Extend Your Wyze Cam Reach with the 20ft USB Extension Cable
If you're looking to install your Wyze Cam in a second-story window or any location where the original USB cable length falls short, the
Wyze Cam USB Extension Cable - 20ft is the perfect solution. This accessory allows you to extend your camera’s reach without compromising power or connectivity, giving you the freedom to place your Wyze Cam exactly where you need it.
Key Features of the Wyze Cam USB Extension Cable - 20ft
- Length: A generous 20 feet of cable length to reach those hard-to-access spots like second-story windows.
- Compatibility: Works seamlessly with a wide range of Wyze Cam models including Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, and the original Wyze Cam OG models.
- Easy Setup: Simply plug the extension cable between your Wyze Cam and its power source—no additional adapters or tools required.
- Reliable Power Delivery: Maintains stable power and data transmission over the extended length, ensuring your camera functions flawlessly.
- Affordable: Priced at just $7.99, it’s a cost-effective way to enhance your home security setup.
Say goodbye to the frustration of short cables and enjoy the flexibility to position your Wyze Cam exactly where it offers the best view and coverage.
Enhance Your Home Security with Wyze Camera Bundles
While the USB extension cable is essential for flexible placement, consider pairing it with Wyze’s advanced camera systems for a comprehensive security solution.
Whole Home Security Starter Kit
- Includes: Wyze Cam v4, Wyze Video Doorbell v2, and Wyze Home Monitoring Starter Kit.
- Wyze Cam v4: Offers crystal-clear 2.5K QHD resolution, enhanced color night vision, and smart motion detection.
- Perfect for: Those who want an all-in-one security solution with indoor and outdoor coverage.
- Colors Available: White, Grey, Black.
Essential Security Bundle
- Comprehensive Protection: Combines Wyze Video Doorbell v2, Wyze Lock Bolt, Wyze Cam Pan v3, and two Wyze Cam OG cameras.
- Wyze Cam Pan v3: Features 360° horizontal pan, 180° vertical tilt, automatic motion tracking, and color night vision.
- Wyze Lock Bolt: Smart lock with fingerprint sensor and backlit keypad for secure, keyless entry.
- Ideal for: Homeowners seeking multi-angle surveillance and smart access control.
Pan v3 + Lamp Socket v2 Bundle
- Smart Exterior Lighting: Powers your Wyze Cam Pan v3 through a lamp socket, eliminating the need for an outlet.
- Compatibility: Works with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3.
- Installation: Fits standard E26 lamp sockets, perfect for outdoor or porch lighting setups.
Why Choose Wyze for Your Home Security?
Wyze products are designed to be user-friendly, affordable, and highly functional. The 20ft USB extension cable complements these devices by removing installation limitations, especially when mounting cameras in elevated or hard-to-reach locations like second-story windows.
With Wyze, you get smart home security solutions that adapt to your home’s unique layout and your lifestyle needs.
Summary
For anyone needing a longer USB cable to install a Wyze Cam in a second-story window or other distant locations, the
Wyze Cam USB Extension Cable - 20ft is an essential accessory. It ensures your camera stays powered and connected without the hassle of relocating power sources or compromising camera placement.
Pair this extension cable with Wyze’s versatile camera bundles like the Whole Home Security Starter Kit or the Essential Security Bundle for a robust, smart home security system.
Secure your home with flexible camera placement
What is the Wyze Cam USB Extension Cable - 20ft used for?
The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze Cam, allowing you to install your camera in hard-to-access locations such as second-story windows or distant areas where the original cable is too short.Which Wyze Cam models are compatible with the 20ft USB extension cable?
The 20ft USB extension cable is compatible with a wide range of Wyze Cam models, including Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, and the original Wyze Cam OG models.Does the Wyze Cam USB Extension Cable affect power or connectivity?
No, the Wyze Cam USB Extension Cable - 20ft maintains stable power and data transmission over the extended length, ensuring your camera functions flawlessly without any compromise in performance.How do I install the Wyze Cam USB Extension Cable?
Installation is simple—just plug the extension cable between your Wyze Cam and its power source. No additional adapters or tools are required.What is the price of the Wyze Cam USB Extension Cable - 20ft?
The Wyze Cam USB Extension Cable - 20ft is affordably priced at just $7.99, making it a cost-effective solution for extending your camera’s reach.Can I use the Wyze Cam USB Extension Cable with outdoor camera setups?
Yes, the 20ft USB extension cable is ideal for both indoor and outdoor Wyze Cam installations, especially when you need to reach elevated or distant locations.What are the benefits of using Wyze camera bundles with the USB extension cable?
Pairing the USB extension cable with Wyze camera bundles like the Whole Home Security Starter Kit or the Essential Security Bundle provides comprehensive home security coverage, flexible camera placement, and smart home integration.What is included in the Wyze Whole Home Security Starter Kit?
The Wyze Whole Home Security Starter Kit includes a Wyze Cam v4, Wyze Video Doorbell v2, and Wyze Home Monitoring Starter Kit, offering all-in-one security with indoor and outdoor coverage.What features does the Wyze Cam Pan v3 offer in the Essential Security Bundle?
The Wyze Cam Pan v3 features 360° horizontal pan, 180° vertical tilt, automatic motion tracking, and color night vision, making it ideal for multi-angle surveillance.How does the Pan v3 + Lamp Socket v2 Bundle work?
The Pan v3 + Lamp Socket v2 Bundle allows you to power your Wyze Cam Pan v3 through a standard E26 lamp socket, eliminating the need for an electrical outlet and making it perfect for outdoor or porch lighting setups.Why should I choose Wyze for my home security needs?
Wyze offers user-friendly, affordable, and highly functional smart home security solutions. Their products, including the 20ft USB extension cable, are designed to adapt to your home’s unique layout and provide flexible, reliable security.
