Wyze Battery Cam Pro: Monitor-Only Camera for Added Security
Monitor-Only Camera Solutions for Enhanced Security with Wyze Battery Cam Pro
When you already have existing security measures in place but want to add a reliable, monitor-only camera for extra peace of mind, the Wyze Battery Cam Pro lineup offers versatile, wire-free options that seamlessly integrate into your setup. These cameras provide high-resolution video, smart detection features, and flexible power solutions to keep an eye on your property without complicated wiring or hubs.
Wyze Battery Cam Pro: Advanced Wireless Security Camera
Crisp 2.5K HDR Video Quality
The Wyze Battery Cam Pro delivers stunning 2560 x 1440 (2.5K) HDR video resolution, ensuring every detail is captured clearly. Whether monitoring your front porch or backyard, the camera’s CMOS-Starlight sensor combined with an F1.6 lens provides sharp, vibrant footage day and night.
Smart Motion Detection with Radar + PIR
Equipped with both radar and PIR motion sensors, this camera detects movement with high accuracy, reducing false alerts. The integrated spotlight and siren add an active deterrent layer, alerting intruders and notifying you instantly.
Wire-Free and Weatherproof Design
With a removable, rechargeable 6200mAh battery pack, the Wyze Battery Cam Pro offers up to 6 months of battery life on a single charge. Its IP65 weatherproof rating means it withstands rain, snow, and dust, making it ideal for outdoor use in various climates.
Flexible Connectivity and Integration
Supporting both 2.4 GHz and 5 GHz WiFi bands, the camera ensures stable connections. It integrates smoothly with Alexa, Google Assistant, and IFTTT, allowing voice control and automation within your smart home ecosystem.
Compact and Easy to Mount
Measuring just 2.5 x 1.8 x 3.5 inches and weighing under 1 lb, the camera is discreet yet powerful. It comes with a standard 1/4” - 20 mount and wall mount included for quick installation anywhere around your property.
The Wyze Battery Cam Pro is perfect for those who want a monitor-only camera that complements existing security systems without the hassle of wiring or hubs.
Outdoor security camera monitoring a home entrance at dusk Alt text: Outdoor home monitored by Wyze Battery Cam Pro at dusk
Wyze Battery Cam Pro + Solar Panel: Extended Power for Continuous Monitoring
Solar-Powered Convenience
For users seeking uninterrupted monitoring without frequent battery swaps, the Wyze Battery Cam Pro + Solar Panel bundle is an excellent choice. The solar panel continuously charges the camera’s battery during daylight, extending its runtime indefinitely under suitable conditions.
Same High-Quality Features
This bundle retains all the core features of the Wyze Battery Cam Pro, including 2.5K HDR video, radar + PIR motion detection, integrated spotlight and siren, and IP65 weatherproofing.
Easy Installation and Compatibility
The solar panel is designed for easy 360° mounting and comes with a 13-foot power cable, allowing flexible placement to maximize sun exposure. It’s compatible with the Wyze Battery Cam Pro and other Wyze outdoor cameras.
This solution is ideal for areas where power outlets are unavailable or inconvenient, ensuring your monitor-only camera stays powered and ready.
Essential Accessories to Enhance Your Wyze Battery Cam Pro Experience
Wyze Removable Battery Pack
Keep your camera running longer with an extra 6200mAh rechargeable battery pack. It charges in approximately 9 hours via USB-C and lasts up to 6 months per charge, making battery swaps quick and hassle-free.
Wyze Battery Charging Dock
Charge two Wyze Battery Cam Pro batteries simultaneously with this compact dual charging dock. It’s perfect for households with multiple cameras, ensuring you always have a fully charged battery ready to go.
Wyze Battery Cam Solar Panel
If you prefer to add solar power separately, this weather-resistant solar panel accessory is designed to extend your camera’s battery life. It includes mounting hardware and a long power cable for versatile installation. Solar panel mounted on a home exterior powering a security camera Alt text: Solar panel powering Wyze Battery Cam Pro on home exterior
Why Choose Wyze Battery Cam Pro for Monitor-Only Security?
  • Wire-Free Setup: No need for hubs or complicated wiring, perfect for supplementing existing security systems.
  • High-Resolution Video: 2.5K HDR ensures clear, detailed monitoring.
  • Long Battery Life: Up to 6 months on a single charge, extendable with solar power.
  • Smart Detection: Radar + PIR sensors reduce false alarms and improve accuracy.
  • Weatherproof: IP65 rating for reliable outdoor use in all seasons.
  • Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT for seamless control.
Adding a Wyze Battery Cam Pro as a monitor-only camera enhances your security coverage with minimal effort and maximum flexibility.
Family monitoring home security on smartphone app Alt text: Person using smartphone app to monitor Wyze Battery Cam Pro security camera
Summary
For those looking to add a monitor-only camera to areas with existing security measures, the Wyze Battery Cam Pro and its solar-powered variants offer an unbeatable combination of high-quality video, smart detection, and flexible power options. With accessories like rechargeable battery packs and solar panels, you can customize your setup for continuous, reliable monitoring without the need for wiring or hubs. Enhance your home or business security effortlessly with Wyze’s innovative, wire-free camera solutions.
Product Tags Recap
  • Wyze Battery Cam Pro:
  • Wyze Battery Cam Pro + Solar Panel:
  • Wyze Removable Battery Pack:
  • Wyze Battery Cam Solar Panel:
FeatureWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelWyze Removable Battery PackWyze Battery Cam Solar Panel
TypeCameraCamera + Accessory BundleAccessory (Battery)Accessory (Solar Panel)
Video Resolution2.5K HDR2.5K HDRN/AN/A
Power SourceRemovable, Rechargeable Battery PacksRemovable Battery + Solar Panel for continuous power6200mAh Rechargeable Battery PackSolar Panel (2.5W, 5VDC)
Battery LifeUp to 6 months per chargeExtended with Solar PanelUp to 6 months per chargeExtends battery life by solar charging
Weatherproof RatingIP65IP65N/AIP65
Motion DetectionRadar + PIRRadar + PIRN/AN/A
Spotlight & SirenIntegrated Spotlight (150 lumens) & SirenIntegrated Spotlight (150 lumens) & SirenN/AN/A
WiFi SupportDual-band 2.4 & 5 GHzDual-band 2.4 & 5 GHzN/AN/A
Local RecordingYes (with microSD card)Yes (with microSD card)N/AN/A
SetupWireless, No Hub, BluetoothⓇ SetupWireless, No Hub, BluetoothⓇ SetupN/AN/A
Mounting OptionsFlexible, includes ceiling mount optionFlexible, includes ceiling mount optionN/AWeather resistant, 360° mount included
Charging TimeN/AN/AApprox. 9 hours at 25°CN/A
DimensionsN/AN/A2.9 in x 1.6 in x 0.9 in (75 mm x 40 mm x 22 mm)173 mm x 120 mm x 17 mm
WeightN/AN/A3.9 oz (110 g)N/A
Price (approximate)$89.98 (1 Pack)$109.98 (Bundle)$22.99$24.99
Included ItemsCamera onlyCamera + Solar Panel + Mounting AccessoriesBattery Pack onlySolar Panel, Mount, Cables, Screws, Guide
CompatibilityN/AN/AWyze Battery Cam Pro, Wyze Duo Cam DoorbellWyze Battery Cam Pro, Wyze Cam Outdoor v1/v2
What is the Wyze Battery Cam Pro and how does it enhance security?The Wyze Battery Cam Pro is a wireless, monitor-only security camera designed to supplement existing security systems. It offers high-resolution 2.5K HDR video, smart motion detection with radar and PIR sensors, and a wire-free, weatherproof design for easy installation and reliable monitoring.
Does the Wyze Battery Cam Pro require wiring or a hub for installation?No, the Wyze Battery Cam Pro is completely wire-free and does not require any complicated wiring or a hub. It operates on a rechargeable battery and connects directly to your WiFi network for easy setup and flexible placement.
How long does the Wyze Battery Cam Pro battery last on a single charge?The Wyze Battery Cam Pro features a removable, rechargeable 6200mAh battery pack that can last up to 6 months on a single charge, depending on usage and environmental conditions.
Is the Wyze Battery Cam Pro suitable for outdoor use?Yes, the Wyze Battery Cam Pro is IP65 weatherproof rated, making it ideal for outdoor use in various climates. It can withstand rain, snow, and dust, ensuring reliable performance year-round.
What smart home platforms does the Wyze Battery Cam Pro support?The Wyze Battery Cam Pro integrates seamlessly with Alexa, Google Assistant, and IFTTT, allowing for voice control and automation within your smart home ecosystem.
What is the benefit of the Wyze Battery Cam Pro + Solar Panel bundle?The Wyze Battery Cam Pro + Solar Panel bundle provides continuous power by using solar energy to recharge the camera’s battery. This setup is ideal for locations without convenient access to power outlets, ensuring uninterrupted monitoring.
Can I add solar power to my Wyze Battery Cam Pro separately?Yes, you can purchase the Wyze Battery Cam Solar Panel accessory separately. It is weather-resistant, comes with mounting hardware and a long power cable, and is compatible with the Wyze Battery Cam Pro and other Wyze outdoor cameras.
What accessories are available for the Wyze Battery Cam Pro?Available accessories include the Wyze Removable Battery Pack for extended runtime, the Wyze Battery Charging Dock for charging two batteries simultaneously, and the Wyze Battery Cam Solar Panel for solar-powered operation.
How does the Wyze Battery Cam Pro reduce false motion alerts?The Wyze Battery Cam Pro uses both radar and PIR (Passive Infrared) motion sensors to accurately detect movement, significantly reducing false alerts and ensuring you are only notified of genuine activity.
What are the video quality specifications of the Wyze Battery Cam Pro?The Wyze Battery Cam Pro captures video in crisp 2.5K HDR (2560 x 1440) resolution, using a CMOS-Starlight sensor and F1.6 lens for clear, vibrant footage both day and night.
Is the Wyze Battery Cam Pro easy to install?Yes, the Wyze Battery Cam Pro is compact, lightweight, and comes with a standard 1/4” - 20 mount and wall mount for quick and easy installation anywhere around your property.
Can the Wyze Battery Cam Pro be used as a monitor-only camera?Absolutely. The Wyze Battery Cam Pro is designed to function as a monitor-only camera, making it perfect for enhancing your existing security system without the need for additional wiring or hubs.
Can you tell me more about the smart motion detection features of the Wyze Battery Cam Pro?What is the battery life of the Wyze Battery Cam Pro when fully charged?Do you have any ongoing sales or promotions for the Wyze Battery Cam Pro?
