, CP65, and more for safety and reliability.
This mount allows you to add powerful floodlighting to your Wyze Cam setup, illuminating your front yard and deterring unwanted activity during nighttime hours. Wyze Cam Floodlight illuminating a deck at night
Why Choose Wyze for Your Front Yard Night Security?
Wyze offers a comprehensive ecosystem of smart cameras and accessories designed to work together for seamless home security. Using the Wyze Cam USB Extension Cable - 20ft with the Wyze Cam v4 and optional Floodlight Plug-In Mount gives you:
  • Extended reach for flexible camera placement.
  • Clear, color night vision to capture every detail.
  • Easy installation with plug-and-play accessories.
  • Weatherproof durability for reliable outdoor use.
  • Smart home integration for voice control and automation.
"Extend your security coverage effortlessly and keep your front yard safe and well-lit all night long with Wyze’s trusted camera solutions."
Summary of Products for Front Yard Night Monitoring
Product NamePurposePrice
Wyze Cam USB Extension Cable - 20ftExtend USB power cable length$7.99
Wyze Cam v4High-resolution outdoor camera$100.00
Wyze Cam Floodlight Plug-In MountOutdoor floodlight power mount$19.98
FeatureWyze Cam USB Extension Cable - 20ftWyze Cam v4Wyze Cam Floodlight Plug-In Mount
TypeAccessoryCameraAccessory
Price$7.99$100.00 (standard), $35.98 (discounted bundle)$19.98
CompatibilityWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoStandalone cameraWyze Cam Floodlight v1, v2, Floodlight Pro
Cable Length20 ft USB extension cable6-Foot Flat micro USB to USB-A cable20 ft power cord
ResolutionN/A2.5K QHD (2560x1440)N/A
Night VisionN/AEnhanced Color Night VisionN/A
Weather ResistanceN/AIP65Outdoor safe
Power SourceUSB poweredWired (5V/1A)110-120V AC
FeaturesExtends USB cable lengthColor Night Vision, Motion-Activated Spotlight, Wi-Fi 6, Two-Way Talk, Siren, Local Recording, AI TrackingPlug-n-play floodlight mount, easy installation, outdoor safe
Operating TemperatureNot specified-4°F to 122°F (-20°C to 50°C)-22°F to 122°F
CertificationsNot specifiedNot specifiedUL153, RoHS, REACH SVHC 240, CP65, UL94, UL746A,B, ASTM D495, UL62, UL817, UL2556, UL1581
Included Items1x 20ft USB Extension CableWyze Cam v4 device1x Floodlight Plug-in Mount, mounting kits, foam tape, quick start guide
Mounting OptionsN/AStand, Wall mount, Ceiling mount, Magnetic wall mountMounts floodlight without junction box
WeightNot specified0.49 lb (222 g)1.39 lbs
What is the Wyze Cam USB Extension Cable - 20ft used for?The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze Cam’s power source, allowing you to position your camera further from a power outlet. This is especially useful for outdoor setups, such as monitoring your front yard at night.
Which Wyze Cam models are compatible with the 20ft USB Extension Cable?The 20ft USB Extension Cable is compatible with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto models.
How do I install the Wyze Cam USB Extension Cable?Installation is simple—just plug the extension cable into your existing Wyze Cam USB cable. No complex installation or tools are required.
What are the key features of the Wyze Cam v4 for nighttime front yard security?The Wyze Cam v4 offers 2.5K QHD resolution, color night vision with 4 IR LEDs and 2 white spotlight LEDs, IP65 weather resistance, a wide 115.8° field of view, two-way talk, built-in siren, noise and echo cancellation, and smart home integration with Alexa and Google Assistant.
Can I use the Wyze Cam v4 outdoors in extreme weather conditions?Yes, the Wyze Cam v4 is rated IP65 and can operate in temperatures ranging from -4ºF to 122ºF, making it suitable for most outdoor environments.
How does the Wyze Cam Floodlight Plug-In Mount enhance nighttime security?The Wyze Cam Floodlight Plug-In Mount provides powerful floodlighting to your Wyze Cam setup, improving nighttime visibility and deterring unwanted activity. It features a 20ft power cord, plug-and-play installation, and is designed for outdoor use.
Which Wyze Cam Floodlight models are compatible with the Plug-In Mount?The Wyze Cam Floodlight Plug-In Mount is compatible with Wyze Cam Floodlight v1, v2, and Floodlight Pro.
Is the Wyze Cam Floodlight Plug-In Mount safe for outdoor use?Yes, the Floodlight Plug-In Mount is outdoor safe, operating in temperatures from -22ºF to 122ºF, and is certified by UL, RoHS, CP65, and more for safety and reliability.
What are the benefits of using Wyze products for front yard night monitoring?Wyze products offer extended reach for flexible camera placement, clear color night vision, easy plug-and-play installation, weatherproof durability, and smart home integration for voice control and automation, making them ideal for front yard night security.
How much does the Wyze Cam USB Extension Cable - 20ft cost?The Wyze Cam USB Extension Cable - 20ft is priced at $7.99, making it an affordable solution for extending your camera’s reach.
Can you tell me more about the compatibility of the Wyze Cam USB Extension Cable with different Wyze Cam models?What are the benefits of using the Wyze Cam v4 for nighttime monitoring?Do you have any ongoing promotions or discounts for the Wyze Cam products?
