Trusted Wyze MicroSD Card for Outdoor Cams in Any Weather
Trusted Memory Card for Wyze Cam Outdoor in Windy and Rainy Conditions
When it comes to securing your home with Wyze Cam Outdoor, having a reliable memory card that withstands harsh weather conditions like wind and rain is essential. The Wyze MicroSD Card is specifically designed to unlock continuous recording and time lapse features for your Wyze cameras, ensuring your footage is safely stored locally without any monthly fees.
Wyze MicroSD Card: Durable Storage for Outdoor Use
Reliable Local Recording for Wyze Cams
The Wyze MicroSD Card offers seamless local storage for your Wyze Cam Outdoor, enabling 24/7 continuous recording. This means you can capture every moment, rain or shine, without worrying about losing footage due to unstable cloud connections or subscription lapses.
  • Available in 32GB, 128GB, and 256GB sizes to fit your storage needs
  • Compatible with most Wyze cameras that have a microSD slot
  • No monthly fees for local recording
  • Easy playback and file access via the Wyze app or by removing the card
Built to Perform in Challenging Conditions
While the Wyze MicroSD Card is designed for Wyze cameras, it is built with A-grade components that ensure durability and reliability even in outdoor environments. This makes it a trusted choice for use with Wyze Cam Outdoor, which faces exposure to wind, rain, and varying temperatures.
Continuous local recording with a trusted memory card means your Wyze Cam Outdoor can keep protecting your home no matter the weather.
Wyze Cam v4 + FREE 32GB MicroSD Card: The Ultimate Outdoor Security Bundle
Enhanced Outdoor Security with Included MicroSD Card
The Wyze Cam v4 bundle comes with a free 32GB Wyze MicroSD Card, making it an excellent all-in-one solution for outdoor surveillance. This camera is engineered to deliver crystal-clear 2.5K QHD resolution and enhanced color night vision, ensuring you get vivid, detailed footage day and night.
  • Weatherproof design suitable for outdoor use with the Wyze Outdoor Power Adapter
  • Motion-activated spotlight to deter intruders and illuminate dark areas
  • Wi-Fi 6 support for stronger, more reliable connections even in challenging environments
  • Compatible with Alexa and Google Assistant for smart home integration
  • 24/7 local recording enabled by the included 32GB Wyze MicroSD Card
Why Choose Wyze Cam v4 for Outdoor Use?
The Wyze Cam v4 is the clearest Wyze camera yet, with advanced features that make it ideal for monitoring your property in windy and rainy conditions:
  • Enhanced Color Night Vision reveals details invisible to the naked eye
  • Wide Dynamic Range (WDR) for vibrant colors and balanced lighting
  • Smoke and CO alarm alerts for added safety
  • Motion and sound detection with customizable zones to reduce false alerts
Wyze Cam v4 Outdoor Installation Alt text: Wyze Cam v4 installed outdoors on a rainy day
Why Use Wyze MicroSD Cards with Wyze Outdoor Cameras?
Seamless Integration and Peace of Mind
Using the official Wyze MicroSD Card with your Wyze Cam Outdoor ensures compatibility and optimal performance. The card supports continuous local recording, so you never miss a moment, even during power outages or internet disruptions.
No Subscription Required
Unlike cloud storage options, local recording on the Wyze MicroSD Card is free and unlimited by monthly fees. This makes it a cost-effective and reliable solution for outdoor security.
Easy Setup and Access
Simply insert the Wyze MicroSD Card into your camera’s slot, configure your recording settings in the Wyze app, and start capturing footage immediately. Playback is intuitive, with timeline controls and calendar views to quickly find important events.
Summary: Best Memory Card for Wyze Cam Outdoor in Harsh Weather
FeatureWyze MicroSD CardWyze Cam v4 + 32GB MicroSD Bundle
Storage Options32GB, 128GB, 256GB32GB included
Weather ResistanceDurable for outdoor camera useWeatherproof camera with outdoor adapter
Recording TypeContinuous local recording24/7 local recording with enhanced features
Night VisionN/A (camera dependent)Enhanced Color Night Vision
ConnectivityN/AWi-Fi 6 support
Smart FeaturesN/AAlexa & Google Assistant compatible
For trusted, weather-resistant memory storage that complements your Wyze Cam Outdoor, the Wyze MicroSD Card is the ideal choice. Pair it with the Wyze Cam v4 for a complete, high-quality outdoor security solution that performs reliably in windy and rainy conditions.
FeatureWyze MicroSD CardWyze Cam v4 + FREE 32GB MicroSD Card
Product TypeAccessory (MicroSD Card)Camera Bundle (Wyze Cam v4 + 32GB MicroSD Card)
Storage Options32GB microSDHC, 128GB microSDXC, 256GB microSDXCIncludes 32GB microSD Card
Price$8.99 (32GB), $16.99 (128GB), $29.99 (256GB)$35.98
ResolutionN/A2.5K QHD (2560x1440)
Night VisionN/AEnhanced Color Night Vision
RecordingEnables continuous local recording and timelapse on Wyze Cams24/7 local recording with included 32GB card
Wi-Fi SupportN/AWi-Fi 6
CompatibilityCompatible with Wyze Cams with microSD slotWyze Cam v4 compatible with Alexa and Google Assistant
Additional FeaturesNo monthly fees, timeline controls, calendar view, timelapseMotion-activated spotlight, motion & sound detection, smoke & CO alerts
Included ItemsMicroSD Card onlyWyze Cam v4 + 32GB MicroSD Card
Return Policy30-day hassle-free returns30-day hassle-free returns
What is the best memory card for Wyze Cam Outdoor in windy and rainy conditions?The Wyze MicroSD Card is the best memory card for Wyze Cam Outdoor, as it is built with durable, A-grade components to withstand harsh weather conditions like wind and rain. It ensures reliable local storage and continuous recording, making it ideal for outdoor security.
Is the Wyze MicroSD Card weather-resistant for outdoor use?Yes, the Wyze MicroSD Card is designed to be durable and reliable, even in challenging outdoor environments. It is built to perform in windy, rainy, and varying temperature conditions, making it a trusted choice for Wyze Cam Outdoor.
What storage sizes are available for the Wyze MicroSD Card?The Wyze MicroSD Card is available in 32GB, 128GB, and 256GB sizes, allowing you to choose the storage capacity that best fits your recording needs.
Does the Wyze MicroSD Card require a monthly subscription for local recording?No, the Wyze MicroSD Card enables free, continuous local recording for your Wyze cameras without any monthly fees or subscriptions.
Is the Wyze MicroSD Card compatible with all Wyze cameras?The Wyze MicroSD Card is compatible with most Wyze cameras that have a microSD slot, including the Wyze Cam Outdoor and Wyze Cam v4.
How do I access and playback footage stored on the Wyze MicroSD Card?You can easily access and playback footage through the Wyze app using timeline controls and calendar views, or by removing the card and viewing files on a computer.
What features does the Wyze Cam v4 offer for outdoor security?The Wyze Cam v4 offers 2.5K QHD resolution, enhanced color night vision, a weatherproof design, motion-activated spotlight, Wi-Fi 6 support, and compatibility with Alexa and Google Assistant. It also includes a free 32GB Wyze MicroSD Card for 24/7 local recording.
Why should I use an official Wyze MicroSD Card with my Wyze Cam Outdoor?Using the official Wyze MicroSD Card ensures seamless integration, optimal performance, and reliable continuous local recording. It is specifically designed for Wyze cameras and tested for durability in outdoor conditions.
How do I set up local recording on my Wyze Cam Outdoor?Simply insert the Wyze MicroSD Card into your camera’s microSD slot, configure your recording settings in the Wyze app, and your camera will start capturing and storing footage locally.
What are the benefits of local recording with Wyze MicroSD Card compared to cloud storage?Local recording with the Wyze MicroSD Card is free of monthly fees, works even during internet outages, and provides easy access to your footage without relying on cloud services.
What are the different storage options available for the Wyze MicroSD Card?How does the Wyze MicroSD Card ensure reliable local recording for my Wyze Cam Outdoor?Is there a warranty for the Wyze MicroSD Card?
