Discover the Wyze Cordless Vacuum S: The Ultimate Cordless & Handheld Cleaning Solution
If you're searching for a
cordless vacuum that doubles as a handheld for quick spot cleans, the
Wyze Cordless Vacuum S is your perfect match. Designed for freedom and power, this vacuum offers unmatched versatility and performance for everyday cleaning tasks, whether it's a full-floor sweep or a quick sofa refresh.
Powerful Suction and Lightweight Design for Effortless Cleaning
Exceptional Suction Power
The Wyze Cordless Vacuum S boasts an impressive suction capability that adapts to your cleaning needs:
- Turbo Mode: 20,000 Pa for deep cleaning stubborn dirt
- Medium Mode: 9,000 Pa for regular cleaning
- ECO Mode: 6,000 Pa for extended runtime and light cleaning
- Air Watts: 100 AW for efficient suction performance
This powerful suction ensures that even the tiniest dust particles and pet hair are thoroughly removed from your floors and upholstery.
Ultra-Lightweight and Ergonomic
Weighing only
2.8 lbs for the main unit and
4.9 lbs when fully assembled, the Wyze Cordless Vacuum S is as light as feathers, making it easy to maneuver around furniture, stairs, and tight spaces without fatigue.
"Finally! A vacuum that is free and independent and no longer reliant on its parents for financial and emotional support." – Wyze
Long-Lasting Battery and Convenient Charging
Interchangeable Lithium-Ion Battery
Equipped with a
6-cell lithium-ion battery (2,000mAh*6), the vacuum provides:
- 40 minutes runtime in ECO mode for extended cleaning sessions
- 23 minutes in Medium mode for balanced power and endurance
- 10 minutes in Turbo mode for intensive spot cleaning
Fast and Flexible Charging
The vacuum charges fully in
4-6 hours via AC charging (100-240V~50/60Hz), ensuring it's ready whenever you need it.
Smart Features and Versatile Attachments
Advanced Cleaning Technology
- Dual motors for enhanced suction and efficiency
- 3-stage filtration system including a HEPA filter to trap allergens and fine dust
- 6 daylight-bright LED lights on the brush head to illuminate dark corners and under furniture
- LED screen for easy monitoring of battery life and cleaning modes
Included Attachments for Every Cleaning Task
- Crevice Tool for narrow spaces
- Floor Brush for hard floors and carpets
- Dust Cap and HEPA Filter for maintenance
- Standard Tube for extended reach
Transform Your Cleaning Routine with Handheld Convenience
The Wyze Cordless Vacuum S easily converts into a handheld vacuum, perfect for quick spot cleans on sofas, car seats, stairs, and pet areas. Its compact size and lightweight design make it ideal for fast, hassle-free cleaning anywhere in your home.
Pet-friendly cordless vacuum for sofas and floors
Enhance Your Vacuum Experience with Wyze Accessories
Maximize the performance and convenience of your Wyze Cordless Vacuum S with these compatible accessories:
- Wyze Cordless Vacuum S - Battery Pack ($59.99)
Need extra juice? Extend your cleaning time with an additional battery designed specifically for the Wyze Cordless Vacuum S.
- Wyze Cordless Vacuum S - Charger ($4.99)
Keep a spare charger handy to ensure your vacuum is always ready to go.
- Wyze Cordless Vacuum - Foldable Vacuum Tube ($15.99)
This flexible tube bends so you don’t have to, making it easier to reach awkward spots.
- Wyze Cordless Vacuum - HEPA Filter (2 Pack) ($15.99)
Replace your filters regularly to maintain optimal air quality and suction.
- Wyze Cordless Vacuum - Mini Motorized Brush Head ($29.99)
Perfect for cleaning car seats and sofas with targeted motorized brushing.
Specifications at a Glance
Feature | Specification |
Suction Power | 100 AW / 20,000 Pa (Turbo Mode) |
Weight | 2.8 lbs (main unit), 4.9 lbs (assembled) |
Battery | 6-cell lithium-ion, 2,000mAh*6 |
Runtime | 40 min (ECO), 23 min (Medium), 10 min (Turbo) |
Charging Time | 4-6 hours |
Dust Cup Volume | 0.7 L |
Noise Level | 65 dBA (Turbo Mode) |
Dimensions | 12.4 x 4.5 x 8.7 in (main unit) |
Color | Steel grey with Wyze green accents |
Why Choose Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S is designed for those who want a powerful, lightweight, and versatile vacuum that can handle both full cleaning sessions and quick spot cleans with ease. Its smart features, long battery life, and handy attachments make it a standout choice for pet owners, busy households, and anyone who values convenience without sacrificing performance.
Effortless hardwood floor cleaning with Wyze Cordless Vacuum S
Conclusion
For a
cordless vacuum that doubles as a handheld and delivers powerful suction, long battery life, and smart features, the
Wyze Cordless Vacuum S is the ideal solution. Whether you’re tackling pet hair, dust, or everyday messes, this vacuum offers the freedom and flexibility to keep your home spotless.
What is the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S is a powerful, lightweight vacuum cleaner that can be used both as a cordless stick vacuum and as a handheld vacuum. It is designed for versatile cleaning, making it ideal for floors, carpets, sofas, stairs, and even car interiors.How powerful is the suction on the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S offers exceptional suction power with three modes: Turbo Mode at 20,000 Pa for deep cleaning, Medium Mode at 9,000 Pa for regular cleaning, and ECO Mode at 6,000 Pa for extended runtime. It delivers up to 100 Air Watts (AW) for efficient cleaning performance.How much does the Wyze Cordless Vacuum S weigh?
The main unit of the Wyze Cordless Vacuum S weighs only 2.8 lbs, and when fully assembled, it weighs 4.9 lbs. Its ultra-lightweight design makes it easy to maneuver around your home.What is the battery life of the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S features a 6-cell lithium-ion battery (2,000mAh*6) that provides up to 40 minutes of runtime in ECO mode, 23 minutes in Medium mode, and 10 minutes in Turbo mode.How long does it take to charge the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S charges fully in 4-6 hours using the included AC charger (100-240V~50/60Hz).Does the Wyze Cordless Vacuum S have a HEPA filter?
Yes, the Wyze Cordless Vacuum S features a 3-stage filtration system that includes a HEPA filter, which helps trap allergens and fine dust for cleaner air.What attachments are included with the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S comes with several attachments: a crevice tool for narrow spaces, a floor brush for hard floors and carpets, a dust cap, a HEPA filter, and a standard tube for extended reach.Can the Wyze Cordless Vacuum S be used as a handheld vacuum?
Yes, the Wyze Cordless Vacuum S easily converts into a handheld vacuum, making it perfect for quick spot cleans on sofas, car seats, stairs, and pet areas.What smart features does the Wyze Cordless Vacuum S offer?
The Wyze Cordless Vacuum S includes dual motors for enhanced suction, a 3-stage filtration system with HEPA filter, 6 LED lights on the brush head for illuminating dark areas, and an LED screen for monitoring battery life and cleaning modes.Are there accessories available for the Wyze Cordless Vacuum S?
Yes, you can enhance your vacuum experience with accessories such as an extra battery pack, spare charger, foldable vacuum tube, HEPA filter packs, and a mini motorized brush head for targeted cleaning.What is the dust cup capacity of the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S has a dust cup volume of 0.7 liters, allowing you to clean more before needing to empty it.Is the Wyze Cordless Vacuum S suitable for pet owners?
Yes, the Wyze Cordless Vacuum S is pet-friendly and designed to effectively remove pet hair and dander from floors, furniture, and other surfaces.What are the dimensions and color of the Wyze Cordless Vacuum S?
The main unit measures 12.4 x 4.5 x 8.7 inches and comes in steel grey with Wyze green accents.Why should I choose the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S is an excellent choice for those seeking a powerful, lightweight, and versatile vacuum. Its smart features, long battery life, and multiple attachments make it ideal for busy households, pet owners, and anyone who values convenience and performance.
