Affordable Refurbished IP65 Indoor Outdoor Security Cameras with Advanced Features
Looking for an affordable, reliable, and feature-packed security camera that works both indoors and outdoors? Our selection of Wyze refurbished IP65-rated security cameras offers advanced technology, weather resistance, and smart home compatibility — all without breaking the bank. Whether you want 360° coverage, crystal-clear video, or powerful lighting integration, these cameras deliver exceptional value and performance.
Wyze Cam Pan v3: 360° Pan & Tilt with IP65 Weather Resistance
Wyze Cam Pan v3 is a versatile indoor/outdoor security camera designed to keep an eye on your property in any weather. With a full IP65 rating, it withstands rain, snow, and dust, making it perfect for outdoor use when paired with the Wyze Outdoor Power Adapter (sold separately).
Key Features:
- 360° Pan and 180° Tilt: Complete coverage with smooth, quiet motorized movement to track motion automatically.
- Color Night Vision: Starlight sensor technology delivers vibrant color footage even in low light.
- Two-Way Audio: Speak and listen through the Wyze app for real-time communication.
- Privacy Mode: Easily disable the camera’s view by pointing it downward when privacy is needed.
- Custom Detection Zones & Alerts: Receive notifications only for important areas and events.
- Local Storage & Cloud Options: Supports microSD cards up to 256GB and optional Cam Plus subscription for advanced AI detection.
Wyze Cam Pan v3 is an excellent choice for those who want dynamic coverage and weatherproof durability at an affordable price.
Wyze Cam Pan v3: Weatherproof 360° security
Wyze Cam v4: Crystal-Clear 2.5K QHD with Spotlight & IP65 Rating
The Wyze Cam v4 is the clearest Wyze camera yet, offering 2.5K Quad HD resolution and enhanced color night vision for stunning image quality day or night. Its IP65 weather resistance means it can be placed indoors or outdoors without worry.
Highlights:
- 2.5K QHD Video: Capture sharp, detailed footage with wide dynamic range (WDR) for vibrant colors.
- Enhanced Color Night Vision: See more details in darkness with improved hardware.
- Motion-Activated Spotlight & Siren: Deter intruders with a bright spotlight and 99 dB siren.
- Wi-Fi 6 Support: Enjoy a stronger, more reliable connection with compatible routers.
- Easy Setup & Mounting: Bluetooth setup and magnetic mount make installation hassle-free.
- Smart Home Integration: Works seamlessly with Alexa, Google Assistant, and IFTTT.
- 24/7 Local Recording: Continuous recording to microSD card (up to 256GB) without subscription.
Wyze Cam v4 is perfect for users who want high-resolution video, smart lighting features, and robust weatherproofing at a budget-friendly price.
Wyze Cam Floodlight v2: Bright 2800 Lumens & 2K Video for Outdoor Security
For those who want to combine powerful lighting with security, the Wyze Cam Floodlight v2 offers a brilliant 2800 lumens LED floodlight alongside a 2K camera with color night vision. Its IP65 rating ensures reliable outdoor performance in all weather conditions.
Features:
- 2800 Lumens Dimmable LED Lights: Illuminate large areas with adjustable brightness.
- 2K Video with 160° Wide-Angle View: Capture clear, wide coverage of your driveway or yard.
- AI-Powered Light Control: Automatically adjusts lighting based on motion and ambient light.
- Two-Way Audio & 105 dB Siren: Communicate and deter unwanted visitors effectively.
- Dusk-to-Dawn Automation: Lights turn on/off automatically based on natural light.
- Local Storage Support: Save footage on microSD cards up to 256GB.
- Smart Assistant Compatibility: Integrates with Alexa, Google Assistant, and IFTTT.
This camera is ideal for outdoor areas needing both bright illumination and vigilant security monitoring.
Wyze Cam Floodlight v2: Bright, smart outdoor security
Wyze Battery Cam Pro: Wire-Free, Rechargeable, and IP65 Rated
If you prefer a wireless option with no hub required, the Wyze Battery Cam Pro offers 2.5K HDR video resolution and IP65 weatherproofing in a compact, portable design. Its removable rechargeable battery packs provide up to 6 months of operation on a single charge.
Advantages:
- Wire-Free Installation: No cables or hubs needed, perfect for flexible placement.
- 2.5K HDR Video: High-quality footage with wide field of view (134° diagonal).
- Integrated Spotlight & Siren: Built-in lighting and 100 dB siren for enhanced security.
- Radar + PIR Motion Detection: Advanced sensors reduce false alerts.
- Two-Way Audio: Talk and listen through the camera’s speaker and mic.
- Dual-Band Wi-Fi Support: Connects to both 2.4 GHz and 5 GHz networks.
- Local Storage: Supports microSD cards up to 256GB for continuous recording.
Wyze Battery Cam Pro is perfect for users needing a flexible, powerful, and weatherproof security camera without wiring hassles.
Wyze Cam OG: Budget-Friendly Indoor/Outdoor Camera with Spotlight
The Wyze Cam OG is the next generation of the original Wyze Cam, offering improved live streaming, faster notifications, and a built-in spotlight. It is IP65 rated for indoor and outdoor use, making it a great entry-level option.
Features:
- Quick Live Streaming & 3X Faster Notifications: Stay updated in real-time.
- Improved Two-Way Audio: Clear communication with built-in mic and speaker.
- Built-In Spotlight: Adds extra security lighting.
- IP65 Weather Resistance: Suitable for outdoor placement.
- Affordable Price Point: Great value for basic smart security needs.
This camera is ideal for budget-conscious buyers who want reliable indoor/outdoor monitoring with essential smart features.
Why Choose Refurbished IP65 Wyze Security Cameras?
Investing in refurbished Wyze IP65 cameras means you get advanced security features, weatherproof durability, and smart home compatibility at a fraction of the cost of new models. These cameras are tested and certified to work like new, offering peace of mind without compromising quality.
With options ranging from dynamic pan-tilt coverage to wire-free battery operation and integrated floodlights, Wyze’s refurbished lineup covers all your indoor and outdoor security needs affordably.
Summary Table of Featured Cameras
Model | Resolution | Weatherproof | Key Features | Price Range (Refurbished) |
Wyze Cam Pan v3 | 1080p | IP65 | 360° pan/tilt, color night vision | $39.98+ |
Wyze Cam v4 | 2.5K QHD | IP65 | Spotlight, siren, Wi-Fi 6, color NV | $35.98+ |
Wyze Cam Floodlight v2 | 2K | IP65 | 2800 lumens floodlight, 2-way audio | $89.98 |
Wyze Battery Cam Pro | 2.5K HDR | IP65 | Wire-free, rechargeable battery | $89.98 |
Wyze Cam OG | 1080p | IP65 | Built-in spotlight, fast alerts | $29.98 |
Secure your home or business with affordable, feature-rich Wyze refurbished IP65 indoor/outdoor cameras. Enjoy peace of mind with advanced video quality, smart alerts, and weatherproof reliability — all at unbeatable prices.
Stay connected with two-way audio
### Tags Summary
What are the benefits of choosing refurbished Wyze IP65 security cameras?
Refurbished Wyze IP65 security cameras offer advanced features, weatherproof durability, and smart home compatibility at a fraction of the cost of new models. Each camera is tested and certified to work like new, providing reliable security and peace of mind without compromising on quality.Are Wyze refurbished security cameras suitable for both indoor and outdoor use?
Yes, all featured Wyze refurbished security cameras are IP65-rated, making them weather-resistant and suitable for both indoor and outdoor installation. They are designed to withstand rain, snow, and dust, ensuring reliable performance in various environments.What advanced features do Wyze refurbished IP65 cameras offer?
Wyze refurbished IP65 cameras offer features such as 360° pan and tilt, color night vision, two-way audio, motion-activated spotlights and sirens, AI-powered detection, local and cloud storage options, and smart home integration with Alexa, Google Assistant, and IFTTT.Which Wyze refurbished camera is best for 360° coverage?
The Wyze Cam Pan v3 is ideal for 360° coverage, offering smooth pan and tilt functionality, color night vision, two-way audio, and IP65 weather resistance for both indoor and outdoor use.Which Wyze refurbished camera provides the clearest video quality?
The Wyze Cam v4 delivers the clearest video quality with 2.5K Quad HD resolution, enhanced color night vision, and wide dynamic range for vibrant, detailed footage day or night.Is there a Wyze refurbished camera with integrated floodlights?
Yes, the Wyze Cam Floodlight v2 features a powerful 2800 lumens dimmable LED floodlight, 2K video resolution, color night vision, AI-powered light control, and a 105 dB siren for comprehensive outdoor security.Are there wire-free, battery-powered Wyze refurbished cameras available?
The Wyze Battery Cam Pro is a wire-free, rechargeable camera with 2.5K HDR video, IP65 weatherproofing, integrated spotlight and siren, radar and PIR motion detection, and up to 6 months of battery life on a single charge.What is the most affordable Wyze refurbished IP65 camera?
The Wyze Cam OG is the most budget-friendly option, offering 1080p video, built-in spotlight, fast notifications, improved two-way audio, and IP65 weather resistance for both indoor and outdoor use.Do Wyze refurbished cameras support local storage?
Yes, all featured Wyze refurbished cameras support local storage via microSD cards up to 256GB, allowing for continuous or event-based recording without a subscription.Can Wyze refurbished IP65 cameras be integrated with smart home systems?
Absolutely. Wyze refurbished IP65 cameras are compatible with popular smart home platforms, including Amazon Alexa, Google Assistant, and IFTTT, enabling voice control and automation.What is the price range for Wyze refurbished IP65 security cameras?
Refurbished Wyze IP65 security cameras range from $29.98 for the Wyze Cam OG to $89.98 for the Wyze Cam Floodlight v2 and Wyze Battery Cam Pro, offering affordable options for various security needs.Do Wyze refurbished cameras require a subscription for full functionality?
No, Wyze refurbished cameras offer essential features such as live streaming, two-way audio, and local storage without a subscription. However, advanced AI detection and cloud storage are available through an optional Cam Plus subscription.
