Professional IP65 Outdoor Security Cameras with Motion Alerts
Professional IP65 Outdoor Security Cameras with Motion Detection Alerts
When it comes to securing your home or business outdoors, choosing a professional-grade security camera that is weather-resistant and equipped with advanced motion detection alerts is essential. Below, we highlight the top Wyze cameras designed specifically for outdoor use, all featuring IP65 weather resistance and smart motion detection capabilities to keep your property safe around the clock.
Wyze Cam Pan v3: Versatile 360° Outdoor Security with Motion Tracking
Wyze Cam Pan v3 is a redesigned indoor/outdoor security camera that offers a full 360° pan and 180° tilt, making it perfect for comprehensive outdoor surveillance. Rated IP65 for weather resistance, it can withstand rain, snow, and harsh conditions when paired with the Wyze Outdoor Power Adapter (sold separately).
Key Features:
  • IP65 Weather Resistance: Durable against rain and snow, ideal for year-round outdoor use.
  • 360° Pan & 180° Tilt: Covers every angle of your property with smooth, automatic motion tracking.
  • Automatic Motion-Tracking: Detects and follows moving objects silently without disturbing your environment.
  • Color Night Vision: Equipped with a Starlight Sensor to capture vivid color footage even in low light.
  • Two-Way Audio: Communicate directly through the camera via the Wyze app.
  • Custom Detection Zones: Focus alerts on specific areas to reduce false alarms.
  • Privacy Mode: Easily disable the camera’s view when privacy is needed.
Wyze Cam Pan v3 is an excellent choice for those who want a flexible, weatherproof camera with intelligent motion tracking and detailed color night vision. Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3 - Weatherproof and reliable in all seasons
Wyze Cam v4: Crystal-Clear 2.5K QHD Outdoor Security with Spotlight
Wyze Cam v4 is the clearest Wyze outdoor camera yet, delivering 2.5K Quad HD resolution and enhanced color night vision. Its IP65 rating ensures it performs reliably in all weather conditions, making it a top contender for professional outdoor security.
Key Features:
  • 2.5K QHD Resolution: Ultra-clear video quality for detailed monitoring.
  • Enhanced Color Night Vision: See vibrant colors even in near darkness.
  • Motion-Activated Spotlight & Siren: Deter intruders with a bright spotlight and loud siren.
  • IP65 Weather Resistance: Built to withstand rain, snow, and extreme temperatures.
  • Wi-Fi 6 Support: Ensures a stronger, more reliable connection.
  • Advanced Two-Way Talk: Clearer audio communication with AAC codec and powerful mic.
  • 24/7 Local Recording: Continuous recording to microSD card (up to 256GB) without subscription.
  • Smart Assistant Compatibility: Works seamlessly with Alexa, Google Assistant, and IFTTT.
Wyze Cam v4 is perfect for users who want high-resolution video, smart deterrence features, and robust weatherproofing.
Wyze Cam Floodlight v2: Bright 2800 Lumens LED Security with AI-Powered Alerts
For those who want to combine lighting and security, the Wyze Cam Floodlight v2 offers a powerful 2800 lumens LED floodlight integrated with a 2K security camera. This IP65-rated camera is designed to illuminate and monitor wide outdoor areas with smart motion detection alerts.
Key Features:
  • 2800 Lumens Dimmable LED Lights: Brighten your driveway or yard with adjustable lighting.
  • 2K Video with Color Night Vision: Capture clear, colorful footage day and night.
  • 160° Wide-Angle View: Covers a broad area for maximum security.
  • AI-Powered Light Control: Lights activate intelligently based on motion detection.
  • Two-Way Audio & 105dB Siren: Communicate and deter intruders effectively.
  • Dusk-to-Dawn Automation: Automatically turns lights on/off based on ambient light.
  • IP65 Weather Resistance: Reliable performance in all weather conditions.
  • Smart Assistant Integration: Compatible with Alexa, Google Assistant, and IFTTT.
This floodlight camera is ideal for users who want to light up their property while maintaining vigilant security with smart alerts. Wyze Cam Floodlight v2 illuminating driveway at night Wyze Cam Floodlight v2 - Bright security lighting with smart detection
Wyze Battery Cam Pro: Wire-Free, Rechargeable Outdoor Security with Radar Motion Detection
Wyze Battery Cam Pro offers a wireless, battery-powered solution with professional-grade features including 2.5K HDR video, radar + PIR motion detection, and IP65 weatherproofing. Its rechargeable battery packs provide up to 6 months of operation, making it highly flexible for outdoor security without wiring hassles.
Key Features:
  • 2.5K HDR Video Resolution: High-quality video with excellent dynamic range.
  • Radar + PIR Motion Detection: Advanced dual-sensor technology for accurate alerts.
  • Integrated Spotlight & Siren: Built-in deterrents to keep intruders away.
  • IP65 Weatherproof: Designed to endure outdoor elements.
  • Wire-Free & Rechargeable: No hub required; easy installation anywhere.
  • Two-Way Audio: Talk and listen through the camera.
  • Supports 2.4 & 5 GHz Wi-Fi: Flexible connectivity options.
  • Local Storage Support: Up to 256GB microSD card for continuous recording.
Wyze Battery Cam Pro is perfect for those needing a flexible, wireless outdoor camera with professional motion detection and long battery life.
Why Choose Wyze IP65 Outdoor Security Cameras?
Investing in an IP65-rated outdoor security camera ensures your device is protected against dust and water jets, making it suitable for all weather conditions. Wyze cameras combine this rugged durability with advanced motion detection alerts, high-resolution video, and smart home integrations to provide comprehensive, professional outdoor security.
Summary Table of Features
FeatureWyze Cam Pan v3Wyze Cam v4Wyze Cam Floodlight v2Wyze Battery Cam Pro
Weather ResistanceIP65IP65IP65IP65
Video Resolution1080p2.5K QHD2K2.5K HDR
Motion DetectionAutomatic trackingMotion zones + alertsAI-powered light controlRadar + PIR detection
Night VisionColor Night VisionEnhanced Color Night VisionColor Night VisionIR LEDs + White LEDs
AudioTwo-Way AudioEnhanced Two-Way TalkTwo-Way AudioTwo-Way Audio
Power SourceWired (Outdoor Adapter)WiredHardwiredBattery (Rechargeable)
Spotlight & SirenNo (adapter sold separately)YesYesYes
Local StoragemicroSD up to 256GBmicroSD up to 256GBmicroSD up to 256GBmicroSD up to 256GB
Smart Assistant IntegrationYesYesYesYes
Secure your outdoor spaces with Wyze’s professional IP65-rated cameras that combine durability, smart motion detection alerts, and crystal-clear video quality. Whether you prefer wired or wireless, floodlight or pan-tilt, Wyze has the perfect outdoor security camera to fit your needs.
Video Resolution1080p2.5K QHD (2560 x 1440)2K (2304 x 1296)2.5K (2560 x 1440)
Field of View360° pan, 180° tilt115.9° (D) x 98.5° (H) x 53.1° (V)160° diagonal134° (DFOV), 108° (HFOV), 56° (VFOV)
Night VisionColor Night Vision (Starlight Sensor)Enhanced Color Night VisionColor Night VisionIR LEDs + White LEDs (Color Night Vision)
Weather ResistanceIP65 (requires Outdoor Power Adapter)IP65IP65IP65
Power SourceWired (Outdoor Power Adapter sold separately)WiredHardwiredBattery (Removable, Rechargeable)
SpotlightNo (sold separately)Yes (motion-activated)Yes (2 dimmable LED panels)Integrated Spotlight
SirenNoYes (99 dB)Yes (105 dB)Yes (100 dB)
Motion DetectionYes (automatic motion tracking)YesYesRadar + PIR Motion Detection
ConnectivityWi-Fi (2.4 GHz)Wi-Fi 6 (2.4 GHz & Wi-Fi 6)Wi-Fi 2.4 GHzWi-Fi 2.4 & 5 GHz
Smart Assistant IntegrationYes (Alexa, Google Assistant, IFTTT)Yes (Alexa, Google Assistant, IFTTT)Yes (Alexa, Google Assistant, IFTTT)Yes (Alexa, Google Assistant, IFTTT)
DimensionsNot specified2in x 2in x 2 3/8in9.5in x 7.7in x 7.0in2.5 x 1.8 x 3.5 inches
WeightNot specified0.49 lb (222 g)2.76 lbs (1.25 kg)0.94 lbs
Additional FeaturesPrivacy Mode, Pan Scan™, Quiet motorAuto-zoom with AI, WDR, 24/7 local recordingAmbient Light Mode, Dusk-to-Dawn automationUp to 6 months battery life, Radar motion detection
Price (1 Pack)$39.98$35.98$89.98$159.98
What does IP65 weather resistance mean for Wyze outdoor security cameras?IP65 weather resistance means Wyze outdoor security cameras are protected against dust and water jets from any direction, making them suitable for use in rain, snow, and harsh outdoor conditions. This ensures reliable performance year-round.
Which Wyze outdoor security camera is best for 360-degree coverage?The Wyze Cam Pan v3 is ideal for 360-degree coverage, offering a full 360° pan and 180° tilt with automatic motion tracking. This allows comprehensive surveillance of your outdoor space.
Do Wyze outdoor cameras have motion detection alerts?Yes, all featured Wyze outdoor cameras offer advanced motion detection alerts. Depending on the model, you get features like automatic motion tracking, custom detection zones, radar + PIR detection, and AI-powered light control for accurate and timely notifications.
Can Wyze outdoor cameras record video locally without a subscription?Yes, Wyze outdoor cameras support local video recording to a microSD card (up to 256GB), allowing for continuous 24/7 recording without the need for a subscription.
Which Wyze camera offers the highest video resolution for outdoor security?The Wyze Cam v4 and Wyze Battery Cam Pro both offer 2.5K QHD/HDR video resolution, providing ultra-clear and detailed footage for outdoor security.
Are Wyze outdoor security cameras compatible with smart home assistants?Yes, Wyze outdoor security cameras are compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless integration with your smart home ecosystem.
What is the difference between Wyze Cam Floodlight v2 and other Wyze outdoor cameras?Wyze Cam Floodlight v2 combines a powerful 2800 lumens LED floodlight with a 2K security camera, offering wide-area illumination, AI-powered motion detection, and a 160° wide-angle view. It is ideal for users who want both lighting and security in one device.
Is there a wireless, battery-powered Wyze outdoor camera option?Yes, the Wyze Battery Cam Pro is a wire-free, rechargeable outdoor security camera with up to 6 months of battery life, 2.5K HDR video, radar + PIR motion detection, and IP65 weatherproofing.
Do Wyze outdoor cameras have night vision capabilities?Yes, Wyze outdoor cameras feature advanced night vision. Models like Wyze Cam Pan v3, Cam v4, and Floodlight v2 offer color night vision, while the Battery Cam Pro uses IR LEDs and white LEDs for clear footage in low-light conditions.
Can I communicate through Wyze outdoor security cameras?Yes, all Wyze outdoor security cameras are equipped with two-way audio, allowing you to listen and speak through the camera using the Wyze app.
What power options are available for Wyze outdoor security cameras?Wyze offers both wired and wireless outdoor security cameras. The Wyze Cam Pan v3, Cam v4, and Floodlight v2 are wired (with the Pan v3 requiring an outdoor adapter), while the Wyze Battery Cam Pro is battery-powered and rechargeable.
How do Wyze outdoor cameras help deter intruders?Wyze outdoor cameras like the Cam v4, Floodlight v2, and Battery Cam Pro feature built-in spotlights and sirens that can be activated by motion detection to deter intruders and alert you instantly.
What are the key features of the Wyze Cam Pan v3?How does the motion detection work on the Wyze Cam Pan v3?Are there any ongoing sales or discounts for Wyze cameras?
