Comprehensive Home Alarm Systems for Ultimate Security
Protecting your home has never been easier or more efficient with the latest home alarm systems designed to offer comprehensive surveillance, smart features, and seamless integration. Whether you want to monitor your indoor spaces, outdoor areas, or entry points, these Wyze security products provide reliable, high-quality solutions tailored to your needs.
Wyze Cam v4 – Crystal-Clear Security Day and Night
Experience unmatched home security with the
Wyze Cam v4, a versatile camera that delivers crystal-clear 2.5K QHD resolution. Equipped with an advanced CMOS Starlight Sensor and enhanced color night vision, this camera ensures you never miss a detail, even in low-light conditions.
- Resolution: 2.5K QHD for sharp, detailed video
- Night Vision: Enhanced color night vision for clear images after dark
- Field of View: Wide angles with DFOV 115.8°, HFOV 98.5°, VFOV 53.1°
- Connectivity: Wi-Fi 6 support for faster, more reliable streaming
- Smart Integration: Compatible with Alexa and Google Assistant
- Recording: 24/7 local recording keeps your footage safe without monthly fees
- Variants: Available in Black, Clear, Grey, and White; packs of 1, 2, or 3
This camera is perfect for both indoor and outdoor use, providing a robust security solution that adapts to your home environment.
Wyze Cam Pan v3 – 360° Pan and Tilt for Full Coverage
For those who want to cover every angle, the
Wyze Cam Pan v3 offers a 360° pan and 180° tilt capability, allowing you to monitor large areas with a single device. Its IP65 weather resistance makes it ideal for outdoor use when paired with the Wyze Outdoor Power Adapter.
- Pan & Tilt: 360° horizontal and 180° vertical movement for full room or yard coverage
- Weatherproof: IP65 rating ensures durability in rain, snow, and other harsh conditions
- Indoor/Outdoor: Versatile use with optional outdoor power adapter
- Colors: Available in Black and White
- Packs: Sold in 1, 2, or 3 packs for scalable security setups
<img src="https://www.wyze.com/cdn/shop/files/IMG_4216-5_1.jpg?v=1670422469&width=1500" alt="Wyze Cam Pan v3 in snowy outdoor setting">
Stay secure in any weather with Wyze Cam Pan v3
Wyze Battery Cam Pro – Wire-Free, Powerful Surveillance
Enjoy the freedom of wire-free installation with the
Wyze Battery Cam Pro, featuring 2.5K HDR video resolution and no hub required. This camera is perfect for locations where wiring is inconvenient, offering a rechargeable battery and smart detection features.
- Video Quality: 2.5K HDR for vibrant, clear footage
- Wireless: Completely wire-free with removable, rechargeable 6200mAh battery packs
- Motion Detection: Radar + PIR sensors for precise alerts
- Integrated Spotlight & Siren: Deter intruders with built-in security features
- Weatherproof: IP65 rating for reliable outdoor use
- Wi-Fi Support: Compatible with both 2.4GHz and 5GHz networks
- Colors: Black and White options available
This camera is ideal for flexible placement around your property without the hassle of cables.
Wyze Bulb Cam – Dual Function Security and Lighting
The
Wyze Bulb Cam combines a smart LED light bulb with a 2K HD security camera, providing both illumination and surveillance in one easy-to-install device. Perfect for outdoor fixtures, it offers color night vision and instant motion alerts.
- Video Resolution: 2K HD with color night vision
- Lighting: Smart LED bulb functionality controllable via the Wyze app
- Installation: Fits most standard light fixtures, no extra wiring needed
- Storage: Supports local video storage with no subscription fees
- Certifications: FCC, IC, UL, and IP65 weatherproof rating
- Price: Affordable security and lighting in one device
<img src="https://www.wyze.com/cdn/shop/files/Wyze_Bulb_Cam_Shopify-07.jpg?v=1746478547&width=1500" alt="Wyze Bulb Cam installed in outdoor light fixture">
Secure and illuminate your home effortlessly with Wyze Bulb Cam
Wyze Video Doorbell v2 – See and Speak to Visitors Anywhere
Enhance your front door security with the
Wyze Video Doorbell v2, offering 2K video clarity and two-way audio. Answer your door from anywhere and receive real-time alerts for motion or visitors.
- Video Quality: 2K resolution for detailed video
- Two-Way Audio: Communicate with visitors remotely
- Storage: Local microSD storage for video clips
- Motion-Activated Voice Deterrence: Scare off unwanted guests with pre-recorded messages
- Color: Sleek Black design
- Easy Installation: Wired setup for consistent power and connectivity
Wyze Cam OG – Next-Gen Indoor/Outdoor Camera
The
Wyze Cam OG is the latest evolution in Wyze’s camera lineup, offering faster live streaming, 3X quicker notifications, and improved two-way audio. It also features a built-in spotlight for enhanced night security.
- Video Resolution: 1080p Full HD
- Field of View: Wide 120° angle
- Performance: 20 FPS during the day, 15 FPS at night
- Spotlight: Built-in for better night visibility
- Indoor/Outdoor: Suitable for versatile placement
- Packs: Available in 1, 2, or 3 packs
<img src="https://www.wyze.com/cdn/shop/files/2_way_talk-03.png?v=1670674480&width=1500" alt="Wyze Cam OG with two-way audio feature">
Communicate clearly with Wyze Cam OG’s two-way audio
Why Choose Wyze Home Alarm Systems?
Wyze offers a comprehensive range of home alarm systems that combine high-resolution video, smart home integration, and weather-resistant designs. Whether you need wired or wireless options, indoor or outdoor coverage, or multi-functional devices like the Bulb Cam, Wyze has a solution to fit your security needs and budget.
Protect your home with smart, reliable, and easy-to-install security cameras that keep you connected and in control, day and night.
Summary of Featured Products
Product Name | Key Features | Ideal Use Case |
Wyze Cam v4 | 2.5K QHD, color night vision | Indoor/outdoor monitoring |
Wyze Cam Pan v3 | 360° pan/tilt, weather resistant | Large area coverage |
Wyze Battery Cam Pro | Wire-free, rechargeable battery | Flexible outdoor placement |
Wyze Bulb Cam | 2-in-1 camera and smart LED light | Outdoor lighting & security |
Wyze Video Doorbell v2 | 2K video, two-way audio | Front door security |
Wyze Cam OG | Fast streaming, built-in spotlight | Indoor/outdoor versatile use |
Secure your home with Wyze’s innovative alarm systems and enjoy peace of mind with every glance.
What are the key features of Wyze home alarm systems?
Wyze home alarm systems offer high-resolution video, smart home integration, weather-resistant designs, and a variety of wired and wireless options. They include features like color night vision, two-way audio, motion detection, and easy installation for both indoor and outdoor security.Which Wyze camera is best for indoor and outdoor use?
The Wyze Cam v4 and Wyze Cam OG are both suitable for indoor and outdoor use. The Wyze Cam v4 offers 2.5K QHD resolution and enhanced color night vision, while the Wyze Cam OG provides fast streaming, a wide 120° field of view, and a built-in spotlight for night security.Does Wyze offer a wire-free security camera?
Yes, the Wyze Battery Cam Pro is a completely wire-free security camera with a rechargeable 6200mAh battery pack. It features 2.5K HDR video, radar and PIR motion detection, and is weatherproof for reliable outdoor use.Can I monitor large areas with Wyze cameras?
Yes, the Wyze Cam Pan v3 is designed for full coverage with 360° pan and 180° tilt capabilities. It is ideal for monitoring large rooms or outdoor spaces and is weather-resistant with an IP65 rating.What is the Wyze Bulb Cam and how does it work?
The Wyze Bulb Cam is a dual-function device that combines a 2K HD security camera with a smart LED light bulb. It fits most standard light fixtures, offers color night vision, and provides both illumination and surveillance without extra wiring.Does Wyze offer a video doorbell with two-way audio?
Yes, the Wyze Video Doorbell v2 features 2K video resolution and two-way audio, allowing you to see and speak to visitors remotely. It also includes motion-activated voice deterrence and local microSD storage for video clips.Are Wyze security cameras weatherproof?
Many Wyze cameras, including the Wyze Cam Pan v3, Wyze Battery Cam Pro, Wyze Bulb Cam, and Wyze Cam OG, have an IP65 weatherproof rating, making them suitable for outdoor use in various weather conditions.Do Wyze cameras require a subscription for video storage?
No, Wyze cameras support local video storage via microSD cards, allowing you to record and access footage without monthly subscription fees.Are Wyze cameras compatible with smart home systems?
Yes, Wyze cameras such as the Wyze Cam v4 are compatible with Alexa and Google Assistant, enabling seamless integration with your smart home ecosystem.What color and pack options are available for Wyze cameras?
Wyze cameras are available in various colors including Black, White, Clear, and Grey, depending on the model. Most cameras can be purchased in single, double, or triple packs to suit your security needs.
