Best Motion Sensor Security Camera Lights for Night Surveillance
Motion Sensor Activated Security Camera Lights for Night Surveillance
When it comes to securing your home at night, motion sensor activated security camera lights are essential. They not only illuminate dark areas instantly but also provide real-time video surveillance, helping you monitor your property effectively. Below, we explore the top Wyze products designed specifically for night surveillance with motion-activated lighting, combining powerful illumination, advanced video quality, and smart home integration.
Wyze Cam Floodlight v2: Bright, Smart, and Reliable Night Surveillance
Powerful Illumination and Wide-Angle Coverage
The Wyze Cam Floodlight v2 dominates the dark with 2800 lumens of bright LED light, ensuring your outdoor spaces are well-lit from dusk to dawn. Its 160° wide-angle lens captures a broad view, reducing blind spots around your home.
Crisp 2K Video with Color Night Vision
Equipped with 2K (2304 x 1296) resolution and color night vision, this floodlight camera delivers clear, detailed video footage even in low-light conditions. The camera records at 20 FPS during the day and 15 FPS at night, providing smooth video playback.
Smart Features for Enhanced Security
  • AI-Powered Light Control automatically adjusts lighting based on detected motion and ambient light.
  • Two-way talk lets you communicate through the built-in speaker and microphone, perfect for greeting visitors or deterring intruders.
  • 105dB siren adds an audible security layer.
  • Dusk-to-dawn automation ensures the floodlight activates only when needed.
  • IP65 weather resistance guarantees durability in harsh outdoor conditions.
Seamless Smart Home Integration
Compatible with Alexa, Google Assistant, and IFTTT, the Wyze Cam Floodlight v2 fits effortlessly into your smart home ecosystem. Wyze Cam Floodlight v2 illuminating driveway at night Bright floodlight with motion detection securing a driveway at night
Wyze Cam Floodlight Pro: Advanced AI and Ultra-Wide Coverage
Ultra-Wide 180° Field of View with 2.5K QHD Video
The Floodlight Pro steps up with a 180° diagonal field of view and 2.5K QHD (2560 x 1440) video resolution, capturing your entire yard in stunning detail.
AI-Powered Object Detection
This model features evolutionary onboard AI computer vision that detects specific objects like people and vehicles, triggering the adjustable 3000 lumen LED lights only when necessary. This intelligent lighting reduces false alarms and conserves energy.
Enhanced Connectivity and Features
  • Supports both 2.4 GHz and 5 GHz dual-band WiFi for stable connections.
  • Includes a 105dB siren and two-way audio for active deterrence.
  • Weatherproof with an IP65 rating, suitable for all seasons.
  • Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation.
Dimensions and Installation
Measuring 10.2 x 9.1 x 7.8 inches and weighing 2.9 lbs, it mounts easily on walls or ceilings. Wyze Cam Floodlight Pro protecting home with AI detection AI-powered floodlight camera providing wide coverage and bright illumination
Wyze Cam v4: Compact, Wireless, and Spotlight Enabled
Wireless Convenience with 2.5K QHD Video
The Wyze Cam v4 offers 2.5K QHD resolution with enhanced color night vision, delivering crystal-clear video day and night. Its wireless design and Wi-Fi 6 support make it easy to install anywhere without complicated wiring.
Motion-Activated Spotlight and Siren
This camera features a motion-activated spotlight that lights up your property instantly when movement is detected. It also includes a built-in 99dB waterproof speaker and siren for active security alerts.
Versatile Mounting and Weather Resistance
Compact and lightweight at 0.49 lbs, it can be mounted on walls, ceilings, or magnetic surfaces. Rated IP65 for weather resistance, it withstands outdoor elements reliably.
Smart Home Compatibility
Works seamlessly with Alexa, Google Assistant, and IFTTT, allowing voice commands and automation routines.
Wyze Battery Cam Pro: Wire-Free Spotlight Security
Wire-Free with Rechargeable Battery Packs
Ideal for locations without easy access to power, the Wyze Battery Cam Pro offers wire-free installation with removable rechargeable batteries lasting up to 6 months on a single charge.
2.5K HDR Video and Integrated Spotlight
Capture sharp 2.5K HDR video with a 134° diagonal field of view. The camera includes an integrated spotlight and siren to illuminate and secure your property instantly upon motion detection.
Dual Radar + PIR Motion Detection
Advanced radar and PIR sensors reduce false alarms by accurately detecting human movement.
Weatherproof and Smart Integration
With an IP65 rating, it’s built to endure outdoor conditions. Compatible with Alexa, Google Assistant, and IFTTT for smart home control.
Wyze Bulb Cam: 2-in-1 Security Camera and Smart LED Light Bulb
Discreet and Easy Installation
The Wyze Bulb Cam fits into any standard E26 light socket, combining a 2K HD security camera with a smart LED bulb that provides up to 800 lumens of light.
Color Night Vision and Motion Alerts
Enjoy color night vision and instant motion alerts to your phone. The camera offers a 166° diagonal field of view to cover wide areas.
Smart Controls and Local Storage
Control lighting manually, by motion, or schedule it via the Wyze app. Supports local storage up to 256 GB microSD cards without subscription fees.
Weather Resistant and Voice Assistant Compatible
Rated IP65 for outdoor use and works with Alexa and Google Assistant for voice commands. Wyze Bulb Cam installed in outdoor light fixture Wyze Bulb Cam providing smart lighting and security in an outdoor fixture
Why Choose Wyze Motion Sensor Security Camera Lights?
Wyze offers a range of motion sensor activated security camera lights tailored to different needs—from wired floodlights with AI detection to wireless battery-powered cameras and smart bulb cams. Each product combines powerful illumination, high-resolution video, and smart home integration to keep your property safe and well-lit during the night.
With features like color night vision, two-way audio, sirens, and AI-powered motion detection, Wyze security lights provide peace of mind and proactive home protection.
Summary of Featured Products
Product NameVideo ResolutionLumensField of ViewPower SourceSpecial Features
Wyze Cam Floodlight v22K (2304x1296)2800160°Hardwired 110-120V ACAI Light Control, Two-way Audio
Wyze Cam Floodlight Pro2.5K QHD (2560x1440)3000180°Hardwired 110-120V ACAI Object Detection, Dual-band WiFi
Wyze Cam v42.5K QHD (2560x1440)Spotlight 72 lm115.8° DFOVWireless (Wi-Fi 6)Motion Spotlight, Siren
Wyze Battery Cam Pro2.5K HDRSpotlight 187 lm134°Rechargeable BatteryRadar + PIR Motion Detection
Wyze Bulb Cam2K (2304x1296)800166°Standard E26 Socket2-in-1 Bulb & Camera, Local Storage
Protect your home effectively with Wyze’s motion sensor activated security camera lights — combining bright illumination, smart detection, and high-quality video for superior night surveillance.
FeatureWyze Cam Floodlight v2Wyze Cam Floodlight ProWyze Cam v4Wyze Bulb Cam
Price$89.98$149.98$35.98 - $107.94 (varies by bundle)$49.98
Video Resolution2K (2304 x 1296)2.5K QHD (2560 x 1440)2.5K QHD (2560 x 1440)2K (2304 x 1296)
Field of View160° wide-angle180° wide-angleDFOV 115.8°, HFOV 98.5°, VFOV 53.1°160° diagonal, 166° diagonal FOV
LED Floodlight Brightness2800 lumens (2 adjustable heads)3000 lumens (3 adjustable heads)Motion-activated spotlight (72 lumens)Up to 800 lumens
Color Night VisionYesYesYesYes
Night Vision TypeColor Night VisionColor Night VisionEnhanced Color Night VisionColor Night Vision + IR Night Vision
Motion Detection270° PIR motion detectionAI computer vision motion detectionYesYes
AI Detection (with Cam Plus)People, Pets, Vehicle, PackagePeople, Pets, Vehicle, PackagePerson detectionMotion alerts only
Two-Way TalkYesYesYesYes
Siren Volume105 dB105 dB99 dB95 dB
Local StoragemicroSD up to 256 GBmicroSD up to 256 GBmicroSD up to 512 GBmicroSD up to 256 GB
Cloud StorageOptional Cam Plus subscriptionOptional Cam Plus subscriptionOptional subscriptionAWS cloud storage
Wi-Fi Support2.4 GHz2.4 & 5 GHz dual-band2.4 GHz & Wi-Fi 62.4 GHz
Weather ResistanceIP65IP65IP65IP65
Power SourceWired (with optional plug-in mount)Wired (with optional plug-in mount)WiredStandard E26 socket (120V AC)
InstallationDIY, junction box or plug-in mountDIY, junction box or plug-in mountStand, wall, ceiling, magnetic mountsScrew-in bulb socket
Ambient Light ModeYesYesMotion-activated spotlightYes
Dusk-to-Dawn AutomationYesYesYesYes
Voice Assistant IntegrationAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant, IFTTTAlexa, Google Assistant
DimensionsNot specifiedNot specified2in x 2in x 2 3/8inNot specified
WeightNot specifiedNot specified0.49 lb (222 g)Not specified
What are motion sensor activated security camera lights and how do they improve night surveillance?Motion sensor activated security camera lights are devices that combine powerful illumination with real-time video surveillance. They automatically light up dark areas when motion is detected and record high-quality video, helping you monitor and protect your property more effectively at night.
Which Wyze security camera light is best for wide-area night surveillance?The Wyze Cam Floodlight Pro is ideal for wide-area night surveillance. It features a 180° diagonal field of view, 2.5K QHD video resolution, and 3000 lumen adjustable LED lights, ensuring comprehensive coverage and clear footage of your entire yard or driveway.
What is the difference between Wyze Cam Floodlight v2 and Floodlight Pro?Wyze Cam Floodlight v2 offers 2K resolution, 2800 lumens, and a 160° field of view, while the Floodlight Pro provides 2.5K QHD resolution, 3000 lumens, and a wider 180° field of view. The Floodlight Pro also features advanced AI object detection and supports dual-band WiFi for enhanced connectivity.
Do Wyze security camera lights support color night vision?Yes, several Wyze security camera lights, including the Wyze Cam Floodlight v2, Floodlight Pro, Cam v4, and Bulb Cam, offer color night vision. This feature allows you to see clear, full-color video footage even in low-light or nighttime conditions.
Are Wyze security camera lights weatherproof for outdoor use?All featured Wyze security camera lights, including the Cam Floodlight v2, Floodlight Pro, Cam v4, Battery Cam Pro, and Bulb Cam, are rated IP65 for weather resistance. This ensures reliable performance in various outdoor conditions.
Can Wyze security camera lights be integrated with smart home systems?Yes, Wyze security camera lights are compatible with Alexa, Google Assistant, and IFTTT. This allows for voice control, automation routines, and seamless integration into your existing smart home ecosystem.
Is there a wireless, battery-powered Wyze security camera light option?Yes, the Wyze Battery Cam Pro is a wire-free security camera with removable rechargeable batteries that last up to 6 months per charge. It features a 2.5K HDR camera, integrated spotlight, siren, and advanced radar plus PIR motion detection.
How does the Wyze Bulb Cam work as a security camera and light?The Wyze Bulb Cam is a 2-in-1 device that fits into any standard E26 light socket. It combines a 2K HD security camera with an 800-lumen smart LED bulb, offering color night vision, motion alerts, and local storage up to 256 GB without subscription fees.
What smart features are included in Wyze Cam Floodlight v2?Wyze Cam Floodlight v2 includes AI-powered light control, two-way talk, a 105dB siren, dusk-to-dawn automation, and compatibility with Alexa, Google Assistant, and IFTTT. It also offers 2K video with color night vision and a 160° wide-angle lens.
Do Wyze security camera lights require a subscription for video storage?Wyze Bulb Cam supports local storage up to 256 GB microSD cards without subscription fees. Other Wyze cameras may offer cloud storage options, but local storage is available on select models for subscription-free video recording.
How easy is it to install Wyze security camera lights?Wyze security camera lights are designed for easy installation. The Wyze Cam v4 and Battery Cam Pro offer wireless, flexible mounting options, while the Bulb Cam simply screws into a standard E26 socket. Floodlight models are hardwired and can be mounted on walls or ceilings.
What is the field of view for Wyze security camera lights?Field of view varies by model: Wyze Cam Floodlight v2 offers 160°, Floodlight Pro 180°, Cam v4 115.8°, Battery Cam Pro 134°, and Bulb Cam 166°. Wider fields of view help reduce blind spots and provide better coverage.
Do Wyze security camera lights have built-in sirens for active deterrence?Yes, Wyze Cam Floodlight v2 and Floodlight Pro feature a 105dB siren, while Cam v4 and Battery Cam Pro also include built-in sirens. These audible alarms help deter intruders and alert you to suspicious activity.
What motion detection technology is used in Wyze security camera lights?Wyze security camera lights use advanced motion detection, including AI-powered object detection (people, vehicles) in the Floodlight Pro, radar plus PIR sensors in the Battery Cam Pro, and standard motion sensors in other models for accurate and reliable alerts.
What are the key features of the Wyze Cam Floodlight v2?How does the AI-Powered Light Control work in the Wyze Cam Floodlight v2?Are there any ongoing promotions or discounts for Wyze products?
