Multi-Camera Synergy with Wyze Solar Panels for Extended Coverage
Creating a robust and extended outdoor security system is easier than ever with Wyze’s innovative combination of battery-powered cameras and solar panels. By leveraging a cluster of Wyze Battery Cam Solar Panels paired with Wyze Battery Cam Pro units, you can achieve continuous, wire-free surveillance with extended battery life and seamless multi-camera synergy.
Wyze Battery Cam Pro: The Core of Your Wireless Security Network
High-Resolution Video & Smart Detection
The Wyze Battery Cam Pro delivers stunning 2.5K HDR video resolution, ensuring crystal-clear footage day and night. Equipped with a CMOS-Starlight sensor and an F1.6 lens, it captures vibrant color night vision enhanced by two IR LEDs and two white LEDs. The integrated spotlight and siren add an extra layer of security, deterring unwanted visitors instantly.
Long-Lasting Battery & Weatherproof Design
Powered by removable, rechargeable 6200mAh battery packs, each camera can last up to 6 months on a single charge. The IP65 weatherproof rating means these cameras withstand rain, snow, and dust, making them perfect for any outdoor environment. Supporting both 2.4 GHz and 5 GHz WiFi, the Wyze Battery Cam Pro ensures reliable connectivity without the need for a hub.
Intelligent Motion Detection & Integration
Radar + PIR motion detection technology minimizes false alerts by accurately distinguishing between people, animals, and objects. Plus, the camera integrates smoothly with Alexa, Google Assistant, and IFTTT, allowing you to customize your smart home security ecosystem.
Wyze Battery Cam Solar Panel: Power Your Cameras with the Sun
Extend Battery Life Effortlessly
The Wyze Battery Cam Solar Panel is designed to keep your Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2 running longer by harnessing solar energy. With a 2.5W, 5VDC solar power rating and a 13-foot USB-C power cable, it offers flexible installation options to capture optimal sunlight.
Durable & Weather Resistant
Built with an IP65 waterproof rating, the solar panel is weather resistant and mountable anywhere — from rooftops to garden walls. Its easy 360° mount allows you to adjust the panel angle for maximum sun exposure throughout the day.
Complete Installation Kit
Each solar panel package includes the solar panel itself, wall mount, micro USB and USB-C adapter cables, screws, wall anchors, and a quick start guide, making setup quick and hassle-free.
Wyze Battery Cam Pro + Solar Panel Bundle: Ultimate Convenience & Value
Ready-to-Go Solar-Powered Security
For those looking to simplify their setup, the Wyze Battery Cam Pro + Solar Panel bundle combines the power of the camera and solar panel in one package. This bundle offers the same 2.5K HDR video quality, integrated spotlight, radar + PIR motion detection, and up to 6 months battery life, now extended indefinitely with solar charging.
Seamless Multi-Camera Coverage
Deploy multiple bundles around your property to create a cluster of cameras powered sustainably by solar panels. This setup ensures continuous monitoring without worrying about battery depletion or frequent recharging.
Why Choose a Cluster of Wyze Solar-Powered Cameras?
“Harnessing solar power for your Wyze Battery Cams means uninterrupted security coverage with minimal maintenance.”
- Extended Runtime: Solar panels keep your cameras charged, reducing downtime and manual battery swaps.
- Flexible Placement: Wire-free cameras with solar panels can be installed anywhere sunlight reaches, covering blind spots and large areas.
- Scalable System: Add as many cameras and solar panels as needed to build a comprehensive security network.
- Weatherproof Reliability: Both cameras and solar panels are rated IP65, ensuring durability in harsh outdoor conditions.
Optimize Your Outdoor Security Setup
By combining multiple Wyze Battery Cam Pro units with their dedicated solar panels, you create a powerful, energy-efficient security cluster. This synergy allows for extended coverage across your property, from front porches to backyards, driveways, and beyond — all while minimizing power concerns and maximizing peace of mind.
Solar-powered outdoor security cameras providing extended coverage
Product Specifications at a Glance
Feature | Wyze Battery Cam Pro | Wyze Battery Cam Solar Panel | Wyze Battery Cam Pro + Solar Panel Bundle |
Video Resolution | 2560 x 1440 (2.5K HDR) | N/A | 2560 x 1440 (2.5K HDR) |
Battery Life | Up to 6 months | Extends battery life indefinitely | Up to 6 months + solar charging |
Power Source | Removable rechargeable battery | 2.5W solar panel, 5VDC output | Battery + solar panel |
Weather Resistance | IP65 | IP65 | IP65 |
Motion Detection | Radar + PIR | N/A | Radar + PIR |
Connectivity | 2.4 & 5 GHz WiFi | USB-C cable to camera | 2.4 & 5 GHz WiFi |
Dimensions | 2.5 x 1.8 x 3.5 inches | 173 x 120 x 17 mm | Same as camera + solar panel |
Compatibility | Wyze Battery Cam Pro, Outdoor v1/v2 | Wyze Battery Cam Pro, Outdoor v1/v2 | Wyze Battery Cam Pro |
Harness the power of the sun and the flexibility of wireless cameras to build a multi-camera security system that never sleeps. Wyze’s solar panel accessories combined with the Wyze Battery Cam Pro provide an unbeatable solution for extended, reliable outdoor surveillance.
What is the Wyze Battery Cam Pro and how does it enhance outdoor security?
The Wyze Battery Cam Pro is a wireless, battery-powered security camera designed for outdoor use. It features 2.5K HDR video resolution, color night vision, radar + PIR motion detection, and an integrated spotlight and siren. Its weatherproof IP65 rating and long-lasting rechargeable battery make it ideal for robust, reliable outdoor surveillance.How does the Wyze Battery Cam Solar Panel work with Wyze cameras?
The Wyze Battery Cam Solar Panel connects to Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2 cameras via a 13-foot USB-C cable. It harnesses solar energy to keep your cameras charged, extending battery life indefinitely and reducing the need for manual recharging.What are the benefits of using multiple Wyze Battery Cam Pro units with solar panels?
Using multiple Wyze Battery Cam Pro units with solar panels allows you to create a scalable, wire-free security network. This setup provides extended coverage, continuous monitoring, and minimal maintenance, as the solar panels keep the cameras charged and ready for use.Is the Wyze Battery Cam Pro weatherproof?
Yes, the Wyze Battery Cam Pro is rated IP65, making it weatherproof and suitable for outdoor use in rain, snow, and dusty conditions.How long does the Wyze Battery Cam Pro battery last on a single charge?
The Wyze Battery Cam Pro can last up to 6 months on a single charge, depending on usage and environmental factors. When paired with the Wyze Solar Panel, battery life is extended indefinitely.What is included in the Wyze Battery Cam Solar Panel package?
The Wyze Battery Cam Solar Panel package includes the solar panel, a wall mount, micro USB and USB-C adapter cables, screws, wall anchors, and a quick start guide for easy installation.Can I use the Wyze Battery Cam Solar Panel with other Wyze cameras?
Yes, the Wyze Battery Cam Solar Panel is compatible with the Wyze Battery Cam Pro and Wyze Cam Outdoor v1/v2 models.What smart home integrations does the Wyze Battery Cam Pro support?
The Wyze Battery Cam Pro integrates with Alexa, Google Assistant, and IFTTT, allowing you to customize and automate your smart home security system.How does the motion detection work on the Wyze Battery Cam Pro?
The Wyze Battery Cam Pro uses advanced radar and PIR (Passive Infrared) motion detection technology to accurately distinguish between people, animals, and objects, minimizing false alerts.What are the advantages of the Wyze Battery Cam Pro + Solar Panel bundle?
The Wyze Battery Cam Pro + Solar Panel bundle offers a convenient, ready-to-go solution for solar-powered security. It combines high-resolution video, smart motion detection, and extended battery life with the convenience of solar charging, ensuring continuous, maintenance-free surveillance.How easy is it to install the Wyze Battery Cam Solar Panel?
Installation is quick and hassle-free. The solar panel comes with a 360° adjustable mount, a 13-foot USB-C cable for flexible placement, and all necessary hardware and instructions for mounting on rooftops, garden walls, or other outdoor locations.Can I expand my Wyze security system with more cameras and solar panels?
Yes, the Wyze security system is fully scalable. You can add as many Wyze Battery Cam Pro units and solar panels as needed to cover larger areas and eliminate blind spots around your property.
