IP65 Indoor/Outdoor Security Cameras with 1080p Color Night Vision
IP65 Indoor Outdoor Weatherproof Security Cameras with 1080p Color Night Vision
When it comes to securing your home or business, having a reliable, weatherproof security camera with clear 1080p resolution and color night vision is essential. Whether you need indoor monitoring or robust outdoor surveillance, Wyze offers a range of IP65-rated cameras designed to deliver exceptional video quality and smart features that keep you connected and protected around the clock. Explore the best Wyze security cameras that combine weather resistance, vibrant color night vision, and advanced smart capabilities to meet your security needs.
Wyze Cam v4: The Ultimate Weatherproof Security Camera
Crystal-Clear 2.5K QHD Resolution & Enhanced Color Night Vision
Wyze Cam v4 is the clearest Wyze Cam ever made, boasting a stunning 2.5K Quad HD resolution that captures every detail with remarkable clarity. Its enhanced color night vision uses advanced hardware to pierce through darkness, revealing vibrant colors and details that traditional black-and-white night vision cameras miss. This means you get superhero-like vision even in low-light conditions.
IP65 Weather Resistance for All-Weather Use
Rated IP65, the Wyze Cam v4 is built to withstand rain, snow, and dust, making it perfect for both indoor and outdoor use. Whether mounted on your porch, backyard, or inside your home, it operates reliably in temperatures ranging from -4°F to 131°F (-20°C to 55°C).
Smart Features for Ultimate Convenience
  • Motion-activated spotlight and a loud 99 dB siren deter intruders and light your way home.
  • 24/7 local recording with microSD card support up to 256GB (sold separately) means no subscription is required.
  • Wi-Fi 6 support ensures a stronger, more reliable connection.
  • Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home integration.
  • Advanced AI-powered auto-zoom and smart focus track what matters while keeping the bigger picture in view.
Easy Installation & Versatile Mounting
The magnetic base and metal mounting plate allow for screw-free, hassle-free installation anywhere you need it. Wyze Cam v4 Outdoor Lifestyle Wyze Cam v4 providing reliable indoor and outdoor security with vibrant color night vision.
Wyze Cam Pan v3: 360° Pan and 180° Tilt with Weatherproof Durability
Full Coverage with Pan, Tilt, and Motion Tracking
Wyze Cam Pan v3 offers a complete 360° horizontal pan and 180° vertical tilt, allowing you to monitor an entire room or outdoor area with a single camera. Its automatic motion-tracking feature quietly follows moving objects, ensuring nothing escapes your view.
IP65 Weatherproof for Outdoor Use
Designed for both indoor and outdoor environments, the Pan v3 is fully IP65 rated. Pair it with the Wyze Outdoor Power Adapter (sold separately) for safe and reliable outdoor operation in all weather conditions.
Color Night Vision & Smart Alerts
Equipped with a Starlight Sensor, the Pan v3 delivers vivid color night vision, so you never miss important details after dark. It also supports custom detection zones and sends instant alerts for motion and sound, including smoke and carbon monoxide alarms.
Privacy Mode & Two-Way Audio
When you want privacy, activate Privacy Mode to spin the camera downward and disable recording. Two-way audio lets you communicate through the camera, perfect for talking to family, pets, or visitors. Wyze Cam Pan v3 in Snowy Outdoor Setting Wyze Cam Pan v3 weatherproof and ready for outdoor security in any season.
Wyze Cam OG: Reliable 1080p Indoor/Outdoor Security with IP65 Rating
True 1080p HD Video with Color Night Vision
Wyze Cam OG features a 1920 x 1080 resolution with a CMOS Starlight Sensor and 4 IR LEDs for clear, detailed video day and night. Its color night vision capability ensures you see more than just shadows in the dark.
IP65 Weather Resistance & Wide Field of View
With an IP65 rating, this camera is suitable for indoor and outdoor use, operating in temperatures from -4°F to 131°F (-20°C to 55°C). It offers a wide 120° field of view to cover large areas effectively.
Enhanced Audio and Smart Features
  • Built-in speaker and microphone with noise and echo cancellation for crisp two-way communication.
  • Supports up to 256GB microSD card for local storage.
  • Custom detection zones and smoke/CO alerts keep you informed of critical events.
  • Faster live streaming and 3X quicker notifications than previous models.
Wyze Cam OG Telephoto: Zoomed-In 1080p Security with IP65 Weatherproofing
3X Telephoto Lens for Detailed Zoom
The Wyze Cam OG Telephoto offers the same 1080p resolution and IP65 weather resistance as the OG model but adds a powerful 3X telephoto lens. This allows you to zoom in on distant objects with clarity, covering narrower fields of view (27° diagonal) for focused surveillance.
Night Vision and Smart Integration
Equipped with 4 IR LEDs and color night vision, it captures clear images in low light. It supports Alexa, Google Assistant, and IFTTT for smart home compatibility.
Compact and Versatile
Measuring just 1.89 inches cubed and weighing 4.1 oz, this camera is easy to mount on walls, ceilings, or stands, making it ideal for targeted monitoring.
Wyze Cam v4 Home Security Bundle: Complete Protection Package
All the Benefits of Wyze Cam v4 with Added Value
This bundle includes multiple Wyze Cam v4 units with 128GB microSD cards, providing extended local storage and coverage for your home or business.
Features at a Glance
  • 2.5K QHD resolution with enhanced color night vision.
  • IP65 weather resistance for indoor/outdoor use.
  • Motion-activated spotlight and 99 dB siren for deterrence.
  • Wide dynamic range (WDR) for vibrant, true-to-life colors.
  • Multiple mounting options including magnetic and adhesive mounts.
This bundle is perfect for those who want comprehensive security with easy setup and no subscription fees.
Why Choose Wyze IP65 Weatherproof Cameras?
Wyze security cameras combine advanced imaging technology, robust weatherproofing, and smart home integration at an affordable price point. Their enhanced color night vision and 1080p+ resolution ensure you never miss a detail, day or night, rain or shine.
Whether you need full 360° coverage, telephoto zoom, or a simple plug-and-play camera, Wyze has a solution that fits your security needs both indoors and outdoors.
Summary of Featured IP65 Weatherproof Cameras with 1080p Color Night Vision
ModelResolutionNight Vision TypeWeatherproof RatingSpecial Features
Wyze Cam v42.5K QHDEnhanced Color NightIP65Motion spotlight, 99 dB siren, Wi-Fi 6
Wyze Cam Pan v31080pColor Night VisionIP65360° pan, 180° tilt, motion tracking
Wyze Cam OG1080pColor Night VisionIP65Fast live streaming, smoke/CO alerts
Wyze Cam OG Telephoto1080pColor Night VisionIP653X telephoto zoom lens
Wyze Cam v4 Home Bundle2.5K QHDEnhanced Color NightIP65Multiple cams + 128GB microSD included
Protect your property with Wyze’s IP65 indoor/outdoor security cameras featuring 1080p resolution and vibrant color night vision. Choose the model that fits your needs and enjoy peace of mind with smart, weatherproof surveillance.
FeatureWyze Cam v4Wyze Cam Pan v3Wyze Cam OGWyze Cam OG TelephotoWyze Cam v4 Home Security Bundle
Video Resolution2.5K QHD (2560x1440)Not specified (assumed 1080p)1080p (1920x1080)1080p (1920x1080)2.5K QHD (2560x1440)
Field of View (DFOV)115.8°360° pan, 180° tilt120°27° (telephoto)115.8°
Night VisionEnhanced Color Night Vision (4 IR LEDs + 2 white spotlight LEDs, 72 lumens)Color Night Vision (Starlight Sensor)4 IR LEDs (850 nm)4 IR LEDs (850 nm)Enhanced Color Night Vision (4 IR LEDs + 2 white spotlight LEDs, 72 lumens)
Audio99dB waterproof speaker, simultaneous two-way talk, noise & echo cancellationTwo-way audioBuilt-in speaker & mic, noise & echo cancellationBuilt-in speaker & mic, noise & echo cancellationImproved 2-way audio
SirenBuilt-in siren (99 dB)Not specified90 dB user-activated sirenNot specifiedNot specified
SpotlightMotion-activated spotlightNot specifiedBuilt-in spotlight (40 lumens)Not specifiedMotion-activated spotlight
Weather ResistanceIP65IP65IP65IP65IP65
ConnectivityWi-Fi 6, Bluetooth 5.2Wi-Fi (802.11 b/g/n)Wi-Fi 2.4 GHz (802.11 b/g/n)Wi-Fi 2.4 GHz (802.11 b/g/n)Wi-Fi 6
Local StoragemicroSD card up to 512 GB (required)microSD card support (up to 256 GB)microSD up to 256 GBmicroSD up to 256 GB128GB microSD included
Cloud StorageAvailable with subscriptionAvailable with subscriptionAvailable with subscriptionAvailable with subscriptionAvailable with subscription
Motion DetectionYes, with detection zonesYes, with detection zonesYes, with detection zonesYes, with detection zonesYes, with detection zones
Sound DetectionYesYesNot specifiedNot specifiedYes
Smoke & CO AlertsYesYesYesNot specifiedYes
Dimensions2in x 2in x 2 3/8in (51 x 51 x 60 mm)Not specified1.89in x 1.89in x 1.89in (48mm)1.89in x 1.89in x 1.89in (48mm)2in x 2in x 2 3/8in (51 x 51 x 60 mm)
Weight0.49 lb (222 g)Not specified4.1 oz (116 g)4.1 oz (116 g)0.49 lb (222 g)
Mounting OptionsStand, wall mount, ceiling mount, magnetic wall mount (adhesive)Not specifiedStand, wall mount, ceiling mountStand, wall mount, ceiling mountStand, wall mount, ceiling mount, magnetic wall mount (adhesive)
Power SourceWired (Indoor adapter included, outdoor adapter sold separately)Wired (Outdoor adapter sold separately)WiredWiredWired (includes power adapter)
BluetoothYes, Bluetooth 5.2Not specifiedNot specifiedNot specifiedNot specified
Smart Assistant CompatibilityAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTNot specifiedAlexa, Google Assistant, IFTTTAlexa, Google Assistant
Price (Single Pack)$35.98$39.98$29.98$25.98$169.99 (bundle)
Release Year2024Not specified (latest version)Not specified20232024
What does IP65 weatherproof rating mean for Wyze security cameras?An IP65 weatherproof rating means Wyze security cameras are protected against dust and can withstand low-pressure water jets from any direction. This makes them suitable for both indoor and outdoor use, ensuring reliable operation in rain, snow, and dusty environments.
Which Wyze security cameras offer color night vision?Wyze Cam v4, Wyze Cam Pan v3, Wyze Cam OG, and Wyze Cam OG Telephoto all feature color night vision. These cameras use advanced sensors and hardware to provide vibrant, detailed video even in low-light conditions.
Can Wyze security cameras be used both indoors and outdoors?Yes, all featured Wyze security cameras, including Wyze Cam v4, Cam Pan v3, Cam OG, and Cam OG Telephoto, are IP65 rated for weather resistance, making them suitable for both indoor and outdoor installation.
What is the video resolution of Wyze security cameras?Wyze Cam v4 offers 2.5K Quad HD (QHD) resolution for ultra-clear video, while Wyze Cam Pan v3, Cam OG, and Cam OG Telephoto provide 1080p Full HD resolution for crisp and detailed footage.
Do Wyze security cameras require a subscription for video recording?No subscription is required for 24/7 local recording with Wyze security cameras. Simply insert a microSD card (up to 256GB, sold separately) to enable continuous local video storage.
What smart features are available on Wyze security cameras?Wyze security cameras offer a range of smart features, including motion-activated spotlights, 99 dB sirens, motion and sound alerts, custom detection zones, smoke and CO alarm detection, two-way audio, and compatibility with Alexa, Google Assistant, and IFTTT.
How easy is it to install Wyze security cameras?Wyze cameras are designed for easy installation. The Wyze Cam v4, for example, features a magnetic base and metal mounting plate for screw-free setup. Other models offer versatile mounting options for walls, ceilings, or stands.
What is the difference between Wyze Cam OG and Wyze Cam OG Telephoto?Wyze Cam OG provides a wide 120° field of view for general surveillance, while Wyze Cam OG Telephoto features a 3X telephoto lens with a 27° diagonal field of view, allowing you to zoom in on distant objects for focused monitoring.
Does Wyze Cam Pan v3 offer full room coverage?Yes, Wyze Cam Pan v3 provides 360° horizontal panning and 180° vertical tilting, along with automatic motion tracking, to cover an entire room or outdoor area with a single camera.
Are Wyze security cameras compatible with smart home systems?Yes, Wyze security cameras are compatible with popular smart home platforms, including Amazon Alexa, Google Assistant, and IFTTT, allowing for seamless integration and voice control.
What is included in the Wyze Cam v4 Home Security Bundle?The Wyze Cam v4 Home Security Bundle includes multiple Wyze Cam v4 units and 128GB microSD cards, providing extended local storage and comprehensive coverage for your home or business.
What temperature range can Wyze IP65 cameras operate in?Wyze IP65-rated cameras are designed to operate reliably in temperatures ranging from -4°F to 131°F (-20°C to 55°C), making them suitable for various climates and weather conditions.
What are the key features of the Wyze Cam v4?Can you tell me more about the installation process for the Wyze Cam v4?Are there any ongoing promotions or discounts for Wyze cameras?
